View Full Version : C/K
- roof Lights
- stalling and stumbling
- '98 Silverado - Difficult to engage 4x4!
- 1997 K1500 4x4
- 88 Chevy Electrical problem
- door lock actuator?
- Full Length Headers For 96 Chevy
- 1992 to Newer year dash upgrade.
- 4.3L to 5.7L Engine Swap...HELP!!!
- Difference between 1500 and 2500
- 97 Chevy 1500 Catlytic Converter
- random misfire 96 5.7 vortec
- ok engine geniuses, help please
- Breaking cv shaft
- question about fuel pump, 89 4x4...
- brakes on chevy silverado
- 1988 350ci code 24 help
- Runs cool
- Fan/Heater Won't Shut Off(95 Chevy 1500)
- milage 89-98 K1500
- 160 amp alternator
- Water Pump
- 94 Pick-up “Air Conditioning Clutch
- 86 1/2 Ton Parts
- Condensor (95 Chevy 1500)
- Pulley (95 Chevy 1500)
- master cyl bad?
- 90 to older block swap
- Need wiring diagram for 92 2500 TD
- looking for towing capacity for my 94 truck?
- 95 Chevy 1500 (4x2)
- 97 misfire
- My new 81
- 1986 Chevy 1 ton 4x4 Front End Shaking
- Vortec 5.7 & 92 silverado EGR or not?
- how much can i go?
- hot Start Problem
- New Intake and Carb
- Vortec Intake Gasket
- Lifting a truck yourself?
- Will 285/75/16s fit a stock K2500?
- 6.5 Diesel Stalling Problem
- Door Closing Takes Work
- bearing noise (knocking) cold start
- Antifreeze missing, smoking... I'm screwed.
- fuel leak 95 4x4
- HVAC problem, loud knocking!
- manual choke
- 86 Chevy k30
- left hand threads or breaker bar
- My 95 Z71's Ball Joints
- Failure to crank...sometimes
- 81 C10 305 V8 Rough Idle No Start
- Idle Question
- 4l80e transmission electrical problems
- 89 Burb Pulley Removal
- Exhaust Manifold VS Headers
- 1982 Gauges don't work
- 95 Z71 ABS light
- buzzer
- Differences - 2500 vs. 3500
- Dash brake warning light on
- 4x4 Troubles
- 73 pickup refuses to run correctly
- 88GMC C3500 ECM-B no power
- 82 GMC Sierra 350TH AT Swaped for 700r4
- carbon fiber hood
- Jacob's ignition frying dist cap!
- coolant burning
- timing set and engine verification
- Powersteering problem.... help!
- Liquid Sounds?
- 1991 Chevy 454SS
- Problems with installation
- low oil pressure. please help!!
- Temp gauge climbs to 225 then quickly drops to 190?
- What's the Process for removing My Bench Seat?
- anyone have a '92/'93 454SS for sale?
- 95 K1500 dies and hard to start
- ABS activation repair
- new Fuel Pump
- 1989 5.7 internal oil leak (long)
- trany prob
- Console to center seat in 97?
- tbi performance
- Which repair manual to buy?
- o2 voltage after cat change
- Slow To Start 5.7 Z71
- Checking for timing chain stretch?
- 1995 Chevy
- 670 CFM TBI Killing Gas Mileage
- Rusted Out Pipes
- Timing with headers and no cat
- OBD II code help.
- need help w/ 4wd please read
- 97 5.7L Vortec, Timing advance connector
- Removing catalytic converter for more BADASS exhaust!
- S10 Crewcab
- How do you check tie rod ends?
- 95 silverado straight pipe questions
- Model# of Stereo/CD player
- Updating My 82 Sierra Doors to Power
- 1988 Chevy overheating
- Starting Problems
- 93 with Knock Help Please
- no oil pressure!!!
- 96 chev 3500 7.4 vortec-no fire
- 82 GMC Sierra Automatic Steering Column
- Engine Rebuild Costs....
- 1997 Silverado 4X4 5.7 heater hose small leak
- 1988 K1500 Standard Cab Weight Question
- Warning Lights
- 94 silverado 4.3 to 5.7 engine swap possible?
- k1500 4wd not working properly
- Throtle Body Spacer help
- Z71 dimming/blinking lights
- Brake Light Problem
- 91 chevy 1500 stalling and chugging
- Lose of overdrive
- Distributor on ebay
- egr valve ? 94 full size
- 97 Chevrolet Z71 Suspension Problem?
- 2000 Chevy 2500 7.4 liter engine gas mileage
- Transmission Identification
- ----Stalling when in Op.Temperature??
- Requesting suspension advice for '94 C2500
- Oil Q's
- Batt to Alt. Wire
- antifreeze on top of intake
- 97 Silverado problem, need help!!!
- Need used/new 1996 K1500 wheel speed sensor
- OBD1 SES light flashes and then stays on
- Checking out a truck...
- 5.7L engine with coolant in the oil
- Noisy Belt In 98 Z71
- Running on empty
- overhaul...
- 97' vortech 305 fuel pressure regulator
- multifunction turn signal lever
- Gauge fun!
- taillights
- engine missing, loss of power
- Service Engine Soon
- 94 z71 trans prob
- Battery losing some Charge(95 Chevy 1500)
- '97 1500 305ci cyl's overloading with fuel
- Fuel Pump or ECM?
- Remote starter kills engine
- stepside 3/4 ton ???
- Overhauling 91... any sugg's?
- tahoe headlight problem
- 4x4 Problems
- 91 3500 454 wont idle
- K 1500 350 in 305 out / NEED HELP!
- Need a 5.7 roller for '91
- ignition timing
- 97 truck won't start when damp outside
- 1997 Silverado 1500 SES Light - reset (?)
- sway
- 96 K1500 turns over but won't start
- 4.3/283 transplant chevy 1500
- Oil flowing out of exhaust!
- Cap or topper for a 1972 C10 Chevrolet long box pck up
- front grill
- 95 ck silverado rough idle when cold
- 1988 4.3l
- '92 cooling fan options
- 98 1500, really bad whine, rear end/transfer case?
- Tranny fluid coming from u-joint
- Air Filter Housing(95 Chevy Silverado 1500)
- Hoses
- Tools
- right side axle/diff seal
- Flashing Brake Warning Light
- C/K Steering Columns
- 97 Chevy C1500 Driver's Door Won't unlock.
- 80' C-10 Body Panels Needed
- transmission
- Wanted 40/20/40 Bench Seat
- k10 tranny
- 94 Chevy
- For Sale
- Diesel Probs
- 1995 Chev.2500 7.4L 4WD - No back brakes!
- New to forum
- How fast when engaging 4WD?
- Door adjustment
- 1997 Weird Tranny
- 1998 lifter problems?
- heated seats
- parting out well mant.1994
- 1992 C1500 5.7l
- kill switch
- 1993 Silverado c1500 good buy?
- 96 Tahoe Fuel Pressure Regulator
- Loud noise in 4HI.......
- Cold Horn
- power steering gear box
- 1994 1500 5.7 Liter Engine Skipping/misfiring
- 92 K1500 dumps too much gas into TBI
- Relay sound under center of dash
- Leaking seal......
- 1977 c10 power steering pump
- Headlights not working.
- 2000 chevy 3500 model changing engine
- rear engine seal
- 97 vortec engine gone bad???????
- 92 K1500 5.7 idles rough, smells like fuel but no leak!
- 92 Silverado Cruise Control problem
- Weak Wiper Fluid Pressure??
- front clip conversion stepside chevy pickup /escalade?
- Catalytic Converter on a 94' Chevy
- '96 K1500 exhaust
- My headlights suck
- trans temp sender in Pressure Port?
- rear wheel problem
- '93 5.7L idles at 200-300 rpm at a light
- how to replace horn
- driver side door sagging
- door lock relays
- Misfire gets worse.. help!
- 97 5.7 goes flat at 4000 RPM
- 67-72 Chevy truck parts for sale!!!
- add extra battery
- oil pump removal?
- Bucking Truck
- Fuel Pressure 98 Vortec 454
- PO453 EVAP pressure sensor voltage high
- Blower Motor Removal
- 95 Chevy 1500 Heater
- to pass a smog test
- My 95 Z71 with manual trans is pretty messed up.
- 1997 Chevy blows gas out of exhaust
- Help ! Rear pass wheel wont turn !! Need this fixed by friday -- 92 Blazer 350 4x4
- 1993 Chevy K2500 Clunk
- leaking oil
- 700r4 Needs Help
- oil driping on spark plug boot
- 96 Tahoe weird noise from blower fan
- cab corners on 73-87 c/k trucks
- Code 1345 after new engine
- Quick connect fuel lines to pump?
- cold idle slump until warm
- New Motor Q's
- 99 Suburban brake lights
- Grill4Sale
- !992 k1500 4.3 won't start
- hard toneau
- need some serious help please
- Alternator Upgrade
