View Full Version : C/K
- C or K
- 97 Z71 Silverado
- AC Delco Plugs? Or Bosch +4's
- Think Truck is missing
- K1500 Tweaks
- Help!!! Help!!! Help!!!
- Auto Trans blows fluid out the vent
- Grille conversion.. plz help me!!!
- P1345 twice with P1351
- Amsoil
- Ading prophane to your Truck...
- shocks
- Back Up Lamp Switch
- Under Dash? ticking.....
- Crazy Fuel Pumps
- help please....TH 400...1990 1/2 ton
- Help Now!!! Truck Overheating!! Why?
- 97 Z71 won't slow down on decel
- Horsepower
- turns off when shifting into gear
- distributor problems
- underdrive pulleys
- c3500 starting problem
- P1345 Code -- Aaargh!
- Gas mileage
- Tach/Speedo acting "WIERD"
- Vacuum hoses
- 1992 K-1500 5.7 V8 4X4 High Idle
- Transmission Issue???
- HELP Fuel pressure problems, bad check valve
- th400
- Help for 3500HD 8.1
- suspention lift
- my 88 new engine
- egr system-86 k10
- edelbrock carb, adapter?
- mpg and power upgrade for TBI
- 97 chevy c1500 will not start
- Brake light switch replacement
- supercharger for 89 350tbi
- 15" to 16" rims Suburban?
- correctly installing a distributer in a 84 350
- Coolant Mixed with Oil!! Help!!!
- 89 k1500 stalling problems
- heater ???
- 1989 k1500 350 codes
- Oil pan gasket
- 92 silverado mystery ?
- 700R4 @#$#& SHIFTING PROBLEMS!
- wierd A/C Problem
- 305 heads on a 350?
- Hydraulic clutch fluid
- #1 cylinder seems to miss intermittanly
- help please...cruise control 90 chev
- brake light switch cruise control not working
- help with cruise control
- fuel pressure regulator?????????????????
- axle swap
- remote programming
- 3/4 ton rearend under a 1/2 pickup, how hard is it?
- Calling All Chevy Lovers
- 95 chevy Silverado Z71 no start
- Where has all the water/AF gone????
- transmission tailshaft endplay???
- 99 6.5 diesel problems
- Put a K&N filter in now Problems??
- flowmaster muffler for sale
- headlight problem
- Oxygen sensor problems
- 96 gmc 1500 misfire
- DRL relay
- freaky fuel lines
- antenna?
- Are all 4L60Es the same??
- Help steering arm
- 86 C20 stuck in high idle
- '98 C/K 2wd Truck TCC intermittent.. weird one
- Did 1983 3/4 ton's have emmissions?
- Dust Cover
- Oil Cooler Line routing
- 89 chevy truck wont start.
- Does Flowmaster exhaust really help to boost power, torque, and fuel mileage??
- Differential blowing fluid
- oil smell
- need help to find headers
- How thorough is the Chilton's repair manual?
- 89 1500 Drivebelt shaking & Squealing with A/C on
- CD Player Install Questions
- 4 wheel drive doesnt work......
- Fuel Gauge
- Fuel Pump - Reliable Brand Names
- Anyone ever used a hypertech or superchip programmer on a 7.4L Vortec Engine??
- My 88 Restoration, gets a new heart!
- Brake problem
- c-60 brakes locking up
- Low Battery Charge 1991 1500
- sunvisor removal
- Clutch Or Tranny Bad?
- Looking for bed info
- Fuel Gauge not working
- Tach and Speedometer acting strange
- Need an Estimate
- Hard start and rough idle
- 91 ck wiring diagram
- 93 5.7l V8 No Start?
- motor mounts
- 1981 C10 305 stalling when hot
- 1999 Chevy 2500 Crewcab Z-71 ???????
- Need wiring help! High Idle?
- Radio question
- will i get enough out of my alternator
- Questions on a 94' Chevy
- trans question
- engine to loud
- 1993 Chevy 3500 Crew Cab Dually
- Low fuel pressure
- coolant leak
- Problems with my 98 K1500 metal sound
- EGR check
- Wheel bearing replacement
- reason for break warning light?
- 91 4.3L oil pressure sending unit.
- 1996 Radio volume switch has no control
- 400 where a 305 was??
- how do i replace the 4wd actuator on 97 silverado
- transmission upgrade
- 98 tahoe possible fuel problem
- 93 Silverado- no power on acceleration or hills
- problems with my freebie
- engine swapping?
- Drive Train Question
- coolant leak
- OBD code information.....
- 1991 chevy truck - AC knocking
- 1990 truck won't idel when cold
- crazy coolant
- Screeching noise when fuel tank runs low?
- can u lower a 4wd? if so, will it hurt it
- my wipers and cruise act up HELP!!!!
- 1996 Vortec 350 injector/fuel system - tough problem
- fuel pump 99 suburban
- Fuel Temp Sensor DTC
- Roller Rockers
- suspension bushings
- overheating 93
- Mileage Drop
- Ac
- Towing with 33 Tires
- '88 C2500 won't accelerate
- no tailights, or signal markers, but i have brake lights
- I feel bad...but not that bad
- oil pump
- 92 1/2 ton 4.3 liter won't idle cuts out
- 83 1/2 ton w/305 won't fire????
- Pulling to right hard
- shorties of long tubes?????
- Won't Start - Clicking Noise
- new engines question
- A/C Indicator
- Stepside --->> Fleetside
- Fuel guage goofy
- 4l60e
- Transmission Decisions
- Please Help!
- 1972 c10 used to "grind" goin in first gear, now no clutch at all
- 95 Silvarado Hard Shift
- loud rattle or rub
- HELP 1998 z71 oil breather?
- 1990 C1500 Interior Doors
- power seat track
- converting TBI to CARBURATED
- zero oil pressure at start up
- Intake manifold upgrade
- new 350
- 89 C/K sometimes has White Smoke at Startup Only
- Mixed Fuel
- Tranny wont shift in OD
- I can't believe my drive shaft broke
- tinging sound
- Speedometer Wrong
- Power window regulator ?
- Brake lights wont shut off!!!
- Idle problems
- 98 chevy performace upgrades
- A/C problems
- Ripped out wiring...
- charging question
- help with inst cluster
- help with 4l80e
- Wipers come on by themselves...
- v6 power
- 350 tbi needs a head gasket
- master cylinder hiss
- Manual tranny question
- 98 water leak at manifold
- 93 6.5L glow plug light
- Please help Don't know what to do!
- Radiator flush, is this a job for me?
- '96 K1500 - Won't go into gear.
- Brake lights only work with the headlights off
- 89 K2500 Code #43...
- 97 Silverado Steering issues.
- Ignition Timing
- Replacing plugs...need advice
- 92 cevy 1/2 ton rpm gauge bouce
- 85 tranny vibration
- are 5.7'z really fast?
- AC not blowing- Vent problems
- 1997 c1500 305ci heater hose leak
- 4.3 Engine Swap
- Steering Column
- 97 k1500 questions
- Possible torque converter problem?
- need help 100$ fillups every 2 weeks
- 1986 k20 military diesel pick up
- 83 trans swap
- oem parts
- seeking '98 w/t 4.3 5speed info
- Back from the beach
- coolant and temp problems.
- TH350 more fluid leakin out then I can pour in!
- master and slave cyl.
- Oil pressure guage
- Wheel Size
- Wiring Diagram for 73 C-10 Pickup
- '90 Gmc Sububban
- rear seat audio (RSA)
- Crazy tach, odometer quit working, engine rough at start
- more blow from my blower
- 4l60e no 1 and 2
- custom truck for sale!
- Smoking from dip stick and through TBI
- 94 K1500 starts hard cold
- difference between 700 and 4l60e
- 87 Silverado 1500 2wd - Starts and runs, but dies several minutes later
- Brake Code 4 Grounded Antilock Valve Reset Switch
- c1500 radio upgrade
- stumble from stop
- 1994 c1500 help
- Motor Build Up???
- Serpentine Belt
- Zmax seems to boost mileage 20%
- 94 k 1500 leaking trans fluid
- electrical charging
- Lower Intake replaced, now strange tranny
- missing and backfire out tailpipe
- fender emblem
- Tranny and trans swaps
- TCC (PWM) valve or Tcc Solenoid valve?
- brake problem
