View Full Version : C/K
- ABS fault light on - How do you turn it off?
- fuel pressure regulator
- Need help with jammed door lock!
- Rear noise
- For Sale
- Looking for a good online performance parts shop
- silverado brake light switch
- R&D Automotive
- I wanted to buy the 04 Z71 Tahoe but I heard
- Leveling
- removing front door panels
- 1999 K2500 454 4WD Suburban Air Injection Noise On Start Up
- 2000 Suburban A/C and front end ?'s
- 88 Front End Went KLUNK Makes Noise Driving, NOW WHAT?
- low idle
- no spark
- Should 4x4 be engaged every once in a while
- where is trailer towing harness located at front of truck on 1998 chev c-3500?
- engine misfire
- 89 c/k 2500 4x4 has no heat
- tahoe
- Changing Auto Tranny fluid and filter-do I need special tool?
- '91 K1500 dies in reverse
- 2001 silverado door lock has jammed
- Fuel gauge problem - help.
- Hard to start after warmed up and sits for 20 to 30 min's
- ,01 rear glass defroster cnnection
- rear knock on '01 2500
- 96 Tahoe Manual 4WD not engaging
- clanking noise rear of truck
- hard to start cold
- Original GM Service Manuals
- L/outside mirror double vision
- Money To Spend
- Aftermarket Brakes-'94 2500-454???
- Westers chip Vs. Hypertech which is better
- sliding rear window
- Help: ABS and Brake Light ON
- Programming remotes 1999 K1500
- 2003 Seat Bolts
- 95 chevy low rough idle
- clicking in dash sound
- I'm completely new, help me out??
- interior upgrade
- 95 Tahoe front axel lock mod
- Transmission on 1993 Z71
- Suburban 4W AUTO mode
- headers
- airbag disabled
- Tahoe with no daylight running lights
- 2001 Tahoe won't start after turning off engine
- My 2000 Silverado won't start
- Sunroof
- big clunk noise after turn off.
- 2001 Headrest removal
- 2000 four 4 wheel drive turning problem
- Steel Braided Brake Lines (help)
- removal/re-install of factory radio
- Front Brake Rotor Failed
- fuel pump fuse
- Mysterious idle problem
- Bose Audio
- Cold engine start
- Rear differential leaks
- Anyone Have A Plow On Their Tahoe?
- stereo codes
- 97 Suburban build sheets
- Chevy starts then dies
- Headers
- Service Four Wheel Drive Message
- Heat then No Heat
- Rear Main Seal on 99 Suburban
- keyless entry programming
- Need help with this noise!
- 95 "Service Engine Soon" light
- Water leak in passenger footwell
- Problem with my 4-wheel drive
- remote start for 2003, and stereo
- 350 Rebuild idle problem
- '96 Suburban...need help.
- 98 tahoe "bump & clunk" drivetrain problem
- Overhead Console
- 1996 GMC Jimmy w/ Blown Engine
- hard starting 1990 suburban
- 96 Tahoe 4dr door panel removal?
- HELP! Need help on programing Please
- gentex mirror temperature
- motor swap
- check engine light
- jerking
- 89 Chevy wiper nightmare
- engine noise, sounds like lifter noise
- 1998 K1500 engine light
- Vibration at 90km / 50 mh
- 2002 Z71 Surburban buzz noise in dash
- 2002 Tahoe - Supercharger?
- My Tahoe is having an acceleration issue
- Very long time for heat
- 96 Tahoe Rear Differential Problems
- EGR unit on silverados?
- Transmission: Reverse Lost and Steerings Problems
- transmission
- 89 Suburban problem
- CD Player
- 2002 Silverado with 5.3 liter Vortex
- a couple of minor problems with an 86
- 4x4 trouble, please help.
- Won't Start
- ??? anybody running a 160 stat with hypertech tuner?
- P452 DTC after Replacing Fuel Pump
- rearview mirror compass problem
- Where is the keyless entry control located?
- Looking for '04 silverado tail lights
- Help !! Truck is showing codes 36,33 & 78
- clicking after intake gasket repair(97 silverado)
- passenger side dash
- Analysis of Tahoe complaints at NHTSA
- Won't start
- electronic cooling fans
- 99 Tahoe heater blower
- Relocation
- did search,97 tahoe programing ?
- Has anyone used this for lift?
- '99 Tahoe
- suburban woes
- Two other sweet truck forums
- Right front brake is squeaking
- 2003 First Mods??
- Anyone have wiring for power seats 2000 silverado
- Remote Start
- 99' Tahoe Oil Pressure and Steering Problem
- Right rear turn light out
- 2000 Suburban Brake Failure
- Tire Tread
- 2000 LT interior noise
- 1995 Silverado Exhaust???
- Idle arm/ Pinon arm replacement
- P0446 Code
- Spray Liners
- Cooooold air intake
- Head Lamps won't work
- PDA-Dyno™ & OBD II Scan Tool
- Remove Tahoe Headlights....How?? Please!
- 2003 Tahoe Performance
- Small Emissions leak 99 silverado
- jerking suburan
- 2000 siverado stepside bed rail caps suck
- questions for Carmelfrapinator
- Shifts out of gear on inclined stops
- Aftermarket CD player
- Cam Upgrade?
- More Power?
- PLEASE HELP - 88 Burb - Intermittent Vibration
- Po442
- 2000 Limited Tahoe Differential Fluid Change
- 305 into c-10
- tsb question
- 04 Suburban Help
- Temp Select Switch
- 2002 Silverado
- Need help disabling auto locks
- Where is the oxygen sensor ??
- "seervice engine soon " light
- 99 2500 7.4 L Hard Start
- Suburban 1985
- Racing Trucks
- brake pedal goes to the floor
- 2003 radio question
- 1997 Chevy Truck igintion problem
- Gas Tank
- 88 G-van stalling??
- ??? on esclade gauge cluster?
- I am looking for a Wiring Diagram for 97 Tahoe
- Speaker Boxes
- Buying a 'Burban, what to look for? (Trouble spots)
- 2003 Silverado JVC head unit install - OK
- New Wiring??
- 01 slower than 99 5.3?
- More 1996 C3500 starting/electrical problems
- 89 suburban stalls
- Vibrations
- towing an A/T Van with a tow dolly?
- 01 tahoe LS questions
- Contact the EPA about your injector problem
- best oil additive?
- aftermarket radio
- power sterring fluid
- 1993 Suburban Amplifier wiring help
- dash removal - cd player install
- Cast Aluminum Oil Pan
- Cams
- Anyone need Rear Rotors? Brand New?
- Throwing a 44 code
- worried about high mileage
- Smog/Non-Smog Legal Heads?
- Bright Lights Question
- hard starting and rough idle
- Cold Air In Passenger Compartment
- Awesome forum www.gm-trucks.com
- 01 Suburban Lights Dimming (Different than post below)
- What the....? (can't set timing)
- 2000 door lock left side switch & remote not working
- Belltech drop kit
- Lights Dimming
- axle problems w/ lifted 99 chevy
- Fipk or programmer?
- changing spark plugs?
- Heater Control
- brake/transmission interlock
- front differential doesn't engage
- Looking for OEM GM fender flares for a 99-04 Pewter
- Where is the pcv filter on a 99 5.3?
- 1988 brakes
- HP & TQ on an 89-5.7L?
- shift clank
- Service Engine Soon
- Electrical Issues with Heater & AC
- Engine Misfire
- Fuel Pump loud
- How to replace fuel filter?
- Help finding the yr and model
- program keyless remote 2001 tahoe
- Change climate control from manual to auto
- Help...Kill Switch Install ??
- 99 Silverado towing/trailer lights
- Water Leak- Cargo area
- slight knock/ping during acceleration
- 95 Tahoe locks automatically
- Hot Start?...
- '99 Silverado 5.3 Starts, then dies
- Lights and locks
- 91 chevy V-6 rough idle and rough running
- " Z " height range 2003 Tahoe
- P R N D 2 1
- More stall
- 1 ton turbo diesel transfer case fill plug?
- CB install with SWR meter
- trailer wiring
- Any Bad Auto Trac push button 4x4's?
- Vibrations from 15 mph up?
- Heavy Duty vs Z71
- Heavy Duty vs Z71
- 1989 suburban info
- Temperature Gauge
- Heater not working
- Slight knock when accelerating
- new member
- chevy heater cores
