Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Avalanche/C&K/Silverado/Suburban/Tahoe
> C/K |
View Full Version :
C/K
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
1990 Surburban rear window tailgate problem
coolant leak
tahoe rear door speakers....GRRRRRRRR
'99 Silverado - Rearview Mirror Compass went dim...
Tire Label on Drivers door
brake pedal travel
2000 chevy silverado won't start
Female needs help!
Demystifying the 95 Chevy Silverado:
What type of suspension do I have?
No Cig Lighters, Power Doorlocks working
1999 Tahoe Hard Start / Fuel Pump Wiring?
6.0L Swap?
Loud clicking noise in 89 front end
New crate engine for Suburban
Can not get my timing right.
A/C not working - bad compressor clutch?
Neat tricks from the factory you need to know!
1994 Suburban battery drain
Brakes go to floor
96 windshiled wiper problem (Motor Noise)
Engine, tranny and computer = What to do!
FUel System
How difficult is it to replace AC compressor
Can't Find Grey Spade Connector on 96' Tahoe
Changing Rear Axle/Differential Fluid
87 Suburban stalls and hard to restart
power door lock problem
Getting New Keyless FOB for '96 Tahoe
S.o.s. Help!!!!!
Broken hood release on '97!
Smoke on startup
more on (moron) fuel pump whine
Resetting the SES light
90 350ci runs bad when warm
Change Door Guts
'97 Z71 Torsion bars
98 ck 5.0 to 5.7 swap
5.3L convert to E85
1999 chevy tahoe factory speaker colors
Aftermarket muffler help/advice
Need help identifying a truck!
99 Tahoe leaking front axel seal
Replacement tires on 2003 Z71
1998 burban high oil pressure
stalls and dies
stalls and dies
Front end issues!
Shift Knob
2004 with no steering wheel lock
Clear roof / marker light covers
Drivetrain Noise
O/D Failure? Engine?
2000 5.3 Vortec Intermittent Misfire on #2 Cyl.
I GOT STUCK! *links to my Pics*
Shift Knob
Broken hood release!
Belt Noise when turning left
Abs Light
where is timing / advance disable connector ?
Driver's side door needs tighten?
1971 C10 Parts for sale
conversion from 4x2 into 4x4
Knock Sensor???
'99 HVAC Fan Control on strike
95 Tahoe chimes
2000 Z71 Trailor Wiring Harness Prob
1998 z71 front bumper/light assembly
LT1 stroker can i spray it or turbo?
Are these Really worth it?
Brake wear
Clock
Antilock brakes
Seats for sale
Detonation/Pinging
draging noise while not moving
95 Suburban trans
99 Suburban Died
1500 vs. 2500
03 Silverado with 4.3l - V8? Perf upgrades?
Suburban service manual
The infamous GM fuel pumps ('98 and up)
99 Tahoe = Bulletproof, kinda.
97 chevy 1500 transmission
6.5 TD on SVO?
My First Truck: '91 Silverado *PIC*
Compressor locking up
91' 5.7L starts then dies, pls help
Brake Light/Turn Signal problem - need the answer please
Radio Button - Wear
Rims and Tires
Problem with Bose 6 disc changer in 03
Exhaust question
z71 Tahoe Warn Winch
Air control Sensor problem or what?
water pump
new gears an gas mileage
Better Brakes
A/C problem 91 chevy
2002 Suburban Captains Chairs
'03 2500HD Tranny Problems
Nasty rust spot on 98 Tahoe tailgate
timing and advance
need new tires?
body work
98 Tahoe AC Compressor Noise.
Extended Warranty
interior for sale
Kenwood x-869 MP3 player
A/C smells like mildew
Removal of converters
fast silverado
Modifying new bedliner
Reccomendations for 2003 with a 4.3
New truck picked up a vibration
Vibration when towing w/'98 Suburban
When I brake the whole truck wobbles please help
Removing Distributor
converting seats in a 95 ck
multiple misfires (p0300)
Looking for the best off-road shock
GAS GAGE NEEDLE "VIBRATES"
5.3L Dyno Disappointment
New Shocks and Fuel Pump
Z71 vs. F-150
wiring problems
Changed oil on 04 Tahoe, longer filter used
dashboard in a 95
Downshifiting out of overdrive
Bad cam or bad lifter,how to tell
Hypertech Rev Limit: 04 Silverado engine redline?
Are Headers Reliable These Days?
Dual Exhaust?!?!?! Which Kind?!?!?!
Just bought a 99 2500
96 suburban won't start
State emmissions test failure
how loud?
4wd noise from a 97 Tahoe
96 Suburban right, and rear spkrs stopped working
PLEASE Can't someone help with motor swap
Bucking Under Power
Hypertech programmer for sale for 2001 silverado's and tahoes!!!!!
2001 Suburban Stalls Intermittantly
Getting ODBII codes P0172 and P0175
Silverado Problem
Need Air Conditioning Help (97 1500 Sub)
03' and 04' Fog Lights ?
Speed sensitive steering on the fritz!!
need front diff parts for my 93 k2500 BURB
Need wiring diagram
looking for a step side bed
Transmission ?'s (Temp guage & shift problems)
Inside Door Panal
2001TahoeTRANS PROB...
towing, 2wd vs 4wd
Gas mileage
oil pressure flux
water leak?
Engine Timing Issue?
89' 350 TBI running rich when cold
1996 k1500 fuel pump issues
E85 Engine
Golfball size hole in rear differential cover help?
Tire size question?
Need TSB #01-08-56-004A
removal of dashboard in 95 1500
Rear End Question
2001 rear window hinge problem
Bucket Seats Source
92 1500 hesitates
02 Tahoe - Does Factory Radio have pre-amp outputs?
3/5 drop
SeTTiNG VaLVeS & Distributor
1997 5.7L quit running
New Hypertech! need 180 stat?
Suburban Brakes Suck
PVC Valve Location / 2000 Silverado 4.8 ltr
Good brand of Brakes for 99 Tahoe
Off Road Lights?
Service Engine Soon On after I changed Sparkplugs
Are differentials from 99 Tahoe and 2000 Chevrolet Pick-up interchangeable?
2001 tahoe- trouble starting
Changing out Ext. Cab Window
Suspension Lift
got beat bad:(
1988 chevy TH375
Fuel Sevice 2000 Z71 5.3l
Add DVD to '03 Tahoe
Brake Squealing on Corners
ABS light sporadic
2000 Chevy Silverado
First SES question
Factory radio removal
Clear the CLN message on radios with remote cassette on 1996-2002 Chevrolet/GMC truck
unbalanced 454 hurt trany?
No gas on May 19th
More Cruise/Brake light problems
Steering wheel vibration
Tire Size
A/C Compressor not engaging
Strange ticking sound when I accelerate
door seals on 89 suburban
2002 Quadrasteer won't start.
Does the 2004 Tahoe 4.8 have a 4L60E transmission?
93 CD Player install/Radio removal
Starter just clicks
Humming sound
sputtering when cold
Gear swap
new speakers
abs problem
irratic fuel guage
1995 305 to 350 swap
Exhaust
air intake
1996 Tahoe Transmission Problems?
Starts and dies
Another "start" problem
reprograming a keyless remote
Silverado VSS?
Need Help Fast!!
When to use tow haul on 01 z?
Code P0430
99 silverado ABS and random brake warning light
99 Silverado
What Type Of Oil
Hard Shifting
City fuel mileage
'04 shifter
1988 350V8 TB SWAP FOR A 70's 454V8 Carb MOTOR
98 silverado
1988 silverado 5.7 engine and towing specs
Oh, here's my truck
Slam when stopping
2004 Chevy Silverado 2500HD
Rubbing noise coming from wheels/axle
1994 Chevy Blazer K1500
01 tahoe with 03 xm head unit??
77 c10 knocking
Bad things about 180 thermostat??
96 sub won't start
Trying to find timing.
Sirius Satellite Radio hookup problem
Engine cranks and dies immediately?????
biggest tires??
C1500 vent system knocking
rear view mirror on stable door
2001 suburban tail/brake/turn lights?
Web
AF
