View Full Version : C/K
- 98 pulling troubles
- Need Header install info -
- power rear window
- help with speed sensitive steering
- hypertech power programmer
- new pics
- Odometer not working
- cab swaping
- heated seat in 99 tahoe
- windshield crack 87 silverado
- so so sad
- Rattle while idling?
- Buying wheels...think they will fit
- torque specs on 350 heads
- Q Power.....or not?
- Truck wrecked, now no tail lights!!!!
- 94 Silvy w/ 4.3 lacks Horsepower
- Pondering Vortec Upgrade On My '94, NEED HELP
- How many miles you got?
- Taking off front d-shaft, 91 k1500???
- eaton posi for 85' c10
- power locks
- Questions about this and other older Silverados. PIC
- Cheap power boost
- New cam....and such
- which tires do you ride?
- 305 To 350 Swap Problem
- 1994 K1500 front pad replacement
- not accelerating
- 1987 changing from throttle body motor to carb. motor!
- 1996 305 to 350 idle surge
- smoke when shifting
- A weird smell and water or gas out of the Pipes
- Engine Starting Problem
- Fuel Tank Switch
- 95 C1500 manual trans help
- 87 not running... not getting gas
- 454 ss wheels
- 1998 GMC Pickup,PO306 Moved from "Venture forum"
- 97 4.3 stumble on acceleration
- Posting Pictures
- 95 4x4 question!!!
- My truck thinks it's a boat....
- Catalytic Converter 1996 C1500 4.3L
- New member..
- '99 Chevy 454 mileage
- silverado power windows and locks
- Electronic shift kit
- Front rotor warpage
- 94 starting problems
- 94 backfiring/popping
- Transmission temp
- '92 350 -- idle hunting on hot start
- 86 Silverado windshield
- emissions diagram
- how do i remove the bed on my 89 c1500?
- Driveline timing.
- Oil pressure drop! is it the pump?
- Sputter at idle/worse when in gear.
- harmonic noise 1400 rpms
- 94' 1500 dieing out and cranks no fuel
- Test Power to 95 Silverado Radio
- 86 Custom Deluxe Vaccum lines
- another torque converter question
- Well I have more major problems...no suprise sombody please help
- Performance parts for 83'
- 91 Silverado tranny problem
- 88' K1500 Silverado - Starter Grinding
- Help! Don't know whats happening
- Transmission Slip
- Random/multiple cylinder misfire
- Problems- Factory Radio Swap
- Anyone here have a Pro Comp 6" lift (obs)?
- remote start car alarm
- composite headlight conversion
- throttle cable for tranny?
- 97 Transmission problem
- Problems with OEM driveshafts?
- O2 sensor location
- a good setup for my 350
- Leaking Antifreeze
- Water in oil
- 1995 chevy cheyenne 4X4 fuse location
- My 1999 Suburban was a 1998 relabeled
- dash cluster lights out, best option
- Shocks!
- 88 Chevy cheyenne
- Help! Major Problem!
- alternator wiring diagram
- Idle speed and engine temp
- Coolant Temp Cycles during warmup.
- need part info
- 350 V8 5.7
- Paint job
- I need a trans BAD!!!
- Major problems with Headers..PLease Help
- ECM (Computer) in Default Mode?
- 89 K1500 starting issues
- stupid question but i need to know
- EGR valve opens just off-idle, closes at wfo
- Another lift ?
- Electric Fans
- Best place for OBDII code definitions?
- Spare Tire Assembley
- Replace Pitman Arm, how hard?
- 1990 TBI 350cid bad mileage/ choppy idle
- 1994 4x4 problem
- Anyone running roller rockers on their 5.7 Vortecs?
- 1990 C1500 Parking Brake Flashing
- Any tips on what controller and 7 way connector I should install
- Bleeding brakes on a 98 3500
- Front Spring/Rear Block lift for 86 chevy
- 1998 power steering troubles
- prerunner!! how to build??
- 98 Z71
- quick rearend question
- Shifting Hard at High Speed
- Knocking On Cold Mornings
- Gauge cluster swap
- Adjusting Idle
- 1998 3500 Crew: squeaking front suspension...
- Smog Pump
- rocker arms or camshaft
- 1993 k1500 Rear Differential for sale.
- OEM Wheel Backspace or Offset
- Dallas 85 C-10 Newbie Help..?
- 89 silverado operating temp
- What would cause this???????
- stock horsepower?
- What do you think this trucks worth
- Different shafts for a 10 bolt rear end?
- interchangeable rear ends for 90 sub
- 1995 4.3L won't start
- 95 c1500 - tranny shift issue
- Custom SUb Box
- Difficult to shift.
- I Need A Winch
- Block Lift for a 86' Chevy K10
- 98 Silverado Starting Problem
- '86 chevy heater fan
- 94 k1500 4.3 v6 gas mileage
- need carb and gas mileage help
- More on 1987 Chevy Truck "sticking throttle"
- trans problem?rearend???
- Exhaust Pipe Questions
- 98 Z71 serice engine soon light came on then went off?????
- 87 Chevy Truck "sticking" throttle
- 1989 Short wheel base chevy
- my truck is dead
- Easiest way to set TDC & dist timing on 93 k1500 5.7
- Will a Holley 670 work on a 95 350?
- Misses badly when tranny shifts down
- 1981 C-10 tachometer
- Rear Differential
- how can i determine the options on my 2500
- need smog expert - 1997 Tahoe 5.7l
- Weird intermittent starting problem...
- PROM chip info for a 1993 K1500
- head torque specs
- Lowering Rear End 96 C1500
- 1985 pickup
- Ignition Switch Wiring
- truck pics
- injector spacer?
- cruise control
- 1992 K1500 w/ 350 - hom much HP
- Advancement timing wire on a 94' Chevrolet Pickup
- Outside Door Handle
- Upgrade to timing gears in 350ci. engine
- '98 silverado, brake,tail lights problem HELP
- I'm losing my mind?
- 95 ignition switch replacement help
- 93 k1500, wants to stall when cold
- is there a relay?
- 93 truck burning and leaking antifreeze
- 91 Silv. Rear suspension
- no speedometer/odometer/abs light on
- Any drivetrain experts out there?
- 4.3 to 350 chip question hypertech??
- rough idle after mod
- cat knockout?
- 94 chevy 350 motor issues?
- 94 Chevy Dash To A 95 Newwer
- K&N Filter Question for 94' 1500
- Power Mirror Control
- Drip Drip Drip
- Vehicle stalls only when cold
- K1500 front suspention
- slight miss after tune up?
- Front Straite Axle Swap
- The Front Grille Of a 1990 Chevrolet Silverado
- Need a 1991 k1500 microfiche
- Help backfiring through the Top w/ pooling gas
- oxygen sensor heater circuit
- Mass Air Flow Sensor or Cat problem???
- abs problem
- 1993 K-1500 wipers work intermittantly
- 98 1500 ext. cab 2wd lowering questions
- MAF problem?
- Will 2000 Silverado 2500 2wd Haul?
- cruise/turn signal
- 97 Z71 Front Diff acuator
- Stock stereo doesnt work anymore?
- performance air filter question
- antoher tire question
- things i WOULD REALLY like to know...
- a/c doesn't get cold
- Power Loss Question
- Help with 97 350 missing
- Fuel Line Help
- need to know
- Radio Swap-AM to AM/FM stereo cassette
- Seat wobbles
- flareside cargo hooks
- Abs Lights
- Abs Light
- Four Wheel Drive 95 Suburban
- 1989 scottsdale 2500 door pins
- What does A.I.R. stand for on 88-95 5.7L TBIs?
- Radiator
- What Transmission Do I Have??
- Turn Signal Problem With Lights On
- 95 K2500 4L80E problem
- 92 350 Hyd. lifters stuck....ALL OF THEM????
- cam for my 91tbi 350
- Lighted grill emblem
- Turnsignal and brake light out, not the bulbs! Please help.
- headlights problem 92' silverado
- New Truck, new problems.
- Shift problems
- quick diconnect fuel line woes
- Trans Whines And Is Slow To Shift While Truck Is Cold.
- Headers for a 72' 454 engine.
- Tire Question
- 1988 Chevy fullsize 1500s
- Why is my truck drinking coolant?
- 350 vs 454 for sleeper
- problems with my 2000 elantra
- Hesitation???
- Rim Changes
- replacing air intake with edlebrock-86 k10
- Heat riser ???
- rear view mirror upgrade-need schematic
- Is it possible to re-program computer for better mileage?
- codes 42 and 43 and 59
- Body work
- Need some information
- fuel pressure low not fpr
- adjusting doors an a 89 chevy 2500 scottsdale.
- water issues
