View Full Version : C/K
- Headers Headers Headers !!!
- 92 "new" 4 bolt tbi knocking
- '95 K2500 5.7 Runs poorly
- error code P0160
- How do I find out what kind of differentials I have
- Charging Circuit Diagram 1973 K2500
- fuel pressure regulator
- air bag safety
- Which fuel injector cleaner for 96 Vortec 5.7?
- Broken quick disconnect nipple
- 92 Chevy C1500 W/Rough Idle
- What Exhaust?
- distrbutor click noise 350
- I have engine frame mounts I dont need.
- keyless entry?
- Possible Supercharger?
- For those who have had an Engine Rebuild
- '92 2500 2wd
- Finally, I'm close to finishing
- get your trouble codes read for free
- Windshield Wiper Motor Failure
- P0171 & 0174 codes
- no juice
- keyless entry help
- Small blocks
- A relatively simple problem... you would think!
- Bouncing...brake problem?
- Clutch
- All over the road steering problem
- stock GM radio question
- ?'s about exhaust
- Best milage?
- Body Work
- New Guy from Calgary!
- 2 bolt or 4 bolt mains
- Rear Tire Locks up while driving
- Tire ???
- Transmission swap question
- cold air intake
- a/c inop.
- transmission cooling lines
- NOOO!!! Blew head gasket!!!!!!
- sticky acceleration
- 97 4.3 engine misfire
- lift kit
- 4x4 Will Not Kick In!!
- MY 96 CK 1500 4X4 fails to start (sometimes)
- Valve seals
- surging in reverse
- Front Diff 92 K1500
- antenna wire
- A couple of questions
- engine stalling
- Compressor works but no Cold air from A/C
- what is my gear ratio?
- 1988 K1500 Fuel pump
- 1990 GM Security System HELP
- hey guys oil change....
- Brake Pedal
- 2001 5.3 high pitched whistling
- suspension
- Missing 1998 K1500 5.7L
- 1995 4l60e transmission bolt problem
- fuel pump relay ground
- Is This a con or not
- switching out an input shaft on a 4l60e
- Egr Valve, Solenoid or Timing
- Nv 4500
- 95 K2500 Low Power, Misses some under load (when Cold)
- 94 c/k body side molding
- Seats
- Rims and tires for sale
- Body Lift Restricts Use Of Truck?
- oil leak
- Windsheild Washer Pump Location?
- 84 C10 new engine swap runs but wont idle
- Rear-end questions, help??
- Help...any tranny techs out there??????
- Horsepower for truck engines
- 93 Chevy PU code 54
- Need advice on changing clutch
- Wiper operation question!
- Gears mashed up
- A/C Compressor
- Exhaust gas
- Looking For Lockers
- Looking 4 opinions on Frnt. brake replacements.
- cold start=no idle
- Thankx for the reply
- 97 Votec 5.7 HP
- Just want to make sure
- 1994 ck 4x4 1500 oil pressure sensor
- Traction Bars
- 94 Trans WTF? blowing out red fluid...
- 1997 Z71 brake problems
- dash lights
- rear disks?
- crew cab ???
- 2 Front O2 Sens. Locations Please
- Need Help For Engine Swap!
- 96 5.7 1500 AC problem
- 1997 C1500 bright lights
- New to the C/K forum, need diag. help....
- Balancing Beads
- 5 spd. to auto
- Now another problem
- Wire or Ignition switch?
- Throttle Posistion Senser
- Starting Problem, only getting worse
- Chevy 3500
- Sea Foam?
- Start Stall Probs 95
- Cooling system connector replacement
- 97 chev 4.3 alternator
- no start [confusing]
- C or K
- 97 Z71 Silverado
- AC Delco Plugs? Or Bosch +4's
- Think Truck is missing
- K1500 Tweaks
- Help!!! Help!!! Help!!!
- Auto Trans blows fluid out the vent
- Grille conversion.. plz help me!!!
- P1345 twice with P1351
- Amsoil
- Ading prophane to your Truck...
- shocks
- Back Up Lamp Switch
- Under Dash? ticking.....
- Crazy Fuel Pumps
- help please....TH 400...1990 1/2 ton
- Help Now!!! Truck Overheating!! Why?
- 97 Z71 won't slow down on decel
- Horsepower
- turns off when shifting into gear
- distributor problems
- underdrive pulleys
- c3500 starting problem
- P1345 Code -- Aaargh!
- Gas mileage
- Tach/Speedo acting "WIERD"
- Vacuum hoses
- 1992 K-1500 5.7 V8 4X4 High Idle
- Transmission Issue???
- HELP Fuel pressure problems, bad check valve
- th400
- Help for 3500HD 8.1
- suspention lift
- my 88 new engine
- egr system-86 k10
- edelbrock carb, adapter?
- mpg and power upgrade for TBI
- 97 chevy c1500 will not start
- Brake light switch replacement
- supercharger for 89 350tbi
- 15" to 16" rims Suburban?
- correctly installing a distributer in a 84 350
- Coolant Mixed with Oil!! Help!!!
- 89 k1500 stalling problems
- heater ???
- 1989 k1500 350 codes
- Oil pan gasket
- 92 silverado mystery ?
- 700R4 @#$#& SHIFTING PROBLEMS!
- wierd A/C Problem
- 305 heads on a 350?
- Hydraulic clutch fluid
- #1 cylinder seems to miss intermittanly
- help please...cruise control 90 chev
- brake light switch cruise control not working
- help with cruise control
- fuel pressure regulator?????????????????
- axle swap
- remote programming
- 3/4 ton rearend under a 1/2 pickup, how hard is it?
- Calling All Chevy Lovers
- 95 chevy Silverado Z71 no start
- Where has all the water/AF gone????
- transmission tailshaft endplay???
- 99 6.5 diesel problems
- Put a K&N filter in now Problems??
- flowmaster muffler for sale
- headlight problem
- Oxygen sensor problems
- 96 gmc 1500 misfire
- DRL relay
- freaky fuel lines
- antenna?
- Are all 4L60Es the same??
- Help steering arm
- 86 C20 stuck in high idle
- '98 C/K 2wd Truck TCC intermittent.. weird one
- Did 1983 3/4 ton's have emmissions?
- Dust Cover
- Oil Cooler Line routing
- 89 chevy truck wont start.
- Does Flowmaster exhaust really help to boost power, torque, and fuel mileage??
- Differential blowing fluid
- oil smell
- need help to find headers
- How thorough is the Chilton's repair manual?
- 89 1500 Drivebelt shaking & Squealing with A/C on
- CD Player Install Questions
- 4 wheel drive doesnt work......
- Fuel Gauge
- Fuel Pump - Reliable Brand Names
- Anyone ever used a hypertech or superchip programmer on a 7.4L Vortec Engine??
- My 88 Restoration, gets a new heart!
- Brake problem
- c-60 brakes locking up
- Low Battery Charge 1991 1500
- sunvisor removal
- Clutch Or Tranny Bad?
- Looking for bed info
- Fuel Gauge not working
- Tach and Speedometer acting strange
- Need an Estimate
- Hard start and rough idle
- 91 ck wiring diagram
- 93 5.7l V8 No Start?
- motor mounts
- 1981 C10 305 stalling when hot
- 1999 Chevy 2500 Crewcab Z-71 ???????
- Need wiring help! High Idle?
- Radio question
- will i get enough out of my alternator
- Questions on a 94' Chevy
- trans question
- engine to loud
- 1993 Chevy 3500 Crew Cab Dually
- Low fuel pressure
- coolant leak
- Problems with my 98 K1500 metal sound
- EGR check
- Wheel bearing replacement
- reason for break warning light?
- 91 4.3L oil pressure sending unit.
- 1996 Radio volume switch has no control
- 400 where a 305 was??
- how do i replace the 4wd actuator on 97 silverado
- transmission upgrade
- 98 tahoe possible fuel problem
- 93 Silverado- no power on acceleration or hills
- problems with my freebie
- engine swapping?
- Drive Train Question
- coolant leak
- OBD code information.....
- 1991 chevy truck - AC knocking
- 1990 truck won't idel when cold
