Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Avalanche/C&K/Silverado/Suburban/Tahoe
> C/K |
View Full Version :
C/K
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
4l80e rebuild
Good 1/4 mile time?
Coolant leak around T/C Cover
throttle body spacer
Another P0300 code question
1994 4L60E Gettin' worried...
Factory Service Manuals??? Where to buy?
backfiring issue
88 TBI? problem
98 Silverado problems with starting
Hypertech Question...
strange rear end sounds?
new additions for 86 454
97 acceleration problem
1993 K1500 4.3 Frustration!!!!
1990 Silverado Stalls
1995 k1500 truck has no second or fourth gear reverse works fine.
back-pressure
pre 1986 Chevy 350 long block
97 1500 INtermittant no start and PCM codes
97 k1500
Puzzleing
My 95 silverado feels like its cutting out
97 silverado interior lights
82 C-10 L6 to V8 engine swap
'94 Chevy 5.7L idle way too low...
1987 Chev C20 Crewcab brakes
97 Idle Vibraton
front end steering play
Transfer case or what?
Bench Seat to Bucket Seat - Need Help!
Towing 88 Chevy 4x4
quasdrajet 4 barrel won't open no more
Blower Relay Location
Truck not shifting into 4wd
92 silverado no brake lights or turn signal
V6 transmissions
FOR SALE!!! 20" KMC Stealth Rims and Goodyear Eagle GT II Tires FOR SALE!!!
restoration
A nice little sparkplug trick
New Tires!!!!
TCC Solenoid Location
In Case You Run Into This......
Funny whistle noise Part 2
7.4 L Fuel Injector Size
totalled truck.....
Repaired Temp Control Mod on 91 Silverado
How would I go about running a house AC thru my sliding back glass?
Clack Clack Clack...
Broken Wire- Where does it lead?
New Exhaust
Power cycling?
Bone Dry Fuel Tank
Transfer Case Fluid Type
intake
Tranny shifts late & PCV valve pops up.
Daytime Running Lights
1996 3500HD PCM Problem
Another Trans Problem
97 Steering Problems
Parts included with Z71 package?
advice on rod knocking please
transmission housing question?
1990 Silverado runs rough and stalls
700R4 shifting question
acceleraation problem
towing with a jimmy
Clutch problem??
Problems with my 60 p/u
Favorite Truck Part
Strange tranny problem?
clicking 5.7 V8
305 tbi problem!
25% better mpg 30% better horse
Pulling boat in Overdrive ?
Problems After 305 To 350 Swap
4l80e transmission trouble
Mirror Fell Out!
98 chevy 2500 350 5 spd islow idle down
How do you spend?
couple questions
good price??
Kv average per cylinder
Leaky Oil Filter Adapter (1997 Chevy K1500)
Specs on 1996 C/K 1500 Z-71
1988 Chevy K1500 Wire Diagram
400000 Ks
Extended profiles
interference or non-interference engine
Spark Arrester Question..!!!!!!!1
Funny whistle noise.
Cold Ticking...
3.73 Gears for an 86 chevy
700r4 pressure cable/ oil presssure sending unit question.
Interesting Topic
lobing Idle
Blue smoke at startup and at takeoff.
looking for a f/s truck
98 Silverado. Must be a starting problem.
Gas Mileage on 86 Chevy
royal purple
throttle body
Front passenger side turn signal lights up when hitting the brakes?!?!?
Lurching when stopping
rear view mirror help
Will stright pipes guzzle gas?
1985 Chevy Pick Up Problem???Need Help!!!
1994 4L60E soft shifts
Spray Paint
Replacement 4wd actuator, '96 Suburban
93 5.7 intermitten miss
97 C-1500 starting problem
tranny fliud
2000 Tahoe electrical - accesories circuit
2000 Tahoe error code P0440
Trans replacment 700R4 90 chevy
oil pressure guage
1996 vortec 5.7 throttle stop adjustment.
98 pulling troubles
Need Header install info -
power rear window
help with speed sensitive steering
hypertech power programmer
new pics
Odometer not working
cab swaping
heated seat in 99 tahoe
windshield crack 87 silverado
so so sad
Rattle while idling?
Buying wheels...think they will fit
torque specs on 350 heads
Q Power.....or not?
Truck wrecked, now no tail lights!!!!
94 Silvy w/ 4.3 lacks Horsepower
Pondering Vortec Upgrade On My '94, NEED HELP
How many miles you got?
Taking off front d-shaft, 91 k1500???
eaton posi for 85' c10
power locks
Questions about this and other older Silverados. PIC
Cheap power boost
New cam....and such
which tires do you ride?
305 To 350 Swap Problem
1994 K1500 front pad replacement
not accelerating
1987 changing from throttle body motor to carb. motor!
1996 305 to 350 idle surge
smoke when shifting
A weird smell and water or gas out of the Pipes
Engine Starting Problem
Fuel Tank Switch
95 C1500 manual trans help
87 not running... not getting gas
454 ss wheels
1998 GMC Pickup,PO306 Moved from "Venture forum"
97 4.3 stumble on acceleration
Posting Pictures
95 4x4 question!!!
My truck thinks it's a boat....
Catalytic Converter 1996 C1500 4.3L
New member..
'99 Chevy 454 mileage
silverado power windows and locks
Electronic shift kit
Front rotor warpage
94 starting problems
94 backfiring/popping
Transmission temp
'92 350 -- idle hunting on hot start
86 Silverado windshield
emissions diagram
how do i remove the bed on my 89 c1500?
Driveline timing.
Oil pressure drop! is it the pump?
Sputter at idle/worse when in gear.
harmonic noise 1400 rpms
94' 1500 dieing out and cranks no fuel
Test Power to 95 Silverado Radio
86 Custom Deluxe Vaccum lines
another torque converter question
Well I have more major problems...no suprise sombody please help
Performance parts for 83'
91 Silverado tranny problem
88' K1500 Silverado - Starter Grinding
Help! Don't know whats happening
Transmission Slip
Random/multiple cylinder misfire
Problems- Factory Radio Swap
Anyone here have a Pro Comp 6" lift (obs)?
remote start car alarm
composite headlight conversion
throttle cable for tranny?
97 Transmission problem
Problems with OEM driveshafts?
O2 sensor location
a good setup for my 350
Leaking Antifreeze
Water in oil
1995 chevy cheyenne 4X4 fuse location
My 1999 Suburban was a 1998 relabeled
dash cluster lights out, best option
Shocks!
88 Chevy cheyenne
Help! Major Problem!
alternator wiring diagram
Idle speed and engine temp
Coolant Temp Cycles during warmup.
need part info
350 V8 5.7
Paint job
I need a trans BAD!!!
Major problems with Headers..PLease Help
ECM (Computer) in Default Mode?
89 K1500 starting issues
stupid question but i need to know
EGR valve opens just off-idle, closes at wfo
Another lift ?
Electric Fans
Best place for OBDII code definitions?
Spare Tire Assembley
Replace Pitman Arm, how hard?
1990 TBI 350cid bad mileage/ choppy idle
1994 4x4 problem
Anyone running roller rockers on their 5.7 Vortecs?
1990 C1500 Parking Brake Flashing
Any tips on what controller and 7 way connector I should install
Bleeding brakes on a 98 3500
Front Spring/Rear Block lift for 86 chevy
1998 power steering troubles
prerunner!! how to build??
98 Z71
quick rearend question
Shifting Hard at High Speed
Knocking On Cold Mornings
Gauge cluster swap
Adjusting Idle
1998 3500 Crew: squeaking front suspension...
Smog Pump
rocker arms or camshaft
1993 k1500 Rear Differential for sale.
OEM Wheel Backspace or Offset
Dallas 85 C-10 Newbie Help..?
89 silverado operating temp
What would cause this???????
stock horsepower?
What do you think this trucks worth
Different shafts for a 10 bolt rear end?
Web
AF
