View Full Version : C/K
- flashing parking brake light
- blower motor problems?
- 95 or 96 5.7
- 96 silverado trany
- Coolant leak at front of intake!
- Manual Tranny Problems! Please Help
- No Start
- windshield squiters
- 1988 K1500 Fuel Line
- Door fricken Panel
- Throttle Body Spacers
- 1996 vortec 5.7 tps fault
- 1996 k1500 - no 4x4
- Engine cranks will not start
- Removing side trim on 94 1500
- 1983 c10 Silverado Temp Gauge Problem
- 89 1ton ECMB fuse keeps blowing. Need Urgent reply.
- Clutch change!
- 1989 5.0 c1500 tail light problem
- 1996 K1500 ABS activation HELP PLEASE!
- 1990 5.7L Chevy Wont Start
- 1998 Silverado-problem with fuel pump?
- Front Driver Side Suspension Noise
- AC/H control panel
- Info on 1995 K1500 ext cabs?
- 91' Chevy c-1500 sport
- 1995 k1500 Fuel pump relay location?
- 94 z71 squeek
- OEM fog lights for '97
- tranny question
- 94 Chevy K1500 retards timing instead of advancing
- speedometer works half ass
- 88 1500 clunking in driveline
- back blinker problem
- 96 C1500 Crew Cab/short bed 4-SALE!! Lowered, Custom, etc...
- 1998 silverado starting problems
- 96 Sierra money pit
- 1992 C2500 7.4l 454 Auto - No power, blows heater cores
- v6 to v8
- Severe Hesitation
- 77 Chevy and 350 Prices?
- Heater
- 1995 chevy tahoe
- 4x4 front actuator-96
- blown head gasket?
- starting problem
- Toasting Starters
- Is this a good deal?
- 88-94 Replacement stereo options
- 95 Chevy 1500 (Heater Core Replacement)
- 1991 Accord startin problem
- downtime
- Windshield?
- Can TBI injectors be disassembled? For cleaning
- 4.3 supercharger
- 1982 Chevy 4x4 4 Sale
- FS Xferr case, 82 K-10 So. NH
- Door lock Chaos
- Help with Fuel Pressure Regulator
- 92 power mirrors don't work...
- new truck
- NO power to fuel pump.
- AM/FM radio alternator noise
- 383 stroker, converting to 4 bolt main, keep TBI?
- Fan DriveBelt (95 Silverado)
- WON'T START - fuel problems - '91 c3500
- 83 C/k 2500 4x4 Noise
- 94 Chevy K1500 4wd wont engage
- 3/4 ton rear end noise
- 71 C10 Window Regulator (Please Help)
- Transmission Change 1987 Chev 1 ton
- Need Help Finding Short!!!!!
- Distributor
- Sick Chevy-Catalytic Converter??
- temp gauge
- Bad Starter?
- SeatBelt Light
- Grease fittings
- overdrive = bad vibration
- 96 fuel tank pressure
- Wipers
- Transmission Problems
- 94 4L60e torqu converter stuck in lock-up mode
- 98 chevy 454 idle high / fast and burns about a quart of oil every 250 miles
- Coolant Flushing
- Bad Vibration
- Strange Noise
- po 174 bank 2 system lean
- i need a manifold
- Here's a good one, kinda off topic a little.
- fuel filter location 95 diesel 2500
- Engine stutters when coasting
- '96 k1500 - no 4x4
- Resonating Sound w/RPM; Possible Exhaust?
- Power loss, bad idle, EGR?
- leak at front of driveshaft
- Brakes? Locking up when I go in reverse
- 6.5 Chev Diesel Harmonic Balancer
- i have no compression in my big block 454
- headers on a 88
- Oil Pressure Indication Drops, low speed turns
- Truck is not level
- Throttle Position Sensor
- coolant
- Fuel system problems
- Missing 4WD Light 1988 K1500
- rebuilding transmission
- Engine Chipping question
- Starts..runs for 1 sec...dies...repeats????
- Problem with overdrive? Need your thoughts.
- 4L60E P0751 Not the solenoid....Help????
- exhaust cutout...
- fuel in oil?
- Headers... tell me which set to buy.
- cam selection
- tranny ???
- wierd drivetrain problems
- 94 c1500 won't idle
- Turning Over but not starting. Need help please...
- Exhaust Cutout. A good Idea?
- heater?ac
- noise - coins in dryer
- Strange Speedo / RPM / Trans problem
- Bed cutout for pump replacement
- 4x4 Parts
- trouble starting when cold
- Heater
- 1980 4x4 c-20
- fuel pump pressure problem
- 4X4 won't lock
- 95 tranny
- Tire size??
- Automatic transmissiom stuck in second gear
- 95 drain plugs
- Headers Headers Headers !!!
- 92 "new" 4 bolt tbi knocking
- '95 K2500 5.7 Runs poorly
- error code P0160
- How do I find out what kind of differentials I have
- Charging Circuit Diagram 1973 K2500
- fuel pressure regulator
- air bag safety
- Which fuel injector cleaner for 96 Vortec 5.7?
- Broken quick disconnect nipple
- 92 Chevy C1500 W/Rough Idle
- What Exhaust?
- distrbutor click noise 350
- I have engine frame mounts I dont need.
- keyless entry?
- Possible Supercharger?
- For those who have had an Engine Rebuild
- '92 2500 2wd
- Finally, I'm close to finishing
- get your trouble codes read for free
- Windshield Wiper Motor Failure
- P0171 & 0174 codes
- no juice
- keyless entry help
- Small blocks
- A relatively simple problem... you would think!
- Bouncing...brake problem?
- Clutch
- All over the road steering problem
- stock GM radio question
- ?'s about exhaust
- Best milage?
- Body Work
- New Guy from Calgary!
- 2 bolt or 4 bolt mains
- Rear Tire Locks up while driving
- Tire ???
- Transmission swap question
- cold air intake
- a/c inop.
- transmission cooling lines
- NOOO!!! Blew head gasket!!!!!!
- sticky acceleration
- 97 4.3 engine misfire
- lift kit
- 4x4 Will Not Kick In!!
- MY 96 CK 1500 4X4 fails to start (sometimes)
- Valve seals
- surging in reverse
- Front Diff 92 K1500
- antenna wire
- A couple of questions
- engine stalling
- Compressor works but no Cold air from A/C
- what is my gear ratio?
- 1988 K1500 Fuel pump
- 1990 GM Security System HELP
- hey guys oil change....
- Brake Pedal
- 2001 5.3 high pitched whistling
- suspension
- Missing 1998 K1500 5.7L
- 1995 4l60e transmission bolt problem
- fuel pump relay ground
- Is This a con or not
- switching out an input shaft on a 4l60e
- Egr Valve, Solenoid or Timing
- Nv 4500
- 95 K2500 Low Power, Misses some under load (when Cold)
- 94 c/k body side molding
- Seats
- Rims and tires for sale
- Body Lift Restricts Use Of Truck?
- oil leak
- Windsheild Washer Pump Location?
- 84 C10 new engine swap runs but wont idle
- Rear-end questions, help??
- Help...any tranny techs out there??????
- Horsepower for truck engines
- 93 Chevy PU code 54
- Need advice on changing clutch
- Wiper operation question!
- Gears mashed up
- A/C Compressor
- Exhaust gas
- Looking For Lockers
- Looking 4 opinions on Frnt. brake replacements.
- cold start=no idle
- Thankx for the reply
- 97 Votec 5.7 HP
- Just want to make sure
- 1994 ck 4x4 1500 oil pressure sensor
- Traction Bars
- 94 Trans WTF? blowing out red fluid...
- 1997 Z71 brake problems
- dash lights
- rear disks?
- crew cab ???
- 2 Front O2 Sens. Locations Please
- Need Help For Engine Swap!
- 96 5.7 1500 AC problem
- 1997 C1500 bright lights
- New to the C/K forum, need diag. help....
- Balancing Beads
- 5 spd. to auto
- Now another problem
- Wire or Ignition switch?
- Throttle Posistion Senser
- Starting Problem, only getting worse
- Chevy 3500
- Sea Foam?
- Start Stall Probs 95
- Cooling system connector replacement
- 97 chev 4.3 alternator
- no start [confusing]
