View Full Version : C/K
- Cummins swap?!?!?
- Quick question about different year engines and parts compatability. HELP!!!
- 1998 Silverado 4x4 ignition warning chime
- '94 6.2L code 36
- 89 4X4 stalls when warm
- new user, many questons, need help.
- Plans for Exhaust
- ticking until warm
- 97 Z-71: Rebuilt Tranny Yesterday; Driveshaft Clunks!
- a/c clutch 94 blazer 5.7
- Door Seals
- 96 Chevy Tahoe has issues
- 1993 c1500 4.3L Motor Problems
- Oil Pressure/Aftermarket Gauge
- Auto dimming mirror comp/mirror
- Does anyone know!!??
- 94 k1500 v6 rough acceleration/stalling
- 'Dump' exhaust....
- FlowMaster Mufflers
- rust free cab for 1977 3/4T
- transfer case
- Cracked Plastic Radiator Tank
- Anybody Get Dealer to Replace Tranny Valve Body Under TSB?
- A New Plan..
- stalls with brake
- hey guys
- 1991 3+3 1 ton flatbed
- slammed and shaved truck for sale!
- Vibration...???
- blinking brake light indicator
- Dash indicators on a 91
- 305 equipped with Super 40
- Ball joint
- pitman arm bolt
- oil leak
- Erratic Temperature gauge
- 85 chevy c10 problems
- Stalls after 20 seconds
- SES Light on
- Need Help!!
- Are there free-wheeling front hubs available for 98 K1500?
- pushrods,rocketarms
- speaker installation
- No Power Clicking under dash
- Brake Bleed
- bypassing the regulator
- PS power window not working
- Heater Core/ Evaporator swap in 96-99 trucks
- 1997 c1500 4.3l won't start
- New Exhaust Parts
- 88 k2500 headlights quit working
- 1990 chevy 1500 brake problems.
- Sputtering when Accelerating
- Squeak
- 92 Silverado keyless entry issues
- How can I tell if my motor is really a 350 or a 305?
- Engine rebuild
- Left rear seal Help
- Setting Timing
- HELP! How Do I Stop Wiper Mechanism From Sqeaking (97 Z71)?
- Forget The O2 Sensor!!!!!!!!!
- heater blower motor
- oil filter adapter problem
- 95 K3500 ABS problem
- problems starting
- Engine Swap 4.3 to 5.0
- K2500 1997 Complete Strip Down
- Shuddering Start - Smell Gas
- front left wheel calipher sticking
- would you get it?
- Fog lamps
- what does the timing
- chev vs GMC
- TBI - is it OK for injectors to drip at idle?
- Upgrade to 4L80E
- Problem regarding starter
- mesurements for rear leafs....
- Door clank
- Valve seals-4.3L V6
- 83 carb questions
- HELP,97' 1500 305ci, Fuel overload in Cyls.
- wiring diagram
- Lund moonvisor
- Better Gas Mileage
- 4l80e
- 93 6.5 diesel
- 95 c1500 check gages light
- hot air form heater constantly
- shocks ands struts
- keep replacing cap and rotors
- 89 350ci high idle and water leak
- aftermarket ABS speed sensor?
- 94 454 Too much gas & lost OD & lock up
- Better brakes
- can someone help me w/my 92 blazer
- PLEASE HELP! Runs rough cold!
- 93 K1500 Loss of power, valve lifter noise, only happens when towing
- scanner question
- E85
- fuel pressure regulator replacment help
- Uneven bed??
- Engine&Tranny Swap 92 K1500
- Everything works except the brake lights
- tranny fluid
- Custom Lift or Buy a Kit?
- wiper arm removal and painting, 97 Chev Cheyenne
- cylnder head from a 89 blazer ?
- 96 vortec 305 to 350 swap
- corvette servo
- cylinder heads reversable ?
- tire ?
- keyless remote programing 1995 k1500
- buying a mid-80's silverado
- fuel pump question
- 6 Lug 15 in. Wheels
- Speedometer cable and tranny help needed
- Broken Wire leading to sensor
- Headers
- 1996 gmc high idle
- replacing factory stereo, and not just the deck
- Non-level ride
- 87 pick up not running ?
- lens cover?
- Converting Grills
- Frozen Rim
- Valve ticking when cold
- '94 K1500 Starting Troubles
- Found a Crack
- floorboard tack welds
- New KC Lights
- abs recall investigation underway
- Tranny problems
- Fuel Pump Intake Plugged By Little Sock?
- air in heater core/cooling system
- strange prediciment
- code 0300 flashes under load
- The world is coming to an end......
- 94 K1500 shifting hard
- Getting lift...tires?
- amsoil synthetic/filters/etc.
- Re-activating the immobilizer
- location of Body Control module
- Tune-up help with parts ??????
- odometerandspeedometer
- trailer brakes w/o brake controller???
- 1988 K1500 Pitman arm replacement
- carter afb
- Speed Sensor question
- Chuggle -- more info -- no ideas?
- Liquid Leaking from Driver side Header
- Code 21, TPS voltage reading backwards
- Huge Tranny Problem Help!!!
- '92 5.7 -- Surge/chuggle or hesitation?
- no brake lights on 98 K1500
- heater wont turn off?
- problem with a/c vent control 88 Silverado
- Dex-Cool Sludge
- Bad engine? Hope not!
- gas milage drop
- antifreeze leak
- 97 Silverado vibrating accelerator @ 42-52mph
- No start problem...
- 91 C1500 Strange Water Leak ??
- Got The New Engine In
- couple questions from a new guy
- 1994 GMC Sierra 1500 Failing Emissions...Low Idle Cyclical Stalling/Surging
- 92 Ext Cab 4x4 - Interior
- F42 SUSPENSION... What this
- turbocharged 350?
- Rear main seal
- project car for sale
- 98 1500 4X4 humming when decelerating?
- Rebuild or Swap?
- LT-1 into 94 3500HD
- 88 Stepside 4x4 Curb Weight
- Beefing up for performance
- 1500 Runs Rough in Overdrive
- 97' Z81 Clutch Petal
- 93 C-1500 4.3 4L60-e trouble code help
- valve adjustment and/or lash???
- suspension lift?
- 81c shortstep side for sale
- '94 truck interior lights question
- victory is close, I can smell it......
- Starter Drive
- Motor install 99.3% complete BUT.......
- paint job
- 92 4.3L starting and stumbling problems
- how do find out?
- Transmission code
- Aww man, what?! Oil Leak!
- asbestos
- lowering an 1987 c-10 with 20s
- Windshield wiper problem 1994 Silvarado
- miles per gallon
- Engine cutting out (long)
- Flipping Air lid on air filter
- heater issues
- On Highway, Backfired then Died
- Service Engine Light
- Changing Wheel and Tire size
- Fuel pump opinions wanted
- 1993 C1500 4.3l 2wheel drive HELP
- HEI distributor replacement
- My 4.3L needs more power!!!
- Flowmaster 40's vs Flowmaster 40's
- 02 sensor probs
- Oil leak
- oil pressure
- 95 clutch won't disengage after replacment
- Catalic converter cutout
- rear differential leak
- Nelson Tune
- Body Lift kits
- No tail (running) lights on '94 crewcab dually
- Air Vent Temps
- O2 sensor
- cam
- Ignition problems on 96 Silverado
- Intake leak or not?? Long story!!
- wonder shine!
- 1989 Chevy %#*@ Nightmare! Need Help on Brake, reverse and running lights
- having difficultys
- 97 c-1500 fuel pump
- Water injection systems
- Exhaust sound
- Cheap mods
- Help please, truck won't work
- mass air flow sensor
- 4.3L shorty style headers
- 1983 C10 Question
- how does V6 sound with flowmaster
- 97 C-1500 Vibration
- 1973 C-10
- Brake problem 73 c-10
- 1997 k1500 ses
- More POWER!
- resetting a Brake Proportioning valve?
- Odometer Stopped
- lt1 help 4 chevelle
- 74 pickup... or indy truck?
- LT255/85R16...Will they fit??
- heat stove
- tranny shifting problem
- Rear Problem
- 110 Octane Race Fuel in 454
- For Sale
- 95 transfer case linkage
- How Do I Remove Rear Speaker Trim (97 Z71)?
