View Full Version : C/K
- Hard Shifting 2-3, no-shift 3-4
- 2003 Silverado C-1500 LT
- service engine soon light
- 1996 Tahoe battery drain
- GMMerlin this is for you
- New Guy here!
- Blower will not blow on vent
- 99sub rough idle
- tire?
- 97 chevy 4x4 low front end not working
- 2002 tahoe suspension click ?
- anti freeze dripping
- need tq specs on a pressure plate
- cam
- 1988 Chevy 1/2 ton overheating
- weird steering problem
- '94 Tahoe 4WD problem !
- How do I convert 4x2 to 4x4 ?
- drive shaft
- Re: 2001 Suburban
- '97 Fuel line leak near tank
- catalytic converter
- Trying to find what headers to get
- Check Engine Light
- Antifreeze coolant block drain plugs
- fuel pump going out .. replacement part question
- 97 tahoe fuel pump problems
- 1997 chevy fuel pump problem?????
- 1998 Tahoe Road Vibration
- 1997 Suburban 454, DTC P0175
- Doors unlock.
- '97 AC mystery
- 350 to a 383 stroker
- 97 suburban tensioner problem
- engine light..yellow...constant
- White Smoke?
- 84 Scottsdale 2wd
- Service Engine Soon Light - warranty info!!
- Fuel pump out? 1987 dual tank
- replacing brake line 1980 Chevy C10 P/u????
- Service Engine Light is on!!
- 2000 z71 will not go into 4wd
- 6" Drop
- 2001 4.8L steering, idle, electrical, 4WD problems
- Service Engine Soon light - new warranty info
- How do you change a fuel filer on 99 suburban
- Heated seat problem
- Magaflow Exhaust?
- injectors
- 2001 Tahoe tire size
- 03 oil life computer thing advice
- Knock sensor
- transfer case problems
- 03 4.8 sounds like a diesel when cranking
- 4.10 gears Silverado to S-10
- I'm leakin' oil!!! Help!
- Heat Shield (Muffler)
- Vibration at 73 MPH
- 1999 Silverado Automatic Door Locks??
- Correct Idle Speed?
- driving lights on my 2000 silverado
- front window noise 2003 Silverado
- Code 0420
- 1991 2500 5.7 problems
- front drive shaft
- Wheels
- Electrical Problem Solved
- Programmers & Superchargers
- cd player
- 1999 Tahoe Rearend Differential Problems
- Ready to pull my hair out
- 96 Suburban Electrical Issues
- Help Multiple Problems
- oxygen sensors
- Manual transmission
- Shaker hood
- Suburban stalls on driveway & freeway
- Installing amsoil by-pass filter?
- keyless entry
- Stiffer shocks for '98 K1500???
- Help choosing '67-'87 GM truck
- 2001 Tahoe wire locations
- Leaking Front Differential Seals
- Dome comes on with window,brake,lock,...
- installing fog lamps 03 Silverado
- '93 Z71 CK 1500 Heater Core Help Needed!
- Service Bulletins
- 2002 stuck in auto 4wd??
- 4.3L to 350 engine swap
- 2003 1500HD transmission noise
- Performance upgrades for 1995 Tahoe
- This just in
- This just in
- 1 more, then im done, for all of you who hate me for so many threads!
- 4wd problem
- factory tint removal
- hypertech (recommendations)
- Hey, I am new the forums!
- 95 Suburban Brake Lights
- 5.7L rough Idle "cough"
- 1988 Chevrolet Van 30
- Won't Start - Fuel System Problem?
- Won't Start - Fuel System?
- 1995 shifting problem
- driver display question on 2003
- No Coolent Pressure
- AIraid of fipk? Whats the diff?
- How Big Can I Go????
- Overhead console
- keyless remote programming
- 2001 Service engine light
- 2001 tahoe rear hatch/window and power door locks
- 97 Silverado Vibration Problems
- Couple of ?'s about a 96' 2500
- In-dash tv w/ dvd for sale
- EGR or ECM Problem?
- 1988 2500 Fast idle
- Service 4WD Light - '01 Sub
- Steering gives when turning
- 99 suburban second battery trays
- Airaid? Any tricks or tweaks for a 5.3?
- Remote starter/alarm wires.
- parts for sale
- voltage drop stalls suburban
- HD hood question
- tach question????
- Aftermarket Discs for Front of 99 Suburban
- 1992 V6 wont accelerate
- For Sale: Hypertech Power Programmer III
- My Driverside Fog lens is cracked, where to buy?
- Tb Spacer or Fipk worth it??
- I need some bass!
- 1996 Tahoe Keyless Remote Prgramming --- Help me
- 89 Drivers side back seat dummy window
- Twin Turbo 99 Tahoe
- 1990 Five Speed Tranny Oil??
- 88-93 C/K Performance exhaust.
- Dimming Mirror
- 2003 silverado 1500 Tail lights
- winch mounting systems
- tire pressure on 1995 LS tahoe
- Turn Signal cancellor broken - 89 Burb
- ash tray light replacement
- 5.7 Vortec Loss of Power Up Hill Final Straw
- 82 Suburban Transmission Problem
- 4.3v6 Rough Idle
- Possible electrical problem on 89 Silverado
- Highway miles vers City miles
- 1999 Tahoe Electrical Problems
- Worn out brake pads
- Leaf springs or Torsion bar?
- 95 Burban 4WD not engaging?
- Engine won't start
- 96 Tahoe Audio problems
- leather or cloth
- !999 Silverado Z71 4x4 antilock brakes
- Drain Tube Location
- prices on avalanches
- Looking for grease fittings
- 350 Full Size Blazer Engine Questions
- Which OBD II tool
- Coolant Leak
- acceleration problem
- how do i set timing/ install distributor on 97 350 vortec?
- Winshield wipers
- finding #1 position after taking distributor out
- 2000 Tahoe Limited (rattling under truck)!
- 94 6.5L Diesel-Engine Stall
- Turning DRL Off On 99 1500
- Changing Oil Reminder On 99
- Boltover Billet Grills...
- need some help repairing a C1500
- FOR SALE: 1999 Chevrolet Silverado 4.3L V6 Engine
- Hard starting 5.3
- squealing when i turn left
- Lost Engine Power...
- crate 572?
- Unsatisactory Ride on Freeway
- 99 Tahoe Fuel Pump
- No brake lights on rear of truck
- Drivers side lumbar support not working
- HELP ME! Low hp problem.
- Evap vent valve clogging
- hella fog light kit 4 sale
- 89 K1500 Cylinder Compression?
- Lowering A C1500
- Factory speakers
- Want to put a 10" Sub in.............
- 00 sputtering when give gas
- Normal fluids "consumption"
- 88 Suburban For Sale
- exhaust leak
- 98 350 Vortec
- Battery Light
- oil use
- temp/compass
- 99 problem with trailer lights
- air intake and exhaust 4.3L V6
- 2001 Chevy Suburban Electrical Problem
- oil pressure sending unit
- Screws for Hub Caps
- mirrors and dome light don't work?
- Radio locked
- what made you buy gm?
- Ram Air Hoods going out of Retail Sale
- 02 chevy 4.3 "random misfire"???
- Delco CD player problem ERR
- brake lights dont work!
- Cheap power upgrades
- 1995 4.3L VIN "Z" TBI rough Idle & Exhaust Smell
- A/C Service Port Pressure at idle
- fan and fan clutch uninstall? 97 tahoe
- 2003 Suburban Intermittent Electrical Trouble
- K&N FIPK
- Engine bogs down and dies
- engine alignment
- I want a Suburban.... pls help me....
- 99 Driver Window FELL. Cable broke. Where to get?
- Broken Heater Hose Quick Connect
- Teouble shifting Getrag 5-speed into 3rd-4th
- 1989 steering problem
- Exhaust
- LQQK Need suggestions Please
- V6 swap
- MBRP Cat Back exaust kit cheap!!!!
- Tweeter Removal
- 95 Suburban: where's that @#$%^ fuel filter?
- Six-Way Electric Seat Rails and Motors Question
- 2002 2500HD Random Electrical Problems
- HELP! Radiator Plug
- HELP! 2003 tahoe keyless remote programming
- 2001 Rear Leaking.
- Clicking noise
- stripped threads and oil pump
- 99 3/4 ton 6.0 L takes what type of oil?
- 5w30 vs 10w30
- best replacement carb for 1978 454 burban
- 4L60-E Transmissoin Problems
- 4 Sale - Bushwaxker Fender Flares
- dexcool
- Removal of Fuel Pressure Regulator
- removing dashboard/swapping radio 2003 silverado
- Aux option on 2003 Stereo
- Black Eagle keyless entry
- C1500 camper weight ratings
- electrial short
- 2001 Suburban - Dealer says New Rear Brakes/Rotors Needed - Not Warrantied
- exhaust flange bolts
