View Full Version : C/K
- Changing Thermostat
- MERLIN, Follow up to 350 TBI power problem
- looking for k-6 or c/k 1500
- Converting Manual To Power
- Power programmer questions
- Tonneau Cover
- Starts then dies??
- 1998 Silverado Ck 1500 5.7,350 Ci
- Paint problems on 1990 Z71 Stepside
- 1999 Silverado 4x4 sputtering
- program to turn off change oil message
- door removal
- Ignition lock. totally locked
- towing capacity ?
- Whats your Subs GAS MILEAGE??
- 1999 5.3L Losing Coolant
- 99 silverado abs comes on 5mph or less
- timing a 1990 c/k 1500
- heater goes tick-tick-tick!
- where to buy parts?
- positraction
- 2004 1500 Silverado - clunk & vibration
- Carburetor for sale!
- ATTN. GM Tech's/Experts, HOW can piston slap "NOT" damage a motor
- Motor Swap question
- Need some info on 87 Burban
- '98 Suburban; Interior lights not working
- Diesel Burb Stalling
- need help quick! 99 5.7L won't start
- 16 yr old in need of help with motor
- Anybody running a 383?
- Remote Start problem
- An ABS question
- power steering problem
- '99 Suburban...Fuel Pump Failure Common??
- Best Place to Plug into 12 volts under dash
- draining radiator
- Rear Rotor Scoring
- 1989 4wd not engaging
- 350 TBI studdering under load???????????
- How do I get all the coolant out of the engine?
- New Silverado owner - a few questions!
- Correct Rear AXLE FLUID for '99 1500 4x4?
- 1996 2wd no drl's or low beams
- 99 Z Autolock disable & floor console
- whats a mean sounding muffler?
- 95 350 TBI power problems? MERLIN help!!!
- '97 5.7 Vortec no start - any ideas?
- Can I ditch the fan on a 2003 Z71 5.3?
- 1999 Tahoe garage door opener how to
- 89 c10 wiring
- 04 cd player install
- 2004 Silverado fuel filter location
- Brake Light flashing
- Tires and Wheels?
- programing
- Track times???
- loads up at idle
- 4WD and different tires question
- Remote starter for 90 Silvrerado
- reproduction Caddy window stickers
- ODBII-Engine Diagnostics
- Increased Engine Power
- Long tube headers
- Do I have a 5.0L or 5.7?
- Understanding wiring on dual fuel tanks?
- climate control
- grinding noise
- 2000 Suburban electrical Windows
- Wtf!?
- suburban 1998 keyless programming
- 2001 burb low engine power light
- Borla for a 96 K1500???
- 1999 silverado wont idle when cold
- Changing the fuel filter
- 2nd gear only
- Intake Manifold water leaks
- 88 Chevy 1500 Heater Core
- frequently fried alternator
- Here are the sympthoms, anyone know the diagnosis
- 94 rear speaker replacement
- Coolant leak and random rough idle
- 1990
- 1988 chevy suburban diesel --help
- heater and defrost problem 1988 silverado
- 1989 Manual Transmission (Gear Oil?)
- Best Choice for Gas Mileage?
- cracked tranny
- Improve Gas Milage ??
- Headlight bulb replacement
- `89 4X4 problems....
- 2001 Chevy Tahoe LS Starting problems
- cold air inside cab?
- Hypertech/Gibson Parts
- 99 Suburban service engine light
- 2001 siverado circuits
- Have you seen any chrome?
- 02 Gauges sticking??
- '01 Silverado 6-1/2" Speaker Install
- 1999 silverado 4.3 won't start
- Towing with a 5.3L
- 97 2 door Tahoe Diesel
- Gas drips underneith when tank is full?
- Machinist ? need help
- Delayed Start
- Starter to flexplate....how much gear contact???
- defrost thump ??
- Clank noise in tranny
- 1997 Chevy C/K Ram Air Hood
- Drivers Seat & Seat Heaters
- 84 chevy k10 4x4 for parts
- 71 4x4 4" lift steering radius correction
- 8.1L gas mileage
- Daytime Running Light Override
- Tireware question 285/75/16 B.F.G. A/T
- 2000 silv manual trans probs?
- DTRL Problem 2000 silverado
- headlight adjustment 2000 silverado stan cab short wheelbase 4x4
- lift questions...
- power problems....
- Bench seat to shag bed conversion Qs..
- rhino liner VS line x whos best?
- 01 Tahoe LT - Auto 4WD Question
- message
- Please help me with a ABS light problem.
- 1997 Silverado headlight knob fell off
- 97 Silverado Z71 Transmission
- Heater Core Replacement
- A.i.r. ?????
- WTB 73 Sub body trim
- 99 Silverado Tranny shifting problems
- What Fuse to REMOVE so truck won't start.
- ABS fault light on - How do you turn it off?
- fuel pressure regulator
- Need help with jammed door lock!
- Rear noise
- For Sale
- Looking for a good online performance parts shop
- silverado brake light switch
- R&D Automotive
- I wanted to buy the 04 Z71 Tahoe but I heard
- Leveling
- removing front door panels
- 1999 K2500 454 4WD Suburban Air Injection Noise On Start Up
- 2000 Suburban A/C and front end ?'s
- 88 Front End Went KLUNK Makes Noise Driving, NOW WHAT?
- low idle
- no spark
- Should 4x4 be engaged every once in a while
- where is trailer towing harness located at front of truck on 1998 chev c-3500?
- engine misfire
- 89 c/k 2500 4x4 has no heat
- tahoe
- Changing Auto Tranny fluid and filter-do I need special tool?
- '91 K1500 dies in reverse
- 2001 silverado door lock has jammed
- Fuel gauge problem - help.
- Hard to start after warmed up and sits for 20 to 30 min's
- ,01 rear glass defroster cnnection
- rear knock on '01 2500
- 96 Tahoe Manual 4WD not engaging
- clanking noise rear of truck
- hard to start cold
- Original GM Service Manuals
- L/outside mirror double vision
- Money To Spend
- Aftermarket Brakes-'94 2500-454???
- Westers chip Vs. Hypertech which is better
- sliding rear window
- Help: ABS and Brake Light ON
- Programming remotes 1999 K1500
- 2003 Seat Bolts
- 95 chevy low rough idle
- clicking in dash sound
- I'm completely new, help me out??
- interior upgrade
- 95 Tahoe front axel lock mod
- Transmission on 1993 Z71
- Suburban 4W AUTO mode
- headers
- airbag disabled
- Tahoe with no daylight running lights
- 2001 Tahoe won't start after turning off engine
- My 2000 Silverado won't start
- Sunroof
- big clunk noise after turn off.
- 2001 Headrest removal
- 2000 four 4 wheel drive turning problem
- Steel Braided Brake Lines (help)
- removal/re-install of factory radio
- Front Brake Rotor Failed
- fuel pump fuse
- Mysterious idle problem
- Bose Audio
- Cold engine start
- Rear differential leaks
- Anyone Have A Plow On Their Tahoe?
- stereo codes
- 97 Suburban build sheets
- Chevy starts then dies
- Headers
- Service Four Wheel Drive Message
- Heat then No Heat
- Rear Main Seal on 99 Suburban
- keyless entry programming
- Need help with this noise!
- 95 "Service Engine Soon" light
- Water leak in passenger footwell
- Problem with my 4-wheel drive
- remote start for 2003, and stereo
- 350 Rebuild idle problem
- '96 Suburban...need help.
- 98 tahoe "bump & clunk" drivetrain problem
- Overhead Console
- 1996 GMC Jimmy w/ Blown Engine
- hard starting 1990 suburban
- 96 Tahoe 4dr door panel removal?
- HELP! Need help on programing Please
- gentex mirror temperature
- motor swap
- check engine light
- jerking
- 89 Chevy wiper nightmare
- engine noise, sounds like lifter noise
- 1998 K1500 engine light
- Vibration at 90km / 50 mh
- 2002 Z71 Surburban buzz noise in dash
- 2002 Tahoe - Supercharger?
- My Tahoe is having an acceleration issue
- Very long time for heat
- 96 Tahoe Rear Differential Problems
- EGR unit on silverados?
- Transmission: Reverse Lost and Steerings Problems
- transmission
- 89 Suburban problem
- CD Player
- 2002 Silverado with 5.3 liter Vortex
- a couple of minor problems with an 86
- 4x4 trouble, please help.
- Won't Start
- ??? anybody running a 160 stat with hypertech tuner?
- P452 DTC after Replacing Fuel Pump
- rearview mirror compass problem
- Where is the keyless entry control located?
- Looking for '04 silverado tail lights
- Help !! Truck is showing codes 36,33 & 78
- clicking after intake gasket repair(97 silverado)
- passenger side dash
