View Full Version : C/K
- More power from my vortec v6?
- 1996 C1500 transmission interchange
- NP203 problems
- 1989 k1500 Chevy 4x4 shifting
- 97 occasionly wont decel
- 2wd to 4wd??
- No idle
- 94 Silverado low headlights no working
- Overhead Console for '99 C 1500
- Oil Pressure - How high is too high?
- 97' Z71 Brake issue (HELP)
- Fuel Issues
- 1989 Chevy K2500 4x4 Problem
- Cv halfshaft to short
- 95 k1500 stalling out
- Intake Manifold question
- Pulley Issue
- lift kit and tire question
- 1997 K2500 7.4L 4L80E No TCC
- 1998 k2500 in a snow bank
- 98 Silverado 5.7 Fuel Pump?
- 1991 Chevy C1500 4.3L Dies No Fuel
- fun truck 88 1500
- 88 gmc won't start
- 95 Chevy Truck 1/2 Ton, 350/5.7L
- Multi issue questions
- 91 K1500 5.7 Cold Start TReMoRs!
- 1990 Silverado starting problem ***HELP***
- 1991 K1500 Dash Brake Light Flashing Code
- Questions for the professionals
- Wheel and Exhaust Suggestions 1994 C1500
- Transmission
- 95' K1500 Cylinder Drop
- 1996 K2500 5.7 random misfire
- 95 Suburban 4L60E Trans Fail-Safe mode
- '97 1/2 ton Chevy 4X4 Brakes!
- 97 chey rear end
- idle problem
- Strange noise
- VSS Vehicle Speed Sensor
- 7.4 Vortec misfire issue
- 90 k1500 intermittent fuel problems (thats new!)
- Tow / Haul does not work
- ball joints
- quick question about mirror..
- 1997 silverado won't start. Help!!!
- 94 Chevy Duelly Headlight fuse location?
- 1998 Chevy 5.7 hard start.
- Overdrive issue
- Lack of power!!
- 1990 5.7L Silverado Engine starting problem
- Help! Low beams and Raido stopped working
- 96 4x4 steering question
- Chevy/GM Truck Fuel Sending Units
- Vibriation
- Value of a 99 K1500 EXT CAB Z71 with 53K
- Lights/Dash dimming
- replacing fuel pump in 95 k1500
- problem with k1500
- 1993 K-1500 Vibration
- Need Help!!
- 700r4 putting 2WD trans in 4X4?
- Fuel PSI
- no oil to top of head
- Ramps
- What this time? 97 Silverado 5.7 auto won't start.
- Coolant Drain Plugs K2500HD
- 1995 C2500 specs.
- 98 C1500 clutch/fan removal
- ECM troubles
- HI/LO Blower Relay
- 1995 K1500 5.7 Engine Swap
- 97 GMC k1500 4x4 Problems!!! Help!
- 89 TBI problem
- 87 TBI question
- 1986 gmc diesel
- A/C issues ??
- 90 K1500 timing issue
- wet weather no start till dry again.
- Trouble Shooting Heater
- Rotor Removal
- Coolant Leak
- '95 3500 HD speedometer
- Replacement tire suggestions
- 98 1500 5.7L Random Misfires
- Pitman Arm
- 95 2500 HD 3/4 4x4 pitman arm removal
- install 5.3 engine in a 1968 c10
- im pretty lost at this point
- charging system?
- Adding Turbo System to TBI???'s
- no roll
- 2000 k 3500 runs bad when warm
- Wiring trailer brakes
- 97 checvy 1500 truck
- erratic idle, lean code, hard start on 95 K1500 w/5.7
- 1996 Silverado Won't Start
- 1980 k10 dies well driving. (electrical)
- body transfer
- How to make a SB 350 in a 1989 c1500 sound like a ferrari
- A/C Compressor
- hydraulic clutch 95 k1500
- Dimming lights
- New Full Size 2 Door SUV 4x4
- need help 98 chevy 1500 Z71 5.7...runs badly
- Door lock remotes standard on all trucks?
- Shifting blues...
- 97 k1500 steering sensor discontinued?
- Causes of "Too Lean" Code
- Pulling to the right under braking....
- temp gauge
- '84 5.7 doughnut gasket or not.
- timing off
- Radio Problems
- 4l60e tranny
- Will a bad Oil Press sending unit cause truck to stop?
- 1998 3500 Chevrolet Crew Cab Front End Shimmy?
- Ran fine yesterday won't start today
- Rusted-on rear drum removal
- ECM Custom Tune
- codes 15 and 32
- Dash cracks
- alignment
- tranny problem
- from 2X4 to 4X4
- loss of fuel pressure?
- a/c compressor not switching on
- Engine swapping issues...
- Tire Question?
- Air shocks for k1500
- $400.00 Fuel Pumps
- 1994 c1500 stalls in idle
- 89 C2500 manual transmission problems.
- 1995 c/k pickup: Engine studders and has coolant in oil. Blown head gasket?
- 1995 chevy pickup studders when started and has rusty-like oil
- 1988/1993 silverado c1500 electrical gremlins
- 94 Chevy Air Conditioner Problems
- hard cold start
- U-Joint Leaking?
- Outside Driver door handle removal
- TPI to Carb
- Exhaust
- 89 c1500 5.7 starts then stalls...
- What is going on with my tranny?
- I need to see what a fuel filter is supposed to look like!
- 79 K20 rattling noise at full throttle, idling too high
- vibrating 95 Z71
- fuel pump pressure
- 1998 Gm K1500 Leather Seat Upgrade
- 73 Custom Deluxe "Ratcheting Noise"
- 1996 K1500 - fuel pump LOUD
- 1996 weird sound - possibly exhaust?
- 97 chevy 1500. how big of tires will fit?
- 97 chevy 1500 - bad brake booster??
- Tranny Leak, Speed Sensor
- rebuild trans
- 1988 Chevy Truck
- release parking brake shuts truck off
- ODB2 question
- 1996 to 1998 305 vortec sensor ?
- ram jet swap?
- Brake line replacement?
- Early-mid 90's serpentine alternator bracket?
- 88 chev pu 1500
- cant shift out of park
- Removing Bed
- 94 k3500 no brake lights!!
- 92 Driver Window Problem
- Ignition trouble?
- 1999 454 E85 Upgrade?
- water 4 gas on a 1998 K1500
- trailer hitch
- Tensioner idler pulley
- Vacuum Leak Possible?
- Lights on tailgate?
- RFI Filter Fuel Pump
- Blower motor dying?
- ABS Light
- HVAC Blower will only blow on floor ?
- Need Grille for 88 Chev PU
- 98 3500 HD tow truck rear end help
- 92 C1500 Won't Idle....help
- no spark
- 1988 Chevy C1500 break lights stuck on w/switch removed.
- Surging when going into drive
- k10 vin location
- engine stall
- 98 Z71 Check Engine/02 Sensor?
- Heater / AC control getting reset ?
- 1997 chevy transmission problem Help
- intake system
- Gas Mileage 5.7L automatic K1500, 4WD
- 1995 c1500 truck lowbeams won't work
- Rear axle weight rating?
- tps
- Anyone know anything about retech fuel pumps?
- Brake / Steering Shudder
- 1990 Chev 3500 350 tbi idle/off idle missing
- AC causes low idle / stall
- Whats the best way to change fuel pump on my 98 crew cab 3500 Dually?
- tranny fluid leaking through thecenter of the tranny yoke!
- Park Brake Adjustment
- 1998 C3500 7.4L trouble starting...Fuel Pump??
- 98 Z71 Won't start unless gas poured in TBI
- clutch adjustment 95 k1500
- '94 chevy truck intermittent problem... !
- How to replace Ingnition Switch 1990 C2500
- Transmission Conversion
- Strange problem - lack of power 30 seconds after startup
- rotor size question
- Tranny Shifting Problems?
- 1990 Chev truck K2500 4x4
- 1988 Chev 350 5 speed
- trans. qestion
- 1996 c1500 brake lights .......please help!!!!!!!!
- 89 K1500 Stalls in reverse
- Shift indicator cable Replacement in 90 Cheyenne
- 94 c1500 700R4 compatability
- P0420 Code
- Sensor, Ground, or Tansmission?
- Fuel pressure drop after 15 minutes
- Code 32
- Heater A/C Control Unit
- Im leaking!
- 98 Z71 No acceleration when pedal to floor
- Harmonic noise @ 45
- 98 silverado trans prob
- Lower Intake Manifold Gasket
- 96 K1500 fixed hesitation/loss of power
- 95 2500 4x4, What Brake system do I have?
- 1998 motor in 1980 chassis
- temp gauge gone wild
- K Vin Compares to R Vin
- EFI Fuel Pump Question
- 1990 chevy 1500 overheating problems
- ABS Light ON- How do I diagnose it?
- 4x4 grates
- 95 Chevy Truck (Minor Wobble)
- 89 chevy 1500 Fuel Problem
- 1993 Chevy 5.0 no spark
- 90 K1500 starving for gas, pops code 43 off and on
- lowering
- 95 Chevy 1500 (Fan Connector)
- engine swap
- 2000 Chevy 3500 misfire
