View Full Version : C/K
- newbie needs some help please
- A-Pillar Tweeters
- 99 Sub. Melting Positive Lead on Battery
- 98 tahoe won,t start after sitting 2hrs
- radiator leaking
- 1999 Tahoe No running lights
- 96 Z71 High Idle Problem
- backfiring problem after installing headers
- 89 Phantom grill
- 85 full size Jimmy 350 problems
- 93 Suburban stalling
- Stock speaker upgrade
- HELP!!, unknown squeaky noise!
- Suburban stuck in 4LO no switch lights
- drivetrain or transmission maybe
- '01 tahoe stats...info websites?
- teansfer case
- 96 Suburban check engine bulb replacement
- 88 K5 TBI 350 (Code 32)
- rear a/c blowing hot
- 1998 Tahoe P0102 code - please help
- Throttle Body Spacers
- 1992 Silverado overheating
- Rattling Dash/Door Panels
- Power/Speed Loss?
- swapping engines
- I Want a Silverado
- I'm new
- air filter mods
- leaking heater control valve...
- 2001 Silverado Headlights don't work !!!
- anti-theft radio,unlock
- Any suggestions for 04 silverado
- recharge a/c
- 2003 Tahoe won't start
- torsion bar lift/turn up, lift kit questions and facts
- 1998 Silverado Fuel Pump
- 383 stroker(crate motor)
- 1990 Engine swap Help?
- 1997 K1500 new 383 motor w/air ratio issues
- 88 Burb Code 45-Wits End HELP!
- seat covers
- Barn Door Automatic Lock
- In need of help
- Lights in AC Controls
- 89 Sub leans to the left
- Speedy for a truck.
- wont shift without help
- Where to get a cool aftermarket Grill and Bumper? I need to Replace Both & some light
- Tailgate assembly
- Instrument panel fuse blown
- Can not change location where air blows
- 99 Tahoe Cam code P0304
- Any Ideas?
- 2003 Tahoe Memory seat problem
- 99 Suburban electrical cut out
- 2004 Tahoe tire lock lug
- 99 Tahoe DRL
- NO Starting when hot!! Passcrap?
- A few questions from a novice :)
- re-programing?
- ABS Light and Turn signal went out Can someone Help??
- What kind of gas mileage do you get with your Tahoe?
- holes in roof
- secondary air check valves
- Replacing back door on 85
- 1998 tahoe transmission
- Motor Swap
- Stainless Exhaust Prices
- 96 Silverado Center Console
- Keyless Entry for 95 year model
- 89 4.3 Coolant Leak
- rear window limiter?
- No Brake lights on 98 K1500
- 98 Silverado Starting problem
- Squeeky Noise
- Starter issue / need help
- 99 Chevy Pickup Brakes
- Power steering problem 99 Silverado
- cats need cutting?
- **FREE Duraliner Bedliner for Silverado 6ft in CT**
- 2003 Automatic Transmission Clunk
- Engine won't start for me, but starts for service techs
- trailer harness connector 2000 suburban
- Won't start after driving through deep puddles
- Stereo upgrade
- JET Performance Chip for 1992 K1500
- choosing a suburban
- 20's on 94 2wd suburban
- 2001 chevy c1500 alarm sticks
- Does your dash clock reset itself ?????
- 91 k1500 4.3 to 5.7 motor swap?
- 1995 Silverado rear seat
- filter inside cab
- Take time to shift
- Fuel Gage
- Pre-Bent Brake Lines 91 G20 Van
- engined governed
- Broken Speedo and brake light
- back window smashed, what will fit?
- 1974 350 Chevy small block
- 1999 lesabre a/c freezes
- Which bars for a Tahoe with a 3" bd lift.
- oil cooling lines '99 k1500
- Engine Missing after head gaskets
- What are these ports for ?
- Timing chain 99 silverado
- 89 350 tbi surges under 2k rpm
- sterio sound improvement
- 350 Silverado smokes at start up
- 88 diesel suburban cranks but doesn't start
- 99 brake light failure
- 99 Z71 Extended cab Window adjustment.
- Trans cooler and temp guage
- Front Disc Brake Will not Retract
- driveshaft noise and vibe 99z
- Lacking power
- Brake Noise
- 2003 lower front bumper hanging loose
- Do Aluminum wheels require special lug nuts?
- 90 to 94 silverado 4x4 cluster swap?
- 4.8l 0-60
- Ignition Upgrades
- Ford Keys or Torsion bar crank?
- Oil Pressure
- O2 SENSOR REPLACEMENT 2000 z71 5.3
- What Year Motor???
- '90 runs but w/o injetors working
- Cold starts cause engine to make clicking sounds.
- Crystal Clear Headlamps for 2004 Tahoe
- Vibration and Humming noise
- Delco Cd Stereo Problems
- antifreeze
- 1999 tahoe Clicking sound.
- ACDELCO Parts
- Rough Idle-2000 Silverado
- 1979 Chevy 350 HEI 4brl
- Rear End
- electric fan
- Acctual 350 Gas Mileage
- Used Tire Pricing...
- help on buying used silverados?
- transmission
- Anyone ever put H2 seats in their vehicle?
- Hummer H2 seats in an 03 Silverado...? HELP!
- 2001 Suburban 2500 fuel pump replacement
- 1999 Silverado FOB set up
- Headlight Sensor
- Replacement doors
- Ignition Sensor on Clutch Pedal?
- Distributor Cap Arcing ??????
- Spare Tire Rear Mount Add-on?
- 88 K1500 manual 5-speed wear problem
- 93 Suburban Electrical Problem
- aftermarket and warranties
- Steering Knuckle repair
- Lug Adaptor
- Service engine soon light
- High Compression Heads
- Fuel pump/line
- Transmission Backlash?
- My new Truck
- A Little Rear End Oil Change Help
- looking for advice/ shudder problem
- No "real" info....???
- lift kit
- c1500 4.3 to 5.7 swap
- Thoughts on Holley 670 CFM Throttle Body
- RV Cam
- Aftermarket step bar
- Steering Problems
- Is there an easier way to chg fuel filter???
- A/C service procedure for '97 w rear A/C
- specs on 1993 5.7 silverado motor
- Recall Notice!!!!!!!
- 98 suburban, clicking noise in reverse
- Replaceing fuel pump 98 silverado z71
- max tire size for 2002 Silverado 2500HD
- 1998 tahoe trans problem
- tire size
- power window problems
- daylight running lights
- Best shocks...what do you think?
- 99 Silverado Electrical Issue?
- Power window trouble
- '97 Tahoe won't start when wet
- 2004 z71 transmission problem
- Wheel Hop! How do I fix?????
- Towing too much? How bad?
- Wheel hubs bad?
- radio static
- what is normal oil pressure
- Please Help!
- buying new truck...need advice
- fs:lots of parts!!!!
- 4x4 wheel bearing grease
- Fuse Location
- Dashboard Backlight Change?
- Transfer Case Rebuild
- Air Vent Controller...No Defrost
- 97 Tahoe - starter relay; intermittent starting
- delco stereo scv problem, HELP!!!
- Swapping in LT1
- Got a 350.
- Power..
- 2001 5.3L gas mileage/power
- 1999 Suburban wont start
- 160 or 180 thermostat purchase
- headlamp removal on 2001 Silverado
- 1999 suburban fuel pump
- 1999 suburban keyless entry
- 93 Suburban changing a water pump
- XM Radio with 2004 head unit
- XM Radio with 2003 Head Unit
- LS1, LS6, LT1.... What is it?
- My SES light comes on when my Gas tank hits 25%?
- New Gauge installation (HELP!!)
- 1990 GMC Sierra Owners manual
- 89 GMC Suburban revs high
- short problem in my Tahoe
- 1997 Z71 Steering Problem
- oil pressure variations
- Anyone have experiece with Warranty Direct extended warranty company?
- Traction Control on 2wd
- Scratched Rims
- '98 C?K looking to swap 4.3 for 5.7
- Thinking of K&N FIPK and Exhaust for '03 4.3
- 95 Suburban won't reach 195° with 2 new thermostats
- Engines
- Heater Core replacement 1991
- 72 C-10 fuel and tach guage questions
- 4WD Vibration
- Front end locks in 4W
- '95 6.5 L Turbo
- keyless entry
- 97 4.3 vibrating
- Noisey Power Window
- cooling system flush
- gear change outs on a 96k1500 z71
- keyless entry system
- Tire Size 2003 Z71
- Fog Light Install Instructions?
- Power Window Cable Broken...
- kyb monomax shocks
- Pic of Window Regulator
- 95 Power lock actuators? + or - trigger?
- 2003 Back Seat
- 3" lift
- Headers and true dual setup
