Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Avalanche/C&K/Silverado/Suburban/Tahoe
> C/K |
View Full Version :
C/K
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
1991 C1500 Steering Column
Electrical Problem
97 transmission noise
1989 Silverado K 3500
Can I Add Shocks???
How to remove a truck bed?
What gears do I have?
4.3 to 5.7 computer question
1990 5.7 TBI dies under load
1998 k2500 6.5 Turbo Diesel
Need some info
Ignition Upgrade
Gas Mileage
Spark Plug Wires - When to replace?
Replacement Torque Converter
bulkhead connector diagram?
Brake lights not working
No Crank, No start
Rough Idle-'89 454 Tbi
Truck Bogging Down
Kenwood radio cooking my CD's
Lowering kit
Steel Seal
Adjusting rockers. Need some advice.
4x4 hub question!
busted shock
'98 Silverado Turn Signal problems
GMC and chevy
96 K1500 Brake Issue
97 Silverado knocking
valve cover oil leak
Stats
93 dash brake lite
Oil Sending unit question, 85 Silverado
wierd one - loud pop and white smoke under hood
Paint Job
Anybody here with a solid axle conversion?
79 Chevy Pickup
96 Z71 Fuel System questions
97 k2500 step bars
FS: 87 chevy 4x4 custom deluxe
94 Silverado - Rear End Noise
98 2/4 drop will 20's fit?
1982 6/8 Engine Swapping?
help
87 Chevy 3/4 ton
Cold Air Intakes??
Reliability of 4.3 (88-95)
1982 chevy 305 Distributor?
Trailer Wirring 94 Chevy
76 Chevy pickup Tumbler replacement
HELLWIG 1535 Helper springs
Speedometer & Air Bag light - '98 Z71
how to remove fuel pump 1999 chevy suburban
1988 K1500 Emissions problem
Engine Swapping
Quadrasteer plus engine question
86 Chevy Difficulty installing Fuel Pump
Speedometer needle sticking..HELP
rough starting engine 92 c/k
Pinstriping on 86
97 350 vortec power loss
Timing Mark Location- 1995 C1500 4.3 V6
Front end diagram
Temp Guage
question about the 6.0 engine
opinions wanted : is a clean 88 body worth $200 ?
1998 Z71 Fuel Pump and mass air question HELP!!!
Please Help!!!!!
So I'm helping out a friend...
'88 2500 losing the will to go
93 to 98 dash swap
Inconsistent oil pressure 98 Silverado
1998 Fuel Pump Issue
5.7 V8 not running on all 8
Front Seat 92K1500?
Drivers side mirror
Rim width
1994 Chevy Cheyenne 4.3L to LT1 swap
Inexpensive leveling
looking for 14 inch lift kit.
Cat Converter/Dual Exhaust Price
ext and std cab mounts
Having trouble replacing pick-up coil
torque converter
1982 Sierra Engine Removal
cold blooded
How much torque on idler arm?
98 Silverado-replace interior driver side door handle
which engine
How much horsepower/torque do you need?
Oil Leak
Door sags,any adjustment
From Pink to Green
Wiring problem
89 Engine Debate
heater a/c controll problem
Difference Between C AND K / FUEL TANK PROBLEMS..Thanks
Engine swap in 1998 Silverado
700r4-92k1500 ?
noise in rear 93 silverado HELP PLEASE
installing in-line fuel pump
700r4 problems
Need 95 Diesel Stalling Advice! PLEASE!!
power steering pump brackets chevy 283
transmission shift points control?
95 Chevy Silverado (Burning Gas)
question on 73-87 trucks
trailer lights
steering play and poor performace
alternator question 67 283
Daytime Running Lights on a 1992 K1500
transmission shift delay?
I have 3 questions about my 85 chevy 4x4; thanks!
motor mounts 4.3 - 283
Gas Type for 95 Chevy Silverado (1500/V8)
4 wheel disc brake conversion and differential change out
Vibration on 85 4x4 Silverado, any ideas???
98 305 to 350 or 454 converison?
door lock actuator
Throttle Body ?
New Guy - '95 Z71 4x4 problem
roof Lights
stalling and stumbling
'98 Silverado - Difficult to engage 4x4!
1997 K1500 4x4
88 Chevy Electrical problem
door lock actuator?
Full Length Headers For 96 Chevy
1992 to Newer year dash upgrade.
4.3L to 5.7L Engine Swap...HELP!!!
Difference between 1500 and 2500
97 Chevy 1500 Catlytic Converter
random misfire 96 5.7 vortec
ok engine geniuses, help please
Breaking cv shaft
question about fuel pump, 89 4x4...
brakes on chevy silverado
1988 350ci code 24 help
Runs cool
Fan/Heater Won't Shut Off(95 Chevy 1500)
milage 89-98 K1500
160 amp alternator
Water Pump
94 Pick-up “Air Conditioning Clutch
86 1/2 Ton Parts
Condensor (95 Chevy 1500)
Pulley (95 Chevy 1500)
master cyl bad?
90 to older block swap
Need wiring diagram for 92 2500 TD
looking for towing capacity for my 94 truck?
95 Chevy 1500 (4x2)
97 misfire
My new 81
1986 Chevy 1 ton 4x4 Front End Shaking
Vortec 5.7 & 92 silverado EGR or not?
how much can i go?
hot Start Problem
New Intake and Carb
Vortec Intake Gasket
Lifting a truck yourself?
Will 285/75/16s fit a stock K2500?
6.5 Diesel Stalling Problem
Door Closing Takes Work
bearing noise (knocking) cold start
Antifreeze missing, smoking... I'm screwed.
fuel leak 95 4x4
HVAC problem, loud knocking!
manual choke
86 Chevy k30
left hand threads or breaker bar
My 95 Z71's Ball Joints
Failure to crank...sometimes
81 C10 305 V8 Rough Idle No Start
Idle Question
4l80e transmission electrical problems
89 Burb Pulley Removal
Exhaust Manifold VS Headers
1982 Gauges don't work
95 Z71 ABS light
buzzer
Differences - 2500 vs. 3500
Dash brake warning light on
4x4 Troubles
73 pickup refuses to run correctly
88GMC C3500 ECM-B no power
82 GMC Sierra 350TH AT Swaped for 700r4
carbon fiber hood
Jacob's ignition frying dist cap!
coolant burning
timing set and engine verification
Powersteering problem.... help!
Liquid Sounds?
1991 Chevy 454SS
Problems with installation
low oil pressure. please help!!
Temp gauge climbs to 225 then quickly drops to 190?
What's the Process for removing My Bench Seat?
anyone have a '92/'93 454SS for sale?
95 K1500 dies and hard to start
ABS activation repair
new Fuel Pump
1989 5.7 internal oil leak (long)
trany prob
Console to center seat in 97?
tbi performance
Which repair manual to buy?
o2 voltage after cat change
Slow To Start 5.7 Z71
Checking for timing chain stretch?
1995 Chevy
670 CFM TBI Killing Gas Mileage
Rusted Out Pipes
Timing with headers and no cat
OBD II code help.
need help w/ 4wd please read
97 5.7L Vortec, Timing advance connector
Removing catalytic converter for more BADASS exhaust!
S10 Crewcab
How do you check tie rod ends?
95 silverado straight pipe questions
Model# of Stereo/CD player
Updating My 82 Sierra Doors to Power
1988 Chevy overheating
Starting Problems
93 with Knock Help Please
no oil pressure!!!
96 chev 3500 7.4 vortec-no fire
82 GMC Sierra Automatic Steering Column
Engine Rebuild Costs....
1997 Silverado 4X4 5.7 heater hose small leak
1988 K1500 Standard Cab Weight Question
Warning Lights
94 silverado 4.3 to 5.7 engine swap possible?
k1500 4wd not working properly
Throtle Body Spacer help
Z71 dimming/blinking lights
Brake Light Problem
91 chevy 1500 stalling and chugging
Lose of overdrive
Distributor on ebay
egr valve ? 94 full size
97 Chevrolet Z71 Suspension Problem?
2000 Chevy 2500 7.4 liter engine gas mileage
Transmission Identification
----Stalling when in Op.Temperature??
Requesting suspension advice for '94 C2500
Oil Q's
Batt to Alt. Wire
Web
AF
