View Full Version : C/K
- 93 runs rich, hesitates and keep getting codes
- 1990 C1500 No Power to Fuel Pump
- moonvisor
- moonvisor
- Truck Wont Move !!!!!!
- no spark
- 89 350 Valve Adjustment
- Transmission Problem 1997 C2500 No Overdrive
- 94 Chevy Silverado Smokes when started
- 1989 1500 silverado window trouble
- 79 rear brake conversion
- question about 1973 454
- 93 1500 half ton
- Lucas Oil Stabilizer in my 95 Z71
- Oil pressure
- 97 Silverado 1500 A/C Weak
- 98 Chevy Silverado Idle problem, Does Not Idle well, until warmered up
- I have a 91 K 3500 with fuel pump run on
- Tools - pt. 2
- Question about timing
- Speed-o-meter problems
- tranny fluid change
- horsepower/torque 1995 cheyenne
- 98 Chevy Silverado Fuel Pump goes in and out. Also won't idle(tries to die)
- Colder plugs for 7.4?
- Power Steerin Gets Real Hard To Steer !
- Headlight Problem
- 89 k1500 Fuel Gauge Problems
- 1998 Silverado 5.7L Fuel Metering Body
- 305 Dipstick length 92
- Heat Issue!
- 97 350 Surging
- 96 k1500 5.7 won't start
- Cruise Control INOP - 03 Sierra
- 94 350ci 4x4 manual tranny swap
- wiring diagram?????
- what rims will fit?
- 98 Silverado Keyless remote problems
- 1988 K1500 5.7 won't start, again!
- 91 wiring
- vibration -Harmonic Balancer?
- '92 Temp Sensor
- Trouble removing driveshaft on an 87 Silverado
- 235 c.i. and small block bellhousing bolt pattern? mounts?
- A little shimmy
- head gasket??
- electrical or grounding problems?
- Noise when stopped
- 94 K1500 Runs Rough When Cold
- Replacing Rear Speakers in 95-98
- Rust
- 96 vs 98 power steering changes?
- 82/86 Sierra C15 Carb trouble
- Just turned 100k - should I change oils?
- Noise from some a/c related part
- wiring
- 86 GMC C1500 V-6 to V-8 Swap
- 86 Silverado won't turn over- please help!
- 4l60e Help
- winshield wiper arms 98 silverado
- Oil pressure
- Rear End Locks Up When Turning (why)
- Need a/c compresser 1995
- oil pressure sending unit
- 1994 c/k 1500 4x4 front axle nut size
- Need some information...
- Sensor Question
- instrument cluster wont light up. HELP!!!
- 91 1500 AC/Heater Floor To Face Problem
- Which one should I do?
- 94 performance help
- actual vehicle weight
- Prndl Light
- E-85 conversion question
- "93" 4L80E home rebuild roadblock!!
- 4L60E shudders before downshift
- 1995 K3500 speed/cruise problem
- Heater core removal 1995 K-3500 with Air
- Help? Project Sierra Oil Spruing
- Autotrac? Do I have this in my 95 K1500?
- Silverado Passenger door problems!!!!
- 1988 K1500 4X4 Front Axle Won't Engage
- Dealer can't even figure it out! What now?
- The Float on my Carburetor Sticks
- 94 1500 4x4 wheel bearings
- 95 C1500 wont start
- Headers
- Brake Diagram
- Trying something new and ned advice
- Headers For My Trucks
- FS: 1990 Silverado Shortbed 4x4 5.7L
- Loose Steering Questions
- Brakes? Ujoints?
- Brakes? Ujoints?
- HELP with my starter motor
- oil pump
- Oil Pressure
- Missing
- How do you know if a fuel pres reg is bad?
- Heating issues
- How Do I Retrieve Transmission Codes
- few questions aboutm 1990 to 1993 engine swap
- Timing, sensors, what the?? I'm stuck
- fuel delivery problems
- installing an alarm
- 82 to 89R Chevy truck cab Swap!!
- 93 Silverado Floor Vibration
- Front Wheel Bearing Adjustment
- teach me about (manual)FLYWHEEELS
- Milky anti freeze in the overflow tank
- Oil pan
- Shifting Problems While Towing
- changing air filter in 97 cheyenne
- Looking For Wheels For your CHEVY???
- Looking for some parts
- EFI conversion
- sputtering
- Distributor pickup coil question
- CD Player Removal 95 Tahoe
- loading up
- loading up
- 1989 Silverado 454 ECM Bad Ground?
- 8 foot box conversion to 6
- Some d-bag sold me a piece of crap
- Soft brake pedal
- How do you?
- 1991 C1500 Steering Column
- Electrical Problem
- 97 transmission noise
- 1989 Silverado K 3500
- Can I Add Shocks???
- How to remove a truck bed?
- What gears do I have?
- 4.3 to 5.7 computer question
- 1990 5.7 TBI dies under load
- 1998 k2500 6.5 Turbo Diesel
- Need some info
- Ignition Upgrade
- Gas Mileage
- Spark Plug Wires - When to replace?
- Replacement Torque Converter
- bulkhead connector diagram?
- Brake lights not working
- No Crank, No start
- Rough Idle-'89 454 Tbi
- Truck Bogging Down
- Kenwood radio cooking my CD's
- Lowering kit
- Steel Seal
- Adjusting rockers. Need some advice.
- 4x4 hub question!
- busted shock
- '98 Silverado Turn Signal problems
- GMC and chevy
- 96 K1500 Brake Issue
- 97 Silverado knocking
- valve cover oil leak
- Stats
- 93 dash brake lite
- Oil Sending unit question, 85 Silverado
- wierd one - loud pop and white smoke under hood
- Paint Job
- Anybody here with a solid axle conversion?
- 79 Chevy Pickup
- 96 Z71 Fuel System questions
- 97 k2500 step bars
- FS: 87 chevy 4x4 custom deluxe
- 94 Silverado - Rear End Noise
- 98 2/4 drop will 20's fit?
- 1982 6/8 Engine Swapping?
- help
- 87 Chevy 3/4 ton
- Cold Air Intakes??
- Reliability of 4.3 (88-95)
- 1982 chevy 305 Distributor?
- Trailer Wirring 94 Chevy
- 76 Chevy pickup Tumbler replacement
- HELLWIG 1535 Helper springs
- Speedometer & Air Bag light - '98 Z71
- how to remove fuel pump 1999 chevy suburban
- 1988 K1500 Emissions problem
- Engine Swapping
- Quadrasteer plus engine question
- 86 Chevy Difficulty installing Fuel Pump
- Speedometer needle sticking..HELP
- rough starting engine 92 c/k
- Pinstriping on 86
- 97 350 vortec power loss
- Timing Mark Location- 1995 C1500 4.3 V6
- Front end diagram
- Temp Guage
- question about the 6.0 engine
- opinions wanted : is a clean 88 body worth $200 ?
- 1998 Z71 Fuel Pump and mass air question HELP!!!
- Please Help!!!!!
- So I'm helping out a friend...
- '88 2500 losing the will to go
- 93 to 98 dash swap
- Inconsistent oil pressure 98 Silverado
- 1998 Fuel Pump Issue
- 5.7 V8 not running on all 8
- Front Seat 92K1500?
- Drivers side mirror
- Rim width
- 1994 Chevy Cheyenne 4.3L to LT1 swap
- Inexpensive leveling
- looking for 14 inch lift kit.
- Cat Converter/Dual Exhaust Price
- ext and std cab mounts
- Having trouble replacing pick-up coil
- torque converter
- 1982 Sierra Engine Removal
- cold blooded
- How much torque on idler arm?
- 98 Silverado-replace interior driver side door handle
- which engine
- How much horsepower/torque do you need?
- Oil Leak
- Door sags,any adjustment
- From Pink to Green
- Wiring problem
- 89 Engine Debate
- heater a/c controll problem
- Difference Between C AND K / FUEL TANK PROBLEMS..Thanks
- Engine swap in 1998 Silverado
- 700r4-92k1500 ?
- noise in rear 93 silverado HELP PLEASE
- installing in-line fuel pump
- 700r4 problems
- Need 95 Diesel Stalling Advice! PLEASE!!
- power steering pump brackets chevy 283
- transmission shift points control?
- 95 Chevy Silverado (Burning Gas)
- question on 73-87 trucks
- trailer lights
- steering play and poor performace
- alternator question 67 283
- Daytime Running Lights on a 1992 K1500
- transmission shift delay?
- I have 3 questions about my 85 chevy 4x4; thanks!
- motor mounts 4.3 - 283
- Gas Type for 95 Chevy Silverado (1500/V8)
- 4 wheel disc brake conversion and differential change out
- Vibration on 85 4x4 Silverado, any ideas???
- 98 305 to 350 or 454 converison?
- door lock actuator
- Throttle Body ?
- New Guy - '95 Z71 4x4 problem
