Chevrolet
Avalanche | C&K | Silverado | Suburban | Tahoe
> C/K
View Full Version :
C/K
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
Tranny problems
Fuel Pump Intake Plugged By Little Sock?
air in heater core/cooling system
strange prediciment
code 0300 flashes under load
The world is coming to an end......
94 K1500 shifting hard
Getting lift...tires?
amsoil synthetic/filters/etc.
Re-activating the immobilizer
location of Body Control module
Tune-up help with parts ??????
odometerandspeedometer
trailer brakes w/o brake controller???
1988 K1500 Pitman arm replacement
carter afb
Speed Sensor question
Chuggle -- more info -- no ideas?
Liquid Leaking from Driver side Header
Code 21, TPS voltage reading backwards
Huge Tranny Problem Help!!!
'92 5.7 -- Surge/chuggle or hesitation?
no brake lights on 98 K1500
heater wont turn off?
problem with a/c vent control 88 Silverado
Dex-Cool Sludge
Bad engine? Hope not!
gas milage drop
antifreeze leak
97 Silverado vibrating accelerator @ 42-52mph
No start problem...
91 C1500 Strange Water Leak ??
Got The New Engine In
couple questions from a new guy
1994 GMC Sierra 1500 Failing Emissions...Low Idle Cyclical Stalling/Surging
92 Ext Cab 4x4 - Interior
F42 SUSPENSION... What this
turbocharged 350?
Rear main seal
project car for sale
98 1500 4X4 humming when decelerating?
Rebuild or Swap?
LT-1 into 94 3500HD
88 Stepside 4x4 Curb Weight
Beefing up for performance
1500 Runs Rough in Overdrive
97' Z81 Clutch Petal
93 C-1500 4.3 4L60-e trouble code help
valve adjustment and/or lash???
suspension lift?
81c shortstep side for sale
'94 truck interior lights question
victory is close, I can smell it......
Starter Drive
Motor install 99.3% complete BUT.......
paint job
92 4.3L starting and stumbling problems
how do find out?
Transmission code
Aww man, what?! Oil Leak!
asbestos
lowering an 1987 c-10 with 20s
Windshield wiper problem 1994 Silvarado
miles per gallon
Engine cutting out (long)
Flipping Air lid on air filter
heater issues
On Highway, Backfired then Died
Service Engine Light
Changing Wheel and Tire size
Fuel pump opinions wanted
1993 C1500 4.3l 2wheel drive HELP
HEI distributor replacement
My 4.3L needs more power!!!
Flowmaster 40's vs Flowmaster 40's
02 sensor probs
Oil leak
oil pressure
95 clutch won't disengage after replacment
Catalic converter cutout
rear differential leak
Nelson Tune
Body Lift kits
No tail (running) lights on '94 crewcab dually
Air Vent Temps
O2 sensor
cam
Ignition problems on 96 Silverado
Intake leak or not?? Long story!!
wonder shine!
1989 Chevy %#*@ Nightmare! Need Help on Brake, reverse and running lights
having difficultys
97 c-1500 fuel pump
Water injection systems
Exhaust sound
Cheap mods
Help please, truck won't work
mass air flow sensor
4.3L shorty style headers
1983 C10 Question
how does V6 sound with flowmaster
97 C-1500 Vibration
1973 C-10
Brake problem 73 c-10
1997 k1500 ses
More POWER!
resetting a Brake Proportioning valve?
Odometer Stopped
lt1 help 4 chevelle
74 pickup... or indy truck?
LT255/85R16...Will they fit??
heat stove
tranny shifting problem
Rear Problem
110 Octane Race Fuel in 454
For Sale
95 transfer case linkage
How Do I Remove Rear Speaker Trim (97 Z71)?
Odometer Rollback on Ebay, Pretty Funny
Brake Caliper bolt snapped... DANG!
Dead Computer?
97 4L60E code P1860 laughing at me.
K1500 1997 air conditioning
RPO codes
Missing posts
Upgrade 94 grill to 98 grill
88 k5 wont go over 30
Favorite 4X4 Magazine
roll pan
Air conditioning compressor won't engage
air intake and exhaust
4l80e rebuild
Good 1/4 mile time?
Coolant leak around T/C Cover
throttle body spacer
Another P0300 code question
1994 4L60E Gettin' worried...
Factory Service Manuals??? Where to buy?
backfiring issue
88 TBI? problem
98 Silverado problems with starting
Hypertech Question...
strange rear end sounds?
new additions for 86 454
97 acceleration problem
1993 K1500 4.3 Frustration!!!!
1990 Silverado Stalls
1995 k1500 truck has no second or fourth gear reverse works fine.
back-pressure
pre 1986 Chevy 350 long block
97 1500 INtermittant no start and PCM codes
97 k1500
Puzzleing
My 95 silverado feels like its cutting out
97 silverado interior lights
82 C-10 L6 to V8 engine swap
'94 Chevy 5.7L idle way too low...
1987 Chev C20 Crewcab brakes
97 Idle Vibraton
front end steering play
Transfer case or what?
Bench Seat to Bucket Seat - Need Help!
Towing 88 Chevy 4x4
quasdrajet 4 barrel won't open no more
Blower Relay Location
Truck not shifting into 4wd
92 silverado no brake lights or turn signal
V6 transmissions
FOR SALE!!! 20" KMC Stealth Rims and Goodyear Eagle GT II Tires FOR SALE!!!
restoration
A nice little sparkplug trick
New Tires!!!!
TCC Solenoid Location
In Case You Run Into This......
Funny whistle noise Part 2
7.4 L Fuel Injector Size
totalled truck.....
Repaired Temp Control Mod on 91 Silverado
How would I go about running a house AC thru my sliding back glass?
Clack Clack Clack...
Broken Wire- Where does it lead?
New Exhaust
Power cycling?
Bone Dry Fuel Tank
Transfer Case Fluid Type
intake
Tranny shifts late & PCV valve pops up.
Daytime Running Lights
1996 3500HD PCM Problem
Another Trans Problem
97 Steering Problems
Parts included with Z71 package?
advice on rod knocking please
transmission housing question?
1990 Silverado runs rough and stalls
700R4 shifting question
acceleraation problem
towing with a jimmy
Clutch problem??
Problems with my 60 p/u
Favorite Truck Part
Strange tranny problem?
clicking 5.7 V8
305 tbi problem!
25% better mpg 30% better horse
Pulling boat in Overdrive ?
Problems After 305 To 350 Swap
4l80e transmission trouble
Mirror Fell Out!
98 chevy 2500 350 5 spd islow idle down
How do you spend?
couple questions
good price??
Kv average per cylinder
Leaky Oil Filter Adapter (1997 Chevy K1500)
Specs on 1996 C/K 1500 Z-71
1988 Chevy K1500 Wire Diagram
400000 Ks
Extended profiles
interference or non-interference engine
Spark Arrester Question..!!!!!!!1
Funny whistle noise.
Cold Ticking...
3.73 Gears for an 86 chevy
700r4 pressure cable/ oil presssure sending unit question.
Interesting Topic
lobing Idle
Blue smoke at startup and at takeoff.
looking for a f/s truck
98 Silverado. Must be a starting problem.
Gas Mileage on 86 Chevy
royal purple
throttle body
Front passenger side turn signal lights up when hitting the brakes?!?!?
Lurching when stopping
rear view mirror help
Will stright pipes guzzle gas?
1985 Chevy Pick Up Problem???Need Help!!!
1994 4L60E soft shifts
Spray Paint
Replacement 4wd actuator, '96 Suburban
93 5.7 intermitten miss
97 C-1500 starting problem
tranny fliud
2000 Tahoe electrical - accesories circuit
2000 Tahoe error code P0440
Trans replacment 700R4 90 chevy
oil pressure guage
1996 vortec 5.7 throttle stop adjustment.
