Chevrolet
Avalanche | C&K | Silverado | Suburban | Tahoe
> C/K
View Full Version :
C/K
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
1982 Chev Diesel 1/2 Ton Pick-Up Side-Step Short Box
Header To Y Pipe Collectors Problem
99 K1500 rear disk conversion
What should I pay for ... cap, rotor and wires?
tranny amintenance - neglected
oil and spark plug's - members liking ?
4L60E Issues
lug pattern on 97 K1500????...
97 chevy with a bad valve
A/C Problems
polishing headlight lens, cabin filter, DRL's
95 chevy brake booster problem??
Oil Pump
no backup lights on 4.3 manual
88 TBI tail lights and remote start don't work after new fuel pump
temperature
coolant in oil question
hidden rust and lamp replacement question
1997 C1500 Power Steering question
steering wheel locked
engine surge
89 350
89 350
transmission winding
2005 4door chey 1500 Z71 rear end hop
Ford to Chevy.... "saw the light ! " -questions.
wierd feeling in the front suspension
Headers
K2500 4L80E transmission whine
having a problem between 50-65 miles per hr with a miss or trans trouble .
Lift parts for 98 z71
Fast Idle problem
98 k1500 starts and dies
Dead Fuel Pump
1990 k 1500 nv 3500 4x4 5spd HELP PLEASE?
1989 350 Inj just sprays fuel
starter bolts
1982 Chev Diesel 1/2 Ton Pick-Up with Cherry Bomb Mufflers
Supercharger for my 95 5.7L Z71
hypertech power programmer III
W/T to Silverado Grille Conversion *PICS*
interchangeabe dash ?
2000 gmc c3500 old body long cranking/starts hard
motor swap question
Ignition Problems...
95wt water pump hose?
6.5 trouble
water heater pipe nipple thread count and size?
rear wiring
5.7L vs 4.8L
98 Z71 5.7L losses power at 3000rpm
1990 Chev truck GM 5.7 EFI to a 383 EFI?
94 ac problem
1988 4.3 fuses
Weird Timing problem
1997 Tahoe transission failure @ 135K
What is proper fuel pressure for 1990 454 TBI?
93 4.3L V6 low/no oil pressure. already changed pump. Help please!
98 4.3l high idle
replacement shocks for 1998 z71?
'89 K stalling, not wanting to start after (LONG)
headlight aiming and removal help
Polishing/Cleaning scratched speedometer lens
what to do about the oil cooler lines???
454ss
heater vent no work?
7.4L ruff running (1997) Injectors?
Pictures of my truck
Looking for a 92 454ss
Suggestions for 91 chevy 350
Radio troubleshooting
Max Tire Size
1988 1500 idles rough
Speedo Problem
belt shakes and makes noise when AC is on
4L60E Problems
if i had a 383 stroker......
finding an aftermarket elecrtical fan
Fuel Pump/Relay- Help!!
Low power when warm for 1 minute after starting
(Heater/AC Fan) No Air
OBDII code P1870?????
1990 C1500 2wd Steering Grease Boots/Fittings
88 K1500 Rear Driveshaft question
Strange problems with door lock
Wheel bearing for '97 Z71
transmission problems????
'79 chevy front end wiring problems
Tranny-won't take off in drive/overdrive
1998 z71 wiper problems
'96 K1500 - Rev's at Idle
'96 K1500 - Hard to start after sitting - Fuel pump?
Running water sound
downshift???
1965 GMC pickup with 1988 chevy pickup parts
Exterior Trim Removal - '88 - '98
99 c2500 hard start and rough idle ....HELP!
engine missing
Radio/speakers stopped working
WAY OFF SUBJECT, but worth a look
Need A/C Help
Alternator upgrade wiring
1995 C1500 windsheild wiper/radio problem. Short?
misfire
Remote Starter for '96 K1500
'96 K1500 "slips" or "jumps" in OD.
White smoke only on startup with low coolant
tranny trouble
Idles rough, lose power when reaching operating temp
Idle rough loses power when hot
Rust
How to replace rear speakers?
still having a problem with plug wires fire running up and down them
'97 C1500 Electrical Problems
A/C Kaput on 97 c/k
horsepower and torque specs
'96 K1500 radio size
Brake parts help?
transmission slipping????
Multiple Battery Wiring
88 Chev Truck 2wd 4.3 no start
emissions trouble
Cowl Induction Hood
wacky dashboard
front shimmy when apply brakes
'91 c2500 350 AC and Alternator questions
national Auto service review website idea
92 1500 A/C problem
TBI Swap
1988 shifter
95 chevy 1500 (Orifice Tube)
Squeaky Torque converter or transmission??
99 6.5 diesel inermittent problem
C1500 Lift
1992 and 1990 original service manuals repairs 15$ each
4WD compared to All wheel drive
Buzzing Noise From Engine Compartment
Can't figure out - alternator or fuel pump or something else?
silverado won't start....sometimes
belt/waterpump problem
89 c1500 brake problem
Water Pump????
95 ck 1500 stalling and wont start
Upper Control arm Mounting studs ?
Slight amount of oil atop 350 engine
95 Chevy 1500(4x2) Parking Brake
White smoke at start up
96 K1500 Fuel Pressure
96 K1500 4.3Vortec Won't stay running
93 6.5 turbo diesel hot start problem
one more question - ngk or ac delco plugs
does it hurt the spark plugs to gap a little bigger
1995 1500 couple problems
looking at a 88 CK2500
80 k-5 350 Starting schematic
82 K5 Emissions
82 K5 Emissions
1995 C1500 Wheels
'94 Chevy AC possible problem.
Strange Electrical Problem
Orfice Tube
A/C Wiring Harness
Motor mounts
Vacuum Source for MAP Sensor
94 5.7 found problem - how to fix . first time i ever seen this please help !
which multimeter to buy?
spark plug wires - 94 5.7
87 chevy questions several
Torsion bar cam lifts
Need Opinions
Trailer Brake Controller Problem
1994 silverado 5.7 - should i set time at 0 degrees or advance the time any
350 motor swap
Optimum RPMs
454 ss 90-93
94 silverado 5.7 - miss came back !!
Gear Ratio
hood release cable broke
1995 K1500 light throttle mis
Ignition Switch Replacement
81 Chevy only goes in 4 wheel low
has anyone ever replaced a fuel gauge?
1981 C10 dies when I let off the gas
94 miss at idle finally fixed !!!!!! found problem
1994 chevy c/k ac compressor replacement
Really Bad Shimmy
Leveling coil spring spacers for 2WD trucks
1990 Chev Sport 305CID Short Box Missing Too!
My 90 Silverado Stepside Body Lift Prob.
broken brake lines
1994 Intake Gasket Replacment
any opinions on this
Rear window in 95 C1500
Brake problem
1994 5.7 - bad miss at idle please help
95 6.5 diesel brake light problem
still a fuzzy fuel gauge
Changing instrument cluster need help
nv3500 help please 4x4
Need help troubleshooting AC
shift kit in a 93 1500 cheyenne truck????????
'98 5.7 Misfiring
Breaking in a new Headgasket
454
Passenger rattle at high speeds
Rattle in Drive
Street Truck
Pitmen Arm
U-Joints
EST location to set timing
transmission snapping end off
new tranny
ENG 1 Fuse Headach
Smashed Steering Column
My 95 Z71 has many problems HELP!
help 92 chevy 454 idle problem
92 Chev Rear ABS wiring
brake problem
Radiator 250 or 305/350
1989 Chevy C1500 Idle Problem
Door panel removal on a 97 Silverado pickup
Bad Coil again / 85 Chevy 4.3L
air bags for a 4wd?
1998 Chevy 1/2 ton pick up
90 5.7 wont hardly run, rich
Leaking Coolant
Help: Heat/AC Flow Problems!
92 K 1500 Vacuum Hoses
AM Radio hum...
headers
Rebuilt transmission still having problems
95 chevy 4.3 283 conversion tranny options any suggestions
94 K2500 6.5 Glow Plugs Inop
98 Chevy Alarm system problem
Shocking Problem!
Possible U Joint Problem & TPS Question
brake lights
glove box knob
Project K1500
Any other 6.5 L diesel people out there?
z71 tranny trouble
350 engine
95 throws error code 35
Oil Pressure Drop & Fluctuation???
Cars after 1987 Metric?
