View Full Version : C/K
- Buying advice on Chevy truck
- 86 305 cracked heads substitute?
- 2003 making some strange sounds
- 2000 Z71....Where does it end?
- 1996 door hinges welded not bolted
- 1996
- 89 C1500 exhaust question
- what is the largest size tire I can get?
- cab break light
- Hot Front Passenger Floorboard
- 383 Stroker?gauges
- 4 wd will not engage
- Spark Plugs
- Defroster
- cLUNK
- Want to bypass air pump
- Shudder/Hesitation At 60MPH+
- Air Bag Light On After Changing Steering Sensor
- Gear Oil Quantity
- high/low lights problem
- "Service 4WD"
- 98 7.4 cranks 20 sec. before starting
- Turn signal indicators in mirror glass
- 98 Silverado Differential
- replacement stereo for 93 suburban
- Is the 4.8L a 283?
- Z71 K1500 Starting Problems
- in-dash changer in an '03 silverado
- Driveline Clunk
- Which Chip???
- Turn signal switch replacment
- 1997 k1500 lowering kit
- 02 Suburban Front Suspension Knock
- Electric 4X4 shift not working
- 01 Chevy Suburban-service engine soon!!
- 305/70R16's (BFG AT/KO's) on a 2000 4x4
- Vibration at 75mph. 1997 Tahoe- Not the tires or wheels
- cadillac+tahoe=cadyHOE
- GM Accessory Security Fob
- Problem of the month club: Compressor oil leak
- removing door panel/replace side mirror
- 99 Suburban: Engine Misses Then Quits While Driving
- Surburban Transmission
- door switch
- Fuel Filter
- Brakes too close too floor!!!
- 4.8/5.3/6.0 Same as 5.7 LS1
- CD changer connection question...
- Power Steering
- air lift bags
- Instrument Panel Squeak & Thump
- 1990 k1500 4+4
- front end noise?
- stock rims...
- Tailgate for a 64 or a 63 c-10 half ton
- Courtesy light in door...
- Intake
- 24" rims on a 2004 tahoe LT
- Anyone want to share pics of your Z71?
- Ignition type
- changing out the dash
- do these really work? are they safe?
- engine clean
- help! want to tint my windows
- 20's, 22's and problems???
- 99 suburban wont start
- Need Help With A 1999 Tahoe Brake System
- Who makes Duramax
- 1999 Tahoe Timing Chain
- HELP! Major problem Factory/or defect?
- tranny slip + reverse noises
- '95 Sub K2500 5.7 liter to 7.4 liter swap?
- 2002 Tahoe Rear Stereo Controls/Cigarette Lighter
- Tahoe Lurches at Stop
- Hesitation after starting 99 Burb
- Rear Bumper
- lug nut problem
- Coolant Leak '98 5.7 127,000 miles
- 2002 Tahoe Lemon....Help
- 60"s Burbs
- Steering Wheel Jerking
- Wanted : 2000 Tahoe Limited
- Looking to buy
- hid's in 97 tahoe
- Hot wire
- Sticky accelerator pedal
- Needing to take front bumper off...
- where is the tag
- Tranny Problem, Please Help
- 99 tahoe braking problem
- Front Wheel Bearing Replacement
- no reverse or second gear
- 98 Tahoe inconsistent non-start? ARGHH!!!
- Hesitation
- Blowing turn signal and brake fuses
- ? Best Carbon Fiber Trim Kit ?
- 1990 C-1500 350 to 305 engine swap problems
- 4x4 low range
- How many MPG do you get on your Tahoe/Yukon?
- Blue wire / Rear Speakers / New head unit / H3LP!
- Tires/wheels 93 Suburban
- 77 Suburban need help A/C & rear tail latch
- C1500 idle
- good engine life of 305, mystery?
- 2004 and Rotor and Cap
- main oil seal leak
- 2002 Tahoe Body Emblems
- Looking to buy '02 or newer Burban
- 2001 Tahoe Traction Assist
- squeak from front
- 1980 trans. swap
- No Go No more
- G80, Gu6, 96 Z71
- 2000 Tahoe Starter Replacement
- AC/Heater Blower motor seized
- 2003 Suburban Smoke on Startup
- Radio upgrade info ?
- Programming PCM/ECM
- max a/c problems
- Power Mirrors
- Engine Miss
- overheating new 86 burban 350
- Fuel Pump and Sending Unit
- Will these tires fit?
- air mods
- 1980 trans. swap
- Rear Rotor /Parking brake removal
- Speedo is wrong
- Front end violently shaking
- Sound Proofing a suburban
- sweet find!...i think
- 94 ignition & a/c problems after break-in
- Loss in power
- Quadrasteer Rocks!
- 69 chevy truck electrical
- Gas Mileage Computer & Cold Air Intake
- Need a Tahoe Manual?
- oil pressure
- 2001 Tahoe blues
- 305/350 combo Help
- duramax diesel inline fuel pump?????
- Best place for OEM parts (hard to find)
- Tahoe Transmission
- Best engine
- Are all 454's Tonawanda engines
- Cheap Chrome
- Marine vs. vehicle heads??
- 99' Tahoe exaust....
- A/C blows on feet & compressor won't turn on
- Just got a 99' Tahoe, need advise.....
- I Got Crank, Gas, Spark, NO FIRE!
- 99 Burb intermittent start
- what is vortec really?
- Dash rattle
- Activate CD-Changer in '03
- fuel pump problems?
- prelube systems?
- Options Explained
- 96 C-1500 High Pressure A/C valve
- 96 C-1500 Daytime Running Lights
- brake help
- 99 burb leaking coolant
- 1989 Chevy Suburban
- Some questions about 2000 Silverado
- Cooling Problem?
- whistling windshield
- installing overhead console
- clearing a/c drain
- reverse solenoid
- High Pitched Humming Noise--'97 2500
- Tailgate emblem
- 1980 C10 4.1l To 5.7l Engine Swap
- Pulling original 454 exhaust manifold off
- 81 c-10 pickup 350 5.7L oldsmobile diesel starting system info needed
- rough idle and sputtering
- front rotor 99 3/4 chevy
- Really weird
- o2 sensors (purpose)
- Water Pump
- need help fast!!!!!
- 97 Z71 Transfer case
- Buyer information GM Truck
- Trailer Brake Controller Issues 2001 Suburban
- 3/8 pressed in studs to 7/16 threaded
- Tires for 3/4 4x4
- Oh God ... another largest tires question: 285/75/16's
- Rough idle, smell of fuel
- 305 needs to warm up in July, runs great warm
- passed emission
- Anyone know stock tire brand?
- 97 surb rear door leak
- 1988 Chevrolet C1500 2WD 4.3L-V6
- Rear Spare Tire Swing
- Removed the badging....what a difference!
- Speedometer Malfunction
- 96-1/2 Z71 Trans Problem
- 1997 K2500 Chevy surging between 45-60 Mph
- 92 k2500 idle surging
- Ls1
- Keyless Entry Conversion
- A good set of spark plugs
- 2002 Suburban A/C Related Heavy Rattle
- What type of distributor?
- Vibrating Torque Converter
- Need Help !! 2000 Suburban
- cranks no start
- 2000 chevy intermiitent stalling
- 1986 K10
- 97 Engine Differences
- Quickest Silverados
- Tires
- fuel pressure testing
- my poor baby is runnin so bad
- HP add ons
- high idle
- the good the bad and the ugly of a 02 tahoe
- 2001 4wd service light - just bought it!!!
- 98 silverado ashtray
- looking for a c/k ashtray
- Door spring hinge tool?????
- Widest tires?
- Fuel Pump...
- 97 5.7L Misfiring
- engine swap from a 96 to a 2003?
- Installing a power antenna . . . ?
- a/c cycleing switch, where is it located? 98 Burb
- 04 Burb accessory power on until door open
- Tahoe fuel pump
- Overhead console in 92?
- Gas Guage defect
- power fluctuations
- Lift and Tires????????
- Hard shifting problem - error code P1870
- 1998 Silverado 4x4 Transmission trouble!!!
- 01 Silverado staring trouble
- How to get codes
- Front Axle Lock
- Door Handle Removal
- she starts then she stops
- Rough Ride
- 96 vortec 350 problems, hard starting and cutting out
- Leather seat cover replacement
- Hard time shifting from 1st to 2nd
- 2004 Tahoe LT 2WD Borla Cat back
- thm400 drops out of 3rd gear
- 2004 bumper on 2000
