View Full Version : Stratus
- Noise in engine
- help me please !!!
- Help
- 2001 Dodge Stratus R/T 3.0 liter won't stay running.
- 1995 stratus battery light issues
- Passenger side mirror broke
- Question about weather stripping for Door
- changing plugs on 2.4L 4-cyl 2004
- 2005 Key needed
- 2005 Key needed
- 2005 Stratus Shake/Shudder
- P1787; 2-1 Downshift Error
- Overheating w/bubbling noise
- Sluggish Steering
- PCM/ASD fuse
- 96 stratus intermittent downshift
- 96 Dodge Stratus
- Stratus timing belt tensioner info - 2.4L
- 97 stratus questions
- any suggestions??
- 1995 stratus 2.4 Auto Trans fluid flush
- !995 Stratus - Rear window defrost switch / relay
- Need Air Ride Suspension Stratus 1999
- Need to sell, taking all offers!
- 2004 won't start on all 4 cylinders-help!
- Antifreeze/Coolant reservoir and head gasket questions
- 1996 Dodge Stratus "no bus" code instrument panel blank
- car is squeaking
- Chugging going up hill
- Can I install factory fogs on my 97 stratus?
- 01 stratus radiator
- 98 stratus brake light behaviour
- 2002 Stratus radio wiring diagram needed
- ECU question
- Brakes
- Can You Change the CD Player in 2005 Stratus SXT?
- Timeing Belt went out HELP!
- 95 stratus wont start
- 01 key/ignition switch
- blower fan only works on high
- 2000 dodge stratus
- 96' Stratus Transmission issue. plz help
- 97 stratus electrical draw
- How do I change Stratus Headlight bulbs?
- Nursing student needs help with fuse prob.
- '00 Stratus radio wiring issues
- No Heat in 2001 Stratus RT
- 99 Dodge Stratus: Battery light Comes On
- Dodge Stratus Tune Up???
- Stratus Brake Problem, Help Needed
- Cai
- Air bag light is on, Fire almost started from steering column. No FAN.
- 97 stratus battery problems
- Looking for a tranny for a '99 Dodge Stratus
- 1995 Dodge Stratus licens plate light
- 4000 RPM bog
- '97 Stratus - Owner's Manual
- Battery Help
- Programming Remote
- 96 Stratus poor braking
- Instrument lights don't work
- Body Trouble Codes/Cruise COntrol
- Car Power Outlet
- Programming Keys
- 2004 Dodge Stratus Idle Issues
- frankenstein the beast?
- 98 stratus car wont start.
- 2000 Stratus Steering doesn't 'return'...
- 99 Stratus/Breeze door speaker
- 98 Stratus Gas Gauge ??
- 97 stratus died again
- Code P0111
- hesitate to accelerate
- Check engine light...again
- 2004 cam shaft sensor
- Trans Wiring.
- Car won't completely turnover
- air conditioner
- 96 stratus...popcorn machine?
- performance chips
- emblems off the trunk lid
- 2004 Stratus R/t Seatbelt Chime
- Car is stalling while driving
- Pray your water pump doesnt go bad
- disable the 15 mph auto locks on my 99 dodge stratus HOW???
- 2004 Dodge Stratus SE
- Advice for buying an R/T?
- 99 DIY collision Repair?
- 97 Stratus starter died - but in a weird way
- Koni front and rear struts for sell on ebay, Dodge Stratus and Chrysler Cirrus
- engine missing
- Leak Detection Pump or Hustle? 1999 Stratus
- 200 Stratus Sedan Steering Knuckles
- 2000 Stratus won't start
- brake lights? 2000 cirrus
- Engine Code
- check engine code?
- 1996 Stratus. Locating Oxygen Sensor (front)
- 2001 Dodge stratus fuel pump problem
- Dodge Stratus 97 Speed Detection Wire?
- Performance without voiding warrenty
- Amp wiring through the firewall
- Pulling crankshaft balancer
- Tie rods
- 95 stratus - map sensor
- 2.0 Timing Torque specs
- Power Steering Lines
- 1997 stratus es
- Anyone have a wiring diagram for a 96 cirrus
- '01 stratus R/T idles loud
- speedomoeter stopped, tranny acts funny
- 2000 Stratus oil light
- 97 stratus, tach dies and odometer too
- Ready for a sledge hammer
- 96-97 v6 overheating. check engine light says cooling.
- Intermittent Turn Signal
- o2 sensor
- Check engine and battery ligth
- Easy question any 1998 Stratus owner. Please answer!
- Problems with my 2000 Dodge Stratus SE
- 98 stock radio/cd player.....
- Blower Problems
- 96 stratus turns over by itself
- Feul Pump
- 98 stratus 4 cyl check engine light
- Stratus wheel ready to fall off
- Dodge Stratus ES 2.5 6 cyl
- Blower Motor - Plymouth Breeze
- brakes
- Growling noise
- Vibration
- Which 02 sensor do I replace?
- manual tranny swap--96 stratus
- Transmission Fluids
- Heater blower only works on high speed
- Rear Brakes
- car wont start, sputtered like crazy when it did last run -- have 6 trouble codes
- Aftermarket
- 99 stratus check engine light.
- stratus cooling fan
- mirror help
- Headlights Clarity Problem
- 02 stratus 2.7L HGelp Please
- 1995 tranny problem
- speakers
- One side of windshield washer nozzle not working
- transmission fluid leak
- 99 stratus stalling and not starting
- i never thought id say this
- Pimping my ride White Marsh Style
- O2 Sensors are expensive!!!
- transmission limp mode p0700 and p1787
- 1997 Dodge Stratus ES
- Dodge stratus fuse problems
- Parting out '96 Stratus
- left head light and tail light out
- replace back dash speakers
- Power Steering Pressure Hose
- 01 Stratus CD Player not working
- Check Engine Light, and tink sound
- # 20 yellow Fuse Keeps Blowing 99 Stratus
- 1997 Stratus Codes
- 96 Stratus stalling problems
- horrible noise when i switch from park to drive on my 2000 stratus v6 when its cold??
- Yet again.
- Vertical headlite adj 2003 Stratus
- Egr
- 2001 r/t computer?
- 2003 stratus wiring diagrams
- '98 Stratus oil light
- Is it posible to ......
- 98 stratus se
- never worked on a stratus
- oil sensor?
- Bleeding Fual Inj. System after elec. pump install HELP
- Quick question
- Opinions any 1 ???
- 02 stratus w/2.4l
- trouble codes
- fsm for 2004 status
- code p0456 control system evap
- body kit for 01 stratus sedan
- Anyone have this problem before???
- 2001 dodge stratus fuse block
- parting out a 97 breeze
- 2002 R/T has Noise at Pass. Front End...
- 97 dodge stratus check engine light
- 2000 Stratus -no heat
- Tranny problems?
- tune up 2.4L stratus
- 97 Stratus Leaking water
- Sway bar
- 97 Stratus- PCM
- 2002 Stratus No Power
- '97 Stratus Won't Start
- stalling problems-help
- has this been done befor
- speakers, dash problem!!
- Guage cluster/electronics problems
- head gasket
- Motor Mount
- Fuse blowing
- whats wrong with my cluster?
- Performance question on an '03 Dodge Stratus
- low oil pressure and white smoke
- Bad Tranny???
- Various intermitent problems
- location of the input turbine speed sensor
- check engine light
- Failed Emissions Test - Help!
- 97 Stratus Tranny trouble
- Does a 2.0 liter SOHC 96 Neon have a non-interference engine?
- C O 2 Censors
- Changing the light bulbs in a 99 Stratus
- Changing Breaks?
- my airbag light pops on and the steering wheel is clickin??? help!!!
- What changed?
- would you buy one twice?
- power seat
- bleeding the brakes did not work!!!
- Touch-Up Paint
- 97 stratus rough idling/stall after timing belt change
- 99 stratus problem
- Cylinder 1 Misfire 1999 Stratus
- performance parts
- not sure whats wrong with brakes
- performance for 2.4L
- performance help
- How reliable is the 2001 R/T? (3.0L)
- Loose Engine Rod!! HELP
- Help...i luv my Stratus but it has an annoying low key thumping sound in the back
- Is this where the AA meeting is J/k.
- Stopping while driving
- performance
- 1998 Dodge Stratus will not start
- 98 Stratus won't start 2.4L
- pcm
- 1998 Stratus 2.4 Cylinder 1 misfire problem
- timing belt help
- keyless entry
- DSM3D v1.0.0.1a Released! 420a
- What kind of Fluids for 2003????
- 97 dodge stratus
- Another question
- no engine check light, no spark no fuel pump
- 1995-2000 Haynes repair manual for sale
- Horn just clicks on 2005 stratus
