View Full Version : C/K
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. engine swapping?
  2. Drive Train Question
  3. coolant leak
  4. OBD code information.....
  5. 1991 chevy truck - AC knocking
  6. 1990 truck won't idel when cold
  7. crazy coolant
  8. Screeching noise when fuel tank runs low?
  9. can u lower a 4wd? if so, will it hurt it
  10. my wipers and cruise act up HELP!!!!
  11. 1996 Vortec 350 injector/fuel system - tough problem
  12. fuel pump 99 suburban
  13. Fuel Temp Sensor DTC
  14. Roller Rockers
  15. suspension bushings
  16. overheating 93
  17. Mileage Drop
  18. Ac
  19. Towing with 33 Tires
  20. '88 C2500 won't accelerate
  21. no tailights, or signal markers, but i have brake lights
  22. I feel bad...but not that bad
  23. oil pump
  24. 92 1/2 ton 4.3 liter won't idle cuts out
  25. 83 1/2 ton w/305 won't fire????
  26. Pulling to right hard
  27. shorties of long tubes?????
  28. Won't Start - Clicking Noise
  29. new engines question
  30. A/C Indicator
  31. Stepside --->> Fleetside
  32. Fuel guage goofy
  33. 4l60e
  34. Transmission Decisions
  35. Please Help!
  36. 1972 c10 used to "grind" goin in first gear, now no clutch at all
  37. 95 Silvarado Hard Shift
  38. loud rattle or rub
  39. HELP 1998 z71 oil breather?
  40. 1990 C1500 Interior Doors
  41. power seat track
  42. converting TBI to CARBURATED
  43. zero oil pressure at start up
  44. Intake manifold upgrade
  45. new 350
  46. 89 C/K sometimes has White Smoke at Startup Only
  47. Mixed Fuel
  48. Tranny wont shift in OD
  49. I can't believe my drive shaft broke
  50. tinging sound
  51. Speedometer Wrong
  52. Power window regulator ?
  53. Brake lights wont shut off!!!
  54. Idle problems
  55. 98 chevy performace upgrades
  56. A/C problems
  57. Ripped out wiring...
  58. charging question
  59. help with inst cluster
  60. help with 4l80e
  61. Wipers come on by themselves...
  62. v6 power
  63. 350 tbi needs a head gasket
  64. master cylinder hiss
  65. Manual tranny question
  66. 98 water leak at manifold
  67. 93 6.5L glow plug light
  68. Please help Don't know what to do!
  69. Radiator flush, is this a job for me?
  70. '96 K1500 - Won't go into gear.
  71. Brake lights only work with the headlights off
  72. 89 K2500 Code #43...
  73. 97 Silverado Steering issues.
  74. Ignition Timing
  75. Replacing plugs...need advice
  76. 92 cevy 1/2 ton rpm gauge bouce
  77. 85 tranny vibration
  78. are 5.7'z really fast?
  79. AC not blowing- Vent problems
  80. 1997 c1500 305ci heater hose leak
  81. 4.3 Engine Swap
  82. Steering Column
  83. 97 k1500 questions
  84. Possible torque converter problem?
  85. need help 100$ fillups every 2 weeks
  86. 1986 k20 military diesel pick up
  87. 83 trans swap
  88. oem parts
  89. seeking '98 w/t 4.3 5speed info
  90. Back from the beach
  91. coolant and temp problems.
  92. TH350 more fluid leakin out then I can pour in!
  93. master and slave cyl.
  94. Oil pressure guage
  95. Wheel Size
  96. Wiring Diagram for 73 C-10 Pickup
  97. '90 Gmc Sububban
  98. rear seat audio (RSA)
  99. Crazy tach, odometer quit working, engine rough at start
  100. more blow from my blower
  101. 4l60e no 1 and 2
  102. custom truck for sale!
  103. Smoking from dip stick and through TBI
  104. 94 K1500 starts hard cold
  105. difference between 700 and 4l60e
  106. 87 Silverado 1500 2wd - Starts and runs, but dies several minutes later
  107. Brake Code 4 Grounded Antilock Valve Reset Switch
  108. c1500 radio upgrade
  109. stumble from stop
  110. 1994 c1500 help
  111. Motor Build Up???
  112. Serpentine Belt
  113. Zmax seems to boost mileage 20%
  114. 94 k 1500 leaking trans fluid
  115. electrical charging
  116. Lower Intake replaced, now strange tranny
  117. missing and backfire out tailpipe
  118. fender emblem
  119. Tranny and trans swaps
  120. TCC (PWM) valve or Tcc Solenoid valve?
  121. brake problem
  122. Gear Spliter
  123. Chevy C10's!
  124. saddle tank recall
  125. ac probs
  126. intermittent a/c blower!!!
  127. more about bad fuel pumps
  128. Chevy to GMC grille swap
  129. Fuel Pump Change Without Dropping the Tank
  130. strait axle swap???
  131. HELP! Is My A/C Compressor Shot?
  132. 95 chevy hardly starts
  133. ac problem
  134. Smoking Wire(s) at attempted start
  135. Help w/keyless entry
  136. Won't start
  137. 95 k1500 z71 owner's manual
  138. Fuel Problem?
  139. Question about A/C for you pros and smart people :-).
  140. Door latch failure from inside 1999 Tahoe LT
  141. distributor cap and rotor wear
  142. Running Amp cables
  143. Help Lean Trouble Codes Maybe Vleak
  144. timing of a 95 k1500 5.7 w/tbi
  145. Question about oil pressure
  146. Airaid TBS question
  147. muffler
  148. speedo works but vss is bad. possible?
  149. shift ???
  150. 1 wire to 3 wire oxygen senser swap
  151. Electric Problem - Won't Charge Battery - '98 5.7
  152. Duel Battery Setup?
  153. Cross-over steering
  154. Front end Noise, Brakes
  155. Exhaust
  156. Oil consumption, Valve stems?
  157. Fiiirrrrsssst to second-harsh shift
  158. abs codes..
  159. 4l80e transmission problem
  160. check it out! truck for sale!
  161. 1994 5.7 propane misfiring
  162. speed sensor- abs or vehicle?
  163. Starter troubles
  164. Phat gauge face...
  165. Wiring schematic
  166. daytime run lights
  167. Lift kit install nightmare
  168. 1996 z-71 transmission nightmare
  169. a/c question
  170. tps 95 vs 96
  171. th350 or 400 instead of 4l60e
  172. 5.7 engine shut down
  173. engine shut down
  174. TPS Sensor low input
  175. transmission 2nd & 4th gone
  176. gas gauge pegs/dies
  177. Air Intake Question??
  178. Transmission won't break free from engine?
  179. Dash rattle is driving me wacky!!! HELP!
  180. 91 to 96-98 interior swap
  181. best place to get a rebuilt motor
  182. True duels
  183. no power to fuel pump
  184. Very Hard Shifting 700r4
  185. Master Cylinder Question
  186. How to shave logos and emblems...
  187. NOISY Shifting
  188. No power
  189. 97-4.3 fuel relay overheating
  190. 84 od tranny
  191. Service engine soon
  192. 84 Od Tranny ??
  193. lots of new parts still wont run...
  194. GMC/CHEVY what's the difference???
  195. 98 Z-71 spongy brakes, might've found a fix, suggestions???
  196. Aftermarket Rocker covers
  197. somebody answer this question 97 Z71
  198. 1993 C1500 overheating
  199. stalling at idle 1989 chev 305 k1500
  200. exhaust keeps breaking!!
  201. Engine miss at idle, Cyliner #1
  202. 97 4.3 vortec no start Please Help!!!
  203. Big Throttle Body upgrade (Holley)
  204. whats reasonable?
  205. chevy 1991 2wd leaf springs
  206. sputtering at cruising speeds
  207. Headers for 1998 cali k1500?
  208. 305
  209. Rear Axle "Clunk"
  210. 89 chevy vibrates at low speeds
  211. Any Transmission experts? Shifting Problems, Any ideas?
  212. day time running lights
  213. Air Conditioner Problem
  214. 4 Sale GM Navigation Radio
  215. flex-a-light 260 or 280 duel fan
  216. Pedal Vibration
  217. Ground Effects
  218. lift
  219. what year engine
  220. TBI problems Please help
  221. 96 Silverado won't start after auto start removed
  222. 95 Chevy mods??????
  223. '96 C1500 headlight lens replacement?
  224. Oil Pressure Problem!!!
  225. more power out of my 4.3
  226. door latch
  227. 1997 Suburban Whining Noise After Oil Seal Replaced
  228. Scratches in glass
  229. how to adjust valve lash
  230. whats the best cam to get
  231. 1991 C/K brake lights won't shut off
  232. who's got the most km?
  233. front end leak
  234. stripping paint
  235. Stereo / Subwoofers for EXT CAB truck...
  236. tilt steering sticks
  237. Yukon XL Rear End Whine
  238. help with my exhaust FAST PLEASE!!
  239. v6... vs....v8
  240. Cummins swap?!?!?
  241. Quick question about different year engines and parts compatability. HELP!!!
  242. 1998 Silverado 4x4 ignition warning chime
  243. '94 6.2L code 36
  244. 89 4X4 stalls when warm
  245. new user, many questons, need help.
  246. Plans for Exhaust
  247. ticking until warm
  248. 97 Z-71: Rebuilt Tranny Yesterday; Driveshaft Clunks!
  249. a/c clutch 94 blazer 5.7
  250. Door Seals
