View Full Version : C/K
- Gear Spliter
- Chevy C10's!
- saddle tank recall
- ac probs
- intermittent a/c blower!!!
- more about bad fuel pumps
- Chevy to GMC grille swap
- Fuel Pump Change Without Dropping the Tank
- strait axle swap???
- HELP! Is My A/C Compressor Shot?
- 95 chevy hardly starts
- ac problem
- Smoking Wire(s) at attempted start
- Help w/keyless entry
- Won't start
- 95 k1500 z71 owner's manual
- Fuel Problem?
- Question about A/C for you pros and smart people :-).
- Door latch failure from inside 1999 Tahoe LT
- distributor cap and rotor wear
- Running Amp cables
- Help Lean Trouble Codes Maybe Vleak
- timing of a 95 k1500 5.7 w/tbi
- Question about oil pressure
- Airaid TBS question
- muffler
- speedo works but vss is bad. possible?
- shift ???
- 1 wire to 3 wire oxygen senser swap
- Electric Problem - Won't Charge Battery - '98 5.7
- Duel Battery Setup?
- Cross-over steering
- Front end Noise, Brakes
- Exhaust
- Oil consumption, Valve stems?
- Fiiirrrrsssst to second-harsh shift
- abs codes..
- 4l80e transmission problem
- check it out! truck for sale!
- 1994 5.7 propane misfiring
- speed sensor- abs or vehicle?
- Starter troubles
- Phat gauge face...
- Wiring schematic
- daytime run lights
- Lift kit install nightmare
- 1996 z-71 transmission nightmare
- a/c question
- tps 95 vs 96
- th350 or 400 instead of 4l60e
- 5.7 engine shut down
- engine shut down
- TPS Sensor low input
- transmission 2nd & 4th gone
- gas gauge pegs/dies
- Air Intake Question??
- Transmission won't break free from engine?
- Dash rattle is driving me wacky!!! HELP!
- 91 to 96-98 interior swap
- best place to get a rebuilt motor
- True duels
- no power to fuel pump
- Very Hard Shifting 700r4
- Master Cylinder Question
- How to shave logos and emblems...
- NOISY Shifting
- No power
- 97-4.3 fuel relay overheating
- 84 od tranny
- Service engine soon
- 84 Od Tranny ??
- lots of new parts still wont run...
- GMC/CHEVY what's the difference???
- 98 Z-71 spongy brakes, might've found a fix, suggestions???
- Aftermarket Rocker covers
- somebody answer this question 97 Z71
- 1993 C1500 overheating
- stalling at idle 1989 chev 305 k1500
- exhaust keeps breaking!!
- Engine miss at idle, Cyliner #1
- 97 4.3 vortec no start Please Help!!!
- Big Throttle Body upgrade (Holley)
- whats reasonable?
- chevy 1991 2wd leaf springs
- sputtering at cruising speeds
- Headers for 1998 cali k1500?
- 305
- Rear Axle "Clunk"
- 89 chevy vibrates at low speeds
- Any Transmission experts? Shifting Problems, Any ideas?
- day time running lights
- Air Conditioner Problem
- 4 Sale GM Navigation Radio
- flex-a-light 260 or 280 duel fan
- Pedal Vibration
- Ground Effects
- lift
- what year engine
- TBI problems Please help
- 96 Silverado won't start after auto start removed
- 95 Chevy mods??????
- '96 C1500 headlight lens replacement?
- Oil Pressure Problem!!!
- more power out of my 4.3
- door latch
- 1997 Suburban Whining Noise After Oil Seal Replaced
- Scratches in glass
- how to adjust valve lash
- whats the best cam to get
- 1991 C/K brake lights won't shut off
- who's got the most km?
- front end leak
- stripping paint
- Stereo / Subwoofers for EXT CAB truck...
- tilt steering sticks
- Yukon XL Rear End Whine
- help with my exhaust FAST PLEASE!!
- v6... vs....v8
- Cummins swap?!?!?
- Quick question about different year engines and parts compatability. HELP!!!
- 1998 Silverado 4x4 ignition warning chime
- '94 6.2L code 36
- 89 4X4 stalls when warm
- new user, many questons, need help.
- Plans for Exhaust
- ticking until warm
- 97 Z-71: Rebuilt Tranny Yesterday; Driveshaft Clunks!
- a/c clutch 94 blazer 5.7
- Door Seals
- 96 Chevy Tahoe has issues
- 1993 c1500 4.3L Motor Problems
- Oil Pressure/Aftermarket Gauge
- Auto dimming mirror comp/mirror
- Does anyone know!!??
- 94 k1500 v6 rough acceleration/stalling
- 'Dump' exhaust....
- FlowMaster Mufflers
- rust free cab for 1977 3/4T
- transfer case
- Cracked Plastic Radiator Tank
- Anybody Get Dealer to Replace Tranny Valve Body Under TSB?
- A New Plan..
- stalls with brake
- hey guys
- 1991 3+3 1 ton flatbed
- slammed and shaved truck for sale!
- Vibration...???
- blinking brake light indicator
- Dash indicators on a 91
- 305 equipped with Super 40
- Ball joint
- pitman arm bolt
- oil leak
- Erratic Temperature gauge
- 85 chevy c10 problems
- Stalls after 20 seconds
- SES Light on
- Need Help!!
- Are there free-wheeling front hubs available for 98 K1500?
- pushrods,rocketarms
- speaker installation
- No Power Clicking under dash
- Brake Bleed
- bypassing the regulator
- PS power window not working
- Heater Core/ Evaporator swap in 96-99 trucks
- 1997 c1500 4.3l won't start
- New Exhaust Parts
- 88 k2500 headlights quit working
- 1990 chevy 1500 brake problems.
- Sputtering when Accelerating
- Squeak
- 92 Silverado keyless entry issues
- How can I tell if my motor is really a 350 or a 305?
- Engine rebuild
- Left rear seal Help
- Setting Timing
- HELP! How Do I Stop Wiper Mechanism From Sqeaking (97 Z71)?
- Forget The O2 Sensor!!!!!!!!!
- heater blower motor
- oil filter adapter problem
- 95 K3500 ABS problem
- problems starting
- Engine Swap 4.3 to 5.0
- K2500 1997 Complete Strip Down
- Shuddering Start - Smell Gas
- front left wheel calipher sticking
- would you get it?
- Fog lamps
- what does the timing
- chev vs GMC
- TBI - is it OK for injectors to drip at idle?
- Upgrade to 4L80E
- Problem regarding starter
- mesurements for rear leafs....
- Door clank
- Valve seals-4.3L V6
- 83 carb questions
- HELP,97' 1500 305ci, Fuel overload in Cyls.
- wiring diagram
- Lund moonvisor
- Better Gas Mileage
- 4l80e
- 93 6.5 diesel
- 95 c1500 check gages light
- hot air form heater constantly
- shocks ands struts
- keep replacing cap and rotors
- 89 350ci high idle and water leak
- aftermarket ABS speed sensor?
- 94 454 Too much gas & lost OD & lock up
- Better brakes
- can someone help me w/my 92 blazer
- PLEASE HELP! Runs rough cold!
- 93 K1500 Loss of power, valve lifter noise, only happens when towing
- scanner question
- E85
- fuel pressure regulator replacment help
- Uneven bed??
- Engine&Tranny Swap 92 K1500
- Everything works except the brake lights
- tranny fluid
- Custom Lift or Buy a Kit?
- wiper arm removal and painting, 97 Chev Cheyenne
- cylnder head from a 89 blazer ?
- 96 vortec 305 to 350 swap
- corvette servo
- cylinder heads reversable ?
- tire ?
- keyless remote programing 1995 k1500
- buying a mid-80's silverado
- fuel pump question
- 6 Lug 15 in. Wheels
- Speedometer cable and tranny help needed
- Broken Wire leading to sensor
- Headers
- 1996 gmc high idle
- replacing factory stereo, and not just the deck
- Non-level ride
- 87 pick up not running ?
- lens cover?
- Converting Grills
- Frozen Rim
- Valve ticking when cold
- '94 K1500 Starting Troubles
- Found a Crack
- floorboard tack welds
- New KC Lights
- abs recall investigation underway
