View Full Version : C/K
- Problem With 97 Sierra
- 1989 1500 speedo wont work
- vapor return line
- Which Replacement Distributor Gear?
- 97 vortec trouble, mt2500 where are you?
- Help Help Help
- 1997 c1500 A/C ain't worth a shhhhh@#$
- Oil Pump replacement 89 1500 4.3
- Leaking Air Conditioner
- 1997 5.7 fuel problem need help
- Help
- Bad Mpg!
- engine knock
- 92 Chevy 2500 gages/ECM go nuts
- EGR vacuum lines? code 32
- 92 k1500 vibrations
- engine miss, fuel odor, code 134 any help?
- 1994 Gmc Sierra Suspenstion question
- 5 lug chrome chevy truck wheels wanted
- Idler arm question
- What Trans Do I Have?
- Fuel Problem
- truck problem.. help please
- Distributor Shims
- 88 silverado tbi or ei problem?
- Brake Light Comes On While Driving
- 95 Chevy (Knock Sensor/Service Engine Soon)
- Intermittent Stalling - Fuel Pump?
- Is my 2wd 1998 Chevy 3500 Crew Cab Dually an HD3500 or regular 3500? How do I tell?
- Rattling Noise Coming From Transmission
- PERFORMANCE!!! High flow cats/mufflers? Looking for testimonials/advice.
- Transmission flush ??
- 1989 4.3L engine miss
- newbie with head gasket question
- 1997 5.7 vortec intake needed
- no 4x4
- C/K Parts
- 89 454, boggy and hesitation
- Stall and no start, 95 CK w/ 305
- LS-6 Motor Swap
- 91 1500 Power Steering Pump Change Questions
- Exhaust
- engine/trans noise
- Quick Question
- oil pressure sensor problems
- PCV system
- 1989 1500 blown head gasket
- transmission shift problems
- 1992 issues
- 4L60E and other trannies...
- identifying engine by vin????
- New Chevy 4.3L Has Misfire --Please Help--
- What could be the problem?
- Temp gauge cause of 'service engine' light?
- 4x4 problems/questions
- Window
- performance parts suggestions
- 350 engine rebuild questions
- 1991 Silverado
- Idle Problems
- crank pulley
- ecm/ing fuse blowing
- What is wrong with it?
- 97 rear end noise HELP
- headers vs manifolds and motor mounts
- Missing after WOT???
- '92 Column Shifter
- 1996 6.5 diesel turbo issue
- low gas mileage
- 1998 Z71 Front Diff Leaking
- Dropped In New 350 Engine
- 93 K1500 5.7 engine surge at idle
- Dist Cap / Rotor -looks like crap ?
- Clutch Problems
- '98 Service Manuals
- adding aftermarket AC
- AC blowing cold??
- Temp Guage stoped working
- Heater core needs replacement!!
- Gas Mileage?
- Missing my '96
- Which header gasket?
- !!!!!help!!! Gas Leak!!!!
- Badfuel injecetor pump?
- restoration
- Wheel Bearings?
- No PCM readout to OTC scanner??
- Front diff 4WD activation
- O'Reilly Antifreeze?
- Failed emissions test
- max tire size?
- Are some trailer brake controllers better than others?
- '96 Chevy truck power steering problem
- Gadangit...I really did it this time.
- '90 Silverado electric fuel pump trouble
- Cam help, and suspention Question's
- '97 305 coolant leak
- 95 k2500 clunk snap pop from rear end?
- C20 I want a positraction- what do I have?
- Fuel tank return line
- A-piller Gauges
- 1998 K2500 Missing and Backfiring - HELP
- Heavy Half Ton needs a facelift
- 95 Chevy 5.7 with ignition problems??
- Random Interior Parts For Sale
- 1992--no radio
- Brake light problems
- Block castings
- Seat Swap
- Rear End
- What year for a good used 4x4
- '97 K-1500 Fuel Pump Problems
- rear end whine
- '88 EFI overhaul
- '97 Chevy K-1500 Reading "Service Engine" codes
- Steering box interchange?
- 1990 Chevy pick-up NO START
- 83 c/k 2500 4x2 need parts sights
- 92 K1500 - will s-10 trans./transfer case work
- Reinforcing box for small crane
- New 350 problems HELP!
- serpentine belt
- Spark Plug Question
- Which wire is hot?
- 1988 Chevy Silverado 5.7 Idle speed control
- Radiator drip
- Moaning noise (Ghost wants out)
- Steering wheel vibration
- Horsepower
- whining and clicking...ring and pinion?
- 94 k1500 stumbles when warm
- vapor recovery schematic
- rear end question
- 93 Blazer Acceleration issue
- Replacing engine oil cooler lines ...
- Airbag light and Check Gauges light help please.
- Motor Flush - good or bad
- 1997 Front Axle Actuator
- 1988 Silveradio 4x4 problem, and oil in exhaust
- Spark plug wires
- Loss of Electrical Pwr
- Headlight removal problem
- 4x4 w/ Longtubes?
- How manny miles?
- Rims??
- Intermittent Problem
- questions about 94silverado
- 5.7L intake
- idle surge
- Transsmission wont shift when hot
- 98 Chevy Silverado 2500 overheating problems
- Swapped 454 in 92 K3500 with rebuilt shortblock
- blower motor install
- Exhaust Leak?
- pulsating brakes update
- Will a 70's BB starter fit a 92 K2500?
- erratic idle then kills
- 96' V6 K1500 Sputter When Accel And Crusing
- 1979 C10 Spark Problem
- 1993 350 chevy pu problem
- 93 z71 engine miss plz help
- 89 dummy lights!!!
- belt
- Dash lights and graphic equalizer display just went out
- New calipers - what's good
- ignition wires
- 95 C1500 ABS Bearings?
- 95 C1500 ABS Light on
- Help! electrical problem, fuel guage
- front brakes pulsate and abs activates
- Need heat
- heater problem
- 1988 K1500 4.3 V-6 engine knock
- LT1 swap
- Need Help!!!
- Towing Comparison between '96 and '07 Silverado
- Future Plans
- Can a GM truck sound good?
- 4x4 Push Button Problem (Not like others)
- noises
- What's the wire next to the thermostat?
- wondering if normal or not
- 94 model tilt steering colum
- 1986 with electrical issues
- ABS issue
- 98 Chev 1500 Security Light ON??
- Duramax Reliability
- cold-air intakes
- 4x4 broke help
- 1996 C1500 For Sale
- OD Slip or Engine Misfire
- 94 4.3 V6 Swap with 92 5.7 V8
- 9c1 alternator on pickup?
- Starter runs with Ignition in off Position
- 95 1500 350 auto hesitates and has no power when warm
- ignition switch stuck on
- 1997 Chevy Truck 1500 Wont Start Agian!
- 90 chevy pu
- possibly misadjusted "transmission cable"?
- Chips/Programmers/Modules
- A/C Low Pressure Switch Question
- Code 43 on 1994 1500 Chevy
- Oil Pressure sending unit on Chevy 7.4L 454
- 95 K1500 Ruff Running & Intake Backfire
- front end noise
- 80 K10 Manual 4 Speed?
- gas pedal sticky/hard to push
- Tranny Hesitation
- Rear lights 1976 K30 Wiring color code
- No Start Code 1351 & 1300 97 K3500 454
- O2 sensor P0161 hot wiring
- Solid Black Wheels?
- 96 stepside bed removal
- 92 Silverado 2500 headlight issue
- Transmission Sending Unit Install
- Camshaft or Crankshaft Sensor?
- 1998 Silverado-start/battery not usual problem
- VATS wehicle security fix
- 97 Silverado 5.7 Vortec engine upgrades?
- 88 ck 2500 pinging
- 1991 C/K 1500 Fuel Pump problem
- 94 Silverado headlight problem
- AC whine?
- trans wont shift in overdrive
- Happy New Year
- 93 2500 help
- looking for dionostics flow chart, 89 gm
- 96 k1500 turn key wont start.jumper wire to starter relay starts??
- 97 Z-71 troubleshoot misfire
- 01 chev4x4
- 01 chev4x4
- t-case
- Hard Starting
- distributor hot/no spark
- MSD 6AL = 6420 INSTALLED in a C1500 350
- Coolant leak on top of valve cover??
- three on the tree problem
- Help..NEW MOTOR in a 1993 with timming problem
- Cleaning under the hood?
- EGR valve OEM number
- 97 k1500 A/T Problem
- Driveline feels like it is binding
- Tire Size help??
- Trans Noises
- throttle body tune up kit
- C 1500 - 5.7L 350 gas mileage!
- SM465 Issues
- No Tail Lights, No Instrument Panel Lights
