View Full Version : C/K
- info on TH350 tranny
- Right rear brakes
- Looking for Aftermarket Electric brake booster for '96 truck
- Front differential on an 86 Silverado
- radio lights
- brakes one last time
- Oil In The Intake
- 1989 k1500 sporadic idle issue
- Rear View Mirror
- do spark plugs make a power difference
- I have a body mounting question.
- Advice on good used truck
- '94 Silverado Problem
- No Vacuum 96 350 Just Checking
- What is a knock sensor
- dex cool leaking
- 305 to 350 swap question
- Power Rear Window on a Pickup?
- Desperate Cry for Help (intermittent spark)
- Need a new EGR for 89 C1500, How important is it really...?
- OBD II Reader Selection
- 3rd Door on 3/4 ton??
- 160 degree thermostat
- variable speed steering box
- 35's with a 3" lift...?
- EGR Valve Replacement
- Front grills
- 96-99 Column shifter Change Question
- Oil pressure problem
- spray on bed liners
- 4l60e Tranny Question
- parts
- ticking is driving me nuts
- 1990 truck running too rich
- No power to rear wheels on 1978 k2500
- Voltage To The Fuel Pump ?
- fan clutch going bad?
- 2wd rear end swaps
- Camshaft swap 4.3 non Vortec
- Help 1995c1500 350 5.7
- Bucking 96 K 2500 Thinking Fuel
- lower rearend gears
- 1993 Chevy column shifter
- Tranny Question
- y pipe
- Transmission Temperature
- fluids for the transfer case
- What Would YOU Do? Knock Knock; Waterfall
- P0300 Trouble Code, Multiple Cylinder Misfire
- block heater install
- 1999 Silverado Tailgate won't close (latch)
- Pictures of your truck(s)!
- 93 K1500 A/C Problem
- interminttently problem solved
- Best add-ons or mods to boost mileage? 98, 5.7 Vortec
- back pressure
- Extra power for little money
- Loose Steering!!!
- Carrier bearing replacement???
- hypertech TBI power charger
- right lowbeem headlight and DRL's out
- auto trac 4x4
- brakes again
- Cross country travelin'
- rechip Duramax
- Can't open hood! Release cable is broken!
- 93 exhaust ideas?
- brakes
- Injector work interminttently
- Help - 02 suburban keyless entry
- no starting w/a 20 degree change??
- 1994 chevy3500 frount axle diagrame
- 95 Silverado Door Pannels
- 88-93 chevy truck owners
- 1989 K2500 4WD Running Terribly...... Ideas?
- Power locks
- miles
- Clutch Noise?
- 52 conversion
- Bench Front Seat
- Interminttent Problem
- gauge cluster swap
- 1987 Chevy start and run problem.
- (k1500) 4wd not engaging......please help
- 1987 K2500 Transmission Troubles..... HELP?
- Underdrives/electric fans
- A dark, dark day.
- Timing Vortec engines
- Poor mileage in 98 Silverado, 350 Vortec
- 1994 silverado timing
- power loss???
- Cam Suggestions??
- 1993 cluster gauge swap
- egr valve, starting issues
- Intermittent problem
- What would you do with my truck? Any opinions would be awesome.
- 98 power locks (autolock)
- My 95wont Idle At All
- 4wd ? again
- Tire Size Clarification
- water pump on 98 chevy
- wondering about Banks exhaust
- Snow plow options
- More power
- Complete Rebuild
- I need lowering advice 98 1500
- any ideas
- new fuel pump now won't start 98 chevy 305
- trade my truck!?
- 98 chevy
- 89 chevy pu steering column wobble
- Installed My NEW Thorley Tri-Y's last night + some extras=WOW!!!!!!!!
- rim / wheel backspacing question
- am i computerized ??
- posi trac
- 95 suburban Idle problem (long)
- 84 pick up sputters
- G80
- 95z71 brakes Advice
- AC Delco copycat?
- going crazy!
- White Smoke that stops Traffic... lol. HELP !
- 94 Chevy Automatic transmission
- Starting Problems after Rebuild - Need Help (96')
- Timing Question 94 C3500 7.4 Dually TBI
- has anyone ever done a lt1 swap ina 87 chevy truck
- 98 silverado power locks
- setting timing
- euro projector headlights for sale.
- Ignition....is it all related???
- Headers!!!
- HELP...Should i buy '69 c-10 SBC 4spd, 2k...QUICK
- '90 chevy needs a new engine help...
- back brakes
- Body lift kits?
- is your truck low?
- C2500 Suburban Floating Axle Brakes
- 89 k2500 error code 44
- 4wd
- Heater Control & Stereo Lights Out
- IAT Sensor..........yeah i know
- Electrical troubles
- 86 4x4, where to start?
- '92 Silverado, Cruise-Control
- tire & rims size on dropped 4x4
- compression on 305cid
- 350 to 383
- Throttle Pedal Vibration
- Pulsing interior and exterior lights
- another 4x4 actuator question
- 1984 p/up wont start
- 1997 Silverado Blower Motor Problem
- HELP! '97 Z-71 Transmission Clunk
- 1993 Cheyenne 4.3V6 TBI
- Cooling System
- 2001 voltage and rpms drop and stall
- 96 Drivetrain making grinding noise
- K1500 Gauges (Tach dash)
- Heater Prob...89 Chev PU...C1500 4x4 5.7Ltr
- lift kit for a 89 k1500 ?
- help please...repair cruise control...1990 silverado
- tires c1500
- RPM at various speeds
- 93 4.3 Rocker Arm torque specs
- Differance Between C1500 & K1500
- 84 4dr dually brakes
- ECM Blown.... Cause?
- Crazy wipers!!
- 89 Chevy k1500 w/ 305 -- Engine runs rough.
- 97 C1500 Dome Lights Stay On
- 90 chev green male wire by distributor
- cylinder compression 90 chev 305
- FX4 off road Vs. Z71 Off road.
- Replaced power steering pump now what???
- 1993 C1500 Heater Core Problems
- Trying again....Miss or Transmission?
- Tribute to all the awesome help I got...
- 87 Silverado heater core
- tire size
- Important question about wiring
- '92 Chevy Z71 Fuel Pump
- I'd like to know what my silv runs 0-60 and
- '94 Cracked Intake Gasket?
- Going to start upgrading my c1500
- Water Pump Labor
- 'Bout died tonight doing tune up
- Thorley Headers any Good?
- IMCO mufflers...
- cold natured transmission
- Heads
- 1994 Chevy K2500 Clutch??? Problem
- 02 Suburban: Erratic Idle On Start
- Intake Manifold..... anyone? anyone?
- grill inserts
- Gas pedal gets stuck?
- need a look under your hood please
- 1995 k/2500 4x4 won't work
- 72 C-10 Tach inaccurate
- 1997 K2500 454 Temp creeps up at idle
- Interior lights going out
- Seems like we all have starting problems with 98's.
- "Tamper" mode? Starts/stalls repeatedly, 10 minutes later it's fine
- noisey 5 speed
- Fuel for '97 z71?
- 98 Z71 cranks then dies, then cranks and runs fine
- WTB used JB7 ABS control unit for 98 K2500
- Engine Backfire on Pass Side Bank
- 1993 Chevy Blazer
- 93 TBI starting problem
- 98 K2500 brake question
- 1976 Scootsdale C10 FOR SALE
- 1991 Chevy 1500 w/ 406ci smallblock -FOR SALE
- Parting out 1989 k1500
- Where is the "data link connector" ???
- i need posi
- tranny oil change?
- A.i.r.?
- Sevice Engine Light WAS on...
- 91 GMC Sierra 4.3 TBI
- NEED a pair of heads for 89 C1500 305 5.0, what should I get!?!?
- Changing Power Steering Pump
- IAC valve reset procedures
- need a set of cylinder heads
- 98 Silverado starts but will not stay running
- motomaster tires
- Where is fuse/relay for heated seat in 2000 chevy 1500 PU?
- Bigger Throttle Body
- black plastic below bumper....remove it??????????
- 95 k1500 350 tbi stalls
- 1994 5.7 engine running rough
- Replace Intake Gaskets???
- 91 Throttle Body Spacer
- my truck's not level
- 1/4 and 0-60
- knocking noise from dash!
- Mirror Compass
- Best Headers for a 95 5.7 Z71
- want bench seat
- tires
- 1991 upper control arm
- rear view mirror with compass/temp.
- Keyless Entry
- no brake lights on 89 chevy 4x4
- Worth it or not
- Engine Size?
- Lift kit/Tire rub/torsion bars
- cowl induction,hood scoop ideas?????????
- 2000 K2500 diesel transmission
- Really Cold!! No Heat!!!
- Several Questions on my 99 C3500
