View Full Version : Neon/Plymouth Neon
Pages : 1 2 [3] 4 5 6 7 8 9
  1. flashed key three times and got code 11 "no dist. reference signal on 99 neon ..help"
  2. About to pull the trigger...
  3. transmission
  4. IAC Valve Inquiry
  5. ALL SRT4's!!! LOOKING FOR HOTCHKIS SWAYBARS FOR CHEAP?
  6. Huge Problem With Smog
  7. Info on SRT-4
  8. Head Gasket - Runs, still oil leak - CAULK???
  9. front lower control arm
  10. Blowoff valve
  11. how much do solid mounts stop wheel hop?
  12. neon code Po601
  13. srt kicker w/amp
  14. Beautiful Engine Bay!!!
  15. Noisey lifter/rocker... TEXSRT4 help?
  16. Timing Belt - Interference Engine 97 Neon SOC?
  17. Moonroof?
  18. Brake Noise?
  19. fuel system lean??
  20. Srt-4 for sale!
  21. Buying an SRT-4
  22. Neon - noise on start up
  23. Engine Knocking help please.
  24. possible fuel problem?
  25. diagnostic codes question
  26. cylinders not firing
  27. Viper chip
  28. Extior Modifications
  29. rim/tire size
  30. looking for performance parts in canada
  31. bracket question
  32. transmision trouble
  33. custom turbo setup
  34. neon engine swap
  35. Stage 1 / 2
  36. help with engine codes
  37. stupid a$$ question
  38. no bus?
  39. my car keeps acting like it wants to stall out!!! please help
  40. Neon Interior Question
  41. Need Help On "Check Engine" Light!!!
  42. Neon stalling at stoplights
  43. Please Help!!!!
  44. What doors fit what years ?
  45. Custom Fiberglass subwoofer boxes 2000 neon
  46. New cluster?
  47. neon aftermarket suppliers
  48. battery or alternator problems ????
  49. I'm such an idiot!!! - Booster cable misshap...
  50. Vote! EVERYONE! (Spark plugs)
  51. Turbo kit
  52. Dome light turning itself on and off
  53. got udp and have a question
  54. axles, tranny problem needs assistant??
  55. car alarm install help???
  56. electrical problem
  57. My Modded Neon
  58. Neon falling apart
  59. Wiring harness locks
  60. fuse box diagram
  61. how much?
  62. Daytime Lights
  63. horn location
  64. starter issues
  65. should i even bother
  66. anyone from tampa area
  67. piston question
  68. READ THIS! Important ignition system fact
  69. modular and non modular clutch
  70. rough starts
  71. Q's about Cam sensor, trans. fluid, other sensors.
  72. Oil Filter Location
  73. Tranny has problem shifting
  74. omg hondas
  75. problem: hesitation
  76. megasquirt 2
  77. Major oil leak!!!
  78. fuel problem
  79. Brakes
  80. help me with my 02 neon
  81. Notchy shifter
  82. Code 54 means I need a New Cam Pos. Sensor??
  83. Fuel Problem ???
  84. gettin ready to build
  85. repair cost
  86. 5 Doors Only!? Ugh!
  87. turbo help
  88. Srt-4 Ok car but Chrysler is a joke!
  89. got a question bout pistons
  90. WTF is this sensor???
  91. neonik freakish car
  92. tranny ques.
  93. Auto Trans Help Needed ASAP
  94. Yellow cloudy headlights - no more! Read this!
  95. and another question as well
  96. problematic audio system
  97. pics available of 95 neon 4dr with blown head gasket for sale as is, $400
  98. Simple stock speaker question
  99. srt-4 with profec E-01 haveing problems
  100. Neon Factory Colors
  101. Goodbye Neon
  102. need working minds
  103. Possible W/ Forced Induction?
  104. Performance cat?
  105. Daytime running lights
  106. Fuses, wiring, grounding...
  107. Interesting Problem
  108. Need for Speed?
  109. Stratus rims on a neon?
  110. Will DOHC head work on a 95 SOHC block?
  111. Unconventional Neon
  112. srt-4/02 neon r/t engine swap help please!
  113. Help please
  114. How to replace rear drum breaks 97 neon?
  115. Remove and replace transmission governor
  116. Sunroof Problems
  117. Does a 2.0 liter SOHC 96 Neon have a non-interference engine?
  118. Price Ok?
  119. engine blowback?
  120. Cable for the Trans
  121. springs
  122. brake problem
  123. i want better mpg
  124. For how much I can sell my car ?
  125. Repeating "humming" sound
  126. I need help!
  127. very confused
  128. More Problems
  129. neon shifting proble
  130. water in transmission tranny shoot
  131. ughhh retard in action {timing issue help)
  132. Automatic transmission kicks up
  133. IAT sensor ?...which wire is which?
  134. Idle problem
  135. NE body knows which is a good fitting body kit for a 95 neon?
  136. no crank no start
  137. Wheels rotate in reverse when going forward
  138. Rear struts
  139. Horn And Fluid Not Working
  140. Dead Battery
  141. Dodge Neon Ignition stuck... Help!!
  142. help to replace suspension bushings
  143. airbag light
  144. Under Drive Pulley
  145. power steering
  146. Does my car have IAT sensor? where is my CTS
  147. CEL code 51
  148. Tranny fluid burned up twice! Help!
  149. need to find cheep turbo kit
  150. Compatable turbo for a 98 dodge neon?
  151. More horses... ?
  152. 1996 Dodge Neon for sale!!!
  153. Uh oh, oil drain plug won't go in.
  154. Evo
  155. well since im retarded
  156. Water flooding passenger side
  157. Door hinges
  158. Very odd idling issue
  159. Engine seizing problem
  160. 95 Neon For sale $400
  161. DSM3D v1.0.0.1a Released! 420a
  162. cant get crank pulley off of 95 neon need help ASAP!!!!!
  163. key wont turn at all
  164. whats a good and easy motor swap for 1st gen neon
  165. K20a2 motor in 1st gen neon
  166. Neon Book coming in September
  167. Neon 1999 Head Gasket
  168. Plymoth Neon head Gasket Repair? (PLEASE HELP!)
  169. Oil in radiator??
  170. SRT-4 ACR 05 AC gets hot and cold sometimes
  171. Labor Charges.
  172. neon tranny cables
  173. car color
  174. Nology?
  175. stalling problem with 96 dodge neon dohc
  176. Sick Neon
  177. Transmission Question?!?!
  178. Enkei Evo 5 wheels and tires FS in NC
  179. Dome light fuse location
  180. wow
  181. Neon cooling fans
  182. rims
  183. running wires from door into car / window regulator
  184. engine knocking only when cold
  185. Hid
  186. Spring help
  187. Intake question
  188. headlights
  189. cam sensor replacement
  190. Anybody have a spring mount??
  191. Transmission light
  192. Neon 1995 rough idling after gets hot!
  193. Exaust
  194. Please Help !!!!!
  195. my reverse lights don't work
  196. LED Taillights
  197. SRT-4 vs. Cobalt SS
  198. front door speakers
  199. Projector Headlights!?
  200. No ACR booklet with car...please help
  201. aftermarket speedometer
  202. mazda motor in a neon body
  203. bypass the o2 sensor?
  204. Ride Height question.
  205. battery dieing
  206. Cold Air Intake help
  207. the wing
  208. Megan Lowering springs?
  209. 96 neon for sale
  210. manifold Converter?
  211. How Fast R U?
  212. Dash lights and dome go out
  213. Skunk2 lowering springs?
  214. when i look at a neon i................
  215. fuel gauge reading incorrectly
  216. Not Starting Need Help!!
  217. engine overheating
  218. NEON upstream O2 Sensor
  219. nvt 350 TrANny for SelL!
  220. AROSPEED Lowering Springs
  221. air suspension
  222. Stratus motor in a neon
  223. Engine dies after starting
  224. EGR replacement
  225. knocking noise
  226. Center Console Changes
  227. Carfax Please
  228. headlights
  229. turbo ???
  230. Caravan engine in neon
  231. Anyone have one of these?
  232. Its my post I do what want.
  233. Frost inside car
  234. All Oil Filters are NOT the same
  235. Wont pass inspection
  236. Authorities on Lubrication Oil
  237. synthetic or non
  238. Stock Bov Question
  239. Engine swap help
  240. Intercooler
  241. Engines
  242. Relay
  243. neon shakes
  244. Just pulled the heater Core NASTY JOB
  245. Battery keeps dying, 99 Neon
  246. Damage for Timing Belt Failure
  247. turbo'd neon
  248. Help, Damn Map sensor...
  249. Knocking Noise, Goes with reving till clutch is in....
  250. neon stalling? possible solution..
