Chevrolet
Avalanche | C&K | Silverado | Suburban | Tahoe
> C/K
View Full Version :
C/K
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
Really Cold!! No Heat!!!
Several Questions on my 99 C3500
BAD hesitation 2
Headlights acting funky
Restoration
valve adjustment
Suspension question...
More exhaust questions...
96 C1500 Fan Removal
catalytic converter
Buy & Build or just buy??
Tires
Charging system problem
96 Parking Brake Lever Not Fully Releasing
lifters
Chevy 350 oil pressure
Running Parking lights 84 Pick-up
95 z71 hp rating
1990 GMC SIERRA starting issue 350 tbi v-8
daytime running lights
Truck usage
just trying to help
radiator replacement
86 f/s CD deck and speaker project
Body lift
SES code help P0452
98 Z71 bogging ???
99 Tahoe Leaking Coolant...
BAD hesitation
piston slap or not???
96 model extended cab rear window leak
Exhaust recommendation?
Heartthrob Exhaust...
door panel
97 305ci, fuel overload??
96 3500 454 running very rough
Carburator Conversion
service engine soon light
Window dimension question: ASAP!
96 C1500 engine swap question
two batteries
1996 Tahoe Slow turn Clunk and grind.
1976 scottsdale seat?
No Cruise Control
98 Knock Knock
Heavy pedal
97 silverado
1994 4x4 350
90 1/2 ton heater controls not funtioning
Tranny Probs. 93 1500
Intake manifold leak
fuel pump/ oil pressure switch
5.7 TBI stalling please help
96 K2500...
wires on replacement thermal actuator
1994 cheyenne won't start
4X4 2 Door Tahoe
92 Suburban 454 Engine Runs Lousy
99 tahoe fuel issues
ball joints seat themselves?
1987 Dashpad
a/c condensor freeze up problem
strange ticking noise inside cab--1994 1/2 ton
Boggy Accelleration
Pistons Pinging
5-speed manual problems
99 Tahoe
89-93/V6-V8 engine swap resuts
1996 K1500 Interior light / Tune up problems
96 1500 dying/wont start for 3 hours
oooooooh that Smell!
Factory Locker
1998 1500 Stalling
Wanted: 1993 Instrument Cluster w/out tach
problem...popping noise
shocks
1993 Instrument Cluster exchange
Good Tire Size for Winter? 285? 265?
Red Hot Exhaust Manifolds!
Tire size on 95 Silvarado
Extensive tests all check out. Still won't start reliably.
hypertech power programmer III
ABS concerns
help!!help!!no heat in 90 silv.
swapping 350 carb for a 305 tbi
86 c10 headlights not working
lowered my truck
Strange idling issue
76 292 to 350 swap
what's up with my truck
Another Fuel Pump Problem
1997 k1500
MAS Question
alternator interchanging
Whistle from heater blower
transmission swap question
1960 P/U oil problem
96 Chevrolet 3500 transmisson problems
92 4x4 upper joint adjustment
Brake lights not working
1986 C10 dies when accelerator pressed
Door Panel Removal
2000 ranger misses while driving and at fast exceleration while in neuteral
Compression check 93 k1500
ECM-IGN fuse keeps popping
86 chevy 4x4 front differential
'96 4x4 Yukon Ball Joint help
89 1500 Acceleration problems after warm-up
Please Help (error code)
Buzz from dashboard
454 running trouble
OBS Parking Brake adjustments???
need truck bed replacement parts
700r4 transmisson servo
Fuel pump?
99 gmc suburban old body style 4x4 loud revving noise
Spark Knock
NO Air blowing
Starting Problems 1994 Z71
What do you think my Hp/Tq would be with these mods?
84 6.2 white smoke from driverside exhaust
93 k1500 Ball Joint Assembly
Did I Destroy the Finish on My Alloy Wheels????
no spark at plugs
Dome light 98 K1500
z71 ifs help....
6.2l Pulsing/vibration
Automatic transmission questions
brakes on 91 chevy 4X4
Pcv valve problems
Brake Light issues...PLZ help!!
Need to find a 12v power source for KC lights
Blown Head Gasket? Intake? Other?
possibly getting a running 350 for free. Stroke to 383? What to do!?
95 Tahoe - Transmission or Electrical ? with check gages lamp on
99 crew cab nerf bars
fuel pump whines
cabin air filter on 1998 k1500
shift kit.
wheels
91 chevy K1500 4X4 Brakes?
Stalls when put in gear
Why Not Air Shocks in Rear for 1" Lift?
still having problem with shutting off
wiring diagram for
Memory for my Aftermarket CD Player
5.0L supercharger
4/6 drop, what size wheels?
reverse lights
92 door panels/ arm rests
need help finding a cam
wiring diagram for 1996 chevy truck
Geo prizm 1994 Radio Err9
1993 torsion bar removal for lift
Modding 97 Silverado
NO SPARK from coil
98 Z71 For Sale- Chicago area
recommended fluid
Fuel Filter Replacement 98 K1500 5.7
'94 K3500 4x4 rough start and poor MPG
Tow package for 98 K1500
Cheap 1" Lift: air shocks or add-a-leaf?
Turbo 350 slippage
Engine Problem
Speedometer Adjustment?
86 chevy leans left
Best fuel pump?
Heater Problems
4.3 Vortech
Howdy
car audio
93 1500 drivability
Are there Problems With 305 Motors? 99 5.3s?
how to modify 82 c10 to electric fuel pump so that it stops with engine
A/C Compressor bearing
best option for lowering a 92 c1500
No Power to 91 silverado fuel pump
1991 5.7tbi stalls
Clutch '97 Silverado Manual
Used 1998 K1500 engine problem?
Parking Break Warning Light Flashing???
1996 vortech 5.7
rough on cold starts (timing)
Lowered my '88 C-1500 by 11 inches!
1989 chevy 1500 4wd sat for 1 year, only has first gear and reverse
Heater Fans woes
Idle too fast
Delayed fuel pump shut off
Power steering pulley removal question
Broken Hood latch
Maybe ECM problem, or should it be like this?
gibson super truck exhaust???
Installing LED bar on roll pan
Wheels For Sale
Brake Warning indicator
94 1500 5.0 liter heater line busted
air conditioning compressor stays on
front end
door panel removal
Torque Converter??
Stupid Deer
Valve Covers
vehicle specific electronics question, sub enclosure
wrench head needs help
93 k1500 temp guage
rough idle, please help
Some Q's On Ford Torsion Bar Keys...Already Did Search
'85 C10 Distributor
4 low
No injector pulse TBI
Charging system problem 89 chevy truck?
Turn signal/cruise control
Shimmy/vibration with washboard effect
air conditioning causing overheating?
No heat, Def blows A/C
replacing cat ?
Need help Flushing Coolant
Air intake kit
99 Suburban Keyless Entry Problem
Extra CPI Injector Upgrade...Anyone Want It?
1976 Scottsdale
anyone have a tailgate for sale at a resonable price?
97 2-wheel drive 350 vortec questions
Used Truck Value????
83 k2500 turning radius
dual exhaust 98 K1500
Hitch question..
your opinion please
WANTED: Interior for 94 extended cab
69 Chevy C10w/ '76 400 smb issues!
bad coolant leak
Sloppy 5 speed
1986 Chev. Suburban Parking Light Prob.
timing problems code P01345
Parting out 88-98 Chev/GMC 1500 truck
blowing fuse
Rear differential leak
Can anyone help?!?!?!?!
98 k1500 starting problem
Not getting fuel
Need help changing heat core
83 3/4 ton. 350 mod help
engine oil cooler conversion. possible?
Carpet
Stripped Headlight screw
New truck, old AF'er... :)
Gas Is Drowning Me!!!
New Here.
vacuum leak??
1998 Vortec 350 Intake Manifold
