View Full Version : C/K
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. 98 Z71 - Keyless remotes quit working
  2. TBI to carb
  3. A little help please!!! 93 k1500 4.3l
  4. Windshield Washer Problem
  5. 91 C1500 Starts & dies intermittedly
  6. 1991 chevy pu, 305
  7. 1993 k1500 4.3L spits & spudders during drive
  8. HELP!! 1997 chevy making weird NOISE!!
  9. 84 C20 - Intermittent Rough Run/Black Smoke
  10. Massive Coolant Loss
  11. bolts not surrendering
  12. 90 Chevy 5.7 Idles Issues
  13. converting a manual to an automatic
  14. 98 1500 5.7lv8 no power whatsoever
  15. No spark
  16. 91 K1500 5.7L 350 Auto HEI - Spark Issue
  17. coolant leak
  18. 94 chevy tbi issues/loading up
  19. Mysterious Transfer Case
  20. Rear U-Joint Cap(s) Removal
  21. 1996 4x4 blinking light issue
  22. 1987 chevy pickup electrical problems
  23. Loss of power and excessive fuel consumption
  24. Carbureted to Fuel injection
  25. 1989 1500 brake light flashing
  26. Got a scanner, now I'm dangerous
  27. 1998 1500 problems
  28. 1992 chevy 1500 need oil dipstick and tube
  29. 1992 1500 4.3 with manual transmission speedometer acting funny
  30. No tail lights on 98 Silverado
  31. Undercoating the bottom half OF my 91 silverado
  32. 4l60E first gear drag
  33. Choosing tranny...HELP!
  34. 92 3500 454 No spark
  35. Distributor Trouble
  36. Radiator cap lbs
  37. 93 C1500 Transmission Wiring
  38. 1998 1500 dash and tail lights not working
  39. body lift and tire question
  40. 1988 Chevy Pickup (FS)
  41. Fuel overflow into evap canister
  42. help please
  43. Bed Rails or Bed Side Caps???
  44. 2500 4x4 Tranny Problem
  45. 1998 K2500 5.7 Hesitation/Misfires
  46. 95 chevy 1500 4x4 ABS light codes 23,12,22,21
  47. Stock Radio Removal
  48. Reverse Tire Direction? (Rotating Tires)
  49. Coolant reservoir has engine oil in it - dipstick has no antifreeze in the oil. Why?
  50. Heated mirrors are out.
  51. Painting Dashboard
  52. help with 2 problems please
  53. Engine swap questions
  54. 1989/c/k 1500 blower fan
  55. 1989/c 1500 pick up gages
  56. no power to injectors... please help!! after 4.3l - 350 swap
  57. 1998 c1500 starts then stops instantly
  58. 05 c/k fuel pressure regulator
  59. 94 K1500 - Only get 3rd gear
  60. '94 5.0, no rpm, mph, or shifting??
  61. 74 400 missing
  62. headers are headers right?
  63. 7.4L long crank time when sit for a few minutes
  64. Stripped Alternator Bolt head on 89 K1500
  65. Cv Joint Boots
  66. pinnouts for instrument cluster?
  67. cpu out?
  68. 5.7 roller rockers 93 gmc new motor
  69. 1999 Chevy 3500 Dually Rear End / Final drive
  70. Neutral saftey switch?
  71. 700R4 Build question
  72. 1983 Pickup, Shift Linkage (Bushing)
  73. 1998 5.7 timing question
  74. 95 Suburban Seats
  75. 95 c/k seats
  76. leak on front differential k3500
  77. 1991 7.4 no spark no fuel
  78. No Codes
  79. No cruise Control?
  80. tdc after eplacing head gaskets 4.3
  81. 2500 express Van fuel problems, 305 vortec
  82. 95 chevy van won't shift
  83. 97 vortek 7.4 ignition timing question
  84. 1990 k1500 electrical nightmare!
  85. 91 C1500 wont start unless gas petal is on the floor
  86. Red brake light on, front locks up ?
  87. 2WD to 4WD Problem
  88. 95 5.0 to 5.7 Motor upgrade
  89. 88 7.4L TBI loss of power issue
  90. 94 c1500 silverado won't start consistently
  91. 96 K1500 4wd Vibration in Front Wheels
  92. Motor is in now but a Question
  93. O2 Sensor Brand Opinions
  94. 88 scottsdale auto front locking hubs?
  95. 95 4x4 5.7 K1500 ABS light on
  96. Warning - Heater hose quick-connect fitting
  97. 94 C1500 silverado won't start, but turns over
  98. 1991 K1500 StiLL CoLD STarTinG - H E L P ! ! !
  99. 5.7 timing question
  100. Intermittant miss
  101. 96 Chev 4x4 1500/ front wheels wont lock anymore
  102. 98 Chev 1500 5.7 fuel evap code
  103. 95 chevy pickup oil pressure
  104. fuel pump issue
  105. idle air control valve troubleshooting
  106. Great deal for c/k Silverado owners
  107. No start,no anything electrical problem
  108. how do I make a dual exhaust quieter?
  109. 97 k1500 oil pan removal
  110. performance upgrade advice
  111. 93 chevy 1500 V6
  112. 94 K1500 hard to start runs rough to warm
  113. 98 7.4L Crew Cab Dually losing coolant into overflow tank?
  114. Major oil leak
  115. Tall deck or not
  116. Error Code 43 on 88 1-ton dually
  117. rearend issues
  118. solved the problem 95 k1500
  119. 92 Cheyenne 1/2 ton with coolant leak
  120. 1998 chevy 3500 HD Heater problem
  121. Studder in tranny in overdrive
  122. 93 4.3L misses when wet, static on radio
  123. More power from my vortec v6?
  124. 1996 C1500 transmission interchange
  125. NP203 problems
  126. 1989 k1500 Chevy 4x4 shifting
  127. 97 occasionly wont decel
  128. 2wd to 4wd??
  129. No idle
  130. 94 Silverado low headlights no working
  131. Overhead Console for '99 C 1500
  132. Oil Pressure - How high is too high?
  133. 97' Z71 Brake issue (HELP)
  134. Fuel Issues
  135. 1989 Chevy K2500 4x4 Problem
  136. Cv halfshaft to short
  137. 95 k1500 stalling out
  138. Intake Manifold question
  139. Pulley Issue
  140. lift kit and tire question
  141. lift kit and tire question
  142. 1997 K2500 7.4L 4L80E No TCC
  143. 1998 k2500 in a snow bank
  144. 98 Silverado 5.7 Fuel Pump?
  145. 1991 Chevy C1500 4.3L Dies No Fuel
  146. fun truck 88 1500
  147. 88 gmc won't start
  148. 95 Chevy Truck 1/2 Ton, 350/5.7L
  149. Multi issue questions
  150. 91 K1500 5.7 Cold Start TReMoRs!
  151. 1990 Silverado starting problem ***HELP***
  152. 1991 K1500 Dash Brake Light Flashing Code
  153. Questions for the professionals
  154. Wheel and Exhaust Suggestions 1994 C1500
  155. Transmission
  156. 95' K1500 Cylinder Drop
  157. 1996 K2500 5.7 random misfire
  158. 95 Suburban 4L60E Trans Fail-Safe mode
  159. '97 1/2 ton Chevy 4X4 Brakes!
  160. 97 chey rear end
  161. idle problem
  162. Strange noise
  163. VSS Vehicle Speed Sensor
  164. 7.4 Vortec misfire issue
  165. 90 k1500 intermittent fuel problems (thats new!)
  166. Tow / Haul does not work
  167. ball joints
  168. quick question about mirror..
  169. 1997 silverado won't start. Help!!!
  170. 94 Chevy Duelly Headlight fuse location?
  171. 1998 Chevy 5.7 hard start.
  172. Overdrive issue
  173. Lack of power!!
  174. 1990 5.7L Silverado Engine starting problem
  175. Help! Low beams and Raido stopped working
  176. 96 4x4 steering question
  177. Chevy/GM Truck Fuel Sending Units
  178. Vibriation
  179. Value of a 99 K1500 EXT CAB Z71 with 53K
  180. Lights/Dash dimming
  181. replacing fuel pump in 95 k1500
  182. problem with k1500
  183. 1993 K-1500 Vibration
  184. Need Help!!
  185. 700r4 putting 2WD trans in 4X4?
  186. Fuel PSI
  187. no oil to top of head
  188. Ramps
  189. What this time? 97 Silverado 5.7 auto won't start.
  190. Coolant Drain Plugs K2500HD
  191. 1995 C2500 specs.
  192. 98 C1500 clutch/fan removal
  193. ECM troubles
  194. HI/LO Blower Relay
  195. 1995 K1500 5.7 Engine Swap
  196. 97 GMC k1500 4x4 Problems!!! Help!
  197. 89 TBI problem
  198. 87 TBI question
  199. 1986 gmc diesel
  200. A/C issues ??
  201. 90 K1500 timing issue
  202. wet weather no start till dry again.
  203. Trouble Shooting Heater
  204. Rotor Removal
  205. Coolant Leak
  206. '95 3500 HD speedometer
  207. Replacement tire suggestions
  208. 98 1500 5.7L Random Misfires
  209. Pitman Arm
  210. 95 2500 HD 3/4 4x4 pitman arm removal
  211. install 5.3 engine in a 1968 c10
  212. im pretty lost at this point
  213. charging system?
  214. Adding Turbo System to TBI???'s
  215. no roll
  216. 2000 k 3500 runs bad when warm
  217. Wiring trailer brakes
  218. 97 checvy 1500 truck
  219. erratic idle, lean code, hard start on 95 K1500 w/5.7
  220. 1996 Silverado Won't Start
  221. 1980 k10 dies well driving. (electrical)
  222. body transfer
  223. How to make a SB 350 in a 1989 c1500 sound like a ferrari
  224. A/C Compressor
  225. hydraulic clutch 95 k1500
  226. Dimming lights
  227. New Full Size 2 Door SUV 4x4
  228. need help 98 chevy 1500 Z71 5.7...runs badly
  229. Door lock remotes standard on all trucks?
  230. Shifting blues...
  231. 97 k1500 steering sensor discontinued?
  232. Causes of "Too Lean" Code
  233. Pulling to the right under braking....
  234. temp gauge
  235. '84 5.7 doughnut gasket or not.
  236. timing off
  237. Radio Problems
  238. 4l60e tranny
  239. Will a bad Oil Press sending unit cause truck to stop?
  240. 1998 3500 Chevrolet Crew Cab Front End Shimmy?
  241. Ran fine yesterday won't start today
  242. Rusted-on rear drum removal
  243. ECM Custom Tune
  244. codes 15 and 32
  245. Dash cracks
  246. alignment
  247. tranny problem
  248. from 2X4 to 4X4
  249. loss of fuel pressure?
  250. a/c compressor not switching on
