Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Avalanche/C&K/Silverado/Suburban/Tahoe
> C/K |
View Full Version :
C/K
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
setting timing
euro projector headlights for sale.
Ignition....is it all related???
Headers!!!
HELP...Should i buy '69 c-10 SBC 4spd, 2k...QUICK
'90 chevy needs a new engine help...
back brakes
Body lift kits?
is your truck low?
C2500 Suburban Floating Axle Brakes
89 k2500 error code 44
4wd
Heater Control & Stereo Lights Out
IAT Sensor..........yeah i know
Electrical troubles
86 4x4, where to start?
'92 Silverado, Cruise-Control
tire & rims size on dropped 4x4
compression on 305cid
350 to 383
Throttle Pedal Vibration
Pulsing interior and exterior lights
another 4x4 actuator question
1984 p/up wont start
1997 Silverado Blower Motor Problem
HELP! '97 Z-71 Transmission Clunk
1993 Cheyenne 4.3V6 TBI
Cooling System
2001 voltage and rpms drop and stall
96 Drivetrain making grinding noise
K1500 Gauges (Tach dash)
Heater Prob...89 Chev PU...C1500 4x4 5.7Ltr
lift kit for a 89 k1500 ?
help please...repair cruise control...1990 silverado
tires c1500
RPM at various speeds
93 4.3 Rocker Arm torque specs
Differance Between C1500 & K1500
84 4dr dually brakes
ECM Blown.... Cause?
Crazy wipers!!
89 Chevy k1500 w/ 305 -- Engine runs rough.
97 C1500 Dome Lights Stay On
90 chev green male wire by distributor
cylinder compression 90 chev 305
FX4 off road Vs. Z71 Off road.
Replaced power steering pump now what???
1993 C1500 Heater Core Problems
Trying again....Miss or Transmission?
Tribute to all the awesome help I got...
87 Silverado heater core
tire size
Important question about wiring
'92 Chevy Z71 Fuel Pump
I'd like to know what my silv runs 0-60 and
'94 Cracked Intake Gasket?
Going to start upgrading my c1500
Water Pump Labor
'Bout died tonight doing tune up
Thorley Headers any Good?
IMCO mufflers...
cold natured transmission
Heads
1994 Chevy K2500 Clutch??? Problem
02 Suburban: Erratic Idle On Start
Intake Manifold..... anyone? anyone?
grill inserts
Gas pedal gets stuck?
need a look under your hood please
1995 k/2500 4x4 won't work
72 C-10 Tach inaccurate
1997 K2500 454 Temp creeps up at idle
Interior lights going out
Seems like we all have starting problems with 98's.
"Tamper" mode? Starts/stalls repeatedly, 10 minutes later it's fine
noisey 5 speed
Fuel for '97 z71?
98 Z71 cranks then dies, then cranks and runs fine
WTB used JB7 ABS control unit for 98 K2500
Engine Backfire on Pass Side Bank
1993 Chevy Blazer
93 TBI starting problem
98 K2500 brake question
1976 Scootsdale C10 FOR SALE
1991 Chevy 1500 w/ 406ci smallblock -FOR SALE
Parting out 1989 k1500
Where is the "data link connector" ???
i need posi
tranny oil change?
A.i.r.?
Sevice Engine Light WAS on...
91 GMC Sierra 4.3 TBI
NEED a pair of heads for 89 C1500 305 5.0, what should I get!?!?
Changing Power Steering Pump
IAC valve reset procedures
need a set of cylinder heads
98 Silverado starts but will not stay running
motomaster tires
Where is fuse/relay for heated seat in 2000 chevy 1500 PU?
Bigger Throttle Body
black plastic below bumper....remove it??????????
95 k1500 350 tbi stalls
1994 5.7 engine running rough
Replace Intake Gaskets???
91 Throttle Body Spacer
my truck's not level
1/4 and 0-60
knocking noise from dash!
Mirror Compass
Best Headers for a 95 5.7 Z71
want bench seat
tires
1991 upper control arm
rear view mirror with compass/temp.
Keyless Entry
no brake lights on 89 chevy 4x4
Worth it or not
Engine Size?
Lift kit/Tire rub/torsion bars
cowl induction,hood scoop ideas?????????
2000 K2500 diesel transmission
Really Cold!! No Heat!!!
Several Questions on my 99 C3500
BAD hesitation 2
Headlights acting funky
Restoration
valve adjustment
Suspension question...
More exhaust questions...
96 C1500 Fan Removal
catalytic converter
Buy & Build or just buy??
Tires
Charging system problem
96 Parking Brake Lever Not Fully Releasing
lifters
Chevy 350 oil pressure
Running Parking lights 84 Pick-up
95 z71 hp rating
1990 GMC SIERRA starting issue 350 tbi v-8
daytime running lights
Truck usage
just trying to help
radiator replacement
86 f/s CD deck and speaker project
Body lift
SES code help P0452
98 Z71 bogging ???
99 Tahoe Leaking Coolant...
BAD hesitation
piston slap or not???
96 model extended cab rear window leak
Exhaust recommendation?
Heartthrob Exhaust...
door panel
97 305ci, fuel overload??
96 3500 454 running very rough
Carburator Conversion
service engine soon light
Window dimension question: ASAP!
96 C1500 engine swap question
two batteries
1996 Tahoe Slow turn Clunk and grind.
1976 scottsdale seat?
No Cruise Control
98 Knock Knock
Heavy pedal
97 silverado
1994 4x4 350
90 1/2 ton heater controls not funtioning
Tranny Probs. 93 1500
Intake manifold leak
fuel pump/ oil pressure switch
5.7 TBI stalling please help
96 K2500...
wires on replacement thermal actuator
1994 cheyenne won't start
4X4 2 Door Tahoe
92 Suburban 454 Engine Runs Lousy
99 tahoe fuel issues
ball joints seat themselves?
1987 Dashpad
a/c condensor freeze up problem
strange ticking noise inside cab--1994 1/2 ton
Boggy Accelleration
Pistons Pinging
5-speed manual problems
99 Tahoe
89-93/V6-V8 engine swap resuts
1996 K1500 Interior light / Tune up problems
96 1500 dying/wont start for 3 hours
oooooooh that Smell!
Factory Locker
1998 1500 Stalling
Wanted: 1993 Instrument Cluster w/out tach
problem...popping noise
shocks
1993 Instrument Cluster exchange
Good Tire Size for Winter? 285? 265?
Red Hot Exhaust Manifolds!
Tire size on 95 Silvarado
Extensive tests all check out. Still won't start reliably.
hypertech power programmer III
ABS concerns
help!!help!!no heat in 90 silv.
swapping 350 carb for a 305 tbi
86 c10 headlights not working
lowered my truck
Strange idling issue
76 292 to 350 swap
what's up with my truck
Another Fuel Pump Problem
1997 k1500
MAS Question
alternator interchanging
Whistle from heater blower
transmission swap question
1960 P/U oil problem
96 Chevrolet 3500 transmisson problems
92 4x4 upper joint adjustment
Brake lights not working
1986 C10 dies when accelerator pressed
Door Panel Removal
2000 ranger misses while driving and at fast exceleration while in neuteral
Compression check 93 k1500
ECM-IGN fuse keeps popping
86 chevy 4x4 front differential
'96 4x4 Yukon Ball Joint help
89 1500 Acceleration problems after warm-up
Please Help (error code)
Buzz from dashboard
454 running trouble
OBS Parking Brake adjustments???
need truck bed replacement parts
700r4 transmisson servo
Fuel pump?
99 gmc suburban old body style 4x4 loud revving noise
Spark Knock
NO Air blowing
Starting Problems 1994 Z71
What do you think my Hp/Tq would be with these mods?
84 6.2 white smoke from driverside exhaust
93 k1500 Ball Joint Assembly
Did I Destroy the Finish on My Alloy Wheels????
no spark at plugs
Dome light 98 K1500
z71 ifs help....
6.2l Pulsing/vibration
Automatic transmission questions
brakes on 91 chevy 4X4
Web
AF
