View Full Version : C/K
- Timing Problem
- 98 1500 trailer wiring
- Dome light
- egr solenoid
- Is the Silverado..
- Captain or Bench?
- 98 Chevy Truck check engine light came on...
- Ball joint replacement
- 86 chevy won't turn off
- Engine swap starter problem?
- silverado
- Door Speaker Install On a 2000 K3500
- Ingnition problems?
- Strange Event - Electrical Short
- shuddering/ vibration help!
- abs sensor location?
- headlights dimming
- Turn Signal Bulb Blowout 8057
- 2500 HD Dash Gauges
- help please
- Brake lights not working
- Contact Points?
- any one know a link on how to body drop a chevy
- 1993 k1500 3" lift
- Steering problems
- ignition timing
- Tonneau Cover for sale $425 NIB
- 4x4
- 95 Burb - Lack of Power
- 95 Chev 1500 heater doesnt work
- 1989 clutch engagement problems
- Strange shift problems 1996 Z71 5.7
- 383
- 1990 Chevrolet 1/2 ton FOR SALE (NEW PRICE) TRADES WELCOME
- fuel pump or no?
- Power Door Locks Not working
- poor idle when cold
- testing for a bad poppet valve
- 1997 C1500 failing to start - intermittent
- 1997 C1500 Fuel Pressure Connection
- 350 heads on a 305?
- 97 Tahoe RKE console location?
- Inadequate Fuel Volume??
- Humming or Whinning noise
- what is the sensor on the firewall, passenger side
- new air filter temp sensor doesn't work
- Backfiring Problem
- A.I.R. removal
- Steering wheel wobble.
- '93 chevy blowing 4wd fuse
- 97 tahoe 5.7
- 90 5.7L + FIPK + Spacer?
- axle nut size and speed sensor repl proc
- 4x4,4wd help, please
- Blower Motor dead. is there an upgrade?
- Brakes-ebcm,dumpvalve or combination?
- I can't figure this %@#Z'n silverado out.
- New tires
- 97 hard to start
- Dont know whether to switch to carb or not
- 17" niche wheels 5 on 5 bolt pattern
- No Brake Lights/Double Speed Turn Signal
- Truck running horrible....why?
- 97 silverado, new fuel pump, truck won't run
- Need help sourcing out power seat parts...
- what is this emblem for?
- cargo light fuse in 2001 silverado
- dash,park lights....blowing fuse
- I need good front shocks, no cheapies please! 1996 Z71 Silverado Ext. Cab
- Fuel Gauge
- Spooky C3500 starter problem
- ZF six-speed conversion
- Changed intake gasket, now there's power loss
- 1996 350 cam and lifter question
- 97 chevy truck clunks in slow turns
- Cheap, Used 350 5.0 or 5.7. rebuilt or not working. where at!?
- Brake light on dash always on.
- 1962 Chevy Shortbed Stepside
- turbo 350 problems
- open loop operation
- <REQ> ADL pin assignments 1991 6.2L
- Speedometer
- 1986 chevy c10 oil pressure
- Vacuum Test
- general carburetion question
- 96 1500 will not start.
- Code 44 ?? O2 Sensor? Lean Exhaust
- 97 k1500 Dies when put in gear
- Question from a non-educated chevy owner
- rear lights
- 96 K1500 wiring diagram for 7 pin trailer socket.
- C/K forum is for 1998 and older models.
- Front Wheel Drive Accuator
- what bolts to my 80k20 205 t-case ?
- 93 5.7ltr code 35? Check engine light on at idle
- 1990 K2500 Tranny clunk/clang
- Throttle/pedal link 2004 Tahoe
- I am a new 4x4 person..please help!
- A/C problem
- Ac Unit blows Hot air
- need wiring diagram
- door handle replacement
- Separate forum/page for Avalanche/C&K/Silverado/Suburban/Tahoe ?
- what is the diff between, Multi-Grade Oils, and Straight-Grade Oils?
- largest tire size
- Tailgate Window Filler
- header install
- 86 Chev K20, fuel guage or sending unit?
- Dash Light Question.
- body kits
- 5.3
- Tranny/rear
- popping noise
- sreering help
- Bad Idle at start up 5.7 tbi
- Brake Light Switch Keeper?!
- rear end vibration, pump not shutting off
- Uneven Tire Wear on 2002 2 wheel drive 1500
- Headers
- Mass Air Sensor
- Oil Pressure malfunction
- Air Conditioning Question
- winding noise in 97 tahoe
- poping noise when shifting 1st to 2nd 2004 yukon
- Replacing fuel pump 97 tahoe
- 96 abs light on
- 2000 k1500 factory tow hich question.
- Couple of questions.
- lowering kits?
- Anti-freeze losses . . . . . .
- hurricane victim needs help! NO 4WD! tahoe
- Rear lighting problems
- acceleration irregular
- Suspension & Interior
- flowmaster muscle truck
- rear end gearing higher than 3.73 beneficial?
- Auxiliary power supply
- need info on replacing turn signal switch
- taking governor off chevy z71 silverado
- Remote "panic" button
- Wiring aftermarket FOG lights into parking lights
- changin headlights
- Anyone have Corsa exhaust?
- Sevice Engine Soon light - loose gas cap
- Exhaust Rattle
- 1997 5.0 swap
- Hypertech reprogram? Performance upgrades.
- A/C pressure on the low end.
- Should I or shouldnt I?
- Oil Changes
- fuel sending unit
- 98 style grille on a 91?
- Big Block Thy 84 Blazer
- Theft loc radio
- Occasional tugging on right side of 88 Silverado??
- Replaced Coolant and Rust everywhere
- Towing
- Shaking over 70 mph
- K&N FIPK / hypertech
- service 4wd
- Security Remote and 4x4
- Bad Idle Air Control Valve?
- Fuse for fuel pump.
- AC noise when over 2000 rpm's
- So whats the big deal about IRIDIUM POWER PLUG
- removing cat?
- Bought New Chevy Help please Oil ?
- Is my truck okay!! Help!!
- 1997 K1500 Intermittent Running
- 96 tahoe ABS light then transmission downshifts
- 1998 5.7 Vortec Questions
- 1996 4X4 transmission R&R help
- What's the difference between...
- gear ratios
- Tahoe head rest removal
- timing problems 98 vortex
- how do i set timing 98 vortex
- How to remove the grill
- transmission advice
- Wiring specs at fuel pump 95/ 1500/ 4x4
- Instrument Panel Cover
- help 84 diesel stalling
- oil pressure problem after starting
- Seafoam usage Help!
- Need Running Boards
- Help, P0700 Transmission Control System Malfunction
- pipes intakes and super n00bs
- 1998 chevy c/k 1500 silverado 4.3 vortex
- steering gear box question
- 3rd seat
- Stutters at acceleration and cruise speeds
- Better Oil
- spark plug gap
- Tow Hooks
- need help,,inspection needed
- Louder Exhaust...In a 91' 305
- slow acceleration
- ABS sensors on rear 2001 Tahoe?
- Rebuilt 454 running rich??
- Better Gas Mileage???
- 3rd row seating
- 396ci 5.3L 500hp on eBay. Awesome!!!
- 95 Sierra AC Problems
- converting a 2wd into a 4wd
- 99 burban cut off while driving
- removing ignition switch
- Question before I buy a 2002 Tahoe Z71
- Check engine light
- automatic tranny causing occasional engine surge
- Washed engine now trouble codes.
- Transmission Fluid Filter Change intervals
- 95 K1500 After Marker CD Deck???
- Tow/Haul Problem
- straight axle
- windshield wipers
- replacing wiper motors
- Computer Cam
- 1996 Trans help please!!!!
- I GOT a JET Chip, What is it doing.
- Fender Removal
- Exterior Door Handles
- service engine light reset
- 96 6.5L Diesel Not Starting
- Intake and Exhaust
- Leaky Back window...
- Window Replacement
- Gear Ratio.
- Gas Tank Size.
- 2000 Suburban 1500 305/70r16 on stock rims
- fuel gauge help on 84 silverado diesel
- Should I buy this truck?
- hypertech programmer
- Forum options question
- Cabin Air Filter - Where is it.
- Miss in Cylinder 8
- Helix or Airaid
- New keyless entry problem/2000 silverado
- Tension In Brake Pedal
- 1988 K2500 intermittent idle
- Need Help Please!!!
- Supplimental Fog Lights
- Grill Manufacturers
- Loose Power steering at idle! Tahoe 2000
- 95 Chevy CK Door Handle Replacement
- 1990 truck AC/H failure
- 99 Suburban Bleed Brakes
