View Full Version : Stratus
- timing belt 98 dodge, is it a non interference engine?
- engine codes
- 2001 Status Please HELP!!!!
- Engine whining in 05 stratus
- pulling engine from 99 stratus
- 2000 Stratus intermittent cruise control
- 95-99 recall
- Need some help with a 96 Dodge Stratus
- 2004 status a/c water drains on passenger floor
- Stratus wont turn over - Fuses keep blowing
- Brakes.
- Car doesn't start or turn over
- help with cold air intake
- Serpentine Belt Runs On This Part... Help me find out what part?
- 2000 Stratus SE
- Spoiler
- 04 stratus
- 2005 r/t radio upgrade
- Is the newer 2.7L V6 any good?
- Code 34
- Stratus pcm/asd fuse
- Drivetrain problem
- 2000 Stratus with Oil in the radiator
- 1998 dodge stratus overheating
- Looking for help
- Rear main seal
- '03 Dodge Stratus
- A/C Blower
- 02 Stratus 2.7L Gas Problem...Maybe
- 2004 Dodge Stratus
- More Power
- Accelerator Problem: 1999 Dodge Stratus ES
- 2001 Stratus R/T radio 17" rims
- 2003 Stratus knocking noise
- Power Seats
- 2001 Stratus sedan
- cigarette lighter fuse
- 1996 Dosdge Stratus Horn location
- PCV Vlave Replacement
- aftermarket help for 2003 stratus rt
- slower than death!!!
- 2000 Dodge Stratus - Need your help!
- Electrical Trouble
- Carfax?
- 2.0 L 96'
- buy it or dont buy?
- fuel pressure 2.5L V6
- 97 stratus keyless remote
- wheres the oxygen sensor?
- oil level sensor?
- 2001 dodge Stratus R/T
- Need input from stratus owners
- oil gauge
- I need a Carfax on this 98 stratus i want really bad!!!
- 2004 dodge stratus
- rims and tires
- How do you disable pass. airbag on '99 stratus?
- 18" KONIG APPEALS with TIRES 4 Sale
- 95 Stratus sensors
- turbonator
- 2001 se parts?
- Several problems with '99, please help!!
- Timing Belt
- whats the deal with stratus r/t insurance?
- '95 Stratus Factory Radio
- 2003 Stratus R/T
- Car Died
- Engine Codes
- 2001 stratus r/t keyless remote programming
- front end noise
- windshield speaker size
- ignition/door locks
- 97 stratus wont start no spark
- Low gas notifier
- 04 stratus coupe
- 98 dodge stratus will not start
- new head gaskit-engine lights on
- engine
- 2002 Stratus SE 2.7L
- 00 Stratus w/ Smoking Steering Wheel
- 98 stratus 2.4 HELP
- 96 stratus, epileptic seizures
- Body Kit Question
- Stratus ES 2.4L Knocking Noise (literally)
- Engine sputtering
- never buy a 98 status-head gasket
- 04' Stratus
- Idle Problems 2000 Stratus V-6
- New Head--No Spark
- 98 Stratus ES NO START
- 2000 Stratus price
- Stratus 96 starting problems
- Rattle in 2.4L Engine
- How to tell which transmission you have?
- A little help, please
- do the parts fit look
- 1998 stratus es
- high pitched engine noise on 05
- car starts when it wants to.
- 1996 Dodge stratus 2.4 Engine Specs???
- strange overheating and engine noise
- 2.4L engine Clicking Noise
- 99 Stratus ES no start
- 96 stratus wont start 1 cylinder no spark
- head gaskets abd distributor
- water noise
- seat covers needed - please help me
- 98 stratus parts interchange help?
- 97 Stratus - Sat a while...what to expect?
- Guide Pins on 2001 stratus
- Noise
- 2001 stratus starter problems
- Ignition Coil
- how to drain radiator.
- excessive brake pressure to stop 96 Stratus
- 96 Stratus O2 sensor replacement
- 02 R\T maybe 4 Sale...
- 2001 Stratus tag light question (help!!)
- gas gage
- the new '05s.
- 01 Stratus transmission probs?
- Starter Fuse Keeps Blowing
- Taillights
- My CAR!!--Help Me Please!!
- '98 Stratus - Check Engine Light
- keyless entry 98
- Is starter easy to get to and replace on 95
- Pop sound from underneath
- 2001 Stratus ES 4 Door Oxygen Sensor...
- check engine light + mofe
- Stratus suddenly stops then starts in 30min - THE SOLLUTION
- Waterpump Problems
- heat& engine problems
- 3000gt sl vs dodge stratus es
- My Flystratus98
- car over heating at idle
- Door bell and light
- R/T engine rpm
- headlights
- Head Lights
- need body kit!!!!
- 2000 Stratus ES noise and ac/heater problems
- 1996 door open sensor
- Heater problems
- 96 stratus 2.4l fuel injected cold start issue
- Intermittant Starting Problem - 96 Stratus
- car won't stay running
- 96 stratus no fast idle
- Brake Noise
- 2004 RT - Engine Whine
- 97 breeze gurgling at shutdown
- 97 breeze steering wheel vibration @ idle
- Front end noise
- shut of auto lock on 96 stratus?
- 1996 Stratus suddenly stops
- Wipers And Horn Activate When I Signal Right
- Specs for 1999 stratus?
- Dodge brakes
- no bus message 2001 stratus
- Checkout My Flystratus98
- dead battery (how the heck do you replace)
- 2001 stratus rt front suspension problems
- Can you replace an Auto-Stick Trans. with Auto?
- 2001 RT P1400 emission code?
- 95 Stratus Stearing column W/key & airbag + pass airbag (NJ)
- 95 Stratus RF Fender (NJ)
- Stratus 99
- Speaker size
- Possible answer for oil light and starting problems
- performance for a 2.4
- 2004 Stratus Se Check engine light
- '99 Stratus 2.5 ltr V6 Opinions?
- 1996 Dodge STratus - Error Code P1496
- Ignition locked
- 95' stratus fuel gauge broken
- AutoStick problem
- 1996 Stratus fuel pump
- 2000 dodge stratus problem???
- Does anyone else have this problem?
- Creaking in front end when turning?
- Stalling 2004 Stratus
- '00 Stratus oil issue
- Sqealing brakes
- Dodge Stratus une-up
- Stratus heater blower resistor
- 98 Stratus- odd times will turn over but not start
- Dash and Running Lights Fuse keeps blowing
- Need some help!!
- having trouble with 2000 dodge stratus
- How is she looking?
- factory radio and four 9"by9" speakers
- New and Interested
- 96 strat engine swap advice/suggestions
- A/C acting up in 2001 Stratus
- 1996 Stratus Idling problem.
- 2002 Stratus Won't Start, Radio Won't Work
- Cirrus awakens from Coma!
- Heater, A/C problems
- what's wrong with this stratus
- Strat Pals, PLEASE help my Cirrus, it's Whack!
- 2k dodge stratus sudden multiple errors
- headlight bulbs
- 2000 Stratus Ignition Problem
- Specific power problem.....
- CD player problems
- Serious Cirrus problems, PLEASE TRY 2 HELP!
- 2000 Stratus Hood / Trunk Lid Replacments
- 2001 Dodge Stratus Moaning
- 1999 Stratus Air Conditioner Hot air at idle
- timing belt tensioner
- 99 stratus for parts
- Stalling
- Where is the RADIO FUSE?!
- 3.o liter V6... replacing spark plugs??
- 4 dics in dash changer
- 96 dodge stratus problems
- need a new exhaust for my 99 Strat
- '01 R/T idling problems
- clunking noise
- 2003 Stratus shuts off while driving any ideas?
- Wanted: 96 Stratus remote for keyless entry
- Need an oil pump for Dodge stratus 2,4 1995
- 1995 dodge stratus ... new need help
- blowing holes in my stratus
- 2.0 Cylinder head
- 96 stratus stalling
- PCV valve located on 02 stratus RT
- 98 stratus wont start part time
- New Stratus Owner....Need some guidance
- Aem Short Ram Air Intake 01 R/T
- rough idle '98 stratus
- Engine head for a 97 2.4
- 96 Stratus - A slow learner??
- Air Conditioner Not getting cool
- buying a stratus
- 95 Stratus Transmission
- 1996 Stratus Trunk Question
- A/C Freon Leak
- odometer & gauge problem
- instrument panel problem
- 2001 Dodge Stratus CD Player Reset button?
- Tachometer and horn questions
- 2001 Dodge Stratus R/T annoyances/problems
- Clicking noise right front wheel
- Know the Off-set numbers for 2002?
- 1995 Stratus idle problems
- 98 Stratus Bucking/Surging
- Keyless remote
- about my digital odometer look please...
- keyless entry
