View Full Version : C/K
- 5.3L Dyno Disappointment
- New Shocks and Fuel Pump
- Z71 vs. F-150
- wiring problems
- Changed oil on 04 Tahoe, longer filter used
- dashboard in a 95
- Downshifiting out of overdrive
- Bad cam or bad lifter,how to tell
- Hypertech Rev Limit: 04 Silverado engine redline?
- Are Headers Reliable These Days?
- Dual Exhaust?!?!?! Which Kind?!?!?!
- Just bought a 99 2500
- 96 suburban won't start
- State emmissions test failure
- how loud?
- 4wd noise from a 97 Tahoe
- 96 Suburban right, and rear spkrs stopped working
- PLEASE Can't someone help with motor swap
- Bucking Under Power
- Hypertech programmer for sale for 2001 silverado's and tahoes!!!!!
- 2001 Suburban Stalls Intermittantly
- Getting ODBII codes P0172 and P0175
- Silverado Problem
- Need Air Conditioning Help (97 1500 Sub)
- 03' and 04' Fog Lights ?
- Speed sensitive steering on the fritz!!
- need front diff parts for my 93 k2500 BURB
- Need wiring diagram
- looking for a step side bed
- Transmission ?'s (Temp guage & shift problems)
- Inside Door Panal
- 2001TahoeTRANS PROB...
- towing, 2wd vs 4wd
- Gas mileage
- oil pressure flux
- water leak?
- Engine Timing Issue?
- 89' 350 TBI running rich when cold
- 1996 k1500 fuel pump issues
- E85 Engine
- Golfball size hole in rear differential cover help?
- Tire size question?
- Need TSB #01-08-56-004A
- removal of dashboard in 95 1500
- Rear End Question
- 2001 rear window hinge problem
- Bucket Seats Source
- 92 1500 hesitates
- 02 Tahoe - Does Factory Radio have pre-amp outputs?
- 3/5 drop
- SeTTiNG VaLVeS & Distributor
- 1997 5.7L quit running
- New Hypertech! need 180 stat?
- Suburban Brakes Suck
- PVC Valve Location / 2000 Silverado 4.8 ltr
- Good brand of Brakes for 99 Tahoe
- Off Road Lights?
- Service Engine Soon On after I changed Sparkplugs
- Are differentials from 99 Tahoe and 2000 Chevrolet Pick-up interchangeable?
- 2001 tahoe- trouble starting
- Changing out Ext. Cab Window
- Suspension Lift
- got beat bad:(
- 1988 chevy TH375
- Fuel Sevice 2000 Z71 5.3l
- Add DVD to '03 Tahoe
- Brake Squealing on Corners
- ABS light sporadic
- 2000 Chevy Silverado
- First SES question
- Factory radio removal
- Clear the CLN message on radios with remote cassette on 1996-2002 Chevrolet/GMC truck
- unbalanced 454 hurt trany?
- No gas on May 19th
- More Cruise/Brake light problems
- Steering wheel vibration
- Tire Size
- A/C Compressor not engaging
- Strange ticking sound when I accelerate
- door seals on 89 suburban
- 2002 Quadrasteer won't start.
- Does the 2004 Tahoe 4.8 have a 4L60E transmission?
- 93 CD Player install/Radio removal
- Starter just clicks
- Humming sound
- sputtering when cold
- Gear swap
- new speakers
- abs problem
- irratic fuel guage
- 1995 305 to 350 swap
- Exhaust
- air intake
- 1996 Tahoe Transmission Problems?
- Starts and dies
- Another "start" problem
- reprograming a keyless remote
- Silverado VSS?
- Need Help Fast!!
- When to use tow haul on 01 z?
- Code P0430
- 99 silverado ABS and random brake warning light
- 99 Silverado
- What Type Of Oil
- Hard Shifting
- City fuel mileage
- '04 shifter
- 1988 350V8 TB SWAP FOR A 70's 454V8 Carb MOTOR
- 98 silverado
- 1988 silverado 5.7 engine and towing specs
- Oh, here's my truck
- Slam when stopping
- 2004 Chevy Silverado 2500HD
- Rubbing noise coming from wheels/axle
- 1994 Chevy Blazer K1500
- 01 tahoe with 03 xm head unit??
- Transmission Problems
- 77 c10 knocking
- Bad things about 180 thermostat??
- 96 sub won't start
- Trying to find timing.
- Sirius Satellite Radio hookup problem
- Engine cranks and dies immediately?????
- biggest tires??
- C1500 vent system knocking
- rear view mirror on stable door
- 2001 suburban tail/brake/turn lights?
- Flat towing 85 K 5
- Rebuilding 350 TBI NEED HELP
- torsion bar swap, anyone done one
- Steering column question
- Poor fitting pillar trim on passenger side (2003 Tahoe)
- 2003 Tahoe Mirror Memory problem
- newbie needs some help please
- A-Pillar Tweeters
- 99 Sub. Melting Positive Lead on Battery
- 98 tahoe won,t start after sitting 2hrs
- radiator leaking
- 1999 Tahoe No running lights
- 96 Z71 High Idle Problem
- backfiring problem after installing headers
- 89 Phantom grill
- 85 full size Jimmy 350 problems
- 93 Suburban stalling
- Stock speaker upgrade
- HELP!!, unknown squeaky noise!
- Suburban stuck in 4LO no switch lights
- drivetrain or transmission maybe
- '01 tahoe stats...info websites?
- teansfer case
- 96 Suburban check engine bulb replacement
- 88 K5 TBI 350 (Code 32)
- rear a/c blowing hot
- 1998 Tahoe P0102 code - please help
- Throttle Body Spacers
- 1992 Silverado overheating
- Rattling Dash/Door Panels
- Power/Speed Loss?
- swapping engines
- I Want a Silverado
- I'm new
- air filter mods
- leaking heater control valve...
- 2001 Silverado Headlights don't work !!!
- anti-theft radio,unlock
- Any suggestions for 04 silverado
- recharge a/c
- 2003 Tahoe won't start
- torsion bar lift/turn up, lift kit questions and facts
- 1998 Silverado Fuel Pump
- 383 stroker(crate motor)
- 1990 Engine swap Help?
- 1997 K1500 new 383 motor w/air ratio issues
- 88 Burb Code 45-Wits End HELP!
- seat covers
- Barn Door Automatic Lock
- In need of help
- Lights in AC Controls
- 89 Sub leans to the left
- Speedy for a truck.
- wont shift without help
- Where to get a cool aftermarket Grill and Bumper? I need to Replace Both & some light
- Tailgate assembly
- Instrument panel fuse blown
- Can not change location where air blows
- 99 Tahoe Cam code P0304
- Any Ideas?
- 2003 Tahoe Memory seat problem
- 99 Suburban electrical cut out
- 2004 Tahoe tire lock lug
- 99 Tahoe DRL
- NO Starting when hot!! Passcrap?
- A few questions from a novice :)
- re-programing?
- ABS Light and Turn signal went out Can someone Help??
- What kind of gas mileage do you get with your Tahoe?
- holes in roof
- secondary air check valves
- Replacing back door on 85
- 1998 tahoe transmission
- Motor Swap
- Stainless Exhaust Prices
- 96 Silverado Center Console
- Keyless Entry for 95 year model
- 89 4.3 Coolant Leak
- rear window limiter?
- No Brake lights on 98 K1500
- 98 Silverado Starting problem
- Squeeky Noise
- Starter issue / need help
- 99 Chevy Pickup Brakes
- Power steering problem 99 Silverado
- cats need cutting?
- **FREE Duraliner Bedliner for Silverado 6ft in CT**
- 2003 Automatic Transmission Clunk
- Engine won't start for me, but starts for service techs
- trailer harness connector 2000 suburban
- Won't start after driving through deep puddles
- Stereo upgrade
- JET Performance Chip for 1992 K1500
- choosing a suburban
- 20's on 94 2wd suburban
- 2001 chevy c1500 alarm sticks
- Does your dash clock reset itself ?????
- 91 k1500 4.3 to 5.7 motor swap?
- 1995 Silverado rear seat
- filter inside cab
- Take time to shift
- Fuel Gage
- Pre-Bent Brake Lines 91 G20 Van
- engined governed
- Broken Speedo and brake light
- back window smashed, what will fit?
- 1974 350 Chevy small block
- 1999 lesabre a/c freezes
- Which bars for a Tahoe with a 3" bd lift.
- oil cooling lines '99 k1500
- Engine Missing after head gaskets
- What are these ports for ?
- Timing chain 99 silverado
- 89 350 tbi surges under 2k rpm
- sterio sound improvement
- 350 Silverado smokes at start up
- 88 diesel suburban cranks but doesn't start
- 99 brake light failure
- 99 Z71 Extended cab Window adjustment.
- Trans cooler and temp guage
- Front Disc Brake Will not Retract
- driveshaft noise and vibe 99z
- Lacking power
