View Full Version : Neon/Plymouth Neon
Pages : 1 2 3 [4] 5 6 7 8 9 10
  1. turbo ???
  2. Caravan engine in neon
  3. Anyone have one of these?
  4. Its my post I do what want.
  5. Frost inside car
  6. All Oil Filters are NOT the same
  7. Wont pass inspection
  8. Authorities on Lubrication Oil
  9. synthetic or non
  10. Stock Bov Question
  11. Engine swap help
  12. Intercooler
  13. Engines
  14. Relay
  15. neon shakes
  16. Just pulled the heater Core NASTY JOB
  17. Battery keeps dying, 99 Neon
  18. Damage for Timing Belt Failure
  19. turbo'd neon
  20. Help, Damn Map sensor...
  21. Knocking Noise, Goes with reving till clutch is in....
  22. neon stalling? possible solution..
  23. Soon to be parting out 95 Neon
  24. help!
  25. Timing Belt
  26. neon dash lights, ecu problem?
  27. Indiglo cluster install
  28. springs/suspension
  29. Neon Engine Knock-Help
  30. Codes Again
  31. Battery Dead?? I disconnected both neg/pos?
  32. Instrument Cluster
  33. power steering noise
  34. starting my car
  35. hoods
  36. crane camshaft
  37. What to do?
  38. potential
  39. FS: Bodykits,Vertical Doors, And Carbon Fiber Hoods buy in
  40. Replacing stereo
  41. Help! Need Torque Specs Soon
  42. cold air intake good or not ???????
  43. Transmission
  44. roll cage
  45. Parting out a 1999 Neon 4 Door.
  46. changing doors
  47. help with tac installation....
  48. CAI close to exaust manifold
  49. rebuilding my engine
  50. Over Drive Question
  51. starter
  52. blinkers broken?
  53. no heater or air
  54. one big neon (pic)
  55. How to change valve cover gasket
  56. Price question
  57. ATF+4 Regular or Synthetic
  58. SX 2.0 sport
  59. dash board removal 95 neon
  60. hesitation
  61. 60,000 mile service and tranny flush
  62. High/inconsistent idle + brakes tight
  63. stock neon rims on crx
  64. oil coating spark plug causing misfire code??
  65. headlight problem??
  66. Fuel Reset Button
  67. timing belt question
  68. need help with code
  69. How do I Install a CAI to a 2nd gen (2001)?
  70. crank shaft sensor
  71. srt-4 d.o.t. drag slicks ..what is the biggest size u can install
  72. code 43
  73. throttle cable loose
  74. Obd Ii Compliant ????
  75. trany changing?
  76. mopar bov conversion kit
  77. Wanted: Alpine Green Driver-side Doors/wheels for 98 Plymouth Neon
  78. knocking noise.
  79. The original turbo dodge
  80. brakes, air intake, ????? HELP
  81. code 12-37-34-55
  82. DOHC Engine weight
  83. Metra stereo install kit
  84. Suspension
  85. How to test a coil
  86. oxygen sensor
  87. looking for info
  88. exterior mods program?
  89. Chill Factory turbo kit
  90. Help pulling drivers side axle
  91. headlight problem
  92. Skunk2 Springs on a 2000 dodge neon
  93. Engine swap HELP
  94. automatic fuel valve shut-off reset
  95. Window,lock,mirror wiring.
  96. Wanted: Alpine Green Door for a 1998 Neon
  97. Wanted: Aluminum Rims for a 1998 Neon
  98. Gauges on 1996 Neon Work Sporadically
  99. P0340 - Escaping Resolution
  100. i hate neons!!
  101. egr valve
  102. Head Job car not starting!!!!
  103. HELP!! Rough Idling!
  104. Lighted Visor and Rearview Mirror Wanted
  105. lacking boost
  106. shakes when braking
  107. any ideas
  108. Losing Power
  109. Multiport Injection
  110. Help Fast Crank Pully Removal!!! Please Help
  111. Some simple neon questions
  112. ATX Swap
  113. eagle talon turbo install on neon?
  114. no balls!!
  115. get to much gas
  116. SRT-4 Stock Fuel Injectors
  117. HELP, Neon was smokin
  118. Has anyone installed hks turbo timer on srt-4
  119. good bye Neon..... HELLO CALIBER
  120. Cruise Control issues
  121. vaccum leak?
  122. oil light
  123. Gas mileage
  124. 60 mm tb install.. plzzz help
  125. Oil leaks, conspiracy theory, questions!!
  126. Mopar ECU???? HELP!:)
  127. Neon Ratteling sounds
  128. Lowering car need camber kit???
  129. Cracking Noise... HELP PLZ!
  130. Need Help Asap!!!
  131. transmission blew up
  132. Neon Inquires (my apologies, this is quite lengthy)
  133. Need Help on install with apex-i safc
  134. regarding old neon+srt-4
  135. Struts for sale
  136. how do i hook a tack up
  137. Neon troubles HELP!
  138. Code 12 and 37
  139. Wondering
  140. Normal?
  141. code 302 (cylinder # 2 misfire)
  142. Power Steering Pump Problem
  143. please help
  144. Need Help with code P01899
  145. My Dodge Neon won't start
  146. Help removing door guards (rubber strips)
  147. What Mods are you doing come spring?
  148. 60,000 mile services
  149. Neon Transmission Interchange
  150. lowering my car?? question??
  151. neon starter smoking
  152. Neons suck
  153. neon chugging when hit the gas
  154. auto lock
  155. Car starts so hard, PLZ HELP!!!
  156. vibration and grinding
  157. Oil still leaking
  158. Transmission question
  159. Doing Swap Witch stratus motor for my 95 sohc neon
  160. Emissions Problem
  161. bought a 2001 es neon..? about intakes
  162. one of the biggest improvement for looks.
  163. SRT-4 Boost Gauge
  164. Getting Sponsored
  165. Interior touches
  166. High Idle 2,000 rpms to 4,000 rpms any help please
  167. Dome Light Help on 02 neon
  168. Wanted: Lighted Rearview Mirror for 2000 Neon
  169. Neon club anyone
  170. EGR is part of the vaccum system right?
  171. Fuel System
  172. Is it worth it?
  173. Im so cheap! but want more speed! lol
  174. Revving Problem?? who dosent have that problem. lets all figure it out.
  175. APC Projector headlamps, Free trick to increase visibility!!
  176. Rich Fuel and mysterious rattle
  177. rough idle
  178. Replaced IAC Sensor... Still have problems...Help with Code 25
  179. 1996 Plumouth Neon for sale - auto - great shape - 110k
  180. Idle Control and PCV Hoses/Valve fixed here is how to do it. Got Spudder and jerking?
  181. Installing a BOV
  182. Fuel Injectors
  183. remote
  184. Major Electrical Problems
  185. need some help
  186. Need advice
  187. Tire question
  188. rpm,s
  189. EGR Questions
  190. Idle Air Control System Malfunction-2
  191. Altenator Belt Size
  192. spark plug backing out...help please
  193. spark plug
  194. fuel guage
  195. What do you think
  196. Just bought Neon
  197. srt-4 2,500 mi. ebay no reserve $10,499
  198. Interier lights always on when car is on?
  199. rough sound while starting
  200. Can't find oil leak...HELP PLEASE!!!
  201. Help Please!
  202. Visual Inspection of Valves
  203. Marks Hot Wen It Is Not Hot
  204. engine code 12,44,43
  205. fuel leakage
  206. Help! engine ign. feed fuse keeps blowing
  207. Confusing ODB code P0703
  208. Clicking sounds from the engine
  209. Difference between Dodge Neon and Plymouth Neon?
  210. Stalling
  211. Ideas on lowering my neon
  212. Cheap performance upgrades
  213. light output of 95 Neon headlights
  214. Died.
  215. winter starting
  216. oxygen sensors
  217. window hard to roll up/down in the cold
  218. Neon Replacement Keys
  219. Neon Ebay stuff
  220. Where can i view rims?
  221. Neon Eclipse Turbo parts interchagable?
  222. I need help fast please!!
  223. Seat stuck
  224. I Need Some Help Please!!!
  225. dealership vs. garage for headgasket repair
  226. NO BUS on odometer, changing radio
  227. Rear stop lights and indicator lights
  228. Rev limiter removal in 2000?
  229. dohc cylinder head swap??????
  230. What do you think of this?
  231. yellow fluid???
  232. rough oil leak
  233. idle air controll system malfunction...please help
  234. Car won't start
  235. Car won't start - Battery? Antifreeze? Neither?
  236. Needing to fix hit and run...
  237. Help!
  238. Fuel Filter
  239. Location of Speed Sensor
  240. back seat removal
  241. Poor running '00 neon
  242. Fuel problem
  243. Need hood for 97 Neon
  244. heater fans won't blow
  245. Crane Ignition, Retard HRC Stage 2 FS!
  246. Car wont start.. battery issues?
  247. Help on installing 6x9's
  248. Possible Blown Head Gasket Fans Backwards???
  249. I need instructions on removing the head for my 1997 Neon
  250. header question
