View Full Version : Stratus
- 2001 stratus 2.7 fuel smell
- cats jammed up?
- 02 stratus 2.4L trans is whinning and not shifting!
- 2006 Dodge Stratus wont start
- 97 Stratus Electrical Issue
- Start/Fuel Pump Keeps Blowing
- what is the trans switch in front of trans
- 2003 stratus 2.4L 41TE trans stuck in third!
- 97 stratus havin issues
- Water leak AGAIN
- 98 dodge stratus misfire
- To Buy, or Not to Buy
- Car no spark no start
- 99 Strat RPM Gage inop
- 2004 stratus won't start. HELP!?
- '04 stratus SE P0441
- Kind of an emergency...timing belt
- PCV Valve 2003
- 1997 Stratus
- Stratus Engine Compression and Oil Issues
- 2003 Stratus SXT Key Fob
- 04 Stratus Radiator Fan Connector Pinout
- 2005 dodge stratus shuts off when air is on
- 99 ES Misfires on 1, 3, 5
- 96 Stratus brake problems
- 2000 camshaft dowel pin
- replaced timing belt - now p0340 code
- Turn Over But Not Start
- 1999 Dodge Stratus Please Help
- We need to locate this sensor
- 2003 stratus r/t 2.7 dohc antifreeze leak
- 2002 startus cooling relay
- 2006 dodge stratus
- UGH!! Water Leak
- Also thinking of buying a Stratus
- stupid stratus!
- Thnking of buying a stratus...
- Car Not Warming Up
- Help! short fried fuses, where is relay?
- 98 dodge stratus won't start
- 2000 stratus egr problems????
- 2004 Stratus won't start
- Door speakers
- Low Cylinder Pressure 2.7L
- 05 stratus rev limiter, timing belt change
- Passenger Side Power Window Circuit
- 1997 Dodge Stratus
- 2004 Dodge Stratus Overheating
- Black 'foam pieces' coming out of vents.
- 2001 Dodge Stratus slow acceleration
- 98 Stratus
- 2000 Dodge Stratus core plugs HELP
- 97 stratus - oil in water
- Stratus misses on 1 & 4
- 2004 Dodge Stratus R/T Bogging down while accelerating
- 2001 Dodge Stratus R/T A/C light flashing
- 99 Stratus 4 cyl
- 96 status es - dies sometimes, won't start
- Stick in the mud (Won't start)
- 2001 LX Air Conditioner/Defroster
- What would win, a gti vr6 or stratus srt stock for stock
- muffler for an 05??
- Power seat parts
- wat the best way to run amp wire to batery
- 98 stratus it leaks around oil cap
- headlight problem
- 2001 white stratus se parts middle Georgia
- rear window panel 98 dodge stratus
- changing speakers in 98 dodge stratus
- 1997 dodge stratus 2.4 no start misfire on 2 & 3
- spuddering on 04 stratus
- Need O2 Sensor location for 04 Stratus 2.7
- 95 2.5 no start
- 2001 Stratus R/T Code P0403?
- humming noise from rear at 60-70 mph
- Solenoid pack replacement
- 2002 stratus cig lighter replacement
- 2002 2.7L stratus starter problems
- 02 Stratus--no heat at idle
- water outlet?
- 03 Dodge Stratus Sxt
- 99 Stratus, Fuel, Crank, but No Spark
- 2004 Stratus windows and locks
- 2000 dodge stratus dies and blows dome light fuse
- 2005 Stratus Interior Lights/Radio not Working
- 2004 Dodge Stratus overheating, I've tried everything,
- HELP Stalling 97 Dodge Stratus
- starter 2002 Stratus
- NEED HELP 03 Stratus
- 2001 stratus parting out
- AC Problems in 01 Stratus
- 1996 Dodge Stratus Shifting Problem
- 2004 Dodge Stratus 2004 2dr Cpe R/T
- 99 stratus rough idle
- Stratus turn signal problem
- Radiator Probs
- 02 Stratus problems
- HELP on some OBD II Codes
- 2000 dodeg stratus, 2.4. lost the timing marks
- 97 Stratus, stuck in 2nd, engine light came on
- MIL and Battery light on
- Heavy shaking while braking
- Engine Needed for my 2004 Dodge Stratus R/T
- 2004 2.7l v6 Tranny issue?
- Anyone Know What The A/C Specs Are?
- 97 Stratus not starting
- Died at stop, gas pedal feels different
- 98 Stratus Grinding Noise
- 02 Stratus dieing
- 2006 Stratus problem. HELP PLEASE!!!!!
- 98 Transmission problem
- 98 stratus wont start-long list
- dodge stratus won't start
- 2.7L V6 okay after 2004
- shakes for up to 30sec after warm start
- flex plate torque converter rattle 2.4L
- Fuel pumps and spark plugs
- 2000 stratus 2.4l died and won't start. help me please
- 1998 dodge stratus
- Stratus turns over but won't start...very strange please help!
- Anyone figure this out?
- P.O.S. Stratus R/T 3.0 ticks at cold start?
- no bu5 on odmeter
- What kinda of trans fluid is compatable with "mitsubishi
- 03 stratus trans filter location
- 06 Stratus Grinding
- po755 and p1782 trouble codes
- 04 Dodge Stratus 2.7 Oil Light On
- 04 Stratus Belt Tensioner
- clearence problems
- 98 2.5 liter stratus alt. belt replacement
- Stratus check engine light from hell
- Power mirrors
- 2002 stratus RT spark plug Wire
- 99 Stratus 2.4 No compression in #2 & #3
- 1998 Stratus 2.4L timing belt
- 2000 Stratus stalls when accelerating and wont start
- 1999 Stratus 2.5L Miss on Acceleration
- oil light on, I need help!!
- Purchase '04 or '05 Stratus SXT or ES
- 2000 Stratus 2.5 Cyl. #2 misfire
- Won't Pop Start and Other Confusion
- Shakes in gear at idle. put in nuetral its fine
- 96 ABS light.
- 2002002 Stratus blower motor resistor replacement
- transmission swap
- 2001 - Takes longer to start than it used to..
- 97 Stratus brake switch
- 2000 ES replaced water pump- won't start
- 99 Stratus Misfiring supposedly
- Asd Fuse Blowing
- Need some help 02 R/t
- 02 Stratus R/t, help!
- car starts, won't idle
- Battery light
- 01 Stratus burning oil
- oil in intake manifold
- 98 Stratus rear brake issue
- 99 stratus making funny noise
- 97 2.0 crazy steering wheel vibration
- Help please, 98 weird battery issues
- stock exhaust pipe size on a 96 2.4L engine?
- why?
- Heating/AC control knob too tight to turn,, breaking knobs.
- Tachometer doesnt work on my 96 2.4L
- What does a code 72 mean for a 96 2.4L
- Were do I put a cai (cold air intake) on a 2.4L 96 stratus
- '04 Stratus Beef-up?
- dying out
- 1996 cirrus ticking sound at idle. IM LOST
- 2000 Dodge Stratus 2.5 engine broke timing belt
- How Long??
- 98 Dodge Stratus Vibrates With A/c On
- 01 Stratus Doesnt Start After Driving
- 98 Stratus shutting down while at highway speed
- no start Stratus
- no start Stratus
- Stratus underbody neon question
- 96 Stratus 2.4 high idle
- Brake light comes on when turning sharp or stopping quick.
- oil pressure gauge install
- 2001 stratus runs rough then quits
- 2004 stratus heater fan is loud
- 2000 ES side mirror
- I am thinking about buying a 2000 Dodge Stratus...any bad news?
- My girlfriend is looking at a 2004 dodge stratus r/t 3.0 automatic any bad news ?
- 96 Dodge Stratus 2.4L
- 99 Strat air bag lite on
- Headlight bulb replacement on an '04 stratus w/a stuck locking cap
- Valve Cover Gasket help
- 99 Stratus won't turn off
- Trans stuck in 3rd gear (limp mode) Help please..
- 98 Stratus o2 Sensors
- cruise issues
- Rear Brake Linings
- 97 Stratus doing funny things
- 98 stratus only firing 2 cylinders
- distributor
- Brake lights
- CV half shaft problems
- 97 cirrus 2.5 vs code 1495
- Ignition key not turning
- ignition fuse keep blowing. dodge stratus 2.4..
- '98 Stratus misfire
- Steps for Performance & Elimination of Rough Idle
- '97 Dodge Stratus Overheating
- gauge cluster and no power
- transmission
- cirrus 2.5 big problems, help plz
- 02 Stratus - replaceable odometer bulb?
- i can put the dodge stratus pistons 2.4 in the mitsubishi ecipse rods?? 2.0
- 98 stratus problem still !!!!!!!!!!!
- Brake Light / Stop Light Switch
- 2001 R/T w/Tranni problems
- HELP! can't find power lock/unlock wire in 1997 dodge stratus
- 97 Stratus - weird noise...suspension problem
- 2001 Stratus R/T dies
- 2003 Stratus dash peeling up
- 98 Stratus How do I get the windows crank off?
- 98 Stratus Oil smells like gas and is thin
- new cam
- Bent in wheel?
- Horn Problems
- 1996 dodge stratus/stuttering
- 98 Stratus Oil Seaping down back of engine
- 96 Stratus Starts,runs 5 sec dies, headlamp flash
- 97 , pcm asd fuse no start
- 98 stratus
- 2002 SE Heating Problems
- can someone tell me how to defog my headlights
- Trans problem
- 2002 Dodge Stratus 2.4L AOD hard downshifting while slowing for stop.
- 97 stratus 2.5 no 3rd p700,720,733
- can someone give me some performance websites
- hey im new to this site and i was wondering where can i fin euro tailights for my 95
- Please check VIN on Carfax !!
- 2000 Stratus: Cylinder 1 misfire
- car wont start
- Highbeams not working on 2001 Dodge Stratus R/T
- Can any one help me find body kits for 95-2000 stratus
- I just got my strat and doing perfomance to it
- 2001 ABS LIGHT on
- 04 stratus power steering
- Clunking Steering on turns and bumps
- Loud Knock
- 1999 Stratus Misfiring I think?
Automotive Network, Inc., Copyright ©2012
