Dodge
> Neon | Plymouth Neon
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
What is the fastest u have ever gone in a neon???
120km/h+ beeping
props
Engine Stalls 96 Neon Expresso SOHC
Neon vs. 98 Mustang Convertible
I might have been ripped off.
question 101 ???
What would be some safe mods after this stuff?
No check engine light????
low voltage
Stereo problem
Auto To 5spd. Conversion??
spark plugs
Neon vs. Corolla
California Laws regarding Turbo
ignition switch
disconnect odometer 2004 neon
best audio brands
money for mods
Neon vs. Viper
s10 vs neon
test results on a wierd ign problem
Is an underdrive pulley even usefull for a second generation?
I need help
Engine Noise / Problems
need trany help
Spark Plug Gap Settings
Ricer or not???
Hahn Race craft turbos
Help with egr code
Turbos?
New info from SCC about Stage 2 & 3
Neons aint slow
Dual cam head???
Cluster Swapping
Turbocharging questions
Neon Magazine!!!!
is there a wide body kit for the 1st gen?
rear upper strut mounts
Rear strut upper mount
Good websites for performance parts?
Help!!
Where to find fog light switch on 2000 Neon?
question about RAGE parts
Mod Ideas
starter
ignition/ sensor help needed
looking for wiring schematic
Removing Side bumper lights.....
What should I rev to...
15 F... cold weather can make cars not start?
embarassing ?'s
head gaskets
oil leak
wiper return
cheap man's intake
neon trouble
Which would win?
Alternator Question
How good do resenators work???
srt-4 prototype stage III
Anyone with mopar stage 1 on there srt 4??
Stock cd player problem.
1/4 mile question???
engine qeustion
Doorskins
Advice on buying 96 Neon
Engine codes
Million Dollar Neon.
HELP!! My acceleration is loping and irratic!
Sound System Problem
KTR wing
SRTGURL-Howell-Moroso Performance
car shuts off and won't start
For Sale: 20lbs Nitrous Tank
For Sale: 1995-1999 Dodge Neon Dohc Speed Parts
Why does everyone look down on neons?
MASSIVE oil leak
How do I know if the fuel pump really is failing?
Very rough engine
Oil temperature gauge
timing belt changing question
Does anyone know ????
defrosting slow!
what is the max. horsepower range
interior parts....
cutting rubber stop to lower..........
Some One Please Help!!!!!!!!
Problems with Sound System
Does anyon eknow about...
Help my neon is leaking oil!!!!
which is the best
make me faster!
insurance on a SRT-4??
interesting thought
sponsors...
I feel so stupid asking this
Srt-4
flip flop trunk?
can a neon 2000 be changed to automatic locks and windows?
SRT-4 vs STI Video
NE1 know why My car won't start
Doorpanel
Hesitation
Oil leaking
Cooling Fans....loss in power
Front end grinding
Happy New Year!!!!!!!!!!!!!!!!!!
sohc auto ?'s
Engine Additives
Removing dashboard. on a 00
Just got my turbo!!!!!!!!!!
got head?
Another Question
Adjusting a fuel regulator
so what nobody knows anything???
has anyone heard of a VOLT exhaust system?
manual to power window conversion
im confused, you will be 2
L.E.D Lights to a on/off switch
Neon that doesn't turn over to start
fixing a window
A Question
Dead Speed sensor and Odometer
wiring diagram for a 2000o neon
Sound system Problem
Trunk rattling
Not to start another endless debate, but...
Where can I find some sound clips?
engine swaps
High Pitched Whine
No Power Neon
Replacing Transmission Lines?
turbo manifold
stumbles on acceleration
Whats the best cold air intake for a 2000?
help!!with blown headgasket
I have a problem with my head gasket
for sale 2003 OEM 15" Chrome neon rims
a Tires Question
heater
crankshaft pos. sensor
HELP ME!!!!!!!!! 00 neon fusible link
high pitch tone?
obdII help
WANTED: stock neon seats!
Tranny Question Need Help ASAP
Trouble Code 54! Help Please!
neon overheating
Redneck air induction and super exhaust.
SRT-4 Shift Light: Anyone help please??
Oil in Water
torque specs on 2000 neon a/t
R/T Emblem
Engine Rattle, Loss of Power -- Timing Belt?
fuel pump blowing air in tank
motor bogs????
three dings and a fuse warning?
srt-4
This Is A Stupid Question
weirdest thing ever
fuel pump and electrical Question
headgasket question..
srt-4 manifold
suddenly must drive in lower gear
HELP!!!! AC will not work unless breaks are pressed
HELP!!! AC only works when the break is applied
neon club! check this out and get back to me!!!
engine swap questions???? please reply!
Proformance help??
Where to find the fuel pump switch?
few questions
Codes 12 and 43????
ITS turbo
Eibach Pro Kit For Sale
rims
HELP! how to change air filter for 1999 neon
engine swap
FS: 14" winter tires, and 17" rims
Poll.....Best UDP?
Idaho Neon
Jerky Neon
A question
Door/light problem after gauge swap
HELP: Blocked off EGR valve w/ code 32
Is the Water evaporating?!?
Stereo Wiring Help!
kirk CIA or iceman
Erebuni Kit
Windows
i need help with speaker setup
Tips on buying a neon
Service Manual on CD?
Problem with brakes?
Cheap Mods
what is a breather filter
Coolant Overflow
SRT-4 Turbo
Transmission Issue 98 Neon
magnum or crane cams?
Timing beslt alignment for Neon '95 SOHC
Squeaky Neon
radio problems
Suspension Testimonials
having probs with 2001 neon R/T
Need Help on my 2003 Dodge Neon SOHC SE 2.0L
Your srt divers are all the same
Manifold Type....
What kinda of turbos can i put in my SRT-4
advertisement for the SRT-4
battery light on
WANTED: 95-99 Doge Neon DOHC engine and trans.
can i put dohc headon sohc engine
turbo for my neon
Need 95 Neon Transmission Help
Painting the Dash
evo body klit
Foggy passenger windows
High RPMs
FOR SALE: 95 Neon Sport!
neon fuel pump isnt working
Please Help!! where is the oil pressure sending unit on a 95 neon at?
WANTED: looking for 3rd brake light, any offer!
Big problems with Neon...
Problems with oil or gas?
coolant bubbling in reservoir tank??
Should be easy but it's not!
underdrive pully
If you love the Neon let us know!!!
Valve Seal Replacement.
Question about Splash Guards for 2003 SXT
neon overheating
Dodge Neon 2003,
neon parts
Final say on what oil is the best for a NEON?
FS: Silver SRT wing
Is it alright to manually shift an Auto Trans?
sporadically overheating
higher redline???
tuning shops
can I add much horse power to a SOHC? Here are my mods.
Dodge Neon Performance
Instrument Cluster help
Early Neon, 98K miles, for a friend
Air/Fuel Gauge
Code 27: Injector Curcuit
