View Full Version : C/K
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. 89 C2500 manual transmission problems.
  2. 1995 c/k pickup: Engine studders and has coolant in oil. Blown head gasket?
  3. 1995 c/k pickup: Engine studders and has coolant in oil. Blown head gasket?
  4. 1995 c/k pickup: Engine studders and has coolant in oil. Blown head gasket?
  5. 1995 chevy pickup studders when started and has rusty-like oil
  6. 1988/1993 silverado c1500 electrical gremlins
  7. 94 Chevy Air Conditioner Problems
  8. hard cold start
  9. U-Joint Leaking?
  10. Outside Driver door handle removal
  11. TPI to Carb
  12. Exhaust
  13. 89 c1500 5.7 starts then stalls...
  14. What is going on with my tranny?
  15. I need to see what a fuel filter is supposed to look like!
  16. 79 K20 rattling noise at full throttle, idling too high
  17. vibrating 95 Z71
  18. fuel pump pressure
  19. 1998 Gm K1500 Leather Seat Upgrade
  20. 73 Custom Deluxe "Ratcheting Noise"
  21. 1996 K1500 - fuel pump LOUD
  22. 1996 weird sound - possibly exhaust?
  23. 97 chevy 1500. how big of tires will fit?
  24. 97 chevy 1500 - bad brake booster??
  25. Tranny Leak, Speed Sensor
  26. rebuild trans
  27. 1988 Chevy Truck
  28. release parking brake shuts truck off
  29. ODB2 question
  30. 1996 to 1998 305 vortec sensor ?
  31. ram jet swap?
  32. Brake line replacement?
  33. Early-mid 90's serpentine alternator bracket?
  34. 88 chev pu 1500
  35. cant shift out of park
  36. Removing Bed
  37. 94 k3500 no brake lights!!
  38. 92 Driver Window Problem
  39. Ignition trouble?
  40. 1999 454 E85 Upgrade?
  41. water 4 gas on a 1998 K1500
  42. trailer hitch
  43. Tensioner idler pulley
  44. Vacuum Leak Possible?
  45. Lights on tailgate?
  46. RFI Filter Fuel Pump
  47. Blower motor dying?
  48. ABS Light
  49. HVAC Blower will only blow on floor ?
  50. Need Grille for 88 Chev PU
  51. 98 3500 HD tow truck rear end help
  52. 92 C1500 Won't Idle....help
  53. no spark
  54. 1988 Chevy C1500 break lights stuck on w/switch removed.
  55. Surging when going into drive
  56. Surging when going into drive
  57. k10 vin location
  58. engine stall
  59. 98 Z71 Check Engine/02 Sensor?
  60. Heater / AC control getting reset ?
  61. 1997 chevy transmission problem Help
  62. intake system
  63. Gas Mileage 5.7L automatic K1500, 4WD
  64. 1995 c1500 truck lowbeams won't work
  65. Rear axle weight rating?
  66. tps
  67. Anyone know anything about retech fuel pumps?
  68. Brake / Steering Shudder
  69. 1990 Chev 3500 350 tbi idle/off idle missing
  70. AC causes low idle / stall
  71. Whats the best way to change fuel pump on my 98 crew cab 3500 Dually?
  72. tranny fluid leaking through thecenter of the tranny yoke!
  73. Park Brake Adjustment
  74. 1998 C3500 7.4L trouble starting...Fuel Pump??
  75. 98 Z71 Won't start unless gas poured in TBI
  76. clutch adjustment 95 k1500
  77. '94 chevy truck intermittent problem... !
  78. How to replace Ingnition Switch 1990 C2500
  79. Transmission Conversion
  80. Strange problem - lack of power 30 seconds after startup
  81. rotor size question
  82. Tranny Shifting Problems?
  83. 1990 Chev truck K2500 4x4
  84. 1988 Chev 350 5 speed
  85. trans. qestion
  86. 1996 c1500 brake lights .......please help!!!!!!!!
  87. 1996 c1500 brake lights .......please help!!!!!!!!
  88. 89 K1500 Stalls in reverse
  89. Shift indicator cable Replacement in 90 Cheyenne
  90. 94 c1500 700R4 compatability
  91. P0420 Code
  92. Sensor, Ground, or Tansmission?
  93. Fuel pressure drop after 15 minutes
  94. Code 32
  95. Heater A/C Control Unit
  96. Im leaking!
  97. 98 Z71 No acceleration when pedal to floor
  98. Harmonic noise @ 45
  99. 98 silverado trans prob
  100. Lower Intake Manifold Gasket
  101. 96 K1500 fixed hesitation/loss of power
  102. 95 2500 4x4, What Brake system do I have?
  103. 1998 motor in 1980 chassis
  104. temp gauge gone wild
  105. K Vin Compares to R Vin
  106. EFI Fuel Pump Question
  107. 1990 chevy 1500 overheating problems
  108. ABS Light ON- How do I diagnose it?
  109. 4x4 grates
  110. 95 Chevy Truck (Minor Wobble)
  111. 89 chevy 1500 Fuel Problem
  112. 1993 Chevy 5.0 no spark
  113. 90 K1500 starving for gas, pops code 43 off and on
  114. lowering
  115. 95 Chevy 1500 (Fan Connector)
  116. engine swap
  117. 2000 Chevy 3500 misfire
  118. 96 K1500 Engine Replaced(Carb), no tranny downshift
  119. 93 chevy, 5.7L acts like its running out of gas
  120. Best Towing Improvements/Mods
  121. 96 1500 Acts like Brakes are on
  122. Oil in coolant
  123. Engine Restore
  124. 93 c1500 tranny trouble
  125. Re: Engine dies
  126. Rough idle and hesitation 92 chevy 1500
  127. Brakes?('91 C1500)
  128. Big Clunk when taking off?(91 C1500)
  129. Looking for a extra capacity transmission Pan
  130. Chevy 6.5 turbo diesel Truck wont start
  131. 97 Z71 starting/starter problem
  132. Trailer Wiring + Brake Controller
  133. 88 Motor mounts
  134. 96 k1500 running rough/engine codes..need help
  135. 97 C1500 Stalls/Rumbles
  136. 97 Chevy intermittent stalling and cutting out
  137. moving drivetrain foward about 3" in 78 c-10 pickup
  138. dually conversion?
  139. Questions for those with lifted trucks...
  140. Automatic to Manual Trans Conversion
  141. How to Disconnect Trans Cooler Lines
  142. Turn Signal Switch Help Needed
  143. help with installing headers
  144. 92' K1500 stalls at idle
  145. Clean under the valve covers?
  146. K25 suburban manual to Automatic swap questions
  147. Matching up O-Rings
  148. 89 700r4 2wd to 4wd conversion
  149. 88 silvarado oil pressure sending unit
  150. rear running lights bad
  151. 88 Chevy Truck
  152. Transmission question
  153. The dreaded question A/T
  154. Are 350's intergangeable?
  155. Question For the shade-tree Mechanics...
  156. 88 k1500 305 code 43?
  157. tranny fluid
  158. Numbers on Rear view mirror
  159. HELP! 1997 350 vortec p305 misfire
  160. ac clutch
  161. What's the difference between...
  162. Right way to clean a Throttle Body?
  163. 454 Headache
  164. Engine Paint Questions...
  165. Engine Paint Questions...
  166. 1990 5.7L 1500 - codes 32 43 44
  167. 1990 5.7L Silverado - Engine Image wanted
  168. Droplets of "water" in left exhaust pipe???
  169. Stalling w/ no forewarning - 2500HD
  170. Ignition Timing
  171. Average Operating Temperature...
  172. Quick Knock right at engine start up..
  173. Fuel Pump Issue?
  174. 88 c1500 stalling on me
  175. Cams for my friend
  176. Suggestions Wanted for Engine Compartment Clean Up...
  177. 93' 5.7 seirra stalls when accelerating
  178. tranny filter for turbo 400 tranny
  179. Trans Filter Seal - Nightmare, Help? 4L60/700R4
  180. 89 4X4 1500 Transmission Leaks
  181. exhaust changes
  182. 1996 Dist Cap and rotor problem
  183. 1993 c1500 -- Low beams OK, Hi beams nothing
  184. 1993 c1500, 4L60E Transmission -- No 2nd gear
  185. Check out what the dealership told me...
  186. I need a wire harness
  187. Computer on 1995 K1500
  188. 98 c 10 4.3
  189. Rear Hitch
  190. 1990 c3500 tranny pan?
  191. Scanner / Decoder Question
  192. 1994 Silverado P/U - Brake Job
  193. Only 1 Push Rod is Squirting Oil
  194. 1990 305 High Idle Now Wont Start
  195. 1989 k5 blazer
  196. Question about OBD1 on 95 K1500
  197. vortec changeover
  198. Question about my guages on my K1500
  199. Headlight problem
  200. Wont Start After Running
  201. read end troubles
  202. Door Hinges
  203. ne1 convert manual 2 power windows 2 look OEM stock
  204. no fuel
  205. 98 5.7 gmc stumbles code P0404
  206. 95 Chevy 1500 (Replacing Balljoints)
  207. 1995 C1500 Died
  208. dash light problem
  209. 1997 5.7L 350 tune-up??
  210. gonna be buying a new truck...
  211. grinding transmission? or what?
  212. 1995 k1500 transmission swap
  213. 92' K1500 Stalling
  214. How to set ignition timing for a 1990 silverado chevy c1500 305 engine?
  215. Another axle question
  216. Stiff steering after repair? Normal?
  217. How much can I tow?
  218. Fuel Pressure Problems
  219. Code Scanner
  220. After-market tach install c/1500
  221. 1998 chevy 1500 trouble codes?
  222. Front Seat Rails
  223. Wheel size for 96k1500
  224. snappin CV joints
  225. Now here is a head scratcher
  226. Front wheel sensors
  227. brake pedal problems
  228. rebuilt trans
  229. Changing out 5.0 vortec for 5.7 vortec?
  230. How do I change the hi/lo beam switch?
  231. 1990 454ss
  232. fuel pump wont pump
  233. what tranny do I have
  234. Oxygen Sensor going bad?
  235. installing aftermarket tach 1984 V8
  236. cold start, bucking and missing, '89 305cu.
  237. heater box/heater core?
  238. 93 chevy bed
  239. 97 vortec 5.7 question???
  240. Just wondering: Transfer case interchange?
  241. 1989 c1500 airaid intake
  242. trans problem
  243. Weird hickup on 97 1500
  244. 4L60E Problem, Different than any I have seen
  245. 68 c10 transmission question
  246. Defrost/Vent Damper
  247. looking for 40/20/40 seats for 95-98 pickup
  248. Diesel VS. Gasoline
  249. `94 6.5 turbo diesel - glow plugs cycle off too fast.
  250. Power steering pump cavitation
