View Full Version : C/K
- 82 C30 350 vacuum line diagram
- 96 chevy k1500 tranny problem
- black rear bumper
- speed sensitive steering
- 97 k2500 manual tranny
- 1997 k2500 engine replace
- Stalling followed by not starting
- torque specs
- Check Engine Light Codes
- HELP! Knocking engine....!
- Turn signal help
- Strange Problem Help Please
- radiator o'ring
- K2500 5.7L no codes misfire
- slows when driving uphill
- 98 k1500 knock
- Pivot Ball
- Rear axle/bearing clearance
- 97 4WD actuator upgrade
- How Much Glue?
- 1995 Z71 Skip
- 96 chevy wont start
- blower problem
- 1996 Chevy K1500 Key fob programming
- 1990 K1500 Electrical diagnosis
- 94/96 door interchange
- Driving me crazy
- PLEASE HELP!!! 1991 4.3tbi wont start
- Charging system
- can't balance mickey thompson 33" tires
- 94 K1500 Oil pan replacement
- 96 Fuel problem
- 1995 Chevy 1500 1/2 Ton Truck (350, 5.7L)
- problem with crank
- Went muddin in the 95 Cheyenne
- 78 chevy 350 build
- '95 5.7 auto - non working tach & speedo
- wont start
- Code P1870 again, new valve body already
- 1986-old low compression 305
- 1997 vortec 5.7L tranny oil change
- Exhaust on 1997 1500 5.7L V8
- no head, tail, insturment or inter. lights
- 96 Chevy cuts out under acceleration
- 350 vortec timing issues?
- Idle Surging. 1990 chevy 2500
- 93 1500, 4.3L just starting to run rough
- 97 1500 60/40 bench head rests. how do i removed them?
- 1998 chevy truck no sound
- Getting a few more horses out of my 4.3
- 1994 k1500 solid axle conversion
- 1989 Silverado 5.7 Auto, Code 43 Rough Idle
- a/c compressor rebuild
- 327 sbc swap
- O2 sensor locations
- Distributor, P1345 Cam retard offset
- Truck problem
- 94 Chevy 4L60E Transmission Problems
- IP Problems! Help!
- Bypass Knock sensor 89 chevy 350
- New Radiator
- can some one tell me
- Performance Chip installed, Service Engine light wont stop flashing
- rear end swap
- 98 2wd 4.3 dual exhaust
- hm rough cituations
- intake maifold or head gasket?
- Radio wont pick up distant stations
- front brake pads for a 93 dualie
- low coolant light and sensor
- 92 Chevrolet K 1500 battery issues
- Dually rotors
- o2 sensor simulators
- 85 C20 fuel tank replacement
- Question about timing chain and gears
- 92 pickup starting problems
- Electrical diagnosis please
- posi-track for 1991 C1500?
- 1985 k10 headunit wiring
- 93 4.3 with rattle in engine
- Removing armrest on a 97
- 1989 c/k 1500
- 99 suburban 454 p0123 code
- 1982 c-1500 diesel V8 pick-up won't start.
- repair bill question
- 92 starts then stalls when warm only
- '94 6.5 diesel fuel in oil
- very sick 95 5.7
- 98 k1500 5.7 manual gear shift knob
- Free Service Manuals??
- 68 and 88 tranny compatable
- Tranny ?
- 94 TD 4L80E stuck in 2nd
- How to replace 2wd front wheel bearing races
- ck recalls
- 4wd Question
- 96 1500 4.3 misfire
- Car is making a Grinding/whistling noise while driving
- 89 chevy truck power window and lock problems, (HELP)
- A/C issue on a '92 Silverado
- 1988 k1500 4wd acuator question
- Check Engine Light, How to CLEAR
- K1500 Wiring issues
- Hotter Plugs? Foulin' out - 91 K1500 plug help...
- 93 c/k cant get stoplight switch right
- frame width
- 95 Silverado 350 TBI running rich??
- more power
- Power Brake Booster Check Valve?
- 95 1500 4wd brake light switch?
- 94 c1500 silverado chevy truck, won't start
- 92 diesel information request
- looking for a good rebuilt engine dealer
- slow coolant loss
- 1990 K1500 Throttle Issues
- 98 K1500 Vortec 350 occasionally overheating
- 1997 C1500, 4.3L random misfire, at constant speed
- 1997 Z71 problem
- Now here is a tough one..... I am just stumped
- 1988 K1500 Wiper problem
- 93 1500 no cruise control
- Another TBI problem
- Having a very hard time replacing the EVO sensor - need suggestions!
- oil filter adaptor
- Help with 4.3 vortec
- 91 Chevy 5.7 Burnt Plug Wires? H E L P ! ! !
- 1991 Chevy 454 backfires, runs good, backfires, sometimes cycles
- 98 C1500 Possible EVO issue?
- 98 Z71 - Keyless remotes quit working
- TBI to carb
- A little help please!!! 93 k1500 4.3l
- Windshield Washer Problem
- 91 C1500 Starts & dies intermittedly
- 1991 chevy pu, 305
- 1993 k1500 4.3L spits & spudders during drive
- HELP!! 1997 chevy making weird NOISE!!
- 84 C20 - Intermittent Rough Run/Black Smoke
- Massive Coolant Loss
- bolts not surrendering
- 90 Chevy 5.7 Idles Issues
- converting a manual to an automatic
- 98 1500 5.7lv8 no power whatsoever
- No spark
- 91 K1500 5.7L 350 Auto HEI - Spark Issue
- coolant leak
- 94 chevy tbi issues/loading up
- Mysterious Transfer Case
- Rear U-Joint Cap(s) Removal
- 1996 4x4 blinking light issue
- 1987 chevy pickup electrical problems
- Loss of power and excessive fuel consumption
- Carbureted to Fuel injection
- 1989 1500 brake light flashing
- Got a scanner, now I'm dangerous
- 1998 1500 problems
- 1992 chevy 1500 need oil dipstick and tube
- 1992 1500 4.3 with manual transmission speedometer acting funny
- No tail lights on 98 Silverado
- Undercoating the bottom half OF my 91 silverado
- 4l60E first gear drag
- Choosing tranny...HELP!
- 92 3500 454 No spark
- Distributor Trouble
- Radiator cap lbs
- 93 C1500 Transmission Wiring
- 1998 1500 dash and tail lights not working
- body lift and tire question
- 1988 Chevy Pickup (FS)
- Fuel overflow into evap canister
- help please
- Bed Rails or Bed Side Caps???
- 2500 4x4 Tranny Problem
- 1998 K2500 5.7 Hesitation/Misfires
- 95 chevy 1500 4x4 ABS light codes 23,12,22,21
- Stock Radio Removal
- Reverse Tire Direction? (Rotating Tires)
- Coolant reservoir has engine oil in it - dipstick has no antifreeze in the oil. Why?
- Heated mirrors are out.
- Painting Dashboard
- help with 2 problems please
- Engine swap questions
- 1989/c/k 1500 blower fan
- 1989/c 1500 pick up gages
- no power to injectors... please help!! after 4.3l - 350 swap
- 1998 c1500 starts then stops instantly
- 05 c/k fuel pressure regulator
- 94 K1500 - Only get 3rd gear
- '94 5.0, no rpm, mph, or shifting??
- 74 400 missing
- headers are headers right?
- 7.4L long crank time when sit for a few minutes
- Stripped Alternator Bolt head on 89 K1500
- Cv Joint Boots
- pinnouts for instrument cluster?
- cpu out?
- 5.7 roller rockers 93 gmc new motor
- 1999 Chevy 3500 Dually Rear End / Final drive
- Neutral saftey switch?
- 700R4 Build question
- 1983 Pickup, Shift Linkage (Bushing)
- 1998 5.7 timing question
- 95 Suburban Seats
- 95 c/k seats
- leak on front differential k3500
- 1991 7.4 no spark no fuel
- No Codes
- No cruise Control?
- tdc after eplacing head gaskets 4.3
- 2500 express Van fuel problems, 305 vortec
- 95 chevy van won't shift
- 97 vortek 7.4 ignition timing question
- 1990 k1500 electrical nightmare!
- 91 C1500 wont start unless gas petal is on the floor
- Red brake light on, front locks up ?
- 2WD to 4WD Problem
- 95 5.0 to 5.7 Motor upgrade
- 88 7.4L TBI loss of power issue
- 94 c1500 silverado won't start consistently
- 96 K1500 4wd Vibration in Front Wheels
- Motor is in now but a Question
- O2 Sensor Brand Opinions
- 88 scottsdale auto front locking hubs?
- 95 4x4 5.7 K1500 ABS light on
- Warning - Heater hose quick-connect fitting
- 94 C1500 silverado won't start, but turns over
- 1991 K1500 StiLL CoLD STarTinG - H E L P ! ! !
- 5.7 timing question
- Intermittant miss
- 96 Chev 4x4 1500/ front wheels wont lock anymore
- 98 Chev 1500 5.7 fuel evap code
- 95 chevy pickup oil pressure
- fuel pump issue
- idle air control valve troubleshooting
- Great deal for c/k Silverado owners
- No start,no anything electrical problem
- how do I make a dual exhaust quieter?
- 97 k1500 oil pan removal
- performance upgrade advice
- 93 chevy 1500 V6
- 94 K1500 hard to start runs rough to warm
- 98 7.4L Crew Cab Dually losing coolant into overflow tank?
- Major oil leak
- Tall deck or not
- Error Code 43 on 88 1-ton dually
- rearend issues
- solved the problem 95 k1500
- 92 Cheyenne 1/2 ton with coolant leak
- 1998 chevy 3500 HD Heater problem
- Studder in tranny in overdrive
- 93 4.3L misses when wet, static on radio
