View Full Version : Neon/Plymouth Neon
Pages : 1 2 3 4 5 6 7 [8] 9 10
  1. SRT-4 vs STI Video
  2. NE1 know why My car won't start
  3. Doorpanel
  4. Hesitation
  5. Oil leaking
  6. Cooling Fans....loss in power
  7. Front end grinding
  8. Happy New Year!!!!!!!!!!!!!!!!!!
  9. sohc auto ?'s
  10. Engine Additives
  11. Removing dashboard. on a 00
  12. Just got my turbo!!!!!!!!!!
  13. got head?
  14. Another Question
  15. Adjusting a fuel regulator
  16. so what nobody knows anything???
  17. has anyone heard of a VOLT exhaust system?
  18. manual to power window conversion
  19. im confused, you will be 2
  20. L.E.D Lights to a on/off switch
  21. Neon that doesn't turn over to start
  22. fixing a window
  23. A Question
  24. Dead Speed sensor and Odometer
  25. wiring diagram for a 2000o neon
  26. Sound system Problem
  27. Sound system Problem
  28. Trunk rattling
  29. Not to start another endless debate, but...
  30. Where can I find some sound clips?
  31. engine swaps
  32. High Pitched Whine
  33. No Power Neon
  34. Replacing Transmission Lines?
  35. turbo manifold
  36. stumbles on acceleration
  37. Whats the best cold air intake for a 2000?
  38. help!!with blown headgasket
  39. I have a problem with my head gasket
  40. for sale 2003 OEM 15" Chrome neon rims
  41. a Tires Question
  42. heater
  43. crankshaft pos. sensor
  44. HELP ME!!!!!!!!! 00 neon fusible link
  45. high pitch tone?
  46. obdII help
  47. WANTED: stock neon seats!
  48. Tranny Question Need Help ASAP
  49. Trouble Code 54! Help Please!
  50. neon overheating
  51. Redneck air induction and super exhaust.
  52. SRT-4 Shift Light: Anyone help please??
  53. Oil in Water
  54. torque specs on 2000 neon a/t
  55. R/T Emblem
  56. Engine Rattle, Loss of Power -- Timing Belt?
  57. fuel pump blowing air in tank
  58. motor bogs????
  59. three dings and a fuse warning?
  60. srt-4
  61. This Is A Stupid Question
  62. weirdest thing ever
  63. fuel pump and electrical Question
  64. headgasket question..
  65. srt-4 manifold
  66. suddenly must drive in lower gear
  67. HELP!!!! AC will not work unless breaks are pressed
  68. HELP!!! AC only works when the break is applied
  69. neon club! check this out and get back to me!!!
  70. engine swap questions???? please reply!
  71. Proformance help??
  72. Where to find the fuel pump switch?
  73. few questions
  74. Codes 12 and 43????
  75. ITS turbo
  76. Eibach Pro Kit For Sale
  77. rims
  78. HELP! how to change air filter for 1999 neon
  79. engine swap
  80. HELP! how to change air filter for 1999 neon
  81. FS: 14" winter tires, and 17" rims
  82. Poll.....Best UDP?
  83. Idaho Neon
  84. Jerky Neon
  85. A question
  86. Door/light problem after gauge swap
  87. HELP: Blocked off EGR valve w/ code 32
  88. Is the Water evaporating?!?
  89. Stereo Wiring Help!
  90. kirk CIA or iceman
  91. Erebuni Kit
  92. Windows
  93. i need help with speaker setup
  94. Tips on buying a neon
  95. Service Manual on CD?
  96. Problem with brakes?
  97. Cheap Mods
  98. what is a breather filter
  99. Coolant Overflow
  100. SRT-4 Turbo
  101. Transmission Issue 98 Neon
  102. magnum or crane cams?
  103. Timing beslt alignment for Neon '95 SOHC
  104. Squeaky Neon
  105. radio problems
  106. Suspension Testimonials
  107. having probs with 2001 neon R/T
  108. Need Help on my 2003 Dodge Neon SOHC SE 2.0L
  109. Your srt divers are all the same
  110. Manifold Type....
  111. What kinda of turbos can i put in my SRT-4
  112. advertisement for the SRT-4
  113. battery light on
  114. WANTED: 95-99 Doge Neon DOHC engine and trans.
  115. can i put dohc headon sohc engine
  116. turbo for my neon
  117. Need 95 Neon Transmission Help
  118. Painting the Dash
  119. evo body klit
  120. Foggy passenger windows
  121. High RPMs
  122. FOR SALE: 95 Neon Sport!
  123. FOR SALE: 95 Neon Sport!
  124. FOR SALE: 95 Neon Sport
  125. neon fuel pump isnt working
  126. Please Help!! where is the oil pressure sending unit on a 95 neon at?
  127. WANTED: looking for 3rd brake light, any offer!
  128. Big problems with Neon...
  129. Problems with oil or gas?
  130. coolant bubbling in reservoir tank??
  131. Should be easy but it's not!
  132. underdrive pully
  133. If you love the Neon let us know!!!
  134. Valve Seal Replacement.
  135. Question about Splash Guards for 2003 SXT
  136. neon overheating
  137. Dodge Neon 2003,
  138. neon parts
  139. Final say on what oil is the best for a NEON?
  140. FS: Silver SRT wing
  141. Is it alright to manually shift an Auto Trans?
  142. sporadically overheating
  143. higher redline???
  144. tuning shops
  145. can I add much horse power to a SOHC? Here are my mods.
  146. Dodge Neon Performance
  147. Instrument Cluster help
  148. Early Neon, 98K miles, for a friend
  149. Air/Fuel Gauge
  150. Code 27: Injector Curcuit
  151. High idle when A/C is on & over heating??
  152. Neon not staying on
  153. Southern Cali... Turnbull Canyon
  154. should i do it
  155. Any Advice
  156. problem with my neon (timing maybe?)
  157. Keyless remote problem
  158. engine swap
  159. srt-4
  160. Code 21 O2 Sensor
  161. Desperate For Help!!!!!
  162. Where's everyone??
  163. Fool Filter
  164. Help..i Need Somebody
  165. Hardcore motorheads come in
  166. Motor Madness 10/18/03
  167. how much would it be to make a neon se with a srt power?
  168. What the hell!! Stock SOHC, Neon SE, Automatic=0-60 in 8.1??
  169. Engine missing power on acceleration
  170. Fuel pump
  171. will underdrive pulley affect my car much, I have a 1200w amp, 2 600w subs, 1.5 cap
  172. what is error code 64?
  173. who's the fastest 1/4?
  174. Subwoofer Problems
  175. 400+ neon believer
  176. squeaking noise
  177. turbo???
  178. coolant fan, NOT the ordinary problem
  179. Update on Idle Problem
  180. Fog Lights
  181. oil preasure
  182. Big Tip 4 a little advice
  183. Need help getting cheap tires in Northern Cal
  184. Idle/Problems with dying
  185. What happened to the SRT's??
  186. Speedometer isn't working HELP !!
  187. Parking break warning light
  188. looking for new paint
  189. stereo problems
  190. Front Bumper Removal
  191. Torque value
  192. Repair Manuals/Changing Fluids and Belts
  193. engine codes 32, 42
  194. Help!!!
  195. Rough Idle
  196. sun roof wont go down all the way and wont go up...
  197. Cylinder Head
  198. error codes??
  199. Catback Exhausts
  200. Engine Shuts off while making right turns
  201. Rear wheel bearing
  202. Dc Sports Neon Srt Parts
  203. car theif
  204. Tensioner Pin
  205. Door moldings
  206. california laws?
  207. A/C problem
  208. Neon Timing Cover
  209. air intakes
  210. Code 54 on car
  211. Radio Blues
  212. Bypassing the AC pulley
  213. Bypassing the AC pulley
  214. help....it won't start....again
  215. Service Engine Soon Light On
  216. Water logged engine....Woops!
  217. Ported Indy Intake for 2000+ -- for sale
  218. Trouble in the family
  219. Rims
  220. Oxygen Sensor
  221. fire kits
  222. Some Advice?
  223. Help me please!
  224. error code 124355
  225. High Beam Problem!
  226. Interior Painting, Etc.
  227. Code 24 - TPS Out of Range Troubleshooting
  228. Code 51- What to do...
  229. Neon 95 Sport Engine Swapping
  230. Stage1 Kit legal in CA
  231. Parting out 98 Neon
  232. Cool SRT-4 Sites
  233. Rear end too high
  234. I found one!!! (SRT-4)
  235. Do neons have breaking problems?
  236. Are neons any good?
  237. Raced an Evo last night
  238. inner tie rod
  239. head gasket
  240. weird scraping noise!!!
  241. hey
  242. Replacing starter need help!
  243. The best looking Neon ever?
  244. engine swaps
  245. Speedo and Reverse Lights Question
  246. Where have all the SRT-4's gone?
  247. Miles on a Neon?
  248. adjustable cam gears?
  249. overheating
  250. WTB Project Neon!
