View Full Version : C/K
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. whining and clicking...ring and pinion?
  2. 94 k1500 stumbles when warm
  3. vapor recovery schematic
  4. rear end question
  5. 93 Blazer Acceleration issue
  6. Replacing engine oil cooler lines ...
  7. Airbag light and Check Gauges light help please.
  8. Motor Flush - good or bad
  9. 1997 Front Axle Actuator
  10. 1988 Silveradio 4x4 problem, and oil in exhaust
  11. Spark plug wires
  12. Loss of Electrical Pwr
  13. Headlight removal problem
  14. 4x4 w/ Longtubes?
  15. How manny miles?
  16. Rims??
  17. Intermittent Problem
  18. questions about 94silverado
  19. 5.7L intake
  20. idle surge
  21. Transsmission wont shift when hot
  22. 98 Chevy Silverado 2500 overheating problems
  23. Swapped 454 in 92 K3500 with rebuilt shortblock
  24. blower motor install
  25. Exhaust Leak?
  26. pulsating brakes update
  27. Will a 70's BB starter fit a 92 K2500?
  28. erratic idle then kills
  29. 96' V6 K1500 Sputter When Accel And Crusing
  30. 1979 C10 Spark Problem
  31. 1993 350 chevy pu problem
  32. 93 z71 engine miss plz help
  33. 89 dummy lights!!!
  34. belt
  35. Dash lights and graphic equalizer display just went out
  36. New calipers - what's good
  37. ignition wires
  38. 95 C1500 ABS Bearings?
  39. 95 C1500 ABS Light on
  40. Help! electrical problem, fuel guage
  41. front brakes pulsate and abs activates
  42. Need heat
  43. heater problem
  44. 1988 K1500 4.3 V-6 engine knock
  45. LT1 swap
  46. Need Help!!!
  47. Towing Comparison between '96 and '07 Silverado
  48. Future Plans
  49. Can a GM truck sound good?
  50. 4x4 Push Button Problem (Not like others)
  51. noises
  52. What's the wire next to the thermostat?
  53. wondering if normal or not
  54. 94 model tilt steering colum
  55. 1986 with electrical issues
  56. ABS issue
  57. 98 Chev 1500 Security Light ON??
  58. Duramax Reliability
  59. cold-air intakes
  60. 4x4 broke help
  61. 1996 C1500 For Sale
  62. 1996 C1500 For Sale
  63. OD Slip or Engine Misfire
  64. 94 4.3 V6 Swap with 92 5.7 V8
  65. 9c1 alternator on pickup?
  66. Starter runs with Ignition in off Position
  67. 95 1500 350 auto hesitates and has no power when warm
  68. ignition switch stuck on
  69. 1997 Chevy Truck 1500 Wont Start Agian!
  70. 90 chevy pu
  71. possibly misadjusted "transmission cable"?
  72. Chips/Programmers/Modules
  73. A/C Low Pressure Switch Question
  74. Code 43 on 1994 1500 Chevy
  75. Oil Pressure sending unit on Chevy 7.4L 454
  76. 95 K1500 Ruff Running & Intake Backfire
  77. front end noise
  78. 80 K10 Manual 4 Speed?
  79. gas pedal sticky/hard to push
  80. Tranny Hesitation
  81. Rear lights 1976 K30 Wiring color code
  82. No Start Code 1351 & 1300 97 K3500 454
  83. O2 sensor P0161 hot wiring
  84. Solid Black Wheels?
  85. 96 stepside bed removal
  86. 92 Silverado 2500 headlight issue
  87. Transmission Sending Unit Install
  88. Camshaft or Crankshaft Sensor?
  89. 1998 Silverado-start/battery not usual problem
  90. VATS wehicle security fix
  91. 97 Silverado 5.7 Vortec engine upgrades?
  92. 88 ck 2500 pinging
  93. 1991 C/K 1500 Fuel Pump problem
  94. 94 Silverado headlight problem
  95. AC whine?
  96. trans wont shift in overdrive
  97. Happy New Year
  98. 93 2500 help
  99. looking for dionostics flow chart, 89 gm
  100. 96 k1500 turn key wont start.jumper wire to starter relay starts??
  101. 97 Z-71 troubleshoot misfire
  102. 01 chev4x4
  103. 01 chev4x4
  104. t-case
  105. Hard Starting
  106. distributor hot/no spark
  107. MSD 6AL = 6420 INSTALLED in a C1500 350
  108. Coolant leak on top of valve cover??
  109. three on the tree problem
  110. Help..NEW MOTOR in a 1993 with timming problem
  111. Cleaning under the hood?
  112. EGR valve OEM number
  113. 97 k1500 A/T Problem
  114. Driveline feels like it is binding
  115. Tire Size help??
  116. Trans Noises
  117. throttle body tune up kit
  118. C 1500 - 5.7L 350 gas mileage!
  119. SM465 Issues
  120. No Tail Lights, No Instrument Panel Lights
  121. 1995 Silverado how to remove steering wheel w airbag?
  122. 1997 Z71 wont shift from park
  123. Strange headlight problem...
  124. O2 threads bad
  125. 93 1/2 ton with Intermit. fuel pump
  126. rear diff leak
  127. Fuel Problems
  128. 1997 truck sounds like running high rpm with low power
  129. 95 K1500 Tach/ Transmission Quit
  130. Noise from the distributor cap
  131. new front end?
  132. Air management/header question
  133. 1994 short bed single cab seat
  134. A simple jack question
  135. Transmission Bogs down...
  136. t400 tranny problems
  137. 90 Chevy K3500 454 bucking/service engine soon light
  138. 1993 1500 4x4
  139. Is the wiring harness the same for all the 73 -87 pickups
  140. 2500 not locking into 4wd
  141. first time engine build
  142. TBI to carburetor...how hard is it?
  143. dry fuel bowl, need opinion
  144. Surging/Hesitation
  145. Afterrmarket In Dash CD Player
  146. when checking timing
  147. 93 silverado dash lights not working
  148. front rotors
  149. Engine Swap To efi in 83 k20
  150. My exhaust idea
  151. A couple questions about 1997-1998 Silverado
  152. 96 1500 won't start
  153. homelink wiring question
  154. 1990 c 1500 5.0 FI
  155. Fan Clutch??
  156. Rochester B 1bbl
  157. '92 Silverado "Blinking AC Indicator"
  158. heater console bulb
  159. engine rebuild
  160. 85 GMC choke
  161. governor
  162. Whining noise
  163. What Scanner Reads Camshaft Retard?
  164. A/C Cycles on (Even with A/C switch off)
  165. 97 Silverado headlight and wiper problem
  166. Weird Idle problem...
  167. I need a bench grey benchseat for a 1991
  168. 89 full size blazer problems
  169. power window HOW To
  170. 98 z71 fan switch problem
  171. Brake pedal
  172. 1990 C3500 crew cab vibrations
  173. remote starter
  174. 91 c 1500 no start, no spark
  175. No Electrical Power
  176. poor gas mileage
  177. Hard to push gas pedal
  178. 92 350 EGR question
  179. hard brake pedal
  180. blower motor
  181. can't get it out of park
  182. which is bank 1 on 1997 5.7l
  183. 93 4l60e tranny problems
  184. '90 C/1500 wont start
  185. Another 98 Waterpump
  186. Rear Drum Upgrade
  187. ___Increase M.P.G___
  188. temp sensor/idle problem
  189. Crate Motor
  190. Cat gone bad?
  191. Transmission woes
  192. Gas Leak Problem..?
  193. Engine oil stop leak?
  194. 1989 k2500 power steering bracket bolt size
  195. '93 5.7L Knock sensor
  196. 1994 Rwal
  197. brake shudder/vibration
  198. Code 32 EGR Problem
  199. Brake question - tis the season.
  200. Wndshield Washer Pump 1996 Chev 1500
  201. Service Engine Soon
  202. Edelbrock Performer system for 94 K1500
  203. 305 or 350
  204. '93 C1500 Cruise Control Gone Bad
  205. 1998 Silverado-needs reprogramming help
  206. hydroboost
  207. 4x4 not engaging
  208. Problem with fan on 98 z71
  209. 96 chev 3/4 4wd p/u slave cyl.,change?
  210. '94 2500 failed smog test - Help !
  211. 5 bolt GMC chrome centers off '93
  212. 5.7 out of '91 GMC
  213. 1998 K1500 fan stuck on high
  214. Throttle body replace or repair
  215. Reverse lights work... sometimes
  216. Temp guage
  217. help finding a bench seat
  218. 7/16 inch diesel fuel line.
  219. 79 C10 no defrost
  220. Idling Arm/pitman Arm Replacement 94 Silverado
  221. 1994 c1500 abs?
  222. 96 Silverado Help Please
  223. I Need Help With My 1985 C10
  224. Brake Problems on my 98 Z71
  225. 94 Silverado Rotor Warped, Need To Take Off
  226. '88 Cheyenne 2500 ignition?/solinoid? trouble
  227. Need help with brighter headlights on a K1500LS 2006 Pick up
  228. 1996 k2500 454 hard to start
  229. Headliner 94 1500
  230. 89 K2500 stall
  231. Brakes on a '98 GMC Z71
  232. 1995 3/4 Ton 454 No Spark
  233. 4x4 slow engagement
  234. 1988 Chevy c3500 5.7L Cold Start
  235. 94 4.3 won't start
  236. Transmision fluid leak...
  237. new starter want stop
  238. exhaust
  239. Lock switch quit working...
  240. guesstimated horsepower/torque?
  241. 1997 Silverado Very Hard to Start
  242. 70 c10 2wd lift questions...
  243. 6.5L Diesel shooting out black smoke
  244. 97 GMC Z71 Fuel Pressure/Misfire Problem
  245. 1987 Scotsdale fuel problem
  246. 85 chevy scotsdale stepside
  247. Ignition switch replacement
  248. truck for sale
  249. EVO sensor problem?
  250. 1998 3500 Chevrolet Crew Cab Rear Side Window Tint Question. Please help!
