View Full Version : Stratus
Pages : 1 2 3 [4] 5
  1. Starter Fuse Keeps Blowing
  2. Taillights
  3. My CAR!!--Help Me Please!!
  4. '98 Stratus - Check Engine Light
  5. keyless entry 98
  6. Is starter easy to get to and replace on 95
  7. Pop sound from underneath
  8. 2001 Stratus ES 4 Door Oxygen Sensor...
  9. check engine light + mofe
  10. Stratus suddenly stops then starts in 30min - THE SOLLUTION
  11. Waterpump Problems
  12. heat& engine problems
  13. 3000gt sl vs dodge stratus es
  14. My Flystratus98
  15. car over heating at idle
  16. Door bell and light
  17. R/T engine rpm
  18. headlights
  19. Head Lights
  20. need body kit!!!!
  21. 2000 Stratus ES noise and ac/heater problems
  22. 1996 door open sensor
  23. Heater problems
  24. 96 stratus 2.4l fuel injected cold start issue
  25. Intermittant Starting Problem - 96 Stratus
  26. car won't stay running
  27. 96 stratus no fast idle
  28. Brake Noise
  29. 2004 RT - Engine Whine
  30. 97 breeze gurgling at shutdown
  31. 97 breeze steering wheel vibration @ idle
  32. Front end noise
  33. shut of auto lock on 96 stratus?
  34. 1996 Stratus suddenly stops
  35. Wipers And Horn Activate When I Signal Right
  36. Specs for 1999 stratus?
  37. Dodge brakes
  38. no bus message 2001 stratus
  39. Checkout My Flystratus98
  40. dead battery (how the heck do you replace)
  41. 2001 stratus rt front suspension problems
  42. Can you replace an Auto-Stick Trans. with Auto?
  43. 2001 RT P1400 emission code?
  44. 95 Stratus Stearing column W/key & airbag + pass airbag (NJ)
  45. 95 Stratus RF Fender (NJ)
  46. Stratus 99
  47. Speaker size
  48. Possible answer for oil light and starting problems
  49. performance for a 2.4
  50. 2004 Stratus Se Check engine light
  51. '99 Stratus 2.5 ltr V6 Opinions?
  52. 1996 Dodge STratus - Error Code P1496
  53. Ignition locked
  54. 95' stratus fuel gauge broken
  55. AutoStick problem
  56. 1996 Stratus fuel pump
  57. 2000 dodge stratus problem???
  58. Does anyone else have this problem?
  59. Creaking in front end when turning?
  60. Stalling 2004 Stratus
  61. '00 Stratus oil issue
  62. Sqealing brakes
  63. Dodge Stratus une-up
  64. Stratus heater blower resistor
  65. 98 Stratus- odd times will turn over but not start
  66. Dash and Running Lights Fuse keeps blowing
  67. Need some help!!
  68. having trouble with 2000 dodge stratus
  69. How is she looking?
  70. factory radio and four 9"by9" speakers
  71. New and Interested
  72. 96 strat engine swap advice/suggestions
  73. A/C acting up in 2001 Stratus
  74. 1996 Stratus Idling problem.
  75. 2002 Stratus Won't Start, Radio Won't Work
  76. Cirrus awakens from Coma!
  77. Heater, A/C problems
  78. what's wrong with this stratus
  79. Strat Pals, PLEASE help my Cirrus, it's Whack!
  80. 2k dodge stratus sudden multiple errors
  81. headlight bulbs
  82. 2000 Stratus Ignition Problem
  83. Specific power problem.....
  84. CD player problems
  85. Serious Cirrus problems, PLEASE TRY 2 HELP!
  86. 2000 Stratus Hood / Trunk Lid Replacments
  87. 2001 Dodge Stratus Moaning
  88. 1999 Stratus Air Conditioner Hot air at idle
  89. timing belt tensioner
  90. 99 stratus for parts
  91. Stalling
  92. Where is the RADIO FUSE?!
  93. 3.o liter V6... replacing spark plugs??
  94. 4 dics in dash changer
  95. 96 dodge stratus problems
  96. need a new exhaust for my 99 Strat
  97. '01 R/T idling problems
  98. clunking noise
  99. 2003 Stratus shuts off while driving any ideas?
  100. Wanted: 96 Stratus remote for keyless entry
  101. Need an oil pump for Dodge stratus 2,4 1995
  102. 1995 dodge stratus ... new need help
  103. blowing holes in my stratus
  104. 2.0 Cylinder head
  105. 96 stratus stalling
  106. PCV valve located on 02 stratus RT
  107. 98 stratus wont start part time
  108. New Stratus Owner....Need some guidance
  109. Aem Short Ram Air Intake 01 R/T
  110. rough idle '98 stratus
  111. Engine head for a 97 2.4
  112. 96 Stratus - A slow learner??
  113. Air Conditioner Not getting cool
  114. buying a stratus
  115. 95 Stratus Transmission
  116. 1996 Stratus Trunk Question
  117. A/C Freon Leak
  118. odometer & gauge problem
  119. instrument panel problem
  120. 2001 Dodge Stratus CD Player Reset button?
  121. Tachometer and horn questions
  122. 2001 Dodge Stratus R/T annoyances/problems
  123. Clicking noise right front wheel
  124. Know the Off-set numbers for 2002?
  125. 1995 Stratus idle problems
  126. 98 Stratus Bucking/Surging
  127. Keyless remote
  128. about my digital odometer look please...
  129. keyless entry
  130. battery keeps dieing
  131. hey about my digital odometer reading..
  132. 1995 stratus transmission problem
  133. 2002 Check Engine light
  134. CAM position sensor
  135. Gas Gage on 2000 Dodge Stratus?
  136. Looking for an '01 R/T
  137. Antifreeze leak
  138. How much for a 2000 Stratus?
  139. head gasket
  140. Antifreeze leaking INTO car..
  141. aftermarket upgrades
  142. Heater problems
  143. Header for 2.4L ?
  144. Radio will not work
  145. dodge stratus air conditioner blower
  146. Performance??
  147. Brake caliper question
  148. 1995 Dodge Stratus won't stay running.
  149. 95 Stratus won't start...and no radio????
  150. Gettin to front door speakers?
  151. Daytime Running Lights/Delays Don't Work!
  152. tachometer
  153. Vibration when braking
  154. Stock stereo swap
  155. Plymouth Breeze Performance...
  156. Removing the radio on 97 stratus.
  157. 02 Stratus Steering Wheel Vibrating While Idling...Is That Normal?
  158. supercharge ready?
  159. 96 Stratus Won't Start
  160. car jerks when driving
  161. Dodge stratus short
  162. 95 Stratus dies at idle
  163. 96 2.4L fuse #8 short
  164. Rotor Question....
  165. Keyless remote programming info
  166. 1997 Stratus instument panel help
  167. Turbo
  168. 1998 Stratus Valve Tap
  169. 2000 Dodge Stratus SE 2.4L EGR Valve Flow Probelm
  170. 2000 stratus wont start tried everything HELP!!!!
  171. Cruiser Control Lost
  172. antenna fix
  173. stratus engine swap, 2.4-2.5
  174. 98 Strarus Tie Rod End
  175. 99 stratus parts for sale (car was totaled)
  176. Hello and help with my 01 stratus r/t
  177. need parts for your STRATUS?! LIST OF TONS OF PARTS FOR SALE
  178. Changing brakelight on 2001 stratus
  179. Strange Refueling Problem
  180. No Bus!?! What the h3ll is th@t!?!
  181. 95 Stratus will not start
  182. Dodge Stratus 2002 Drivers side auto lock not working
  183. FS, 95- 2000 coilovers, never used
  184. 2001 stratus rt wont start
  185. ** Parting Out A 1995 Stratus!! **
  186. 2000 stratus - trouble starting car
  187. Help....Timing belt Reinstaltion 1995 Stratus
  188. 2000 Stratus Tranny Problems
  189. 1996 Clutch Replace
  190. 2.0l, 2.4l Timing Belt Tensioner
  191. body kits....
  192. 2003 stratus body kits
  193. Muddy Trans Filter
  194. Ignition problems
  195. where do y'all get oem parts
  196. 2002 Stratus Heater Problem
  197. 96stratus
  198. Head Gasket Problem
  199. just got a motor change
  200. I need a motor
  201. Heater not producing heat.
  202. Cool Air Intake
  203. Engine Oil in Spark Plug Chambers
  204. check out these stratus HID's!!!
  205. what is this loud noise on my 98 stratus????
  206. Oil pump
  207. CD Player Problem...HELP PLEASE!!!
  208. Cruise control went out this summer
  209. Tailight Conversion
  210. Starter fuse blowing..
  211. 04 Stratus R/T Coupe idles at 1300 rpm when cold
  212. steerimg
  213. Just bought a 02 Stratus R/t
  214. no HP!
  215. Aftermarket for 01 Stratus RT
  216. Problem after fueling 2000 Stratus!!
  217. Cd Receiver Help
  218. Heater Cores
  219. Euro taillights
  220. Want to buy my 98 dodge, I blew the engine
  221. ignition fuse keeps blowing.
  222. Parts for 02 stratus r/t
  223. Stratus Who makes it?
  224. 98 Stratus wont start
  225. 01 Stratus 4dr. SE
  226. 2000 ES Plug Change
  227. 2004 R/T Stratus leaking coolant
  228. Suspension 1995 Stratus
  229. STOLEN Gold 99 Dodge Stratus
  230. Loud Knocking
  231. 1996 Standard Faulty Clutch/related To Shifter Cable Repair?
  232. Convert Cold Air To Short Air
  233. New Here
  234. 1996 Stratus Tie Rod Ends
  235. Performance Upgrades
  236. 2000 Stratus - HELP Rattles over rough patches
  237. exhaust
  238. electric window prob
  239. Help!
  240. Would You Buy This?
  241. I want custom wheels.....
  242. I found ONE!!!
  243. Need Stratus help.
  244. 2002 Stratus ES Mods?
  245. 2002 Status ES
  246. First time Installing a Subs with Amp...
  247. How fast is a 01-03 Stratus RT
  248. problems with the air control
  249. Cirrus/Stratus
  250. WET FLOOR Passanger side??
