View Full Version : Intrepid
Pages : [1] 2 3 4 5 6
  1. 1997 intrepid dies
  2. headlights
  3. 94 Intredpid runs for a while then dies
  4. Engine swap problems .
  5. 96 3.5 motor into 2001 Intrepid
  6. alternator or starter problems on 96 dodge intrepid
  7. 2003 Dodge Intrepid engine swap question!
  8. 98 Intrepid A/C heater fan
  9. 94 Intrep Key won't turn
  10. 1999 intrepid tranny problems
  11. 94 Intrepid - Intermittent Turn Signal
  12. Location of Trans LR Solenoid Valve??
  13. 02 wont shift into OD? help please
  14. Questions On A Driveline Swap
  15. pls help with my 97 intrepid
  16. 1999 Dodge Intrepid 3.2L 24 valve SOHC timming process and tools needed?
  17. 98 intrepid no spark.
  18. Auto shutdown relay problems on 98 intrepid 3.2l?
  19. 1998 intrepid 3.2 Heater/AC
  20. Front coolant leak 2004 2.7L
  21. HELP Please 99 2.7 won't start
  22. Please help me with this!!!
  23. 00 Car. advice please. Rod bearings
  24. transmission
  25. 94 Intrepid Limp mode?
  26. Brake Caliper and Knock Noise solved, sort of!
  27. 95 Intrepid EGR Valve
  28. I need help bad!!!!!!!!!!
  29. 04 dodge intrepid wont shift out of 2nd gear
  30. Everyone knows the 2.7 is junk do something about it
  31. 99 intrepid a/c question
  32. 94 intrepid radiator fan fuse keeps blowing
  33. 95 Intrepid Tranny Issue
  34. 1998 Intrepid- Alternator location/replacement
  35. 1995 intrepid 3.3 bad missfire
  36. 1995 Dodge Intrepid
  37. Expected VSS connector voltage
  38. Entry System
  39. major and chalenging problem with my 1998 intrepid
  40. 04 Intrepid "jerks" when accelerating (3.5)
  41. 96 Intrepid ES - starting issue
  42. 2002 intrepid oil sensor location?
  43. 1997 intrepid gauges
  44. 97 Intrepid 3.5 coolant leak
  45. 1997 Dodge Intrepid 3.5L what side is bank one?
  46. 95 Intrepid. Stall, no start.
  47. 97 Intrepid starting problems
  48. 1998 Dodge Intrepid Turn signals/flasher Not working
  49. 1998 Dodge Intrepid - Window, Turn Sig Problems
  50. airbag light has gone crazy
  51. 02 Intrepid 2.7L swap 2.7L seabring
  52. Intrepid motor change
  53. Need a little info
  54. 2001 Intrepid 2.7 has no compression or spark
  55. 97 intrepid oil light on at stop light
  56. Its Electric!!????
  57. Serpintine belt Question
  58. Chrysler 3.5 Intrepid
  59. 95 intrepid factory stereo amp
  60. dosent run great now
  61. fault codes
  62. runs great now
  63. difference in intrepids?
  64. running like crap
  65. 2001 intrepid
  66. Compression Test?
  67. 02 Intrepid 2.7l to 3.5l conversion help
  68. Car Jerking please Help!!
  69. stability issue 2000 intrepid
  70. 96 Intrepid 3.5l fans always running
  71. problem with harmonic balancer
  72. rev limiter kicking in too soon
  73. replace starter on 2000 intrepid
  74. 2000 intrepid no start
  75. 1996 Dodge Intrepid ES 3.5 Liter Starting Problems, turns Over
  76. horrible gas mileage
  77. Looking for an electrical expert - 99 Intrepid
  78. 2004 intrepid dies
  79. 2001 Intrepid Washer Fluid issue
  80. 98 dodge intrepid 2.7 v6 stalling
  81. 2000 Intrepid 2.7 Spark Plug problem
  82. 1997 Intrepid Won't Cold Start
  83. fan problems
  84. 94 intrepid trany limp mode when turning left
  85. 2000 Dodge Intrepid Ignition Switch
  86. Bosch Titanium +4 spark plugs
  87. 2003 intrepid wiper motor or switch problems
  88. COMPLETE LIST OF PARTS 1998 2.7 Intrepid
  89. Code P0340
  90. 2000 Intrepid electrical issues
  91. 2000 Intrepid oil light comes on at idle
  92. 99 Intrepid ES - bump shift in Transmission
  93. Blew my 2.7, what to do?
  94. oil light on I need Help!!
  95. 96 Intrepid 3.5L Wont Fire!!!!!
  96. 2.7 issue 1998
  97. help!! 02 Dodge intrpied wont start now that its cold
  98. 2002 Dodge Intrepid - my heat stopped working this morning!!!!!
  99. 94, 3.3l, hasn't run for 1.5 years
  100. 01 Rt
  101. dodge intrepid 1996 problems!
  102. 2003 intrepid electrical issue
  103. 2000 2.7 ticking issue
  104. 1996 intrepid problem
  105. How is it possible?
  106. Intrepid 1995
  107. Transmission problems. Have codes.
  108. Shuts down
  109. Where is the bcm on a 99 intrepid
  110. 98 Spitting and Sputtering
  111. 98 Intrepid heater problem
  112. 2000 Intepid has 4 codes pulled
  113. Blower Fan Module
  114. heater setting low/med/hi prob
  115. 1999 2.7 Water Connector
  116. Heater blows cold
  117. I am 1/2 way through my engine transplant.
  118. 98 Intrepid Grinding noise
  119. Transmisson Issue
  120. 95' Intrepid tranny problems
  121. 1999 intrepid motor change
  122. 2001 rt clock spring
  123. Starting Problems
  124. 1994 dodge intrepid stalling
  125. is it possible to put a corvette engine in a 02 intrepid
  126. Power seat removal
  127. How do you make a 2.7 v6 last?
  128. 96 Intrepid Tranny Issue
  129. 94 intrepid tranny problem PLEASE HELP
  130. 2002 Dodge intrepid Problem
  131. 95 Intrepid 3.3L fuel line question
  132. Check Engine Light Issue
  133. 97 Intrepid Cooling trouble
  134. intrepid tranny warranty?
  135. 95 intrepid -won't run
  136. tranmission 200 4 intrepid
  137. 98 headlight question.
  138. stabilizer bar replacement
  139. installed cd player and know it wont work
  140. 2004 doge intrepid
  141. 98 A/C question
  142. car died while driving
  143. 1993 3.3L V6 (Non-SE) Intrepid Electrical Problems
  144. Please give me the 101 of a 98
  145. 2002 Intrepid problems
  146. cylinder number
  147. 96 abs problems
  148. stalling and cutting off!!!!
  149. 1994 Intrepid Power Door Lock Issue?
  150. motor mount and transmission mount broke
  151. 04 intrepid o2 sensor 2/1
  152. 95 dodge intrepid guages don't work!!
  153. Motor swap
  154. 1994 Intrepid 3.5 V6 Steering/Suspension noise
  155. Key Less Entry Need Help
  156. 94 rpm flucuate @ warm idle
  157. Are there Aftermarket Cruise Controls for 94 Intrepids?
  158. 2000 intrepid alternator change..
  159. Rear Wheel Click
  160. 2002 Intrepid transmission problems 3.5
  161. Overheating w/ AC : Details Inside
  162. 94 Intrepid 3.5 V6 OBD1 Data Connector loacation?
  163. tach
  164. 1997 Intrepid Hazard Wiring
  165. 2000 Intrepid Limp Mode
  166. 2002 intrepid key lock cylinder
  167. 2.7
  168. starter?
  169. 1994 Intrepid 3.5 V6 Intake Manifold Broken Bolts HELP!
  170. 01 R/T Growling Noise
  171. 99 Interpid stereo removal
  172. 2000 Intrepid
  173. 94 intrepid turns off after 10 mins running
  174. Short Circuit in the wiring harness crankshaft sensor connector
  175. a/s cond/fan problem 2001 intepid
  176. 99 Intrepid Idling Low Problem
  177. Help on Sensor readings with a MultiMeter
  178. 1997 Dodge Int Engine swap|Help reading codes
  179. Fuel line disconnects problem.
  180. Did a engine change, now i have some questions.
  181. 93 intrepid heater controls
  182. concorde buckets in an intrepid with a bench
  183. 2.7 no start prob
  184. Factory 2002 Service Manual
  185. 2001 3.2L Trans code P0740
  186. 1995 Intrepid won't fire
  187. 1999 Intrepid revs up and down
  188. headlight assembly cracking
  189. fog lights not working 94 intrepid...
  190. 94 headlights blowing
  191. 96 intrepid...no gauge lights and won't shiff out of first
  192. 1994 Intrepid 3.5L running on 2-3 of 6 cylinders
  193. intrepid cradle mounts
  194. intrepid 96 speaker changing problem
  195. 95 intrepid cooling fan won't stop running
  196. 95 trep cooling issues...really getting on my nerves
  197. 97 Intrepid
  198. 2001 and 2002 Dodge Intrepid Interchange Parts
  199. 1995 intrepid transmission removal
  200. Power Steering issue
  201. 2002 Dodge Intrepid!! Where Is The Bank One Knock Sensor Located
  202. 99 intrepid in trouble and dead!!!!
  203. 1997 dodge intrepid axles.
  204. Won't start unless gas pedal is held down
  205. 01 Hub and bearing question
  206. Intermittent starting problem - 94 Dodge Intrepid (3.3 engine)
  207. 1995 Dodge Intrepid Won't Fire
  208. Idling too low Problem
  209. 2001 ABS Light
  210. oxygen sensor plz help
  211. gear shift
  212. Intrepid stalls
  213. engine change
  214. want to change 3.5 to 3.3
  215. 98 intrepid High idle at start up!
  216. Over heating problem?????
  217. Subframe bushings
  218. Starting problem?
  219. Possible Motor Mounts??
  220. 98 intrepid camshaft timing marks
  221. 1994 3.5 V6 PART NEEDED: Intrepid Concorde LHS 1994-1997
  222. Trans dont want to shift
  223. Battery running dead!!!!!
  224. Power seat
  225. computer problem 98 intrepid
  226. 98 Intrepid No Spark N Injectors
  227. 00 interpid key lock
  228. 1995 3.3L no Spark
  229. Intrepid
  230. 1994 Intrepid 3.5 V6 Fuel Pressure Regulator FUEL LEAK!
  231. Turn signals/Flasher buzzes.
  232. 95-dash lights flashing, gear changing,buzzing noise
  233. 2001 Intrepid ticking noise!!
  234. how to change thermostat, 98 intrepid???
  235. Map sensor Question
  236. '99 - no heat, my 2 yr old daughter is freezing in the morning!! HELP!
  237. 96 3.5 just dies sometimes
  238. 94 Intrepid 3.5 Major Oil Leak From the Front!
  239. my Treps Governor
  240. 1994 Dodge Intrepid Trans Swap
  241. Drivers Side Mirror
  242. 99 dodge intrepid car surges while driving
  243. No heat in cabin for first 15 mins. Please help
  244. Retarded Timing 95 Intrepid
  245. 1998 Intrepid-computer problems
  246. 2001 Intrepid Valve Tick, Rapid Ind. and Defrost Sqeal
  247. 96 Intrpid tranny questions
  248. 98 intrepid 2.7 trans solonid pack replacement
  249. hate this 94
  250. 1994 Intrepid 3.5 whining noise...
