View Full Version : Neon/Plymouth Neon
Pages : [1] 2 3 4 5 6 7 8 9 10
  1. 1998 neon wants to die
  2. Starter problem 99 neon
  3. 1995 throtle surge
  4. Is it possible???
  5. 95 Neon. Major camber problem
  6. 95 neon alternator swap
  7. 99 Neon backup light fuse blows/AC quits working.
  8. Timing Belt/Tensioner Question
  9. 05 dodge neon starter grinding noise
  10. 2000 dodge neon shutters when slowing down
  11. stuck in 2nd gear
  12. 96 ATX won't lock in park!!!
  13. I need some help with my 1996 neon
  14. 97 Neon overheated, now won't start
  15. 1995 neon p0734
  16. 98 Neon Auto Tranny cable came loose, now Won't go
  17. Just Changed Engine need help with codes.
  18. 1997 dodge neon ecu problem
  19. 2003 neon mystery!
  20. help for my girlfriends neon please
  21. 1997 Plymouth Neon wont start
  22. 2002 neon a/c pressure problem
  23. first car ideas?
  24. My 96 Plymouth Neon will not start :(
  25. No starting/ No power to starter
  26. 1997 Dodge Neon Overheat
  27. 2002 Dodge Neon
  28. 1998 Dodge neon door speakers
  29. 99 Neon front drivers side brakes sticking...
  30. Neon stalling
  31. weird radio problem
  32. A/C Compressor quit
  33. Idles good, cuts out bad in gear
  34. Spark plugs with engine oil
  35. Leaking Tranny Fluid, Hesitation in Acceleration, sticky gas pedal
  36. 1996 Neon - How do I set timing for new belt
  37. is it wise to replace the ecm
  38. Car is making a Grinding/whistling noise while driving
  39. 97 neon plymouth
  40. 2005 Dodge Neon running rough
  41. 95 neon keeps dying, please help
  42. weird speedometer problem
  43. 1995 neon 2.0 sohc wont fire on cylinder 3????
  44. Automatic Tranny Shifter sticking
  45. 1996 neon rough everything
  46. auto tranny
  47. flickering headlights
  48. Yet another problem with my 03
  49. 2003 Neon SE new belts
  50. headlights on 02 neon
  51. Car problems, of all sorts, HELP please
  52. 2003 Neon SE fuel gauge issue
  53. 2000 Neon - fuse problem - indicators/radio/dome
  54. 96 Neon starts chugging then dies
  55. 2000 Neon-code P1687 Cluster
  56. Oil Leak
  57. 02 neon
  58. how many filters for 98 neon
  59. neon just stops running help me!!
  60. Spark plugs fouling
  61. 2000 Neon swap with SRT4 engine?
  62. no start
  63. 95 neon brake light
  64. Coolant Resevoir
  65. 2003 Neon SE air issue
  66. 2003 Neon SE air issue
  67. 2002 belt tensioner. PLEASE help.
  68. removing remote starter problem
  69. adjust motor mounts
  70. Max Miles
  71. gas tank removal
  72. Door Speakers
  73. Can't get the window crank off
  74. Tires for 2000 Neon
  75. 2000 Plymouth Neon Highline - Check Engine Light.. Runs fine.
  76. My Plymouth Neon wont spark
  77. obd code p1390
  78. Weird Cooling Problem
  79. Lamp Problem
  80. dodge neon 2002
  81. pulling to one side/steering wheel cocked!
  82. Weak Rear Brakes
  83. paint the rims????
  84. 2001 Neon clicks but won't start unless I,
  85. problem with the fuses...
  86. squeaking
  87. water damage.....
  88. Brake problem!
  89. Struts???????
  90. 95 neon aftermarket radio help please
  91. 2000 neon power mirror 4 manual mirrors
  92. Old beater...what do I do with it? Replacement? [big post]
  93. dodge neon
  94. 00 Neon - loud speed-dependent humming noise from engine compartment
  95. crazy gauges
  96. lights dimming out?
  97. clicking ,but no start
  98. 1997 Neon Radiator Leak
  99. is 04 neon engine belt or train driven?
  100. 95 neon blown head gasket
  101. Lug nut missing on my neon
  102. Dodge Neon Mist coming from vents...
  103. Knock on start
  104. 95 neon problem
  105. 99 Neon-A/C leak-No freon-Still drive it?
  106. 95 neon
  107. 1996 dodge neon cranks but no spark!!!
  108. Are 2000 Dodge Neons any good????
  109. 1998 Neon Tune Up?
  110. Plymouth neon 99- oil leak/ coolant leaks from water pump
  111. is there any way to make this work on my car
  112. easy ways to add little more power? 1998 neon
  113. A/c Problems For 1997 Dodge Neon Help!!!
  114. 1996 Neon Electrical Problem????
  115. 1999 Neon - runs in reverse, dies in drive
  116. Car hesitation and stuttering..please help!!
  117. 1995 Neon
  118. 1995 Doge Neon Turn Signals
  119. acceleration problem
  120. 98 neon chugging bad
  121. headrest
  122. 99 neon overheating
  123. True or False
  124. 97 neon window regulator
  125. door panels
  126. back seat
  127. 98 starting problems
  128. Reving problems
  129. fusable link???? help
  130. Recommendations for better Brake Shoes?
  131. 98 Neon Coupe...Enhancements....
  132. 04 neon hick ups getting worse
  133. 95 Neon SOHC Only Firering#2 Injector
  134. Brake light
  135. 03 motor in a 98
  136. Would like to upgrade my '03 Neon
  137. Dome Operation
  138. Courtesey Dome Light Switch
  139. 95 Neon - Electrical Problem
  140. 1998 Neon Blinker
  141. 1998 Dodge Neon tranny woes
  142. Thumping/Knocking
  143. 03 dodge neon sxt idle problem causing vibration
  144. 2005 Transmission leak
  145. My 2000 Neon will not start.... please help
  146. Stripped out spark plug hole
  147. gas guage is reading wrong
  148. coolant temp problem
  149. fan or alter Belt squeels
  150. P0171 too lean
  151. brake shoe help
  152. no fuel to the engine
  153. electric problem with dogde neon 1995
  154. Idk what the problem is...
  155. No Clutch Pressure
  156. Accelerates slightly on its own
  157. '96 Plymouth Neon Oil Pressure Light
  158. broken alt belt leads to no start!
  159. 2000 Neon Power Steering Fluid
  160. Call 570-815-4697 For Help With Your Neon
  161. 2000 Dodge Neon Sick Wit It
  162. 98 neon fuel accumulator????
  163. Tach swap out
  164. 2000 Neon blowing fuse?
  165. Please help me neon wont start in cold weather?
  166. 97 Neon- Hard start and stalls
  167. 2000 Neon no heat
  168. 99 neon r/t gets 9 miles a gallon need help
  169. FOR SALE - First Gen Aftermarket Muffler
  170. 96 neon acceleration problem
  171. help 99 neon r/t wont hold an idle
  172. Oil Leak
  173. Key Fob Question
  174. Radio Install ?
  175. bad vibrations
  176. NEON squeaks while in reverse
  177. Plymouth Neon 00 "oil pressure switch"
  178. Airbag, brake lights on !!! Help !!!
  179. wanna buy a neon
  180. neon coolant possible thermastat?
  181. installing passenger side mirror on 96 base neon
  182. Heater Freezing
  183. neon 2000 help
  184. crate motors
  185. 97 neon headlight replacement
  186. 96 dodge neon want to convert SOHC to DOHC
  187. Need help w/cd changer
  188. Starter Problem???
  189. Wont Start in Park Will Start in Drive
  190. New Tires Wow
  191. Obdii Trouble Code Po123
  192. weird electrical problems
  193. weird SCREEEECH noises.
  194. acceleration problem
  195. Bad to pull a trailer and quad with my Neon u think?
  196. Dented Door
  197. 2000 neon automatic adjuster lever!
  198. Neon Clutch Replacement - Hard or Easy?
  199. 98 Dodge Neon idle little rough when park on Red light.
  200. Fuel Tank Filler Pipe Broken!
  201. FS: BRAND NEW AXIS REVERBS with BRAND NEW TIRES
  202. bashing a neon
  203. 03 se 4 sale
  204. sunroof help
  205. plastic headlight covers any ideas on how to clean them
  206. oil leak need help to identify where
  207. im having some engine problems
  208. 2004 R/T Clutch hydraulic issue
  209. what side does the larger cooling fan mount on a 1997 dodge neon?
  210. What's wrong with my a/c
  211. can anyone help identify leaking unit?
  212. Neon runs rough then shuts down
  213. Screeching from backend
  214. Car thinks is overheating....Help!!!
  215. buying a 2000 neon
  216. Buying a Neon...
  217. Keeps Shuting Down
  218. need a little help
  219. code 25
  220. Fuel Air Metering Code P1193
  221. Rough Idle
  222. Can anyone help me?
  223. Impossible to move shift selector
  224. wheel size
  225. F Car
  226. Back Drivers side wheel won't move
  227. Anyone giving up ther stock spoilers, the SXT type (2000&up)
  228. Is high idle OK ?
  229. tachometer
  230. Engine oil in the coolant
  231. Need help with rims/tires!!!!!!!
  232. Where can i find a body kit for a 1988-89 Lancer?
  233. More specifically: What's the best oil VISCOSITY for your Neon?
  234. I almost died!!
  235. tires
  236. No bass in new after market stereo
  237. heat!!
  238. alternator not working?
  239. Question about rims??
  240. 98 neon vacuum lines
  241. Spark Plug Problems
  242. rim size ?
  243. cracking sound? cracked axel??
  244. Neon Wont Run Even with gear In!!!
  245. My brakes suddenly stopped working...o.0
  246. Getting a neon
  247. buy them i want them GONE
  248. Help!!!
  249. For Sale 99 Neon Sport. 2.0 Dohc
  250. Re-attaching a car door.
