View Full Version : C/K
- Strange headlight problem...
- O2 threads bad
- 93 1/2 ton with Intermit. fuel pump
- rear diff leak
- Fuel Problems
- 1997 truck sounds like running high rpm with low power
- 95 K1500 Tach/ Transmission Quit
- Noise from the distributor cap
- new front end?
- Air management/header question
- 1994 short bed single cab seat
- A simple jack question
- Transmission Bogs down...
- t400 tranny problems
- 90 Chevy K3500 454 bucking/service engine soon light
- 1993 1500 4x4
- Is the wiring harness the same for all the 73 -87 pickups
- 2500 not locking into 4wd
- first time engine build
- TBI to carburetor...how hard is it?
- dry fuel bowl, need opinion
- Surging/Hesitation
- Afterrmarket In Dash CD Player
- when checking timing
- 93 silverado dash lights not working
- front rotors
- Engine Swap To efi in 83 k20
- My exhaust idea
- A couple questions about 1997-1998 Silverado
- 96 1500 won't start
- homelink wiring question
- 1990 c 1500 5.0 FI
- Fan Clutch??
- Rochester B 1bbl
- '92 Silverado "Blinking AC Indicator"
- heater console bulb
- engine rebuild
- 85 GMC choke
- governor
- Whining noise
- What Scanner Reads Camshaft Retard?
- A/C Cycles on (Even with A/C switch off)
- 97 Silverado headlight and wiper problem
- Weird Idle problem...
- I need a bench grey benchseat for a 1991
- 89 full size blazer problems
- power window HOW To
- 98 z71 fan switch problem
- Brake pedal
- 1990 C3500 crew cab vibrations
- remote starter
- 91 c 1500 no start, no spark
- No Electrical Power
- poor gas mileage
- Hard to push gas pedal
- 92 350 EGR question
- hard brake pedal
- blower motor
- can't get it out of park
- which is bank 1 on 1997 5.7l
- 93 4l60e tranny problems
- '90 C/1500 wont start
- Another 98 Waterpump
- Rear Drum Upgrade
- ___Increase M.P.G___
- temp sensor/idle problem
- Crate Motor
- Cat gone bad?
- Transmission woes
- Gas Leak Problem..?
- Engine oil stop leak?
- 1989 k2500 power steering bracket bolt size
- '93 5.7L Knock sensor
- 1994 Rwal
- brake shudder/vibration
- Code 32 EGR Problem
- Brake question - tis the season.
- Wndshield Washer Pump 1996 Chev 1500
- Service Engine Soon
- Edelbrock Performer system for 94 K1500
- 305 or 350
- '93 C1500 Cruise Control Gone Bad
- 1998 Silverado-needs reprogramming help
- hydroboost
- 4x4 not engaging
- Problem with fan on 98 z71
- 96 chev 3/4 4wd p/u slave cyl.,change?
- '94 2500 failed smog test - Help !
- 5 bolt GMC chrome centers off '93
- 5.7 out of '91 GMC
- 1998 K1500 fan stuck on high
- Throttle body replace or repair
- Reverse lights work... sometimes
- Temp guage
- help finding a bench seat
- 7/16 inch diesel fuel line.
- 79 C10 no defrost
- Idling Arm/pitman Arm Replacement 94 Silverado
- 1994 c1500 abs?
- 96 Silverado Help Please
- I Need Help With My 1985 C10
- Brake Problems on my 98 Z71
- 94 Silverado Rotor Warped, Need To Take Off
- '88 Cheyenne 2500 ignition?/solinoid? trouble
- Need help with brighter headlights on a K1500LS 2006 Pick up
- 1996 k2500 454 hard to start
- Headliner 94 1500
- 89 K2500 stall
- Brakes on a '98 GMC Z71
- 1995 3/4 Ton 454 No Spark
- 4x4 slow engagement
- 1988 Chevy c3500 5.7L Cold Start
- 94 4.3 won't start
- Transmision fluid leak...
- new starter want stop
- exhaust
- Lock switch quit working...
- guesstimated horsepower/torque?
- 1997 Silverado Very Hard to Start
- 70 c10 2wd lift questions...
- 6.5L Diesel shooting out black smoke
- 97 GMC Z71 Fuel Pressure/Misfire Problem
- 1987 Scotsdale fuel problem
- 85 chevy scotsdale stepside
- Ignition switch replacement
- truck for sale
- EVO sensor problem?
- 1998 3500 Chevrolet Crew Cab Rear Side Window Tint Question. Please help!
- replacing water pump on 85 305
- what year
- 98 chevy help
- I got scammed at the tranny shop
- figure this out..
- lights
- 1988 4.3l
- kevin
- 5W-40 syntetich Engine oil 89 Sub 5,7 TBI
- whats the differance c1500 k1500??????
- 1988 Silverado car stereo installation. Need help.
- need help
- upgrading rear small speakers to 6x9s
- this is funny
- 89 K1500 CV Replacment
- 1994 c/k 1500 2wd w/ rear abs bleeding
- I need some help diagnosing my truck
- vin number is where???
- 1997 c1500 headlight and door handle problem
- Hesitation
- 1994 TBI 350 Breather
- Timing Jumps in ESC Bypass Mode/Rough Idle
- Anyone have any issues with the headlight switch
- 96 k1500 outside door handle broke, HELP!
- What do ya think?
- Heater hose help....
- 1994 c1500 brakes question
- Euro Headlights
- 67 c10
- 95 C1500 Door Panel
- intake gasket instalation question
- ABS Light
- Rear End Lube and Additive 96 k1500
- Howling intake noise after new intake and TBI
- Gremlins in my 1989 C1500 - 350 5.7
- Engine skip in damp/foggy weather
- 92 chevy ck 1500 stallling
- 1994 Sub when cold has loud knock
- 90 chevy dying
- ROCKER ARM Torque
- 1995 C1500 Dead Speedo/Tach
- 1997 1500 350 5.7
- '91 won't start
- 89 K1500 tail lights wont light up
- 1969 truck value?
- 1994 Chevy c1500 questions
- Power Window Problem
- 350 throttle body swap and rewire??????
- 1994 silvarado K1500 Clicking
- Are there digital cluster panels?
- steering adjustment ??
- 91 High Idle Problem
- Oil pressure
- rpm gauge
- 4l60e 2wd to 4wd conversion question
- truck shakes above 35 mph?
- Transfer Case to Transmission Seal
- Brake Light On
- 89 C1500 Ignition Timing
- Blue Bowtie........Thank You
- problems w/ 2001 chevy 25hd *Allison trans. HELP
- 91 C1500 Almost kills then fine
- Key/Door Warning buzzer ??
- rear axle angst...
- oil pressure?
- a/c problem
- 1970 c10 2wd suspension and tires question
- 94' Fuel Guage issue
- Odd Knock
- 1997 C1500 just quits
- Ford mechanic with Chevy problem
- Gas smell in bed of truck
- removing power steering pulley
- will a 350 bolt up to a 4.3 auto trans?
- Installing New A/C Compressor In A 91... Which Brand To Buy??
- 1994 C1500 Misses
- Preparing for the worst...
- 1995 Silverado 4x4, 1500,auto, died & does not start!
- engine woes
- 1997 chevy 4 X 4 1500 5.7 Wont Start Need Help!
- Ive always wondered.............
- 90 chev shift when at red light
- power mirrors
- 1998 K1500, 1995 350 swap??
- 1994 Silverado 5.7L engine torque
- Replacing Valve Seals - Which One's Work The Best??
- airbag stuff for sale
- Airaid TBI Spacer Causing Tranny Shift Problems?
- 1991 Chev 2500 Engine swap ?
- 97 C1500 Radiator Question
- Seat Belts
- Need a 4x4 truck frame!!!
- Nelson Tune
- 1993 6.2L diesel hard start when cold
- 1993 silverado
- Dist Cap - why so costly ?
- grinding noise ???
- Cruise Control Switch Replacement
- Low Idle??
- '98 Z71- Old or New style front end?
- Safe ways of flushing my tranny at home
- Replacement Seat Belts
- 97 4.3 verry rough idol
- hazard lights dont work!
- 350 Upgrades
- a/c's not working...HELP?
- 350 headers
- 454ss mpg
- Throttle Body rebuild...pars?
- Oil Pressure On A 89 350
- Newbie with no lights....
- 97 chevy wont start!!!
- Power Windows
- 1990-93 454 ss Vs 90-95 Ford Lightning
- Crew cab rear seat
- Center console on 40/60 seat - back seat?
- Tried all the tricks to disable DRL's - no luck
- 92 Chevy 3500 diesel brakes
- 97 c3500 7.4 new engine
- 88 1500 4wd not working does anybody know how to hard wire the front axle on ?
- What should I do to my new trucK?
- diff swap
