View Full Version : C/K
- 1990 truck AC/H failure
- 99 Suburban Bleed Brakes
- Front seats 1997
- Looking for MPG information
- !987 Chevy G20 Van 4.3 262 v6 Will not idle or run HELP.
- 98' strange radio problem, thoughts???
- 4x4 question
- Stalling 1999 Tahoe
- 5 speed auto
- Knocking at start up ?????
- 1988 chevy wiring diagram please!!!!!!!!!!!
- Disabling panic alarm button on remote
- 1988 1500 Heater Core Replacment
- Parts cut away or parts over view on the web?
- carbon in upper intake manifold
- FIPK and factory/extended warranties
- weird OverHead Problem ! HELP Pls. !
- No tail lights or dash lights???
- Installing power mirrors
- CD Changer Location
- Service 4WD light
- Transmission Fluid Flush?
- help moderator
- Molding on side of 89 - How attached and How remove?
- '98 Chevy Z71 vibrates when low idle with A/C on
- 2001 Tahoe not starting - just RAPID clicking!
- Turn signal problems
- Radiator
- swapin a 4.8 for a 5.3 or 6.0
- Odometer lights went out
- Low rumble when loaded in 4WD
- Injector popping on 95 350.
- swapping bench seats for buckets/console
- Could someone runs these VINs to see what they are.
- Transmission Trouble!!!!!!!
- Straight Pipes
- Exterior Accessories for 2005 1500 Crew Cab
- Spark Plug Gap
- Ran Compression Check, now what???
- bumpy ride?
- 4x4 question
- engine swap
- How can you tell when shocks need replacing?
- 1998 water pump replacement
- 99 sub hole in rear bumper
- Going to by a K3500
- Cracked Exhaust Pipe, Yikes $1000
- ABS Activation
- Which Wire For Accessory Light With Dimmer?
- 88 chevy c1500 fuel injection, a/c, and other questions
- 94 K1500 - no 4wd!
- 1996 K1500 Squeaking Noise
- compression question
- New Exhaust ?
- need links to good parts sites
- program 2003 suburban keyless entry remote
- Audio
- locating a live + wire when ignition is hot
- paperclip and engine codes
- msd ignition/timing/carb
- 4 wd wont engage fully / help
- ABS Activating Un-necessarily
- 92 Rear Drum Brake Problem
- 2 wheel to 4 wheel
- 01 Suburban thump
- "flutter" noise
- where do I find replacement part for "check engine light" bulb?
- Replacing rear window rubber seals on 89
- '89 C1500 smoking at startup
- Keyless Entry Sticking
- Gas mileage not as good as identical trucks
- shut off engine while filling tank
- Door Panel Removal
- 94 Burb Transmission problem (long) please help!!!
- 496 c.i. under-hood squeal
- Accessory Lighting
- 1998 Z71 5.7L starter knock
- 1999 Diesel Suburban
- a/c is on.....loud noise!
- 350 Tbi No Start No Injector Pulse
- Balance tube and OBD II
- Side exit exhaust - 96 Tahoe
- New Shocks
- 4L60E fluid capacity
- 2000 Burb---repair hard start
- Ram/ Cold Air??
- '04 1st to 2nd clunk
- No more badges?
- Power steering boosting
- 2003 4.3 Rev and shift points
- 1990 c1500 Chevy, Another Question...
- 1999 chevy suburban wont start
- Carpet for a 99
- Throttle Body Spacer?
- Torsion lifts?
- Help! Brake Lights Stay on ALWAYS!
- '91 Burb; no dash lights, A/C blower or radio
- Modifications & Warranty
- 1998 5.7 Z-71 normal oil pressure?
- How to change anti lock brake module
- What to do with my '93 4.3L Swap or not?
- Power window regulator
- Oil
- Rt Frt Brake Drags, R&R'd Caliper, Same!
- ?flowmaster or gibson?
- 1990 c1500 5.7 a/c problem...
- fuel injectors not working
- Instrument Cluster 120+
- front axil center pumpkin leak
- 94 Suburban Dying
- lift kit for 94 2wd
- lubricating accelerator pedal 2000 silv
- Ram Air 94 1500 350
- Smog headers for trucks
- Easy Hp gains?
- 89 5.7L TBI won't idle with "Set Timing Connector" Plugged in
- C30 Load valve???
- 01 Suburban rear brake trouble
- Brake Problems!!!
- Brake Problems!!!
- Whistlin' somethin', drivin' me nuts.
- MAF Screen NON-removable?
- New LOUD exhaust
- Best Chevy offroad 4X4 you can get used for cheap?
- cruise control problem
- ?manual to power locks?
- '04 turn signal mirrors on '01?
- Intermediate steering shaft
- Dash and Headlights Pulsating
- PowerAid TBI FOR SALE
- Metalic popping noise front axle
- 2001 Suburban transmission
- 99 Suburban shakes when climbing
- Freeing a sticky gas tank float?
- How do you turn off that annoying Security bell?
- It just bogged down then quit!
- 99 Suburban interior lights stay on after doors closed.
- that new lucas octane boaster
- 99 Suburban Parking Lamps Out
- Installed FIPK... Service Engin Soon Light???
- block cracked at starter mount
- P0147 Code
- Tire Size
- some time ago i bent my axel
- exhaust project with pictures help plz
- weird noise
- 1996 Suburban plugs
- error codes 2001 suburban
- Project K2500
- quadrjet adjusting
- 93 Distributor problem?
- 1986 chevy gas tank switch
- 4L60E tranny question
- 2001 Suburban cd not working
- Crazy custom exhaust work suggestions
- Tranny Swap question
- 1996 K1500 Fuel Pump Problems
- Brakes & Front End Hopping
- 327 replace
- 97' or 99' suburban any real difference?
- Engine rotates but will not start
- fast idle when 5.3L is hot
- Any experiences with LMC Truck?
- tranny
- Parking brake doesn't work
- What muffler sounds best for an 89 C1500?
- Dex Cool Vs. Green Stuff?
- New Vehicle Service
- HVAC fan setting "2" not working
- Fuel Pressure Regulator
- What's wrong with my transmission?
- 93 sub fuel gauge stuck on full?
- Stock Rim Width?
- Third Row Seat
- Need Some Advice
- 5.7L Performance Upgrades-The results
- Tranny ID
- 99 sub. brakes scrub when making a slow stop?
- Stupid Poweraid TBS
- boggy acceleration! GAH!
- 305 V8 C1500?
- Where is my turn signal flasher???
- Fuel filter
- 1980 chevy 1 ton camper special
- 00 Airbag light on
- C30 Hydro-assist Brakes 1983
- Bfg Mudders
- 01 cruise control out
- Dull headlight lenses
- weird noise in front end, brakes/steering etc.
- rear ac expansion valve, where is it?
- No Reverse 02 2wd Silverado
- Install a new Ignition switch '94 Sub.
- 4 Wheel Drive Help
- Transmission Clatter
- 350 turbo
- rubbing with 33 inch tires
- 67 chevy truck
- Need help to diagnose starting problem
- Gas Pedal
- Wipers don't stop.
- 86 brake, tail, and turn signal probs.
- engine tickin
- What's the best way to run battery cables into cab . . .?
- Can you guys help me out with a rumor I heard?
- Is a rebuilt motor from Schuck's any good?
- Brake Controller
- Engine code
- stalling intermitantly
- Radiator size?
- Three Trucks 7 Rotor Caps
- injection pump
- 89 c1500 parking/dash lights out
- 14 bolt ring and pinion swap help
- 79 chevy truck gauges
- 2000 suburban seat wiggle. Please Help.
- Gas Mileage...97 K1500 Z71
- Personal cellphone attached to the on-star microphone and speakers
- 5.3L perf upgrades? + Splitfire question...
- Looking for engine build up kit for 2001 5.3.
- grinding noises, then suddenly will not move!
- 1987 no power, engine revs, goes slow
- Reset oil change light?
- 1985 Suburban
- VIN help
- ?clear corners?
- HELP! 94 suburban wont start
- Changing the high pressure power steering hose
- tahoe "bump" while driving
- surburban suspensios and body changeout
- Correct Idle RPM for 4.8?
- fuel filter
- Help!!! Changing Intake Gaskets On A 96 Tahoe
- K2500 1997 abnormal engine run
- 22" and 23" Tires for Sale, Very low prices.
- F/S 22" and 23" Tires, Sweet, very low prices
- Steering Stabilizers - how long do they last?
- a link for rear bumper brackets??
- Trunk Doors ***help***
- BFG Mud Terrains
- runnin rough in rain
- 1994 1500 computer programmer available?
- HELP! 88 1500w 5.0 (almost!)
- 4.8 VS 5.3 GOOD and the BAD
- Engines
- '99 - How to drain the PS pump and rack
- backup light switch
- Shifting into Lowrange with insta-trac
