View Full Version : Silverado
- Checking the odometer?
- sound system
- Codes I'm getting - 332, 141, 161, and 719
- Cruise Control INOP
- Dick Cepek Wheels
- Drilled rotors illegal...
- MPG on 4.8 Crew Cab
- Is it bad to idle 4 long periods?
- Holes I don't want/need
- 2006 hood on 2003 Silverado
- Door Locks 2006 Silverado
- Need help installing Dual Halo Angel Eyes
- Engine Trouble...again
- Brake Line Size?
- Wheels ???
- lost bottom end
- how do you remove dash mounted fog light switch?
- 1999/2000 Silverado dash lights
- Question for you brake guys......
- Water leaking inside 2002 Silverado Driver Door??
- tow/haul not working
- new silverado owner, whats a nelson tune?
- 99, Silverado Replacing Rear Brake Pads?
- Add a leaf, leaf spring helper
- 2002HD Inaccurate Fuel Gauge/Circuit Breaker problem
- Panic Stop!!!
- 2003 silverado 4x4 vibration
- wiring on 91
- 1994 Silverado, Bad Vibration
- tranny wont downshift on freeway?
- Which rims to get?
- "Cranked Bars"? Torsion bar question...
- Injectors
- Replacing Cats in 99 4.8
- front firing 12in subs
- '95 z71 Ball joints
- Sound in drivers side door
- Please help, automatic delayed door lock 2003 Silverado.
- shift kits
- Help, won't shift into Park!
- Cabling for CD changer
- chime sound
- Help with a seemingly dumb question
- P/s Pulley
- Chipping my 99 silverado
- Bad News........
- Remote CD player compartment replacement?
- 2000 Shifting hard & Tow/Haul Mode
- Anybody got $20,000 lying around???
- 4 wheel drive not working
- bedside replacement
- Passlock Theft System
- thought i put up some pics
- Grinding & Loss of brakes
- transmission question...
- Drop spindle safety issues
- One quick question...
- OUCH ... Slave CD Player
- New 2 Forum Introduction of self
- for new pictures.
- Silverado passenger door problems!!!
- 03 Silverado W/ Illuminated Wheel
- What sub and box will work for a single cab?
- cold air coming in
- Door guards/molding removed and up for sale...
- '97 Silverado going to break me
- Changing U-Joints on an aluminum driveshaft
- how to set a disturbed disturbutor
- torsion bar
- brake lights 98 gmc 1/2 ton
- tv show trucks change???
- 2000 z71 5.3 SES light on
- Throttle body spacers
- coolant leak??
- knock sensor
- 1999 silverado at 112,000 has developed a squeal/ sqeak
- Headers or Cam?
- One Bad @ss Truck What Do You Think
- 2007 silverado
- Brake job walkthrough
- Multiple problems with '04 2500HD
- o2 Emulators
- Fender FLare Advice
- Tow/Haul
- ABS disable: ABS fuse or brake fuse
- Blown Out Glasspacks
- Thought Id throw some pictures up.
- pin holes in transfer case
- hoe to get pics on tread
- Low Coolant Message
- 02 silvy 4.3 fans
- hesitation on cold start
- power steering whine???
- Help with the horn
- Rough idle at lights ~ EGR valve code
- Parking Brake Issues 2000 Silverado???
- Tranny Lines
- Towing in OD
- Heater question
- Window motor/regulator
- Reset CPU on 2000 Silverado
- borgeson shaft
- how to get headlights to turn off
- Hail Repair?
- First day of Spring....
- Windshield wiper tube is broke by the battery..
- pcm tunes
- buckets & door handles
- Where to put my amp?
- Stock leather seat PROBLEM!! HElp
- What would be the best metal tubing to fab a brush guard?
- Backseat problem
- Stock Wheel Question.
- Stock radio + sub/amp question
- caddy gauge milage
- Tailgate emblems and 'LT' badges for sale if interested...
- I was wondering if there was a way to remove the cup holder.
- SIlverStars
- 245 vs 265
- Leveling arms
- Yee Haw!
- CD Changer for sale...NEW
- 1997 Silverado Starting Problems
- Custom Box for 05 Silverado.
- 1990 Silverado Shortbed 4x4
- How can you go to Allans shop to get a pin turned on & not get a tune???
- 94 wiring problem
- roll up or trifold tonneau cover
- 2001 Silverado Wiper Problem
- Toolbox/bed cover for a short bed (CC)
- Locking Center console????
- Door Speakers
- bearing sizes-rotors?
- 2004 Silverado Roof Warning Light
- 03 front end
- Wheels
- Transfer Case Problems
- Dallas area - need Pin 42 turned on - know anyone?
- PIAA Air Dam
- cadillac gages
- muffler
- Loud Metallic PING Sound From Underneath?
- PLEASE tell me my MPG will improve?!
- 2003 Silverado tachometer quit working...?
- Horsepower upgrades and a few other questions
- rear squeek
- rear brakes on 99 silverado
- Pcv
- Steering diag help
- Steering Diag help
- dome light
- Sportside on a Crew Cab
- 12 mpg is this normal for a 02 5.3
- well i need a new bumper
- Wanna Make Sure About Audio
- Silver Creek Shootout
- shock question
- 2000 z71 remove white letting from tires?
- Replacing front rotors 2003
- Heard piston slap for the first time today...
- Loose Converter after shift kit install
- Stupid plastic license plate lights!
- 2002 silverado 5.3L Misfiring
- GM FINALLY including '99s for tailgate strap recall
- Ford keys installed on my Z, question about Avalanche
- Passenger Side Air Filter?
- Hard to steer at low speeds.
- '05 Tail Lamps Into '00??
- Stereo Problem!!! Need Help FAST or will kill myself!
- i need help w/ my silverado plz
- 4 wheel disc brakes
- crazy fuel gage
- clear corners?
- power source help?
- bedrail add ons
- 4X4 light on all the time
- Crank, Crank, Crank - Won't Start!
- Can I Add Shocks???
- Praise for Nelson Performance
- Looking for a truck Cap
- slowly but surely
- My truck go bye-bye.
- 94 Chevey Silverado with TPS Problems
- 2003 Chevrolet Silverado Z71 question
- Help me label this picture
- Better prices on these items?
- My 2006 Silverado CC Problem (2K miles)
- Bolt Pattern?
- Z71 Graphics removal/replacement...
- Everyone who has installed the Transgo sk4l60e please come in
- Brackets for LS1 Electric Fans
- Help. 22" rims. Witch rubber size??
- Loose handling
- everything you ever wanted to know about oil
- oxygen sensor question
- K&N Filter for sale if interested...
- Picture Posting Priviledges
- 99 Silverado ext cab wind noise
- 6-speed manual
- Poll for effect of Ford Torsion Keys on ride quality
- Sensor Location
- trouble starting
- New Tires on a Z-71
- Tow Hook Question
- 02 1500 hd front drive shaft
- 99 Silvy transfeer case leaking??? crack?
- Vent always blows hot air
- '04 Fuel Filter
- 2000 Silverado towing ?
- Exhaust Help!!!!!!
- silverado lower console lock
- Light/Reflector thingy on interior door panel...
- Speaker removal question 2000 silverado
- Need help! 2001 Silverado 4.8 Emissions system
- ipod to factory radio
- Durmax Diesel
- what tires should i get??
- Need help with intake issue...
- Which touch-up paint?
- Speaker Sizes
- AC Blower sound
- Front Door Speakers
- 99 Silverado Transmission ???
- 2000 Z71 Tire question
- Exhaust/Intake
- 2004 silverado heated mirrors
- Exhaust pipe size
- '05 5.3L Loss of power towing?
- Handheld Tuners vs. Nelson Tune
- door locks
- Identifying Transmission
- power programmers???
- Tool Question for Front End Crank
- WANTED: 1500HD badges
- Need straight answers on LS1 fan install...
- Want to know what fast is???????
- 03 silverado 4.8 1500 hepertech III setting
- 2 12's and box for sale, extended cab silverado
- Getting Rid of Handheld
- 94 Silverado - Rear End Noise
- ABS and Brake Lights On
- 01 Silverado Fog light question.
- Evap Emission Codes '99 LS 5.3 Ext 4x4
- transmission problems typical?
- Vibration (probably my fault),please help!
- electrical system draining... ?
