View Full Version : C/K
- dome and cargo light grounds
- erratic temp
- 700r4 4x4
- 1970-85 Chevy Van questions & parts needed
- 94 c1500 transmission shifting problems
- 1994 c1500 brake problems
- 4.3 Valve Seal Replacement
- Help! what is this ticking?
- 94 c1500 transmission question
- 1995 C1500 sputtering/bogging issue
- oil pump???
- 1990 Chevy Silverado - turns over, but won't start - checked the obvious
- 98 k1500 engine problem
- Hydraulic Slave Cylinder/Throw out bearing
- 1993 Chevy 1500 transmission problems
- Hydraulic clutch line options
- electrical issue
- stumped
- W/T 1500 Engine Swap
- spindels
- Engine stumbles after small throttle inputs
- Painting grill
- Exhaust manifold gaskets not holding.
- Front diff pushing fluid out vent tube
- Low Beams Dont Work
- 96chevy shutdown issue
- 1986 Chevy K-10 won't shift into overdrive
- 1989 Chevy c1500 5.7l 2wd 1/2ton EMERGENCY/PARKING BRAKE PROBLEM!!!!
- 1995 chevyc/k1500 transmition clicking noise
- 1998 k2500 4x4 fuel pump problems
- 98 C1500 5.7L Fuel Pressure (Won't start)
- 4WD doesn't engage Thermal Actuator
- 1994 1500 dies at idle after warm
- 2000 Chevy K3500 start stop
- Truck won't start for 15 minutes following shutoff
- Low engine rpms, intermittent stalling.
- '91 C2500 stock stereo issues...
- 94 C3500 7.4l 454 trans jumps in and out of gear
- 1999 K3500 brake problem
- 2000 K2500 Turn signals
- How to hookup fuel injector tool for cleaning injectors
- Looking to purchase a PU, any specific places to check for rust?
- 1999 Silverado Brake Issue
- Hard shift clunking 96 chev 4x4 cheyenne
- Clock problem driving me crazy
- 4L80-e Trans slips after going into overdrive
- 1995 chevy c/k1500 4x4 actuator problem
- 1991 Chevy C/K 1500 Wont start
- trouble with chevy
- 88 k1500 transmission
- MT 2500:) 99 5.7 cuts out only at 3000rpm
- 94 K1500 4x4 camshaft/oil question
- 97 chevy 1500 2wd extended cab
- new ignition switch w/ accessory position for a 66'
- 1997 3500 pickup 5.7
- 97 5.7 timming off dis. gear worn out
- harness ?
- 2000 K3500 7.4L Hard start
- 4l80e no upshift 1995
- p1406 code on a 1997 5.7 4x4
- 97 k1500 wont engage back into park
- How to replace a rear seal on a 4L60E trans
- C2500 trans line repair?
- 96 Chevy Cheyenne speedometer stopped working
- Ghost Code 44
- 350 running rich
- 1996 K1500 4l60e trans. Skips second gear
- 1995 C1500 Silverado seat belt issue
- 89 C1500 Extreme high mileage oil question.
- 94 chev pu 5.7 liter code 33
- 92 K1500 problems/"gutless"
- 94 K1500 strong gas smell......again
- centering steering wheel
- 88 Silverado Heater gone bad.
- 2001 2500HD hard shifting
- vortec 5.7 really doggy, sucking down fuel, please help!!
- rear door won't open
- Time to FIX MY STICK!
- 99 K3500 diesel shift problems and DTC P0751
- Spare Tire Size
- WTB Throttle Body Spacer
- 1995 GMC K1500 4x4 P/U - Compressor
- 1995 GMC K1500 4x4 P/U - Starter
- wont run
- 96 C3500 5.7 Hard Start
- 97 5.7l runs a little rough on idle
- chevy cheyenne WT k1500 grille???
- 4l60E loses 1st gear & won't shift automatically when hot
- AC bracket in the way of intake mainfold
- 700R4 high RPM shift problems
- 1995 GMC K1500 4x4 P/U - Heat
- Anybody here swapped an LS motor in a 96-98 C1500???
- acceleration problem
- Security,starts then stalls?
- 96 K1500 shudder at hwy cruise
- 96 K1500 brake line
- 1995 GMC K1500 4x4 P/U - Cruise
- 91 floods out
- 1995 3500 stuck in second gear
- is a electronic ignition better??
- 1981 c20 pulls right when braking
- 96 4WD wiring problem
- 6.5 TD Non Start
- ABS Light Always ON 1996 Chevrolet Cheyenne 4x4
- P0336 crankshaft sensor code issues
- Change headlights? 1996 Chevrolet Cheyenne 4x4
- 1995 C1500 Silverado electrical issues
- Help need FAST!!!!! Pickup wont start
- which intake gasket kit for a 97 5.7l
- 95 gmc neg. battery cable issue
- 94 K1500 hesitation and flooding?
- '94 K1500 Transfer case ?
- weather stripping problems or door bent
- inner tie rod change
- Autozone reman. steering gear boxes - don't buy
- composite vs sealed beam lights
- k1500 steering drift
- Groaning/Moaning Noise (1998 Chevy C1500)
- Another Electric ,Fan conversion post
- starter problem maybe?
- Trim Beauty rings.
- Bench seat swap to 60/40
- Finally Done!
- 1989 1/2 ton 2wd cheyenne lost all electric
- grille guard modification
- Brakes went kaput
- 16 bent pushrods
- ABS and wheel speed sensor
- curtesy and dome light problems
- brake reservoir leaks
- front end problems
- New headers... i'm starting to get nervous
- 98 Chev Vortec 5.7 Misfire
- 1999 C3500 Misfire
- how to finish my exhaust
- O2 sensors???
- 1996 chevy homemade air dam/valence
- 89 C1500...spongy brake pedal
- 94 C1500 front end lift torsion bar?
- '89 C1500...radio question
- 92 C1500 fuel pump
- 92 Silverado High Idle
- Missing at idle only 88 5.7 k1500
- ground locations
- Help needed in buying rims for my 35's
- 92 C1500 "TPS too low"
- chevy AC problems
- painting my wheel wells
- window tinting????
- 1994 C-1500 wiper problem
- wiring for trailer 05 chevy
- 1995 K1500 EC - Rear drum brakes
- 1999 v6 Chevy Silverado won't start
- 1996 350 =Best water pump?
- Erratic idle '87 Chev injected 383..
- 1995 K1500 EC - Brake line
- 1996 chevy k1500 ignition switch problems
- A/C quits working when it gets 90+
- air blower problem
- 2000 k3500 door hinge bushings
- Transmission fluid question
- 1996 Chev 1500 K 350CID Cruise Control Part
- fuel pump problems????
- stock 1991 4.3L bent a pushrod?
- 88 k1500 stalling problems
- 1985 Rainbow RV on Chevrolet Chassis... HELP WITH MY BRAKES PLEASE!
- new shocks??
- 99 chevy k1500 z71 no fire
- Lack of power problem with 92 K1500
- 1998 K2500 tach problem
- chevy 1500 4.3 problem
- Transmission Question
- 1996 chevy fuel pump without power
- How do you remove the front rotors on a '96 Chevy 3500? Diagrams would be helpful.
- 1996 chevy exhaust modification
- driving on 7pistons
- 94 K1500 4x4 A/C comp. noise
- k 1500 stalled, fires with ether
- 1996 cheyenne dome light and 3rd brake light problems?
- 1996 chevy cheyenne ignition setup
- Prob with the 97 4wd upgrade kit
- 96 Silverado A C Control head unit ?
- 1998 C1500 Silverado 3rd Brake light problem
- 96 chev ac does not blow hard
- tires
- dual cherry bombs exhaust system
- welding fabrication project for my truck
- looking
- remote keyless entry
- 94 chevy 350 needs some help
- actin up when temp hit normal opperating
- 94 k1500 4x4, strong gas smell underhood
- 94 PU running after parked won't start
- 79 truck is calling for help
- 92 chevy 1500 TPS circuit
- 93 k1500 running flat in midrange
- ignition control switch?
- Engine swap
- Intake coolant fitting
- A/c inop
- throttle body spacer on a chevy 350
- '91 C3500 crappy mileage
- 94 K1500 4x4 erratic idle
- Distributor cap
- Transmission Noise
- o2 sensor manufacture
- Vertical doors
- Ease of adding A/C to C1500
- Hard starting
- swapping a np8 into a np2
- 94 k1500 stalls at take off
- pesky top shock nut
- Has anyone put a 4l80 from a 454 behind a 6.5 diesel?
- 98 k1500 a/c heat vent control problem
- 1981 c20 tbi swap no injector pulse HELP!!!
- Rear differential
- Brake Problems on '90 C1500
- 95 k1500 wont start. wont even try to turn over HELP!!!
- G80 rear diff
- Service Engine Soon Light
- How to fix large dent
- 2000 c2500 5.7 cel
- 95 chevy 350 with throttle body, is both injectors supose to be spraying ay idle
- Slow to come out of 4x4
- 1998 GMC K2500 5.7L fuel pump question
- 94 4.3 rocker arm studs
- Oil leak from Distributor shaft??? 92 Chevy Truck
- Code 44 Lean Exhaust '88 K1500 5.7 TBI
- 96 5.7 ltr timing off
- 1990 k1500 ignition problem
- Electric window problems
- Sticking door window
- 9500 K2500 Transmission Problems! Help!
- 91 chevy k1500 misfire
- Intake problem?
- 98 k1500 4.3 manual trans high idle problem??
- everything all at once...
- 1007 1500 w/305 Vortec blowing ecm-i fuse and coils
- 92 Chevy C1500 Running Rough
- 96 Z71 extended cab engine removal with manual trans question
- No wipers, A/C blower, power windows, no TC lockup, and ABS light on
- Pros/Cons putting 2500 suspension on 1500
- 6.5 diesel wastegate question
- Transmission Questions
- 2000 Vortec 350 Roller Lifters
- Blend door in 94 chev pick up
- hellp stuck in 4wd
- 97 Chevy wont shift into 4wd
