View Full Version : C/K
- 1994 1500 Front End Alignment Question
- Replacing door window seals
- Valve Seal O-ring
- Location of BTSI
- 97 chevy wont start!!!
- 84 c-10 305 cranks, won't start
- 93' c1500 4.3L squeaks at low rpm
- replaced a 305 with a 350
- 1987 CHevy won't start unless primed
- Cylinder misfire and other probs
- ac and heater problem
- 350 very sluggish until engine warms up
- 1994 Chevy temp guage doesn't work
- 1990 runs 15 min then stops till cooled off
- a bit sluggish
- Which years...
- 2004 2500 noise under dash
- Interior Trim parts
- 92 454 ignition cuts out
- ac heat controls and display not working.
- 94 silverado heater core
- No start: Fuel pump runs but 50psi
- Idle miss
- 96 k1500 brake problem
- stoplight switch
- Fuel Mileage Increase?
- '95 C1500 a/c evaporator leak
- Engine Possesed
- 94 K2500,, 6.5 no running lights and trans in limp mode
- Trouble Starting
- wierd sensor setup
- 95 possible motor swap
- 1998 jeep grand cherokee laredo..300..strt line 6
- 99 1500 need help
- 88 Silverado dash lights going crazy
- I Need Heat
- Replacing brake rotors on a '00 K2500
- 83 6.2L diesel swap
- 2000 vortec 4.3 swap
- 350 new OE engine how much performance?
- blower motor 1985 silverado doesn't work all the time
- tranni no overdrive and starts in 2nd gear
- 4.3 low on power... ideas???
- T-Body!!!!! Help!!!!
- 93 2500 radio problum
- 1998 5.0 stalls out
- gas tank 72 chevy
- '93 C1500 350 TBI Specs
- problems with my 1971 chevy truck
- 98 5.7L Alternator whine and low voltage
- 93 4.3 extreme high idle rpm
- 1994 1500 Power Steering Issue
- 96 4.3 knocks
- Cranks More
- Transmission Fluid Level
- question 4u gear heads
- starter wont turn, fuel pump wont turn on, guages dont move
- 95 runs bad, no codes
- '98 Silverado Climate Control Parts?
- 96 k1500 o2 sensor codes
- 2003 blower motor quit. speed resistors?
- 1972 C10, engine/trans swap
- Ht383e
- 1994 C1500 Blower motor
- Temp sensor changed, new problem now
- Lift Gate
- 98 1 ton code p0175
- 1994 c/k Stop Light Switch Location
- Swapping 4.3's
- need dual battery setup help please
- Calling all tranny experts. 4l60e
- '98 K1500 - AC compressor stays on...
- Replacing Lower Ball Joints
- roof panel noise
- 95 Chevy PU (High Idle)
- 1994 C1500 4.3liter Injector Pulse
- 94 5.7L Idle Miss/Stall-for the experts
- tire size
- aux. tranny cooler
- Bewildered
- Leveling kit
- 1997 a/c question
- What Kind of Shocks?
- 98 work truck
- Won't run
- Power Steering went out!
- What is a 94, Heavy Duty 350 engine ?
- 1981 Chevy 1500 Doesn't Fire!!!
- 97 C/K No power to fuel pump...
- 1997 yukon light throttle hesitation
- Catalyst System Efficiency Below Threshold (Bank 1)
- AC/Heater control blackout, fuse blowing
- 92 350 Borderline Emissions
- Suggestions?
- 4x4 Not Dis-Engaging
- Ignition wires pop off
- 4L80 transmissiom
- Performance Chip- Power and Fuel Economy
- 1997 dash pad
- 1998 Silverado - white smoke from engine NOT tailpipe
- Spark Plugs
- 97 chevy truck evaporator core removeal
- Surging while braking
- 98 K1500 Front Susp. Question
- 1997 C2500 - little cooling from A/C
- 88 GMC 5.7l cuts out / diesels
- 77 c10 to a Pontiac Engine swap
- 1986 305 emission question - new thread
- 94 Chevy Silverdo stalling
- 94 Chevy Silverado stalling
- 4.3L Towing Question
- 97 5.7L wont start
- Fuel tank
- no fuel spray on start
- 87 1/2 ton 4x4 stalling
- 1992 Chevy C Pickup No Defrost
- sounds like starter dragging when warm
- ac vent controller on my 1984 Chevy Pickup
- Electrolysis Eating Heater Cores
- Thanks for the advice guys!!!!
- '98 K1500 Reverse light on in 'Park'
- Pwr window switch in '85 Chevy K10
- how do I do this?
- 92 c1500 4.3L: stalls - won't idle - no DTC codes
- Will a 2001 disc brake dif fit my 92 K2500?
- chevy SB turbo questions?
- Will all parts fit?
- to rebuild or just repair
- Oil for new engine...
- '98 K1500 overheat and power loss
- Torque Converter and flywheel problem.Help!
- system too lean fault...
- SES light won't go away
- a/c not very cold!!
- running rich
- Steering issues on 74 3+3
- 91 K1500 Interior noises?
- Both heads cracked on 97 Sierra
- m Air gap adjustment compressor clutch
- ticking/rattling sound
- 97 Z71 fuel pump intermittent
- 93 2500 propane converstion
- Tranny
- Wrong shocks on Z71 question???
- 4L60E problem?
- 98 Silverado Won't Start
- Shock ?
- Help! 97 won't start, pulling out hair
- Clutch doesnt release after a few mins
- 88 C10 350 - high pressure oil leak
- Brake light prob.
- AC compressor will not engage
- 94 4.3LV6 HVAC Blower tapping noise
- What should I expect?
- actuator
- From TBI to Carb. ?
- Temp needle pinned
- 88' K1500 loss of power at over half throttle
- 88 cheyenne...timing problems
- 96 5.7 Intermittent stalling-fuel pump?
- 1988 1500 Brake Lights/ Turn Signal Problem
- a/c compressor won't engage
- 89 C1500 A/C Question
- '93 1500 Runnin a little rough
- '93 1500 Clutch/Cruise issue
- headers or manifolds
- 98 7.4 timing and then some
- misfire at idle?
- Slight Electrical Problem
- power steering pump
- a/c compresser
- Spark Plug questions.....
- '98 AC Compressor Not Working
- Alternator/Electrical issues!
- I'm back
- Location and removal of EGR help
- Monroe Sport Edition
- replacing a starter on a 95 c1500 4.3 5 speed
- bolt pattern
- Rotor Button
- 1998 Chevy Tahoe Steering Sensor
- '93 C1500 4.3, 5 speed now has starter issue
- Code 1345 Need some help guys!
- 1989 c1500 brive shaft
- 1986 chevy 3/4 ton
- 1994 Gmc Sierra Suspenstion Question
- 1994 gmc sierra exhaust question
- Air Fuel Gauge on 95 5.7
- Has anyone ever had this problem?
- 89 k3500 454 timing issues
- 1996 5.7 Vortec starting problem
- 89 running badly
- 1999 454 high idle
- 93 2500 clutch ajustment ?
- How do I know what Tranny I have???
- 1996 5.7 fuel regulator
- 98 5.7 Timing all over and misfires
- Transmission swap
- 94 K1500, Erratic instrument cluster
- Bad Gas Mileage!
- Big Block Swap?
- 98 7.4 L spark knock and power loss problem
- Temp sensor
- 99 C1500 classic
- 96 K1500 AC Compressor Question
- 94 C1500 Whistling at Intake???
- Auto Enthusiast
- transmission
- MISFIRE - help, please!
- ecm fuse blowing
- '91 C2500 Silverado seatbelt?
- 350 starter wiring
- 305 & 350 Engine HP Ratings
- Erractic Idle
- 1996 Silverado Z71 4x4 Problems
- help!
- looking for headers
- Truck won't start
- Clunking Rear Axle
- 92 350 Engine Swap
- Soft Clutch on 93 C1500
- OBD-1 sensor readings
- 1992 c/k 1500 2wheel drive swap
- bogged down and sluggish like a wet sponge
- Drivings lights dont work on 99 tahoe
- Alot of Water through muffler and intake mani
- 97 1500, sometimes won't start with key..
- dual exhaust mileage
- Truck Won't Start!!!
- 97' accelation issue
- Instrument Cluster (Mileage)
- 98 silverado projector install help?
- Auto Transport Tips For Trucks And Truck Lovers :)
- 94 Tranny Slipping after Engine swap
- 2-Horsepower Starter (95 Chevy P/U)
- Fuel Gauge stuck past full
- rear end klunk
- Suburban shakes during acceleration
- 98 Power Windows
- Cylinder MIsfire - Experts help, please!
- Transmission Down! Need Help!
- TBI interchange
- 00 Z-71 air condition
- oil amount for 4.3
- 98 silverado 350 to 454 vortec swap
- Grille Makeover.....any Ideas
- Vats / Passlock Bypass Help '98 K2500
- bolt sizes
- Replacing Ball joints
