View Full Version : C/K
- tcc solenoid problem 95 k1500 4l60E
- 97' Silverado timing issue
- Front axle grinds when put into 4WD
- Cold start issues
- Brake Repair mistake???
- 95 k1500 wont shift into 2nd.. found melted solenoids
- Rear wheels lockup
- 88 K1500 5.7 sputtering, backfiring occasionally
- 94 Chevy Silverado 4.3 V6 - No Power
- Sensor Problem diagnoses help!
- need help with 4x4 problem quick!!!
- Installing headers
- need some help. 1995 chevy
- 96 k1500 bad trans or ignition switch
- Carb ?
- A few crate engine related questions
- 350 running rich
- 1998 5.7L spider
- 1998 chevy k1500 with 4.3 performance ideas???
- Check Engine Light at 40-45mph
- 97 c/k 1500 5.7 Missing
- 98 chevy k1500 w/4.3... p0141 code and bad gas mileage
- 96 transmission woes
- 94 k1500 transmission
- Ebay Wheel Hubs
- 92 1500 Won't Shift Into 4 Wheel Drive
- th700r4 swap
- 96 k1500 eng change CEL with codes
- 1988 k1500 pulley question
- 2000 C 2500 Coolant in Oil
- 91 5.7 runs good cold not hot
- turn signals/brake lights
- 1997 c1500 turns over but no start
- lower ball joint
- Front Differential-Mad Mike's project 3.42
- ECUM acting weird?????
- 96 Chevy 5.7 Fuel Gauge Pegged and no Fuel
- truck wont stay running
- 97 chevy 1500 oil pressure at 55 with check gauges light on
- ABS Pulsing on Dry Pavement
- '88 K1500 died
- Brakes and Rotors
- 94 k1500 350 hard starting
- Lower ball joint
- Wipers Acting Up Again
- '94 5.7L K1500 - Parking Brake Light is on
- heater controler problems
- 99 K3500 diesel dies intermittently
- Gooseneck conversion?
- 1988 K2500 350 4x4 starter replacment
- Manual to electric fan?
- Lifted truck appearance question
- 1998 Suburban Eng1 fuse keeps blowing
- 98 short block to 94 auto 4.3
- -=Axle Warning=-
- K1500 Bogs and Stalls when taken out of Park or Neutral
- 92 K1500 Transfer case/4x4 issues. HELP!!
- '95 C1500 head scratching issues
- 95 K1500 Brake Light Switch Replacement
- Changing fluid in Rear Differential
- 1997 C-1500 security screwed up!
- why new style acuator?
- 96 4x4 trans which model and what upgrades
- 99 starting hard
- 94 1500 Trans shift problem
- '89 C1500 interior door panel removal
- 1993 1500 4X4 fuel problem help!!!!
- 96 trans 4x4 not going into any gears
- another c1500 fuel problem
- 1994 K1500 4x4 high idle,shifts high rpms
- 98 K1500 5.7L Cylinder Misfires
- 1990 c 2500,all original with 462,000 miles
- Brake Pedal to floor on Startup, brakes work fine
- Strange clicking noise inside cab when turning right
- 1994 C1500- Brake Pedal to Floor
- 96 k1500 4x4 question
- Catalyst efficiency below threshold bank 1
- 1990 no start problem
- oil pressure problems
- 1994 K1500 - Diagnostic Code Reader - Which one?
- 1994 K1500 - A/C grinds when on...
- 1997 K1500 A/C problem
- 1995 c1500 no power at all idles perfect
- Major electrical problems
- low fuel pressure
- 88 chevy stepside ground problem
- Differential
- 92 c1500 dies at decelleration
- Strange grinding noise in cab
- AC Pump Howling
- brake line
- Fast idle speed 1996 K1500 5.0
- 4L60e Trans Fluid Change
- 1977 Chevy Pickup - Power Steering Pulley Screeches
- 4L60E transmission return line
- Runs Rough, only give 0300 error code
- 94 K1500 4.3 low vacuum
- Help needed in finding a part please
- Transmission Temps temp Gauge
- 94 1500 fuel pump problem
- 1992 K1500 Hesitation
- 97 K1500 350 Ignition Mishap/Question (please read)
- 1995 Cam ?
- 88 K1500 Steering column loose
- 1988 chevy stepside 4x4 fuel pump problems
- I know it's a stpid ? but I had to ask...
- 2 differant questions
- 84 k1500 rear end seal
- 90 Silverado 2500 Fuse Marking Question
- 94 K1500 4.3 running rich
- ac problems
- Pinellas County, FL - Looking for a good chevy mechanic - '94 K1500 5.7ltr V8
- Heat gauge redlines during first cycle
- 5Amp Current Draw with key off
- Transmission cooler line options
- 97 Z71 keeps vapor locking
- Lowering/Air Ride??
- 4l60e transmission problems
- p1870 code
- tough transfer case question for tech guys
- New speakers in my pickup
- Radiator leaking
- K2500 wont start
- 95 k1500 305 ignition
- 1989 trans wont shift out of 1st?
- 1994 K1500 5.7Ltr V8 - Wrrrrr-ing sound @ idle
- starter repair 89 v6
- Help with fouling plug
- Seat cables
- A/C help needed
- 97 chevy k1500 rear end
- 89 chevy pick-up wont start
- 700R4 to th400 tranny swap?
- 91 stalling please help
- busting flywheels
- changing a manual shift 4x4 to an electronic
- Best way to get rid of bad smell inside the cab
- What size do I go with?
- 97 350 vortech distributor issues/timing
- 1997 350 ci code p0133
- 1998 rough idle
- 93 c3500 6.5 turbo diesel problem
- Running cool
- Where to get a radiator and tranmision cooler lines?
- CPFI to MPFI Conversion
- 1998 5.7 losing fuel prime
- 98 hard to start when warm
- Pitman arm ??
- Cap and Rotor 96 1500
- Need some help again(exhaust this time)
- chevy stepside starter
- Cabin Fan Works Off and On
- Installing an after market CD player in my K1500
- Yup I need more help.....
- 98 K2500 miss at idle?
- Bearing work
- Factory or Shop rebuilt transmission????
- Tailgate Badges.....?
- 96 k1500 rough idle, power loss
- Transmission cooler ??
- need help!!! with my k1500
- 285/75/r16 vs. 265/75/r16
- Not the usual turn signal problem...
- signal light repair
- 1992 Silverado 4X4 lift kit question
- 88 k1500 in dash brake light
- 95 Chevy 1500 (Power Seats)
- 97 K1500 Extended Cab AC Freon Lean
- Key off drain courtesy light...
- 92 C1500 electrical issue.
- 1995 Silverado: Rough, Surging Idle and Poor Throttle Responce
- 1990 Scottsdale Wont Start
- 4.3 engine swap part two
- 98 5.7 no fuel
- Help: Engine swap
- no fuel at start up
- Help 92 c1500 5.7L
- 1994 4.3 v6 egr??
- Where to find a dashboard for a 1991 c1500?
- 1982 6.2 Diesel Injector Pump
- power problem
- 2000 ck2500 vortec 350 cutting out badly
- 1977 K10 4WD - Wheel Bolt Pattern / Tire Size / 4WD Shifter
- 1998 Chevy K1500 Back up light Issue
- 99 C3500hd - starting trouble
- '97 5.7 Vortec 1500 , MSD ignition installed...HELP!!!
- brake light swtitch
- Transfer case
- No spark from coil
- 94 CK 1500 uncommanded wiper during acceleration
- Engine Swap Electrical Problems
- 89 Suburban backup light switch
- 91 C2500 antenna wire
- Cat question?
- Adding cruise control
- 4x4 trouble
- loose outer door skin
- Door Lock Wires
- 1995 K1500 TBI injector pigtail
- ignition problem comes and goes
- 95 k1500 / 5.7 missing at idle
- automatic tranny question
- Changing 79 front clip to 86 clip ????
- 92 454 wont idle
- 91 1500 will not Start!!!
- 94? transfer case into 97?
- K2500 won't start
- 97 C1500 w/codes PO339 and 341
- 94 having trouble with trans
- Help 96 5.7 vortec won't start
- '96 GMC 2500 overheating problems...or not?
- Runs good for 20 minutes, then dies and won't start until the next day
- 2 codes, please help!!
- Transmission not shifting
- Missfire at Idle
- '90 4.3 running like crap!
- Brake Pads & Rotors
- '92 K1500 350 TBI stumbles and recovers while braking / slowing down when warm
- 1995 Chevy misses on acceleration???
- 98 4.3 water in oil
- How to refurbish faded gauge needles
- 95 K2500! No crank! Keeps blowing ignition maxi fuse! Help!
- New Symptom!!
- Slowly getting there!
- '94 1/2 ton-thumping under dash
- '95 1/2 ton truck
- Gotta get this AC working for summer!!! 1997 c1500
- low front suspension
- Surging in 96 chev pu
- Hole in Firewall?
- 1997 K1500 Windshield
- 1994 454 missing and running on 7
- 98 1500 hazard light switch
- 1995 k1500 missing when accelerating
- 97 z71 LOWWWWW brake pedal
- New to Chevy- c1500 which engine has best rep?
- 95 Chevy 3500 w/5.7L...need help!
- flywheel replacement tutorial - '94 k1500 auto 4x4
- 1988 k1500 4x4 Electrical and Brake problems
- patch panels
- Is my G80 diff broken?
- Optional instrument panel with tach
- Another tranny question 98 k1500
- 95 k2500! No brakes! Help please!
- Overheating!!!!
- 93 K1500 5.7 running rough
- Roaring/road noise under floor
- 95 Chevy 1500 (Steering Column Shift)
