View Full Version : C/K
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. `94 6.5 turbo diesel - glow plugs cycle off too fast.
  2. Power steering pump cavitation
  3. I need alittle help 1998 c3500 idler
  4. no turn,hazard,or brake lights
  5. Crate motor - Where to buy in Canada?
  6. Hazards not working!!! WHY?!?!?!
  7. 98 Silverado - no brake lights, no 3rd light
  8. Spark Issue..
  9. No Heat
  10. HELP with keyless remote please
  11. GGRRRR..fix one thing something else breaks ( 4x4 transfer case related)
  12. 98 chevy 5.7 code P0306
  13. Lowering question
  14. 88 1/2, 5.7L Engine stalls?
  15. wiring 4l80e
  16. 5.7 surge
  17. 88 Gmc K1500 / 5.0
  18. 97 Z71 - Driver's door won't open from inside
  19. 97 sub blows fuse ecm b with fpump relay removed
  20. Coolant Leak, Top of Engine
  21. I think I blew a rod or something
  22. '91 6.2 diesel head bolt torque
  23. '91 6.2 diesel head bolt torque
  24. '91 6.2 diesel head bolt torque
  25. 89 K1500 starting problem
  26. Bigger tires on a 1998 Z71 ext cab?
  27. 1989 c1500 remote start
  28. 95 1500 4.3v6 very rough idle/stallin when warm
  29. Security Systems
  30. 4l60E slips when cold..why?
  31. Door Stuck
  32. Fuel Pump problems...
  33. 4x4 problems
  34. 94 c1500 transmission surge at a stop light.
  35. Brake Problem on 95 K1500
  36. HELP!!!!!!! 97c/k 1500 wont start....
  37. Factory Service Manuals
  38. Ignition control module location please help
  39. 350 engine upgrades - Intake manifold
  40. Brake Thump
  41. '84 5.7 exhaust
  42. Which Throttle Body Spacer is right?
  43. Auto pilot
  44. 4.3 backfire
  45. 97' 1500 5.7l will not start and brake light on
  46. New cam and alum heads
  47. 95 1/2 ton, 305ci, high idle
  48. rear vents only blow cold
  49. It sounds like someone rear-ends me and shakes the truck.
  50. 1990 k1500 rear end locked up?
  51. 97 k1500 no start, failed PCM?
  52. Parts 1996 K1500
  53. 1998 k1500 axles
  54. 1993 K1500 Transfer Case Grinding
  55. what kind of heads to put on a 454?
  56. Muffler questions
  57. Thermal actuator
  58. 1500 Truck ignition key cylinder Remove and Replace
  59. Oil pressure gauge acting up 1988 C1500, 5.7L
  60. Low Coolant and Heat
  61. How many miles on 5.7L/4L60?
  62. 88 Chevy PU won't go into Reverse
  63. strange problem?
  64. 86 K10 power steering
  65. tranny leak
  66. dually conversion
  67. hydraulics
  68. Heater Relay clicking!!!
  69. 88 Sliverado electrical flicker
  70. 1991 Silverado Radio
  71. Faulty Cruise Control on '96 Chevy Z71
  72. Replacing Locks on Chevy Truck
  73. 91 pk with no power to the fuel pump
  74. 91 v6 not power to primary side of fule pump relay
  75. Manual 4-Wheel Drive
  76. body change
  77. 95 1/2 ton 4WD, irregular high idle
  78. 97 C1500 Fan Blower Switch Replacement
  79. 700R4 no reverse
  80. '96 Chevy Z71... won't always start after installing 2 Fuel Pumps
  81. brake lights on a 98 ck
  82. Bellhousings for GM small blocks
  83. Better mpg for 91 dually
  84. 1993 chevy won't idle
  85. Service engins soon blinking fast
  86. 98 k1500 5.7 stumble on light acceleration
  87. Help!! 1997 Silverado won't start.
  88. help
  89. Chevy fuel selector
  90. 95 truck idles fine but stumbles badly while driving
  91. piz help me 454
  92. Starts cold, won't start after been running
  93. 98 K1500 4X4 or 4X3
  94. Pushy Pushy
  95. Turn Signal Blowing Fuse
  96. Starts then stalls???
  97. crank. position sensor question.
  98. transfer case repair?
  99. 5.7 Stumbles when Oil fill cap removed
  100. 98 1500 no first or OD trans
  101. shimming a starter
  102. Door Adjustment
  103. blowing fuse
  104. 454 4x4 !!!!!
  105. 97 1500 I think engine is locked up what do you think
  106. Can't figure out - 1996 K1500
  107. need a tranny
  108. Temperature question K1500
  109. 97 1500 tranny problem 4L60E
  110. ?'s about 14 bolt semi floater posi
  111. rough idle
  112. My 1989 K2500 Stalls when stopped
  113. 96 k1500 misfire
  114. Spring Coil Compression
  115. 1995 3500hd 6.5TD rough idle & black smoke
  116. 1995 Chevy Z71 won't start after changing my fuel pump
  117. First Post...Awesome Forum!
  118. Front wheel bearings - '98 K1500 4WD
  119. Just wondering about replacing 1989 TH400 with 1992 4L80e
  120. Air Filter housing for a 5.7 Vortec 96-98
  121. 92 K2500 -- Windsheild nozzles
  122. 1997 stuck in 2nd gear
  123. 97 C1500 Daytime Running Light problems
  124. 1998 chevy1/2 ton 4x4 missfire 5.7 po300
  125. windshield wiper circuit board
  126. Will 285/75/R16 fit under the bed as a spare on a 98 Z71?
  127. 350 to 454 engine swap
  128. 95 K 2500 454 intermittent ignition start problem
  129. 1994 Chevy Truck windshield wipers/dashlight/running lights not working
  130. 1997 Chev Silverado want start cold
  131. Temerature Gauge Not Working
  132. Death Wobble
  133. transmission question...
  134. 1985 silverado
  135. Switching 454 cab out for 350 cab
  136. 1993 K1500 Misfire?
  137. 1988 Chevy k1500 missing/sluggish
  138. distributer ??????
  139. 98 K1500 will not start(just Clicks and Clicks and Clicks!!
  140. 1994 v6 4.7L 4x2 conversion to 4x4
  141. Jetchip Air mass Sensor
  142. a/c - heat troubles
  143. Minor Electrical Quest.
  144. Heater Problems
  145. rough idle
  146. 95 K2500 blower motor resistor
  147. 96 fuel pressure specs?
  148. Please help, unusual no-start condition on '97 Vortec 5.7L
  149. Add Methanol To Fuel?
  150. 1991 Silverado y-pipe issue
  151. 1998 K1500 Starts and Dies- MAP Code
  152. 92 454 throttle position sensor
  153. Question about EVO Sensor on 1996-1999 C/K GM trucks
  154. heater stopped working
  155. code 32
  156. No Heat
  157. 97 Silverado won't start
  158. Running Board Advice..
  159. muffler location ?
  160. 92 Chevy Silverado 350 won't start after tuneup
  161. locks not cycling
  162. 1998 5.7L vortec ( no start, no fuel pump buzz)
  163. low rmp idle idles rough
  164. Bad upper intake manifold on 1998 305 vortec?
  165. 96 k1500 front brake pad wear question
  166. A/C Control panel buttons
  167. 1997 Vortec 5.7L fuel pressure regulator location??
  168. Replacing rear turn signal bulb...
  169. 1996 K1500 cargo light wiring
  170. 1985 K10 need new transmission
  171. Replacing th400 w/ th350
  172. 92 Noise in drivetrain
  173. oil in the intake
  174. Heater Core Question
  175. 1996 C/1500 Chevy temp guage doesn't work
  176. 95 Silverado Shifting? HELP
  177. 95 Z71 shifting?? HELP
  178. 1986 K5 Blazer having problems
  179. 93 Cheyenne heater issues...
  180. 1996 1500 ABS issue
  181. need some help please
  182. chevy wont start
  183. Fuel Mileage Improvement
  184. Engine needed
  185. 1992 Cheyenne. Defrost acuator wont direct air.
  186. should i buy
  187. Engine bogs down when I get on
  188. Tcase
  189. 99 K1500 rough idle
  190. HELP! I think new flowmasters are on wrong!
  191. 1997 c3500 7.4 3500 hard start
  192. 98 Chevy Z71 Brake Lights Dont Work
  193. SpeedOmeter gear
  194. Ball Joints
  195. Having trubble starting engine
  196. question
  197. how much is this truck worth?
  198. Passenger Air filter
  199. 4wd circuit
  200. Instrument cluster change
  201. 1992 C-1500 4x4 5.7L Tranny?
  202. 93' 1500 Turns over, won't start
  203. Front end shakes in 4x4
  204. How loud will the truck be?
  205. 4.3 vs 4.3 vortec
  206. 1992 C1500 350
  207. Headlight adjustment?
  208. 2001 454 crank sensor
  209. Need New Tie Rods
  210. 94 1500 Stalling
  211. Front End!
  212. Riding Rough
  213. 350 Tbi Egr?
  214. Too much fuel pressure
  215. Gear Ratio
  216. 1989 4.3 1500 transmission
  217. 98 chev died and wont start
  218. headlights dont work.
  219. fuel gauge flickers
  220. 1999 Chevy Z71 ExtCab SWB metallic noise when accelerating
  221. Shock Absorber
  222. 1997 C3500 7.4L P1345 code
  223. Clunk in Steering
  224. 87 k10 Hard start warm
  225. rear oxygen sensors
  226. 1998 V6 5-speed ext cab questions
  227. Rear window glass
  228. Transmission leaks BAD only in reverse??????
  229. 98 K2500 6.5L Turbo Diesel, Died
  230. hazard weirdies
  231. TBI 454 camshafts?
  232. 98 k1500 fuel pump problems
  233. Replacing front axle shaft seal
  234. 78 400 timing specs?
  235. Automatic Hubs for 84 K20
  236. heavy 2500 specs
  237. turning issue- (front end?)
  238. 1998 C1500 No Heat
  239. 98 Chevy 3500 1 ton dually diesel turbo dying
  240. slight rust on cab corner
  241. 1997 C1500 low fuel indicator light?
  242. 4x4 fender flares
  243. Modulating Vlv Location
  244. ?'s about engine swap
  245. 93 cheyenne 4.3L bogging, backfiring
  246. 1989 V6 Running Lights
  247. What's the sound???
  248. Turning off ABS light?
  249. 1994 1500 Front End Alignment Question
  250. Replacing door window seals
