View Full Version : C/K
- 99 crew cab nerf bars
- fuel pump whines
- cabin air filter on 1998 k1500
- shift kit.
- wheels
- 91 chevy K1500 4X4 Brakes?
- Stalls when put in gear
- Why Not Air Shocks in Rear for 1" Lift?
- still having problem with shutting off
- wiring diagram for
- Memory for my Aftermarket CD Player
- 5.0L supercharger
- 4/6 drop, what size wheels?
- reverse lights
- 92 door panels/ arm rests
- need help finding a cam
- wiring diagram for 1996 chevy truck
- Geo prizm 1994 Radio Err9
- 1993 torsion bar removal for lift
- Modding 97 Silverado
- NO SPARK from coil
- 98 Z71 For Sale- Chicago area
- recommended fluid
- Fuel Filter Replacement 98 K1500 5.7
- '94 K3500 4x4 rough start and poor MPG
- Tow package for 98 K1500
- Cheap 1" Lift: air shocks or add-a-leaf?
- Turbo 350 slippage
- Engine Problem
- Speedometer Adjustment?
- 86 chevy leans left
- Best fuel pump?
- Heater Problems
- 4.3 Vortech
- Howdy
- car audio
- 93 1500 drivability
- Are there Problems With 305 Motors? 99 5.3s?
- how to modify 82 c10 to electric fuel pump so that it stops with engine
- A/C Compressor bearing
- best option for lowering a 92 c1500
- No Power to 91 silverado fuel pump
- 1991 5.7tbi stalls
- Clutch '97 Silverado Manual
- Used 1998 K1500 engine problem?
- Parking Break Warning Light Flashing???
- 1996 vortech 5.7
- rough on cold starts (timing)
- Lowered my '88 C-1500 by 11 inches!
- 1989 chevy 1500 4wd sat for 1 year, only has first gear and reverse
- Heater Fans woes
- Idle too fast
- Delayed fuel pump shut off
- Power steering pulley removal question
- Broken Hood latch
- Maybe ECM problem, or should it be like this?
- gibson super truck exhaust???
- Installing LED bar on roll pan
- Wheels For Sale
- Brake Warning indicator
- 94 1500 5.0 liter heater line busted
- air conditioning compressor stays on
- front end
- door panel removal
- Torque Converter??
- Stupid Deer
- Valve Covers
- vehicle specific electronics question, sub enclosure
- wrench head needs help
- 93 k1500 temp guage
- rough idle, please help
- Some Q's On Ford Torsion Bar Keys...Already Did Search
- '85 C10 Distributor
- 4 low
- No injector pulse TBI
- Charging system problem 89 chevy truck?
- Turn signal/cruise control
- Shimmy/vibration with washboard effect
- air conditioning causing overheating?
- No heat, Def blows A/C
- replacing cat ?
- Need help Flushing Coolant
- Air intake kit
- 99 Suburban Keyless Entry Problem
- Extra CPI Injector Upgrade...Anyone Want It?
- 1976 Scottsdale
- anyone have a tailgate for sale at a resonable price?
- 97 2-wheel drive 350 vortec questions
- Used Truck Value????
- 83 k2500 turning radius
- dual exhaust 98 K1500
- Hitch question..
- your opinion please
- WANTED: Interior for 94 extended cab
- 69 Chevy C10w/ '76 400 smb issues!
- bad coolant leak
- Sloppy 5 speed
- 1986 Chev. Suburban Parking Light Prob.
- timing problems code P01345
- Parting out 88-98 Chev/GMC 1500 truck
- blowing fuse
- Rear differential leak
- Can anyone help?!?!?!?!
- 98 k1500 starting problem
- Not getting fuel
- Need help changing heat core
- 83 3/4 ton. 350 mod help
- engine oil cooler conversion. possible?
- Carpet
- Stripped Headlight screw
- New truck, old AF'er... :)
- Gas Is Drowning Me!!!
- New Here.
- vacuum leak??
- 1998 Vortec 350 Intake Manifold
- 97 Z71, fluid levels
- 1987 k or v motor rebuild nightmare
- Timing Problem
- 98 1500 trailer wiring
- Dome light
- egr solenoid
- Is the Silverado..
- Captain or Bench?
- 98 Chevy Truck check engine light came on...
- Ball joint replacement
- 86 chevy won't turn off
- Engine swap starter problem?
- silverado
- Door Speaker Install On a 2000 K3500
- Ingnition problems?
- Strange Event - Electrical Short
- shuddering/ vibration help!
- abs sensor location?
- headlights dimming
- Turn Signal Bulb Blowout 8057
- 2500 HD Dash Gauges
- help please
- Brake lights not working
- Contact Points?
- any one know a link on how to body drop a chevy
- 1993 k1500 3" lift
- Steering problems
- ignition timing
- Tonneau Cover for sale $425 NIB
- 4x4
- 95 Burb - Lack of Power
- 95 Chev 1500 heater doesnt work
- 1989 clutch engagement problems
- Strange shift problems 1996 Z71 5.7
- 383
- 1990 Chevrolet 1/2 ton FOR SALE (NEW PRICE) TRADES WELCOME
- fuel pump or no?
- Power Door Locks Not working
- poor idle when cold
- testing for a bad poppet valve
- 1997 C1500 failing to start - intermittent
- 1997 C1500 Fuel Pressure Connection
- 350 heads on a 305?
- 97 Tahoe RKE console location?
- Inadequate Fuel Volume??
- Humming or Whinning noise
- what is the sensor on the firewall, passenger side
- new air filter temp sensor doesn't work
- Backfiring Problem
- A.I.R. removal
- Steering wheel wobble.
- '93 chevy blowing 4wd fuse
- 97 tahoe 5.7
- 90 5.7L + FIPK + Spacer?
- axle nut size and speed sensor repl proc
- 4x4,4wd help, please
- Blower Motor dead. is there an upgrade?
- Brakes-ebcm,dumpvalve or combination?
- I can't figure this %@#Z'n silverado out.
- New tires
- 97 hard to start
- Dont know whether to switch to carb or not
- 17" niche wheels 5 on 5 bolt pattern
- No Brake Lights/Double Speed Turn Signal
- Truck running horrible....why?
- 97 silverado, new fuel pump, truck won't run
- Need help sourcing out power seat parts...
- what is this emblem for?
- cargo light fuse in 2001 silverado
- dash,park lights....blowing fuse
- I need good front shocks, no cheapies please! 1996 Z71 Silverado Ext. Cab
- Fuel Gauge
- Spooky C3500 starter problem
- ZF six-speed conversion
- Changed intake gasket, now there's power loss
- 1996 350 cam and lifter question
- 97 chevy truck clunks in slow turns
- Cheap, Used 350 5.0 or 5.7. rebuilt or not working. where at!?
- Brake light on dash always on.
- 1962 Chevy Shortbed Stepside
- turbo 350 problems
- open loop operation
- <REQ> ADL pin assignments 1991 6.2L
- Speedometer
- 1986 chevy c10 oil pressure
- Vacuum Test
- general carburetion question
- 96 1500 will not start.
- Code 44 ?? O2 Sensor? Lean Exhaust
- 97 k1500 Dies when put in gear
- Question from a non-educated chevy owner
- rear lights
- 96 K1500 wiring diagram for 7 pin trailer socket.
- C/K forum is for 1998 and older models.
- Front Wheel Drive Accuator
- what bolts to my 80k20 205 t-case ?
- 93 5.7ltr code 35? Check engine light on at idle
- 1990 K2500 Tranny clunk/clang
- Throttle/pedal link 2004 Tahoe
- I am a new 4x4 person..please help!
- A/C problem
- Ac Unit blows Hot air
- need wiring diagram
- door handle replacement
- Separate forum/page for Avalanche/C&K/Silverado/Suburban/Tahoe ?
- what is the diff between, Multi-Grade Oils, and Straight-Grade Oils?
- largest tire size
- Tailgate Window Filler
- header install
- 86 Chev K20, fuel guage or sending unit?
- Dash Light Question.
- body kits
- 5.3
- Tranny/rear
- popping noise
- sreering help
- Bad Idle at start up 5.7 tbi
- Brake Light Switch Keeper?!
- rear end vibration, pump not shutting off
- Uneven Tire Wear on 2002 2 wheel drive 1500
- Headers
- Mass Air Sensor
- Oil Pressure malfunction
- Air Conditioning Question
- winding noise in 97 tahoe
- poping noise when shifting 1st to 2nd 2004 yukon
- Replacing fuel pump 97 tahoe
- 96 abs light on
- 2000 k1500 factory tow hich question.
- Couple of questions.
- lowering kits?
- Anti-freeze losses . . . . . .
- hurricane victim needs help! NO 4WD! tahoe
- Rear lighting problems
- acceleration irregular
