View Full Version : C/K
- engine swap
- 2000 Chevy 3500 misfire
- 96 K1500 Engine Replaced(Carb), no tranny downshift
- 93 chevy, 5.7L acts like its running out of gas
- Best Towing Improvements/Mods
- 96 1500 Acts like Brakes are on
- Oil in coolant
- Engine Restore
- 93 c1500 tranny trouble
- Re: Engine dies
- Rough idle and hesitation 92 chevy 1500
- Brakes?('91 C1500)
- Big Clunk when taking off?(91 C1500)
- Looking for a extra capacity transmission Pan
- Chevy 6.5 turbo diesel Truck wont start
- 97 Z71 starting/starter problem
- Trailer Wiring + Brake Controller
- 88 Motor mounts
- 96 k1500 running rough/engine codes..need help
- 97 C1500 Stalls/Rumbles
- 97 Chevy intermittent stalling and cutting out
- moving drivetrain foward about 3" in 78 c-10 pickup
- dually conversion?
- Questions for those with lifted trucks...
- Automatic to Manual Trans Conversion
- How to Disconnect Trans Cooler Lines
- Turn Signal Switch Help Needed
- help with installing headers
- 92' K1500 stalls at idle
- Clean under the valve covers?
- K25 suburban manual to Automatic swap questions
- Matching up O-Rings
- 89 700r4 2wd to 4wd conversion
- 88 silvarado oil pressure sending unit
- rear running lights bad
- 88 Chevy Truck
- Transmission question
- The dreaded question A/T
- Are 350's intergangeable?
- Question For the shade-tree Mechanics...
- 88 k1500 305 code 43?
- tranny fluid
- Numbers on Rear view mirror
- HELP! 1997 350 vortec p305 misfire
- ac clutch
- What's the difference between...
- Right way to clean a Throttle Body?
- 454 Headache
- Engine Paint Questions...
- 1990 5.7L 1500 - codes 32 43 44
- 1990 5.7L Silverado - Engine Image wanted
- Droplets of "water" in left exhaust pipe???
- Stalling w/ no forewarning - 2500HD
- Ignition Timing
- Average Operating Temperature...
- Quick Knock right at engine start up..
- Fuel Pump Issue?
- 88 c1500 stalling on me
- Cams for my friend
- Suggestions Wanted for Engine Compartment Clean Up...
- 93' 5.7 seirra stalls when accelerating
- tranny filter for turbo 400 tranny
- Trans Filter Seal - Nightmare, Help? 4L60/700R4
- 89 4X4 1500 Transmission Leaks
- exhaust changes
- 1996 Dist Cap and rotor problem
- 1993 c1500 -- Low beams OK, Hi beams nothing
- 1993 c1500, 4L60E Transmission -- No 2nd gear
- Check out what the dealership told me...
- I need a wire harness
- Computer on 1995 K1500
- 98 c 10 4.3
- Rear Hitch
- 1990 c3500 tranny pan?
- Scanner / Decoder Question
- 1994 Silverado P/U - Brake Job
- Only 1 Push Rod is Squirting Oil
- 1990 305 High Idle Now Wont Start
- 1989 k5 blazer
- Question about OBD1 on 95 K1500
- vortec changeover
- Question about my guages on my K1500
- Headlight problem
- Wont Start After Running
- read end troubles
- Door Hinges
- ne1 convert manual 2 power windows 2 look OEM stock
- no fuel
- 98 5.7 gmc stumbles code P0404
- 95 Chevy 1500 (Replacing Balljoints)
- 1995 C1500 Died
- dash light problem
- 1997 5.7L 350 tune-up??
- gonna be buying a new truck...
- grinding transmission? or what?
- 1995 k1500 transmission swap
- 92' K1500 Stalling
- How to set ignition timing for a 1990 silverado chevy c1500 305 engine?
- Another axle question
- Stiff steering after repair? Normal?
- How much can I tow?
- Fuel Pressure Problems
- Code Scanner
- After-market tach install c/1500
- 1998 chevy 1500 trouble codes?
- Front Seat Rails
- Wheel size for 96k1500
- snappin CV joints
- Now here is a head scratcher
- Front wheel sensors
- brake pedal problems
- rebuilt trans
- Changing out 5.0 vortec for 5.7 vortec?
- How do I change the hi/lo beam switch?
- 1990 454ss
- fuel pump wont pump
- what tranny do I have
- Oxygen Sensor going bad?
- installing aftermarket tach 1984 V8
- cold start, bucking and missing, '89 305cu.
- heater box/heater core?
- 93 chevy bed
- 97 vortec 5.7 question???
- Just wondering: Transfer case interchange?
- 1989 c1500 airaid intake
- trans problem
- Weird hickup on 97 1500
- 4L60E Problem, Different than any I have seen
- 68 c10 transmission question
- Defrost/Vent Damper
- looking for 40/20/40 seats for 95-98 pickup
- Diesel VS. Gasoline
- `94 6.5 turbo diesel - glow plugs cycle off too fast.
- Power steering pump cavitation
- I need alittle help 1998 c3500 idler
- no turn,hazard,or brake lights
- Crate motor - Where to buy in Canada?
- Hazards not working!!! WHY?!?!?!
- 98 Silverado - no brake lights, no 3rd light
- Spark Issue..
- No Heat
- HELP with keyless remote please
- GGRRRR..fix one thing something else breaks ( 4x4 transfer case related)
- 98 chevy 5.7 code P0306
- Lowering question
- 88 1/2, 5.7L Engine stalls?
- wiring 4l80e
- 5.7 surge
- 88 Gmc K1500 / 5.0
- 97 Z71 - Driver's door won't open from inside
- 97 sub blows fuse ecm b with fpump relay removed
- Coolant Leak, Top of Engine
- I think I blew a rod or something
- '91 6.2 diesel head bolt torque
- 89 K1500 starting problem
- Bigger tires on a 1998 Z71 ext cab?
- 1989 c1500 remote start
- 95 1500 4.3v6 very rough idle/stallin when warm
- Security Systems
- 4l60E slips when cold..why?
- Door Stuck
- Fuel Pump problems...
- 4x4 problems
- 94 c1500 transmission surge at a stop light.
- Brake Problem on 95 K1500
- HELP!!!!!!! 97c/k 1500 wont start....
- Factory Service Manuals
- Ignition control module location please help
- 350 engine upgrades - Intake manifold
- Brake Thump
- '84 5.7 exhaust
- Which Throttle Body Spacer is right?
- Auto pilot
- 4.3 backfire
- 97' 1500 5.7l will not start and brake light on
- New cam and alum heads
- 95 1/2 ton, 305ci, high idle
- rear vents only blow cold
- It sounds like someone rear-ends me and shakes the truck.
- 1990 k1500 rear end locked up?
- 97 k1500 no start, failed PCM?
- Parts 1996 K1500
- 1998 k1500 axles
- 1993 K1500 Transfer Case Grinding
- what kind of heads to put on a 454?
- Muffler questions
- Thermal actuator
- 1500 Truck ignition key cylinder Remove and Replace
- Oil pressure gauge acting up 1988 C1500, 5.7L
- Low Coolant and Heat
- How many miles on 5.7L/4L60?
- 88 Chevy PU won't go into Reverse
- strange problem?
- 86 K10 power steering
- tranny leak
- dually conversion
- hydraulics
- Heater Relay clicking!!!
- 88 Sliverado electrical flicker
- 1991 Silverado Radio
- Faulty Cruise Control on '96 Chevy Z71
- Replacing Locks on Chevy Truck
- 91 pk with no power to the fuel pump
- 91 v6 not power to primary side of fule pump relay
- Manual 4-Wheel Drive
- body change
- 95 1/2 ton 4WD, irregular high idle
- 97 C1500 Fan Blower Switch Replacement
- 700R4 no reverse
- '96 Chevy Z71... won't always start after installing 2 Fuel Pumps
- brake lights on a 98 ck
- Bellhousings for GM small blocks
- Better mpg for 91 dually
- 1993 chevy won't idle
- Service engins soon blinking fast
- 98 k1500 5.7 stumble on light acceleration
- Help!! 1997 Silverado won't start.
- help
- Chevy fuel selector
- 95 truck idles fine but stumbles badly while driving
- piz help me 454
- Starts cold, won't start after been running
- 98 K1500 4X4 or 4X3
- Pushy Pushy
- Turn Signal Blowing Fuse
- Starts then stalls???
- crank. position sensor question.
- transfer case repair?
- 5.7 Stumbles when Oil fill cap removed
- 98 1500 no first or OD trans
- shimming a starter
- Door Adjustment
- blowing fuse
- 454 4x4 !!!!!
- 97 1500 I think engine is locked up what do you think
- Can't figure out - 1996 K1500
- need a tranny
- Temperature question K1500
- 97 1500 tranny problem 4L60E
- ?'s about 14 bolt semi floater posi
- rough idle
- My 1989 K2500 Stalls when stopped
- 96 k1500 misfire
- Spring Coil Compression
- 1995 3500hd 6.5TD rough idle & black smoke
- 1995 Chevy Z71 won't start after changing my fuel pump
- First Post...Awesome Forum!
