View Full Version : C/K
- stock horsepower?
- What do you think this trucks worth
- Different shafts for a 10 bolt rear end?
- interchangeable rear ends for 90 sub
- 1995 4.3L won't start
- 24" Panther wheels with tires almost new
- 95 c1500 - tranny shift issue
- Custom SUb Box
- Difficult to shift.
- I Need A Winch
- Block Lift for a 86' Chevy K10
- 98 Silverado Starting Problem
- '86 chevy heater fan
- 94 k1500 4.3 v6 gas mileage
- need carb and gas mileage help
- More on 1987 Chevy Truck "sticking throttle"
- trans problem?rearend???
- Exhaust Pipe Questions
- 98 Z71 serice engine soon light came on then went off?????
- 87 Chevy Truck "sticking" throttle
- 1989 Short wheel base chevy
- my truck is dead
- Easiest way to set TDC & dist timing on 93 k1500 5.7
- Will a Holley 670 work on a 95 350?
- Misses badly when tranny shifts down
- 1981 C-10 tachometer
- Rear Differential
- how can i determine the options on my 2500
- need smog expert - 1997 Tahoe 5.7l
- Weird intermittent starting problem...
- PROM chip info for a 1993 K1500
- head torque specs
- Lowering Rear End 96 C1500
- 1985 pickup
- Ignition Switch Wiring
- truck pics
- injector spacer?
- cruise control
- 1992 K1500 w/ 350 - hom much HP
- Advancement timing wire on a 94' Chevrolet Pickup
- Outside Door Handle
- Upgrade to timing gears in 350ci. engine
- '98 silverado, brake,tail lights problem HELP
- I'm losing my mind?
- 95 ignition switch replacement help
- 93 k1500, wants to stall when cold
- is there a relay?
- 93 truck burning and leaking antifreeze
- 91 Silv. Rear suspension
- no speedometer/odometer/abs light on
- Any drivetrain experts out there?
- 4.3 to 350 chip question hypertech??
- rough idle after mod
- cat knockout?
- 94 chevy 350 motor issues?
- 94 Chevy Dash To A 95 Newwer
- K&N Filter Question for 94' 1500
- Power Mirror Control
- Drip Drip Drip
- Vehicle stalls only when cold
- K1500 front suspention
- slight miss after tune up?
- Front Straite Axle Swap
- The Front Grille Of a 1990 Chevrolet Silverado
- Need a 1991 k1500 microfiche
- Help backfiring through the Top w/ pooling gas
- oxygen sensor heater circuit
- Mass Air Flow Sensor or Cat problem???
- abs problem
- 1993 K-1500 wipers work intermittantly
- 98 1500 ext. cab 2wd lowering questions
- MAF problem?
- Will 2000 Silverado 2500 2wd Haul?
- cruise/turn signal
- 97 Z71 Front Diff acuator
- Stock stereo doesnt work anymore?
- performance air filter question
- antoher tire question
- things i WOULD REALLY like to know...
- a/c doesn't get cold
- Power Loss Question
- Help with 97 350 missing
- Fuel Line Help
- need to know
- Radio Swap-AM to AM/FM stereo cassette
- Seat wobbles
- flareside cargo hooks
- Abs Lights
- Abs Light
- Four Wheel Drive 95 Suburban
- 1989 scottsdale 2500 door pins
- What does A.I.R. stand for on 88-95 5.7L TBIs?
- Radiator
- What Transmission Do I Have??
- Turn Signal Problem With Lights On
- 95 K2500 4L80E problem
- 92 350 Hyd. lifters stuck....ALL OF THEM????
- cam for my 91tbi 350
- Lighted grill emblem
- Turnsignal and brake light out, not the bulbs! Please help.
- headlights problem 92' silverado
- New Truck, new problems.
- Shift problems
- quick diconnect fuel line woes
- Trans Whines And Is Slow To Shift While Truck Is Cold.
- Headers for a 72' 454 engine.
- Tire Question
- 1988 Chevy fullsize 1500s
- Why is my truck drinking coolant?
- 350 vs 454 for sleeper
- problems with my 2000 elantra
- Hesitation???
- Rim Changes
- replacing air intake with edlebrock-86 k10
- Heat riser ???
- rear view mirror upgrade-need schematic
- Is it possible to re-program computer for better mileage?
- codes 42 and 43 and 59
- Body work
- Need some information
- fuel pressure low not fpr
- adjusting doors an a 89 chevy 2500 scottsdale.
- water issues
- info on TH350 tranny
- Right rear brakes
- Looking for Aftermarket Electric brake booster for '96 truck
- Front differential on an 86 Silverado
- radio lights
- brakes one last time
- Oil In The Intake
- 1989 k1500 sporadic idle issue
- Rear View Mirror
- do spark plugs make a power difference
- I have a body mounting question.
- Advice on good used truck
- '94 Silverado Problem
- No Vacuum 96 350 Just Checking
- What is a knock sensor
- dex cool leaking
- 305 to 350 swap question
- Power Rear Window on a Pickup?
- Desperate Cry for Help (intermittent spark)
- Need a new EGR for 89 C1500, How important is it really...?
- OBD II Reader Selection
- 3rd Door on 3/4 ton??
- 160 degree thermostat
- variable speed steering box
- 35's with a 3" lift...?
- EGR Valve Replacement
- Front grills
- 96-99 Column shifter Change Question
- Oil pressure problem
- spray on bed liners
- 4l60e Tranny Question
- parts
- ticking is driving me nuts
- 1990 truck running too rich
- No power to rear wheels on 1978 k2500
- Voltage To The Fuel Pump ?
- fan clutch going bad?
- 2wd rear end swaps
- Camshaft swap 4.3 non Vortec
- Help 1995c1500 350 5.7
- Bucking 96 K 2500 Thinking Fuel
- lower rearend gears
- 1993 Chevy column shifter
- Tranny Question
- y pipe
- Transmission Temperature
- fluids for the transfer case
- What Would YOU Do? Knock Knock; Waterfall
- P0300 Trouble Code, Multiple Cylinder Misfire
- block heater install
- 1999 Silverado Tailgate won't close (latch)
- Pictures of your truck(s)!
- 93 K1500 A/C Problem
- interminttently problem solved
- Best add-ons or mods to boost mileage? 98, 5.7 Vortec
- back pressure
- Extra power for little money
- Loose Steering!!!
- Carrier bearing replacement???
- hypertech TBI power charger
- right lowbeem headlight and DRL's out
- auto trac 4x4
- brakes again
- Cross country travelin'
- rechip Duramax
- Can't open hood! Release cable is broken!
- 93 exhaust ideas?
- brakes
- Injector work interminttently
- Help - 02 suburban keyless entry
- no starting w/a 20 degree change??
- 1994 chevy3500 frount axle diagrame
- 95 Silverado Door Pannels
- 88-93 chevy truck owners
- 1989 K2500 4WD Running Terribly...... Ideas?
- Power locks
- miles
- Clutch Noise?
- 52 conversion
- Bench Front Seat
- Interminttent Problem
- gauge cluster swap
- 1987 Chevy start and run problem.
- (k1500) 4wd not engaging......please help
- 1987 K2500 Transmission Troubles..... HELP?
- Underdrives/electric fans
- A dark, dark day.
- Timing Vortec engines
- Poor mileage in 98 Silverado, 350 Vortec
- 1994 silverado timing
- power loss???
- Cam Suggestions??
- 1993 cluster gauge swap
- egr valve, starting issues
- Intermittent problem
- What would you do with my truck? Any opinions would be awesome.
- 98 power locks (autolock)
- My 95wont Idle At All
- 4wd ? again
- Tire Size Clarification
- water pump on 98 chevy
- wondering about Banks exhaust
- Snow plow options
- More power
- Complete Rebuild
- I need lowering advice 98 1500
- any ideas
- new fuel pump now won't start 98 chevy 305
- trade my truck!?
- 98 chevy
- 89 chevy pu steering column wobble
- Installed My NEW Thorley Tri-Y's last night + some extras=WOW!!!!!!!!
- rim / wheel backspacing question
- am i computerized ??
- posi trac
- 95 suburban Idle problem (long)
- 84 pick up sputters
- G80
- 95z71 brakes Advice
- AC Delco copycat?
- going crazy!
- White Smoke that stops Traffic... lol. HELP !
- 94 Chevy Automatic transmission
- Starting Problems after Rebuild - Need Help (96')
- Timing Question 94 C3500 7.4 Dually TBI
- has anyone ever done a lt1 swap ina 87 chevy truck
- 98 silverado power locks
